  4. Tuya lief eigentlich recht gut aber jetzt Probleme.
    5.4k
70 Beiträge 4 Kommentatoren 6.6k Aufrufe 3 Beobachtet
  • K kg36304
    Also ich habe den Adapter neu gestartet und das kam beim loggen raus. Mir sagt das leider wenig.
    2023-06-07 13:31:23.124  - info: tuya.0 (3436) Got terminate signal TERMINATE_YOURSELF
    2023-06-07 13:31:26.131  - info: tuya.0 (3436) terminating
    2023-06-07 13:31:26.134  - info: tuya.0 (3436) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-07 13:31:26.856  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-07 13:31:30.996  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 6039
    2023-06-07 13:31:34.877  - info: tuya.0 (6039) starting. Version 3.14.2 (non-npm: Apollon77/ioBroker.tuya) in /opt/iobroker/node_modules/iobroker.tuya, node: v16.18.0, js-controller: 4.0.24
    2023-06-07 13:31:35.119  - info: tuya.0 (6039) Cloud polling interval is too low. Set to 120 seconds
    2023-06-07 13:31:37.105  - error: tuya.0 (6039) The id "bfebde501ddd0454806kem.ir-." is invalid. Ids are not allowed to end in "."
        at Adapter.setObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:1904:40)
        at Immediate._onImmediate (/opt/iobroker/node_modules/@apollon/iobroker-tools/lib/objectHelper.js:202:25)
        at processImmediate (node:internal/timers:468:21)
    2023-06-07 13:31:37.350  - info: tuya.0 (6039) bfe88cb882c48fa75cotyw: Connect locally to device
    2023-06-07 13:31:37.354  - info: tuya.0 (6039) bfe88cb882c48fa75cotyw Init with IP=192.168.62.167, Key=63398cbe60c9ea09, Version=3.3
    2023-06-07 13:31:37.390  - info: tuya.0 (6039) bfebde501ddd0454806kem: Connect locally to device
    2023-06-07 13:31:37.417  - info: tuya.0 (6039) bf83b64049fc85c197nknz: Connect locally to device
    2023-06-07 13:31:37.418  - info: tuya.0 (6039) bf83b64049fc85c197nknz Init with IP=192.168.62.174, Key=41b7a18c9b851ea6, Version=3.3
    2023-06-07 13:31:37.420  - info: tuya.0 (6039) bf48c87af978e1b8bbnyfw: Connect locally to device
    2023-06-07 13:31:37.430  - info: tuya.0 (6039) bfa548c73b79de64ebfpcn: Connect locally to device
    2023-06-07 13:31:37.432  - info: tuya.0 (6039) bfa548c73b79de64ebfpcn Init with IP=192.168.62.143, Key=84398c4e4e3f6cdc, Version=3.3
    2023-06-07 13:31:37.438  - info: tuya.0 (6039) bfd2855f90c35a138ba8js: Connect locally to device
    2023-06-07 13:31:37.482  - info: tuya.0 (6039) bf84c5b1a616b5d91addsh: Connect locally to device
    2023-06-07 13:31:37.483  - info: tuya.0 (6039) bf84c5b1a616b5d91addsh Init with IP=192.168.62.53, Key=af05a1f7d0e58fb5, Version=3.3
    2023-06-07 13:31:37.489  - info: tuya.0 (6039) bf4cf14e8603a9bd83goud: Connect locally to device
    2023-06-07 13:31:37.490  - info: tuya.0 (6039) bf4cf14e8603a9bd83goud Init with IP=192.168.62.156, Key=fbcd8122b3d4be09, Version=3.3
    2023-06-07 13:31:37.493  - info: tuya.0 (6039) bf535b2ddff9e6c0b8zuzg: Connect locally to device
    2023-06-07 13:31:37.495  - info: tuya.0 (6039) bf535b2ddff9e6c0b8zuzg Init with IP=192.168.62.158, Key=eb36e847e54e2da1, Version=3.3
    2023-06-07 13:31:40.607  - warn: tuya.0 (6039) bf84c5b1a616b5d91addsh: Error on Reconnect (1): connect EHOSTUNREACH 192.168.62.53:6668
    2023-06-07 13:32:00.077  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 6110
    2023-06-07 13:32:03.583  - info: dwd.0 (6110) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.0, js-controller: 4.0.24
    2023-06-07 13:32:03.723  - warn: tuya.0 (6039) bf84c5b1a616b5d91addsh: Error on Reconnect (3): connect EHOSTUNREACH 192.168.62.53:6668
    2023-06-07 13:32:04.529  - info: dwd.0 (6110) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-07 13:32:05.062  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    @kg36304 sagte in Tuya lief eigentlich recht gut aber jetzt Probleme.:
    node: v16.18.0
    Losgelöst vom tuya: Geh auf nodejs@18.
    Zu tuya:
    Keine Ahnung wo die ID herkommt. Lösch mal die states und objects zu dem Adapter.
    Hier ist das Gerät nicht im Netzwerk erreichbar.
      node: v16.18.0
      Zu tuya:
      kg36304
      ok, mache jetzt erst mal nodejs neu und lösche die Objekte.
      Melde mich wieder sobald das erledigt ist.
      Vielen Dank.
        kg36304
        past das so?
        pi@raspberrypi:~ $ node -v
        v16.18.0
        pi@raspberrypi:~ $ nodejs -v
        v18.16.0
        pi@raspberrypi:~ $
        • K kg36304
          past das so?
          v16.18.0
          v18.16.0
          pi@raspberrypi:~ $
          @kg36304
          Kann ich so nicht sagen.
          Schau dir
          iob diag
          an.
            kg36304
            Da erscheint unter anderem das.
            Wie bekomme ich den node auch auf v18.16.0?
            *** NodeJS-Installation ***
            /usr/bin/nodejs 	v18.16.0
            /usr/local/bin/node 		v16.18.0
            /usr/local/bin/npm 		8.19.2
            /usr/local/bin/npx 		8.19.2
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 18.16.0-deb-1nodesource1
              Candidate: 18.16.0-deb-1nodesource1
              Version table:
             *** 18.16.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u3 500
            No problems detected
            • K kg36304
              nodejs:
                Version table:
              Nein, passt nicht.
              Schau in meiner Signatur wie man das fixt.
              • K kg36304
                nodejs:
                  Version table:
                warum nicht alles?
                was du für unwichtig erachtest kann fundamental sein.
                  kg36304
                  Hier aktuell alles. Irgendwie bekomme ich Node nicht auf 18.16.0.
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Model		: Raspberry Pi 4 Model B Rev 1.1
                  Architecture    : armv7l
                  Docker          : false
                  Virtualization  : none
                  Distributor ID:	Raspbian
                  Description:	Raspbian GNU/Linux 10 (buster)
                  Release:	10
                  Codename:	buster
                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                  Systemuptime and Load:
                   14:35:43 up 15 min,  1 user,  load average: 4.18, 2.79, 1.54
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  Other values than 0x0 hint to temperature/voltage problems
                  temp=67.2'C
                  volt=0.8563V
                  *** Time and Time Zones ***
                                 Local time: Wed 2023-06-07 14:35:44 CEST
                             Universal time: Wed 2023-06-07 12:35:44 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  Boot Target: 	graphical.target
                  *** MEMORY ***
                  Mem:           3.8G        2.2G        638M        8.0M        960M        2.1G
                  Swap:           99M          0B         99M
                  Total:         3.9G        2.2G        738M
                           3837 M total memory
                           2238 M used memory
                            463 M active memory
                           2529 M inactive memory
                            638 M free memory
                            175 M buffer memory
                            784 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4      459G  7.6G  433G   2% /
                  devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                  tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                  /dev/sda1      vfat      253M   50M  203M  20% /boot
                  tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                  [Wed Jun  7 14:20:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:50:A2:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [Wed Jun  7 14:20:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                  [Wed Jun  7 14:20:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Wed Jun  7 14:20:21 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                  TARGET        SOURCE    FSTYPE OPTIONS
                  /             /dev/sda2 ext4   rw,noatime
                  |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                  `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  786M	/var/
                  567M	/var/cache
                  562M	/var/cache/apt
                  503M	/var/cache/apt/archives
                  112M	/var/lib
                  Archived and active journals take up 8.0M in the file system.
                  /opt/iobroker/backups:
                  915M	/opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  727M	/opt/iobroker/iobroker-data/
                  403M	/opt/iobroker/iobroker-data/files
                  171M	/opt/iobroker/iobroker-data/backup-objects
                  72M	/opt/iobroker/iobroker-data/files/telegram.admin
                  69M	/opt/iobroker/iobroker-data/sonosCache
                  21M	/opt/iobroker/iobroker-data/objects.jsonl
                  19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                  15M	/opt/iobroker/iobroker-data/objects.json.migrated
                  15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                  15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                  nodejs:
                    Version table:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  admin: 		6.3.5
                  javascript: 	6.1.4
                  Adapters from github: 	2
                  Adapter State
                  + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                    system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                  + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                  + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                  + system.adapter.ds18b20.0                : ds18b20               : Slave                                    -  enabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                  + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                  + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                  + system.adapter.hm-rega.1                : hm-rega               : raspberrypi                              -  enabled
                  + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                  + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                  + system.adapter.kodi.0                   : kodi                  : raspberrypi                              -  enabled, port: 9090
                  + system.adapter.kodi.1                   : kodi                  : Slave                                    -  enabled, port: 9090
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                    system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : Slave                                    -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.octoprint.0              : octoprint             : Slave                                    -  enabled
                  + system.adapter.openligadb.0             : openligadb            : raspberrypi                              -  enabled
                  + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                  + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : Slave                                    -  enabled, port: 1884, bind: 0.0.0.0
                  + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                  + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                  + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                  + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                  Adapter    "backitup"     : 2.6.19   , installed 2.6.19
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                  Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                  Adapter    "denon"        : 1.15.0   , installed 1.15.0
                  Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                  Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                  Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                  Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                  Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                  Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                  Adapter    "iot"          : 1.14.2   , installed 1.14.2
                  Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                  Adapter    "kodi"         : 2.0.9    , installed 2.0.9
                  Adapter    "meross"       : 1.14.0   , installed 1.14.0
                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                  Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                  Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
                  Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                  Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                  Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                  Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                  Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                  Adapter    "tado"         : 0.4.8    , installed 0.4.8
                  Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "tuya"         : 3.13.1   , installed 3.14.2
                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                  Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                  Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                  Adapter    "wled"         : 0.6.7    , installed 0.6.7
                  Adapter    "worx"         : 2.1.3    , installed 2.1.3
                  Adapter    "yahka"        : 0.17.0   , installed 0.17.0
                  Objects and States
                  Objects: 	24251
                  States: 	21059
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Get:3 https://repos.influxdata.com/debian buster InRelease [7038 B]
                  Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
                  Err:3 https://repos.influxdata.com/debian buster InRelease
                  Fetched 7038 B in 1s (5117 B/s)
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18497      715/sshd
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13049      368/influxd
                  tcp        0      0 192.168.62.93:2010      0.0.0.0:*               LISTEN      1001       32465      3655/io.hm-rpc.3
                  tcp        0      0 192.168.62.93:8701      0.0.0.0:*               LISTEN      1001       33762      3666/io.hm-rpc.4
                  tcp        0      0 192.168.62.93:12001     0.0.0.0:*               LISTEN      1001       34509      3644/io.hm-rpc.2
                  tcp        0      0 127.0.0.1:40579         0.0.0.0:*               LISTEN      1001       42263      4474/io.yahka.0
                  tcp        0      0 127.0.0.1:46503         0.0.0.0:*               LISTEN      1001       42267      4474/io.yahka.0
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       33538      3532/iobroker.js-co
                  tcp        0      0 0.0.0.0:38697           0.0.0.0:*               LISTEN      1001       41488      4474/io.yahka.0
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       33528      3532/iobroker.js-co
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32249      3550/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41111      4334/io.web.0
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1001       39111      4190/io.socketio.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          18499      715/sshd
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        14937      368/influxd
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       36778      4183/io.simple-api.
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1001       35370      3765/io.sonos.0
                  udp        0      0 0.0.0.0:58928           0.0.0.0:*                           108        13015      348/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37083      3855/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15749      704/dhcpcd
                  udp        0      0 0.0.0.0:60530           0.0.0.0:*                           1001       38054      3960/io.broadlink2.
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       38046      3960/io.broadlink2.
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       40256      4451/io.wled.0
                  udp        0      0 192.168.62.93:5353      0.0.0.0:*                           1001       37030      3776/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13013      348/avahi-daemon: r
                  udp        0      0 0.0.0.0:49502           0.0.0.0:*                           1001       38051      3960/io.broadlink2.
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       41614      4724/io.deconz.0
                  udp6       0      0 :::546                  :::*                                0          15774      704/dhcpcd
                  udp6       0      0 :::5353                 :::*                                108        13014      348/avahi-daemon: r
                  udp6       0      0 :::34149                :::*                                108        13016      348/avahi-daemon: r
                  udp6       0      0 :::1900                 :::*                                1001       41616      4724/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       41615      4724/io.deconz.0
                  2023-06-07 14:35:27.020  - info: hm-rega.1 (3633) update rooms to enum.rooms
                  2023-06-07 14:35:27.198  - info: hm-rega.1 (3633) update functions to enum.functions
                  2023-06-07 14:35:27.308  - info: hm-rega.1 (3633) update favorites to enum.favorites
                  2023-06-07 14:35:28.805  - info: sourceanalytix.0 (4537) Initialization of hm-rpc.2.LTK0120568.2.POWER successfully
                  2023-06-07 14:35:28.806  - info: sourceanalytix.0 (4537) Initialising (3 of 3) "meross.0.2102034871107090841348e1e94a9ad7.0-power"
                  2023-06-07 14:35:29.139  - info: meross.0 (3871) Can not get Data for Device 2102034230510490841348e1e94a67d1: Error: Device has no data connection available
                  2023-06-07 14:35:29.141  - warn: meross.0 (3871) Can not get Data for Device 2102034230510490841348e1e94a67d1: undefined
                  2023-06-07 14:35:31.314  - info: sourceanalytix.0 (4537) Initialization of meross.0.2102034871107090841348e1e94a9ad7.0-power successfully
                  2023-06-07 14:35:31.325  - info: sourceanalytix.0 (4537) Successfully activated SourceAnalytix for 3 of 3 states, will do my Job until you stop me!
                  2023-06-07 14:35:31.721  - info: tankerkoenig.0 (4232) Start first request
                  2023-06-07 14:36:00.071  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5222
                  2023-06-07 14:36:05.041  - info: dwd.0 (5222) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.0, js-controller: 4.0.24
                  2023-06-07 14:36:07.179  - info: dwd.0 (5222) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-06-07 14:36:07.519  - info: web.0 (4334) ==> Connected system.user.admin from ::ffff:192.168.62.197
                  2023-06-07 14:36:07.738  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-06-07 14:36:35.462  - info: meross.0 (3871) Can not get Data for Device 2102034230510490841348e1e94a67d1: Error: Device has no data connection available
                  2023-06-07 14:36:35.463  - warn: meross.0 (3871) Can not get Data for Device 2102034230510490841348e1e94a67d1: undefined
                  2023-06-07 14:36:46.938  - info: alexa2.0 (3887) No smart home devices to query
                  2023-06-07 14:36:54.919  - info: alexa2.0 (3887) Subscribing to states...
                  2023-06-07 14:36:54.927  - info: alexa2.0 (3887) Deleting the following states: ["Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9","Smart-Home-Devices.01fbc3c9-ccbe-48f8-960f-a6943c0729f9","Smart-Home-Devices.326487b9-cf39-4260-ba48-2bc24f09bd15","Smart-Home-Devices.98150042-cb6e-4a69-8810-bbe8b66a04c2","Smart-Home-Devices.d7904c4a-3128-47e0-a774-328ab4722ac7","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754","Smart-Home-Devices.7525202e-9633-41de-b350-d145b03f822a","Smart-Home-Devices.4fbb5e78-df77-416e-8c0a-621537e91ca0","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.#enabled","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.#delete","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.powerState","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.connectivity","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.#query","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9.#enabled","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9.#delete","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9.powerState","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9.#query","Smart-Home-Devices.01fbc3c9-ccbe-48f8-960f-a6943c0729f9.#enabled","Smart-Home-Devices.01fbc3c9-ccbe-48f8-960f-a6943c0729f9.#delete","Smart-Home-Devices.01fbc3c9-ccbe-48f8-960f-a6943c0729f9.powerState","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.connectivity-reason","Smart-Home-Devices.25a59d6f-47fe-45b4-adb0-c0826b721638.#includeInAllQuery","Smart-Home-Devices.5046079e-a31d-4c3e-86c5-0e79c0c51be9.#includeInAllQuery","Smart-Home-Devices.326487b9-cf39-4260-ba48-2bc24f09bd15.#enabled","Smart-Home-Devices.326487b9-cf39-4260-ba48-2bc24f09bd15.#delete","Smart-Home-Devices.326487b9-cf39-4260-ba48-2bc24f09bd15.powerState","Smart-Home-Devices.98150042-cb6e-4a69-8810-bbe8b66a04c2.#enabled","Smart-Home-Devices.98150042-cb6e-4a69-8810-bbe8b66a04c2.#delete","Smart-Home-Devices.98150042-cb6e-4a69-8810-bbe8b66a04c2.powerState","Smart-Home-Devices.d7904c4a-3128-47e0-a774-328ab4722ac7.#enabled","Smart-Home-Devices.d7904c4a-3128-47e0-a774-328ab4722ac7.#delete","Smart-Home-Devices.d7904c4a-3128-47e0-a774-328ab4722ac7.powerState","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.#enabled","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.#delete","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.powerState","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.colorTemperatureName","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.colorTemperatureInKelvin","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.colorName","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.color-hue","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.color-saturation","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.color-brightness","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.colorRgb","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.brightness","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.connectivity","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.connectivity-reason","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.#query","Smart-Home-Devices.a13a126e-6ec8-4bd8-a0be-170e4c4d6128.#includeInAllQuery","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.#enabled","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.#delete","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.powerState","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.connectivity","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.connectivity-reason","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.#query","Smart-Home-Devices.c26cca75-adec-4ba7-9de9-8082e6392e80.#includeInAllQuery","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.#enabled","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.#delete","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.powerState","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.colorTemperatureName","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.colorTemperatureInKelvin","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.colorName","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.color-hue","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.color-saturation","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.color-brightness","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.colorRgb","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.brightness","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.connectivity","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.connectivity-reason","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.#query","Smart-Home-Devices.aac88855-1698-4c14-a813-8cfae402eba4.#includeInAllQuery","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.#enabled","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.#delete","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.powerState","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.colorTemperatureName","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.colorTemperatureInKelvin","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.colorName","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.color-hue","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.color-saturation","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.color-brightness","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.colorRgb","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.brightness","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.connectivity","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.connectivity-reason","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.#query","Smart-Home-Devices.fb515f66-7851-4b71-b5ed-d3c4f913a754.#includeInAllQuery","Smart-Home-Devices.7525202e-9633-41de-b350-d145b03f822a.#enabled","Smart-Home-Devices.7525202e-9633-41de-b350-d145b03f822a.#delete","Smart-Home-Devices.7525202e-9633-41de-b350-d145b03f822a.powerState","Smart-Home-Devices.4fbb5e78-df77-416e-8c0a-621537e91ca0.#enabled","Smart-Home-Devices.4fbb5e78-df77-416e-8c0a-621537e91ca0.#delete","Smart-Home-Devices.4fbb5e78-df77-416e-8c0a-621537e91ca0.powerState","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.#enabled","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.#delete","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.powerState","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.colorTemperatureName","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.colorTemperatureInKelvin","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.colorName","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.color-hue","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.color-saturation","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.color-brightness","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.colorRgb","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.brightness","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.connectivity","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.connectivity-reason","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.#query","Smart-Home-Devices.f314ff4e-d3e3-40ab-849e-1d6bee947d9e.#includeInAllQuery","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.#enabled","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.#delete","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.powerState","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.colorTemperatureName","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.colorTemperatureInKelvin","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.colorName","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.color-hue","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.color-saturation","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.color-brightness","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.colorRgb","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.brightness","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.connectivity","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.connectivity-reason","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.#query","Smart-Home-Devices.08a3793d-75d6-4446-9813-4e8840d4406a.#includeInAllQuery","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.#enabled","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.#delete","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.powerState","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.colorTemperatureName","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.colorTemperatureInKelvin","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.colorName","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.color-hue","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.color-saturation","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.color-brightness","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.colorRgb","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.brightness","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.connectivity","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.connectivity-reason","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.#query","Smart-Home-Devices.b2964042-10fa-4dd0-bd2a-950d23b16ad3.#includeInAllQuery","Echo-Devices.G070L808745700FM.Info.WifiSSID"]
                  2023-06-07 14:36:57.255  - info: alexa2.0 (3887) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-06-07 14:37:00.069  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 5607
                  2023-06-07 14:37:04.530  - info: dwd.0 (5607) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.0, js-controller: 4.0.24
                  2023-06-07 14:37:05.397  - info: dwd.0 (5607) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-06-07 14:37:05.945  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  Und dann noch
                  		     v.2023-04-16
                  Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
                  Kernel: 		5.10.103-v7l+
                  Installation: 		Native
                  Timezone: 		Europe/Berlin (CEST, +0200)
                  User-ID: 		1000
                  X-Server: 		false
                  Pending OS-Updates: 	0
                  Pending iob updates: 	0
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:           3.8G        2.3G        561M        8.0M        978M        2.1G
                  Swap:           99M          0B         99M
                  Total:         3.9G        2.3G        661M
                  Active iob-Instances: 	49
                  ioBroker Core: 		js-controller 		4.0.24
                  			admin 			6.3.5
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		24251
                  States: 		21059
                  Size of iob-Database:
                  22M	/opt/iobroker/iobroker-data/objects.jsonl
                  7.9M	/opt/iobroker/iobroker-data/objects.json.broken
                  44K	/opt/iobroker/iobroker-data/objects.json.old
                  15M	/opt/iobroker/iobroker-data/states.jsonl
                  5.1M	/opt/iobroker/iobroker-data/states.json.migrated
                  5.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                  4.1M	/opt/iobroker/iobroker-data/states.json.old
                  0	/opt/iobroker/iobroker-data/states.json.broken
                  • K kg36304
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:	10
                    Codename:	buster
                    VERSION_ID="10"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=67.2'C
                    volt=0.8563V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server: 	false
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Swap:           99M          0B         99M
                             3837 M total memory
                             2238 M used memory
                              463 M active memory
                              638 M free memory
                              175 M buffer memory
                              784 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    786M	/var/
                    567M	/var/cache
                    562M	/var/cache/apt
                    112M	/var/lib
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		6.3.5
                    javascript: 	6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	24251
                    States: 	21059
                    Pending Updates: 0
                    Und dann noch
                    		     v.2023-04-16
                    User-ID: 		1000
                    X-Server: 		false
                    MEMORY:
                    Swap:           99M          0B         99M
                    			admin 			6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		24251
                    States: 		21059
                    buster
                    Ist längst abgekündigt. Installier da den Nachfolger Debian 11 'Bullseye'.
                    Mein HowTo aus meiner Signatur gelesen?
                    Tip: Falsche Pfade.
                      buster
                      Tip: Falsche Pfade.
                      kg36304
                      ja habe ich gelesen.
                      Aber irgendwie nicht richtig gemacht. Ich versuche es nochmal.
                        kg36304
                        Kann ich Debian einfach drüber installieren ohne den IoBroker zu verlieren?
                        • K kg36304
                          Mach es danach:
                          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                          Aber zuvor nodejs aufräumen.
                            kg36304
                            Wie bekomme ich es hin das alle dort installiert ist:
                            Wichtig und richtig ist:
                            nodejs liegt in /usr/bin
                            node liegt in /usr/bin
                            npm liegt in /usr/bin
                            npx liegt in /usr/bin
                            bei mir steht, das:
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            /usr/local/bin/npx
                            Ich werde diesbezüglich aus der Anleitung nicht schlau, sorry ich stell mich scheinbar etwas doof an ;-)
                            Danke.
                            • K kg36304
                              bei mir steht, das:
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              /usr/local/bin/npx
                              Danke.
                              @kg36304
                              Auch den zweiten Teil gelesen? Da steht nämlich genau drin was zu tun ist:
                              Szenario 1 / falsche Pfade
                              Wenn der Test auf 'ordentliche' Installation über
                              uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                              andere Verzeichnisse als /usr/bin für eines der vier Elemente (nodejs, node, npm oder npx) zeigt, dann ist da meist 'irgendwas' manuell von 'irgendwoher' installiert worden. Ich habe bis dato leider noch nicht nachvollziehen können, was genau da immer angestellt wurde.
                              In der Regel kann man diese Dateien dann von Hand löschen.
                              sudo rm /pfad/zu/der/falschen/datei
                              Auch ein Eintrag namens 'corepack' im falschen Pfad muss gelöscht werden.
                              • K kg36304
                                bei mir steht, das:
                                /usr/bin/nodejs
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                /usr/local/bin/npx
                                Danke.
                                wirklich alles gelesen?
                                https://forum.iobroker.net/post/460759
                                  kg36304
                                  So, hatte wohl eine Zeile vergessen, sorry. So sieht es jetzt aus:
                                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/bin/npx
                                  v18.16.0
                                  v18.16.0
                                  9.5.1
                                  9.5.1
                                  4.0.24
                                  pi
                                  tty
                                  /home/pi
                                  OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Holen:3 https://repos.influxdata.com/debian buster InRelease [7.038 B]
                                  OK:4 https://deb.nodesource.com/node_18.x buster InRelease
                                  Fehl:3 https://repos.influxdata.com/debian buster InRelease
                                    Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                  Es wurden 7.038 B in 2 s geholt (4.348 B/s).
                                  W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                  W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                  nodejs:
                                    Installiert:           18.16.0-deb-1nodesource1
                                    Installationskandidat: 18.16.0-deb-1nodesource1
                                    Versionstabelle:
                                  pi@raspberrypi:~ $
                                  Passt es jetzt, zum größten Teil weiß ich aber nicht was ich gemacht habe ;-)
                                  HomoranH Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                                  • K kg36304
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v18.16.0
                                    v18.16.0
                                    9.5.1
                                    9.5.1
                                    4.0.24
                                    pi
                                    tty
                                    /home/pi
                                    nodejs:
                                      Versionstabelle:
                                    pi@raspberrypi:~ $
                                    Passt es jetzt,
                                    nope
                                    Siehe Thread zu Key von influx
                                    • K kg36304
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      v18.16.0
                                      v18.16.0
                                      9.5.1
                                      9.5.1
                                      4.0.24
                                      pi
                                      tty
                                      /home/pi
                                      nodejs:
                                        Versionstabelle:
                                      pi@raspberrypi:~ $
                                      nodejs passt. Aber an influx musst du auch noch ran.
                                      Grafana gar nicht installiert? Geht ja üblicherweise mit influx einher.
                                      Hier steht im weiteren Verlauf auch was zum influx-Repo dabei:
                                      https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                                        kg36304
                                        Doch grafana ist instaliert aber mit influx auf einem anderen Pi.
                                        • K kg36304
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.16.0
                                          v18.16.0
                                          9.5.1
                                          9.5.1
                                          4.0.24
                                          pi
                                          tty
                                          /home/pi
                                          nodejs:
                                            Versionstabelle:
                                          pi@raspberrypi:~ $
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          @kg36304 und leider noch buster - kein bullseye
                                          Lehrling seit 1975 !!!
                                          K Thomas BraunT 2 Antworten Letzte Antwort
