  5. JSON Inhalt von Website auslesen
14 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    ankubo
    ich habe mir im Forum einige Tips zum auslesen von JSON angesehen, aber irgendwie wollen die nich auf den Inhalt greifen den ich haben.
    Anbei der Inhalt der bei mir angezeigt wird wenn ich die URL eingeben:
    {"UPTIME":"00d 00:45:26","RSSI":96,"VERSION":"1.10 04.05.2023 06:16","DEVICENAME":"T2SG8BBF6C","STATICIP":"192.168.88.68","STATICGW":"192.168.88.1","STATICSN":"255.255.255.0","VGRID":236.8,"VBAT":25.6,"SETACPOWER":700,"TEMP":42,"DAC":23637,"CALSTEP":0,"MAXPOWER":"700","POWERLIMIT":700,"VBATCUTOFF":24,"VBATREBOOT":24.5,"SUN2IP":"","SUN3IP":"","SUN2ROUNDTRIP":"0","SUN2SETPOINT":0,"SUN2POWERLIMIT":0,"SUN3ROUNDTRIP":"0","SUN3SETPOINT":0,"SUN3POWERLIMIT":0,"METERURL":"http://192.168.88.57/status","METER_USER":"admin","METER_PASS":"","JSONKEYS":"total_power","METERINTERVAL":"500","METERREADOUT":142,"ZEPCTARGET":"15","ZEPCAVERAGE":"20","MQTT_SERVER":"","MQTT_PORT":"1883","MQTT_USER":"","MQTT_PASS":"","HADISCOVERY":0,"MQTT_ACSETPOINTOVR_NAME":"T2SG8BBF6C/ACSETPOINTOVR","MQTT_ACSETPOINTOVR_VALUE":"","MQTT_DACOVR_NAME":"T2SG8BBF6C/DACOVR","MQTT_DACOVR_VALUE":"","MQTT_CALSTEPOVR_NAME":"T2SG8BBF6C/CALSTEPOVR","MQTT_CALSTEPOVR_VALUE":"","MQTT_METEROVR_NAME":"T2SG8BBF6C/METEROVR","MQTT_METEROVR_VALUE":"","MQTT_MAXPOWEROVR_NAME":"T2SG8BBF6C/MAXPOWEROVR","MQTT_MAXPOWEROVR_VALUE":"","MQTT_TARGETOVR_NAME":"T2SG8BBF6C/TARGETOVR","MQTT_TARGETOVR_VALUE":"","MQTT_ACSETPOINT_NAME":"T2SG8BBF6C/ACSETPOINT","MQTT_ACSETPOINT_VALUE":7000,"MQTT_ACDISPLAY_NAME":"T2SG8BBF6C/ACDISPLAY","MQTT_ACDISPLAY_VALUE":7211,"MQTT_VGRID_NAME":"T2SG8BBF6C/VGRID","MQTT_VGRID_VALUE":2368,"MQTT_VBAT_NAME":"T2SG8BBF6C/VBAT","MQTT_VBAT_VALUE":256,"MQTT_DAC_NAME":"T2SG8BBF6C/DAC","MQTT_DAC_VALUE":23637,"MQTT_CALSTEP_NAME":"T2SG8BBF6C/CALSTEP","MQTT_CALSTEP_VALUE":0,"MQTT_TEMPERATURE_NAME":"T2SG8BBF6C/TEMPERATURE","MQTT_TEMPERATURE_VALUE":42,"MQTT_METER_NAME":"T2SG8BBF6C/METER","MQTT_METER_VALUE":"2963.35","MQTT":"not set","ACPOWER":"721.10 W","ACPOWERSUN2":"not set","ACPOWERSUN3":"not set","METERPOWER":"2963.35 W","ZEPCPOWER":"2083.90 W"}
    Ich möchte nur den Wert "VBAT" in einem Datenpunkt anzeigen lassen. Aber irgendwie klappt das nicht. Bei alles anderen Beispielen sehen die JSON Inhalte so sortiert aus, bei mir halt nur so wie oben zusehen.
    Ich habe ein Blockly dazu gebaut, so wie ich meinte, dass es richtig wäre:
    Vielleicht hat ja jemand die passende Idee für mich. Ich dafür sehr dankbar.
    Andreas
    OliverIOO HomoranH 2 Antworten Letzte Antwort
    • A ankubo
      Andreas
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @ankubo sagte in JSON Inhalt von Website auslesen:
      Wenn nur ein einziger Wert abgerufen werden soll, wäre es mit dem parser adapter einfacher
      url im parser adapter einstellen
      als pattern den folgenden ausdruck eintragen
      "VBAT":([\d\.]+),
      Bei Typ number (.)
      einstellen
      Meine Adapter und Widgets
      Links im Profil
      A 2 Antworten Letzte Antwort
      • A ankubo
        Andreas
        HomoranH Offline
        HomoranH Offline
        @ankubo es muss result heißen
        • OliverIOO OliverIO
          "VBAT":([\d\.]+),
          Bei Typ number (.)
          einstellen
          ankubo
          @oliverio Perfect, ganz lieben Dank, das ist genau was ich gesucht habe. Jetzt funktioniert es 👍
            "VBAT":([\d\.]+),
            Bei Typ number (.)
            einstellen
            ankubo
            @oliverio Kannst Du mir sagen wie ich den "ACPOWER" herausbekomme? Habe einfach versucht das VBAT mit ACPOWER zu ersetzen, doch das geht scheinbar nicht. Liegt es daran, dass da noch eine Leerzeile ist und dann W kommt?
            Verstehe leider die Zeichenfolge nicht.
            • A ankubo
              HomoranH Offline
              HomoranH Offline
              welches?
              Die Meter Werte ACPOWER":"([\d.]+) und oben bei SETACPOWER ACPOWER":([\d.]+)
              A HomoranH 2 Antworten Letzte Antwort
                welches?
                ankubo
                @homoran Nur ACPOWER, ohne Sun oder ähnliches dahinter. Der Wert mit den 721.20
                • A ankubo
                  HomoranH Offline
                  HomoranH Offline
                  gibt es hinter VAC als SETACPOWER mit 700 und unten als MQTT Meter mit 712.20
                  (siehe letzten Post)
                    ankubo
                    @homoran said in JSON Inhalt von Website auslesen:
                    Wie schon darüber geschrieben ist das, das ACPOWER mit den 721.20 W
                      welches?
                      HomoranH Offline
                      HomoranH Offline
                      wie noch, noch darüber geschrieben
                      @homoran sagte in JSON Inhalt von Website auslesen:
                      • A ankubo
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @ankubo
                        Hier wird der Begriff deine Suche genau an deinem Beispiel erklärt
                        https://regex101.com/r/Kc7FYA/1
                        Aber zugegeben regex ist für viele erst einmal eine harte Nuss, da es doch sehr kryptisch wirkt. Im endeffekt ist es die erweiterte Form von den Dateisuchpattern * und ?, aber mit unheimlich viel mehr Möglichkeiten
                        @Homoran das Escapen des Punkts in der Zeichauswahlliste ist zwar nicht notwendig, aber ich mache es trotzdem, das es klar ist, das hier der Punkt und nicht nur der any character Platzhalter ist
                        Links im Profil
                          @ankubo
                          HomoranH Offline
                          HomoranH Offline
                          @oliverio sagte in JSON Inhalt von Website auslesen:
                          das ist auch wahrscheinlich die korrektere Art. Hab ich früher auch gemacht, bis ich einmal any character+ mit einem Punkt ohne escapen in einer Gruppe machen wollte und nichts klappte :-)
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            Du weißt warum das kein Sinn macht? Zumindest bei Match newline?
                            Links im Profil
                              HomoranH Offline
                              HomoranH Offline
                              ja!
