    2. Prince3k
    P
    • Posts 31
    Prince3k
    @Prince3k
    12
    31
    Prince3k Follow
    Best posts made by Prince3k
    • RE: [Problem][modbus] Daten R/W Lüftungsanlage euroAIR
      @miki @Schimi
      Vielen Dank für die Vollendung meiner Idee. Ich saß danach an meiner Abschlussarbeit fest, deshalb konnte ich nicht mitwirken.
      Hier packe ich die aktuellen Register für die Modbus Version 6.3.2 rein:
      Eingangsregister
      _address	name	description	unit	type	len	factor	offset	formula	role	room	cw	isScale
      30001	Fortluft nach aussen	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30002	Zuluft in Raeume	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30003	Abluft aus Raeumen	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30004	"Aussenansaugluft		"	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30005	"Aussenfuehler		"	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30006	"Raumtemperatur 		"	-30.0 .. 80.0 °C	°C	uint16be	1	0.1	0		value		false	false
      30007	rotational speed fresh air (Zuluft)	0 .. rpm max	rpm	uint16be	1	10	0		value		false	false
      30008	rotational speed exhausted air (Abluft)	0 .. rpm max	rpm	uint16be	1	10	0		value		false	false
      30009	Setpoint rpm fresh air (Zuluft)	0 .. rpm max	rpm	uint16be	1	10	0		value		false	false
      30010	Setpoint rpm exhausted air (Abluft)	0 .. rpm max	rpm	uint16be	1	10	0		value		false	false
      30011	speedcontrol fresh air (Zuluft)	0 .. 100 %	%	uint16be	1	0.1	0		value		false	false
      30012	speedcontrol exhaused air (Abluft)	0 .. 100 %	%	uint16be	1	0.1	0		value		false	false
      Holding- Register
      _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
      40001	Type_R	1 = Basis 2 = Bypass 3 = Comfort		uint16be	1	1	1		value		true	false	false	false
      40002	"On/Off_R/W	"	1 = An, 0 = Aus		uint16be	1	1	1		value		true	false	false	false
      40003	Bypass open Temperatur	15.0 .. 30.0	°C	uint16be	1	0.1	0		value	true	true	false	false	false
      40004	Recirculation temperature	-15.0 .. 30.0	°C	uint16be	1	0.1	0		value		true	false	false	false
      40005	Comfort Temperatur	setp min .. setp max	°C	uint16be	1	0.1	0		value		true	false	false	false
      40006	turn on delay Hygr	0 .. 120	min	uint16be	1	1	0		value		true	false	false	false
      40007	turn off delay Hygr	0 .. 120	min	uint16be	1	1	0		value		true	false	false	false
      40008	Filter-Schmutz-Zeit	"1 .. 99	Wochen"		uint16be	1	1	0		value		true	false	false	false
      40009	Filterzeit zurücksetzen	0 = Nein 1 = Ja		uint16be	1	1	0		value		true	false	false	false
      40010	Start Montag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40011	Start Montag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40012	Start Dienstag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40013	Start Dienstag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40014	Start Mittwoch Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40015	Start Mittwoch Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40016	Start Donnerstag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40017	Start Donnerstag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40018	Start Freitag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40019	Start Freitag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40020	Start Samstag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40021	Start Samstag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40022	Start Sonntag Tag	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40023	Start Sonntag Nacht	0:00 .. 23:50, OFF	min*1	uint16be	1	1	0		value		true	false	false	false
      40024	Aut Som/Win Zeit	1 = Ja, 0 = Nein		uint16be	1	1	0		value		true	false	false	false
      40025	Ferienmodus aktiv	1 = Ja, 0 = Nein		uint16be	1	1	0		value		true	false	false	false
      40026	Betriebsstunden Stufe-low_R	Std		uint16be	1	1	0		value		true	false	false	false
      40027	Betriebsstunden Stufe-mid_R	Std		uint16be	1	1	0		value		true	false	false	false
      40028	Betriebsstunden Stufe-max_R	Std		uint16be	1	1	0		value		true	false	false	false
      40029	"Betriebsstunden-Filter_R	"	Std		uint16be	1	1	0		value		true	false	false	false
      40030	Status_R	Bit 0 = Reserved Bit 1 = Midden vent Bit 2 = Hoog vent Bit 3 .. 16 reserved		uint16be	1	1	0		value		true	false	false	false
      40031	Digin_R	Bit 0 = dp_la Bit 1 = dp_bla Bit 2 = Hygrostaat Bit 3 = Fan hoog (3- s) Bit 4 = Fan mid (3-s) Bit 5 = aan/uit Bit 6 = Lucht onderdr Bit 7 = Lucht kwal Bit 8 = reserved		uint16be	1	1	0		value		true	false	false	false
      40032	Bypass status	1 = Offen, 0 = Zu		uint16be	1	1	0		value		true	false	false	false
      40033	earth cooler status	1 = Offen, 0 = Zu		uint16be	1	1	0		value		true	false	false	false
      40034	Uhr: SEK	59	sek	uint16be	1	1	0		value		true	false	false	false
      40035	Uhr: MIN	59	min	uint16be	1	1	0		value		true	false	false	false
      40036	Uhr: STD	23	std	uint16be	1	1	0		value		true	false	false	false
      40037	Uhr: Wochentag_R	0=Mo..6=So		uint16be	1	1	0		value		true	false	false	false
      40038	Datum: Tag	1 .. 31		uint16be	1	1	0		value		true	false	false	false
      40039	Datum: Monat	1 .. 12		uint16be	1	1	0		value		true	false	false	false
      40040	Datum: Jahr	xxxx		uint16be	1	1	0		value		true	false	false	false
      40041	Fehler	"status-1	Bit 0 = Reserved Bit 1 = E1 Bit 2 = E2 Bit 3 = E3 Bit 4 = E4 Bit 5 = E5 Bit 6 = Et Bit 7 = Ea Bit 8 = Ft Bit 9 = Fa Bit 10 = oO Bit 11 = Tijd Bit 12 = EP"		uint16be	1	1	0		value		true	false	false	false
      40042	Fehler	"status-2	Reserved"		uint16be	1	1	0		value		true	false	false	false
      40043	Lüfter Stufe	0 = auto 1 = min 2 = mid 3 = max		uint16be	1	1	0		value		true	false	false	false
      40044	Rezirkulationsstatus_R	1 = Offen, 0 = Zu		uint16be	1	1	0		value		true	false	false	false
      40045	Kühlzustand_R	1 = An, 0 = Aus		uint16be	1	1	0		value		true	false	false	false
      40046	Heizstatus_R	1 = An, 0 = Aus		uint16be	1	1	0		value		true	false	false	false
      40047	Kühlprozentsatz_R	0 .. 100 %	%	uint16be	1	1	0		value		true	false	false	false
      40048	Heizprozentsatz_R	0 .. 100 %	%	uint16be	1	1	0		value		true	false	false	false
      40049	-unbekannt-			uint16be	1	1	0		value		true	false	false	false
      P
      Prince3k
    Latest posts made by Prince3k
      @miki @Schimi
      Eingangsregister
      Holding- Register
      P
      Prince3k
    • RE: [gelöst] Skripte laufen nicht mehr script.js. compile failed
      Danke, genau das war mein Fehler. Im Global lief ein Script.
      P
      Prince3k
    • RE: [gelöst]zigbee ..serial/by-id => no such file or directory
      @thomas-braun said in zigbee ls -l /dev/serial/by-id => no such file or directory:
      @prince3k sagte in zigbee ls -l /dev/serial/by-id => no such file or directory:
      Alles neu einspielen oder gibt es ein paar Repairbefehle ?
      Mir fällt da nix zu ein.
      Ich habe die falsche Firmware installiert.
      Der CC25xx ist ein 2531 und ich habe die Firmware vom 2530 installiert.
      Es funktioniert wieder alles.
      Ich hätte nie gedacht, dass falsche Firmwares ohne Fehler installiert werden können - wieder etwas dazugelernt.
      P
      Prince3k
      Es liegt am Stick, anderer Stick wird sofort erkannt. Entweder ist er wie schon damals vermutet kaputtgeflasht oder falsch geflasht. Einen Fehler hatte ich nämlich beim Flashen nicht gehabt.
      P
      Prince3k
      Danke vielmals für die ganze Unterstützung.
      Das ist aber kein Thema. Ich setze mich gleich dran und werde alles SAUBER neu einspielen und poste das Ergebnis.
      Vorab flashe ich nochmals den Stick neu und versuche auch einen anderen, der definitiv läuft.
      Ergebnis folgt.
      P
      Prince3k
      @prince3k
      Bitte das Fenster vom puTTY vor dem Kopieren größer zeihen. Dann werden die Zeilen auch nicht auseinandergerissen.
      Dein Dateisystem scheint ein wenig bröselig zu sein.
      pi@iobroker-pi-main:~ $ dmesg -wT
      [Thu Jun  2 18:52:25 2022] Booting Linux on physical CPU 0x0
      [Thu Jun  2 18:52:25 2022] Linux version 5.15.32-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP Thu Mar 31 19:39:41 BST 2022
      [Thu Jun  2 18:52:25 2022] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [Thu Jun  2 18:52:25 2022] CPU: div instructions available: patching division code
      [Thu Jun  2 18:52:25 2022] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [Thu Jun  2 18:52:25 2022] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      [Thu Jun  2 18:52:25 2022] random: fast init done
      [Thu Jun  2 18:52:25 2022] Memory policy: Data cache writealloc
      [Thu Jun  2 18:52:25 2022] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
      [Thu Jun  2 18:52:25 2022] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [Thu Jun  2 18:52:25 2022] Zone ranges:
      [Thu Jun  2 18:52:25 2022]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
      [Thu Jun  2 18:52:25 2022]   Normal   empty
      [Thu Jun  2 18:52:25 2022]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
      [Thu Jun  2 18:52:25 2022] Movable zone start for each node
      [Thu Jun  2 18:52:25 2022] Early memory node ranges
      [Thu Jun  2 18:52:25 2022]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
      [Thu Jun  2 18:52:25 2022]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
      [Thu Jun  2 18:52:25 2022] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
      [Thu Jun  2 18:52:25 2022] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
      [Thu Jun  2 18:52:25 2022] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
      [Thu Jun  2 18:52:25 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [Thu Jun  2 18:52:25 2022] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
      [Thu Jun  2 18:52:25 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:19:03:5B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ff98ab5b-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Jun  2 18:52:25 2022] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [Thu Jun  2 18:52:25 2022] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [Thu Jun  2 18:52:25 2022] mem auto-init: stack:off, heap alloc:off, heap free:off
      [Thu Jun  2 18:52:25 2022] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
      [Thu Jun  2 18:52:25 2022] Memory: 3601328K/4050944K available (10240K kernel code, 1390K rwdata, 3292K rodata, 2048K init, 590K bss, 121936K reserved, 327680K cma-reserved, 3264512K highmem)
      [Thu Jun  2 18:52:25 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [Thu Jun  2 18:52:25 2022] ftrace: allocating 35355 entries in 104 pages
      [Thu Jun  2 18:52:25 2022] ftrace: allocated 104 pages with 3 groups
      [Thu Jun  2 18:52:25 2022] trace event string verifier disabled
      [Thu Jun  2 18:52:25 2022] rcu: Hierarchical RCU implementation.
      [Thu Jun  2 18:52:25 2022]      Rude variant of Tasks RCU enabled.
      [Thu Jun  2 18:52:25 2022]      Tracing variant of Tasks RCU enabled.
      [Thu Jun  2 18:52:25 2022] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [Thu Jun  2 18:52:25 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [Thu Jun  2 18:52:25 2022] GIC: Using split EOI/Deactivate mode
      [Thu Jun  2 18:52:25 2022] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
      [Thu Jun  2 18:52:25 2022] random: get_random_bytes called from start_kernel+0x574/0x758 with crng_init=1
      [Thu Jun  2 18:52:25 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [Thu Jun  2 18:52:25 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [Thu Jun  2 18:52:25 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [Thu Jun  2 18:52:25 2022] Switching to timer-based delay loop, resolution 18ns
      [Thu Jun  2 18:52:25 2022] Console: colour dummy device 80x30
      [Thu Jun  2 18:52:25 2022] printk: console [tty1] enabled
      [Thu Jun  2 18:52:25 2022] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [Thu Jun  2 18:52:25 2022] pid_max: default: 32768 minimum: 301
      [Thu Jun  2 18:52:25 2022] LSM: Security Framework initializing
      [Thu Jun  2 18:52:25 2022] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Thu Jun  2 18:52:25 2022] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [Thu Jun  2 18:52:25 2022] cgroup: Disabling memory control group subsystem
      [Thu Jun  2 18:52:25 2022] CPU: Testing write buffer coherency: ok
      [Thu Jun  2 18:52:25 2022] CPU0: Spectre BHB: using loop workaround
      [Thu Jun  2 18:52:25 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [Thu Jun  2 18:52:25 2022] Setting up static identity map for 0x200000 - 0x20003c
      [Thu Jun  2 18:52:25 2022] rcu: Hierarchical SRCU implementation.
      [Thu Jun  2 18:52:25 2022] smp: Bringing up secondary CPUs ...
      [Thu Jun  2 18:52:25 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [Thu Jun  2 18:52:25 2022] CPU1: Spectre BHB: using loop workaround
      [Thu Jun  2 18:52:25 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [Thu Jun  2 18:52:25 2022] CPU2: Spectre BHB: using loop workaround
      [Thu Jun  2 18:52:25 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [Thu Jun  2 18:52:25 2022] CPU3: Spectre BHB: using loop workaround
      [Thu Jun  2 18:52:25 2022] smp: Brought up 1 node, 4 CPUs
      [Thu Jun  2 18:52:25 2022] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [Thu Jun  2 18:52:25 2022] CPU: All CPU(s) started in HYP mode.
      [Thu Jun  2 18:52:25 2022] CPU: Virtualization extensions available.
      [Thu Jun  2 18:52:25 2022] devtmpfs: initialized
      [Thu Jun  2 18:52:25 2022] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [Thu Jun  2 18:52:25 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [Thu Jun  2 18:52:25 2022] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [Thu Jun  2 18:52:25 2022] pinctrl core: initialized pinctrl subsystem
      [Thu Jun  2 18:52:25 2022] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [Thu Jun  2 18:52:25 2022] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [Thu Jun  2 18:52:25 2022] audit: initializing netlink subsys (disabled)
      [Thu Jun  2 18:52:25 2022] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
      [Thu Jun  2 18:52:25 2022] thermal_sys: Registered thermal governor 'step_wise'
      [Thu Jun  2 18:52:25 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [Thu Jun  2 18:52:25 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [Thu Jun  2 18:52:25 2022] Serial: AMBA PL011 UART driver
      [Thu Jun  2 18:52:25 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [Thu Jun  2 18:52:25 2022] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
      [Thu Jun  2 18:52:25 2022] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
      [Thu Jun  2 18:52:25 2022] Kprobes globally optimized
      [Thu Jun  2 18:52:25 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [Thu Jun  2 18:52:25 2022] vgaarb: loaded
      [Thu Jun  2 18:52:25 2022] SCSI subsystem initialized
      [Thu Jun  2 18:52:25 2022] usbcore: registered new interface driver usbfs
      [Thu Jun  2 18:52:25 2022] usbcore: registered new interface driver hub
      [Thu Jun  2 18:52:25 2022] usbcore: registered new device driver usb
      [Thu Jun  2 18:52:25 2022] usb_phy_generic phy: supply vcc not found, using dummy regulator
      [Thu Jun  2 18:52:25 2022] pps_core: LinuxPPS API ver. 1 registered
      [Thu Jun  2 18:52:25 2022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [Thu Jun  2 18:52:25 2022] PTP clock support registered
      [Thu Jun  2 18:52:25 2022] clocksource: Switched to clocksource arch_sys_counter
      [Thu Jun  2 18:52:25 2022] VFS: Disk quotas dquot_6.6.0
      [Thu Jun  2 18:52:25 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [Thu Jun  2 18:52:25 2022] FS-Cache: Loaded
      [Thu Jun  2 18:52:25 2022] CacheFiles: Loaded
      [Thu Jun  2 18:52:25 2022] NET: Registered PF_INET protocol family
      [Thu Jun  2 18:52:25 2022] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
      [Thu Jun  2 18:52:25 2022] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [Thu Jun  2 18:52:25 2022] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [Thu Jun  2 18:52:25 2022] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [Thu Jun  2 18:52:25 2022] TCP: Hash tables configured (established 8192 bind 8192)
      [Thu Jun  2 18:52:25 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Thu Jun  2 18:52:25 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [Thu Jun  2 18:52:25 2022] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [Thu Jun  2 18:52:25 2022] RPC: Registered named UNIX socket transport module.
      [Thu Jun  2 18:52:25 2022] RPC: Registered udp transport module.
      [Thu Jun  2 18:52:25 2022] RPC: Registered tcp transport module.
      [Thu Jun  2 18:52:25 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [Thu Jun  2 18:52:25 2022] PCI: CLS 0 bytes, default 64
      [Thu Jun  2 18:52:26 2022] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
      [Thu Jun  2 18:52:26 2022] Initialise system trusted keyrings
      [Thu Jun  2 18:52:26 2022] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [Thu Jun  2 18:52:26 2022] zbud: loaded
      [Thu Jun  2 18:52:26 2022] FS-Cache: Netfs 'nfs' registered for caching
      [Thu Jun  2 18:52:26 2022] NFS: Registering the id_resolver key type
      [Thu Jun  2 18:52:26 2022] Key type id_resolver registered
      [Thu Jun  2 18:52:26 2022] Key type id_legacy registered
      [Thu Jun  2 18:52:26 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [Thu Jun  2 18:52:26 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [Thu Jun  2 18:52:26 2022] Key type asymmetric registered
      [Thu Jun  2 18:52:26 2022] Asymmetric key parser 'x509' registered
      [Thu Jun  2 18:52:26 2022] bounce: pool size: 64 pages
      [Thu Jun  2 18:52:26 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [Thu Jun  2 18:52:26 2022] io scheduler mq-deadline registered
      [Thu Jun  2 18:52:26 2022] io scheduler kyber registered
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
      [Thu Jun  2 18:52:26 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [Thu Jun  2 18:52:26 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
      [Thu Jun  2 18:52:26 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
      [Thu Jun  2 18:52:26 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [Thu Jun  2 18:52:26 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
      [Thu Jun  2 18:52:26 2022] PCI: bus0: Fast back to back transfers disabled
      [Thu Jun  2 18:52:26 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [Thu Jun  2 18:52:26 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [Thu Jun  2 18:52:26 2022] pci 0000:01:00.0: PME# supported from D0 D3cold
      [Thu Jun  2 18:52:26 2022] PCI: bus1: Fast back to back transfers disabled
      [Thu Jun  2 18:52:26 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [Thu Jun  2 18:52:26 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [Thu Jun  2 18:52:26 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
      [Thu Jun  2 18:52:26 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [Thu Jun  2 18:52:26 2022] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [Thu Jun  2 18:52:26 2022] pcieport 0000:00:00.0: PME: Signaling with IRQ 77
      [Thu Jun  2 18:52:26 2022] iproc-rng200 fe104000.rng: hwrng registered
      [Thu Jun  2 18:52:26 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [Thu Jun  2 18:52:26 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [Thu Jun  2 18:52:26 2022] brd: module loaded
      [Thu Jun  2 18:52:26 2022] loop: module loaded
      [Thu Jun  2 18:52:26 2022] Loading iSCSI transport class v2.0-870.
      [Thu Jun  2 18:52:26 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [Thu Jun  2 18:52:26 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver r8152
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver lan78xx
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver smsc95xx
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
      [Thu Jun  2 18:52:26 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
      [Thu Jun  2 18:52:26 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [Thu Jun  2 18:52:26 2022] usb usb1: Product: xHCI Host Controller
      [Thu Jun  2 18:52:26 2022] usb usb1: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
      [Thu Jun  2 18:52:26 2022] usb usb1: SerialNumber: 0000:01:00.0
      [Thu Jun  2 18:52:26 2022] hub 1-0:1.0: USB hub found
      [Thu Jun  2 18:52:26 2022] hub 1-0:1.0: 1 port detected
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [Thu Jun  2 18:52:26 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [Thu Jun  2 18:52:26 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
      [Thu Jun  2 18:52:26 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [Thu Jun  2 18:52:26 2022] usb usb2: Product: xHCI Host Controller
      [Thu Jun  2 18:52:26 2022] usb usb2: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
      [Thu Jun  2 18:52:26 2022] usb usb2: SerialNumber: 0000:01:00.0
      [Thu Jun  2 18:52:26 2022] hub 2-0:1.0: USB hub found
      [Thu Jun  2 18:52:26 2022] hub 2-0:1.0: 4 ports detected
      [Thu Jun  2 18:52:26 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [Thu Jun  2 18:52:26 2022] dwc_otg: FIQ enabled
      [Thu Jun  2 18:52:26 2022] dwc_otg: NAK holdoff enabled
      [Thu Jun  2 18:52:26 2022] dwc_otg: FIQ split-transaction FSM enabled
      [Thu Jun  2 18:52:26 2022] Module dwc_common_port init
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver uas
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver usb-storage
      [Thu Jun  2 18:52:26 2022] mousedev: PS/2 mouse device common for all mice
      [Thu Jun  2 18:52:26 2022] sdhci: Secure Digital Host Controller Interface driver
      [Thu Jun  2 18:52:26 2022] sdhci: Copyright(c) Pierre Ossman
      [Thu Jun  2 18:52:26 2022] sdhci-pltfm: SDHCI platform and OF driver helper
      [Thu Jun  2 18:52:26 2022] ledtrig-cpu: registered to indicate activity on CPUs
      [Thu Jun  2 18:52:26 2022] hid: raw HID events driver (C) Jiri Kosina
      [Thu Jun  2 18:52:26 2022] usbcore: registered new interface driver usbhid
      [Thu Jun  2 18:52:26 2022] usbhid: USB HID core driver
      [Thu Jun  2 18:52:26 2022] Initializing XFRM netlink socket
      [Thu Jun  2 18:52:26 2022] NET: Registered PF_PACKET protocol family
      [Thu Jun  2 18:52:26 2022] Key type dns_resolver registered
      [Thu Jun  2 18:52:26 2022] Registering SWP/SWPB emulation handler
      [Thu Jun  2 18:52:26 2022] registered taskstats version 1
      [Thu Jun  2 18:52:26 2022] Loading compiled-in X.509 certificates
      [Thu Jun  2 18:52:26 2022] Key type ._fscrypt registered
      [Thu Jun  2 18:52:26 2022] Key type .fscrypt registered
      [Thu Jun  2 18:52:26 2022] Key type fscrypt-provisioning registered
      [Thu Jun  2 18:52:26 2022] uart-pl011 fe201000.serial: there is not valid maps for state default
      [Thu Jun  2 18:52:26 2022] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [Thu Jun  2 18:52:26 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
      [Thu Jun  2 18:52:26 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [Thu Jun  2 18:52:26 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [Thu Jun  2 18:52:26 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [Thu Jun  2 18:52:26 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [Thu Jun  2 18:52:26 2022] of_cfs_init
      [Thu Jun  2 18:52:26 2022] of_cfs_init: OK
      [Thu Jun  2 18:52:26 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
      [Thu Jun  2 18:52:26 2022] Waiting for root device PARTUUID=ff98ab5b-02...
      [Thu Jun  2 18:52:26 2022] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      [Thu Jun  2 18:52:26 2022] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
      [Thu Jun  2 18:52:26 2022]  mmcblk0: p1 p2
      [Thu Jun  2 18:52:26 2022] mmc1: new high speed SDIO card at address 0001
      [Thu Jun  2 18:52:26 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Thu Jun  2 18:52:26 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Thu Jun  2 18:52:26 2022] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [Thu Jun  2 18:52:26 2022] EXT4-fs (mmcblk0p2): recovery complete
      [Thu Jun  2 18:52:26 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Jun  2 18:52:26 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Jun  2 18:52:26 2022] devtmpfs: mounted
      [Thu Jun  2 18:52:26 2022] Freeing unused kernel image (initmem) memory: 2048K
      [Thu Jun  2 18:52:26 2022] Run /sbin/init as init process
      [Thu Jun  2 18:52:26 2022]   with arguments:
      [Thu Jun  2 18:52:26 2022]     /sbin/init
      [Thu Jun  2 18:52:26 2022]   with environment:
      [Thu Jun  2 18:52:26 2022]     HOME=/
      [Thu Jun  2 18:52:26 2022]     TERM=linux
      [Thu Jun  2 18:52:26 2022] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [Thu Jun  2 18:52:26 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [Thu Jun  2 18:52:26 2022] usb 1-1: Product: USB2.0 Hub
      [Thu Jun  2 18:52:26 2022] hub 1-1:1.0: USB hub found
      [Thu Jun  2 18:52:26 2022] hub 1-1:1.0: 4 ports detected
      [Thu Jun  2 18:52:27 2022] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
      [Thu Jun  2 18:52:27 2022] systemd[1]: System time before build time, advancing clock.
      [Thu Jun  2 18:52:27 2022] usb 1-1.3: device descriptor read/64, error -32
      [Thu Jun  2 18:52:27 2022] NET: Registered PF_INET6 protocol family
      [Thu Jun  2 18:52:27 2022] Segment Routing with IPv6
      [Thu Jun  2 18:52:27 2022] In-situ OAM (IOAM) with IPv6
      [Thu Jun  2 18:52:27 2022] systemd[1]: systemd 247.3-7+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
      [Thu Jun  2 18:52:27 2022] systemd[1]: Detected architecture arm.
      [Thu Jun  2 18:52:27 2022] systemd[1]: Set hostname to <iobroker-pi-main>.
      [Thu Jun  2 18:52:27 2022] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
      [Thu Jun  2 18:52:28 2022] usb 1-1.3: device descriptor read/64, error -32
      [Thu Jun  2 18:52:28 2022] usb 1-1-port3: attempt power cycle
      [Thu Jun  2 18:52:28 2022] systemd[1]: Queued start job for default target Multi-User System.
      [Thu Jun  2 18:52:28 2022] random: systemd: uninitialized urandom read (16 bytes read)
      [Thu Jun  2 18:52:28 2022] systemd[1]: Created slice system-getty.slice.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Created slice system-modprobe.slice.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Created slice system-systemd\x2dfsck.slice.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Created slice User and Session Slice.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Reached target Local Encrypted Volumes.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Reached target Paths.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Reached target Slices.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Reached target Swap.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on Syslog Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on fsck to fsckd communication Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on Journal Audit Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on Journal Socket (/dev/log).
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on Journal Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on udev Control Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Listening on udev Kernel Socket.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting POSIX Message Queue File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting RPC Pipe File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting Kernel Debug File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting Kernel Trace File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Restore / save the current clock...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Set the console keyboard layout...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Create list of static device nodes for the current kernel...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Load Kernel Module configfs...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Load Kernel Module drm...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Load Kernel Module fuse...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting File System Check on Root Device...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Journal Service...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Load Kernel Modules...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Coldplug All udev Devices...
      [Thu Jun  2 18:52:28 2022] fuse: init (API version 7.34)
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted POSIX Message Queue File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted RPC Pipe File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted Kernel Debug File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted Kernel Trace File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Restore / save the current clock.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Create list of static device nodes for the current kernel.
      [Thu Jun  2 18:52:28 2022] systemd[1]: modprobe@configfs.service: Succeeded.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Load Kernel Module configfs.
      [Thu Jun  2 18:52:28 2022] systemd[1]: modprobe@drm.service: Succeeded.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Load Kernel Module drm.
      [Thu Jun  2 18:52:28 2022] systemd[1]: modprobe@fuse.service: Succeeded.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Load Kernel Module fuse.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting FUSE Control File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounting Kernel Configuration File System...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Started File System Check Daemon to report status.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Load Kernel Modules.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted FUSE Control File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Mounted Kernel Configuration File System.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Apply Kernel Variables...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished Apply Kernel Variables.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Finished File System Check on Root Device.
      [Thu Jun  2 18:52:28 2022] systemd[1]: Starting Remount Root and Kernel File Systems...
      [Thu Jun  2 18:52:28 2022] systemd[1]: Started Journal Service.
      [Thu Jun  2 18:52:28 2022] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
      [Thu Jun  2 18:52:28 2022] usb 1-1.3: Device not responding to setup address.
      [Thu Jun  2 18:52:28 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
      [Thu Jun  2 18:52:29 2022] systemd-journald[135]: Received client request to flush runtime journal.
      [Thu Jun  2 18:52:29 2022] systemd-journald[135]: File /var/log/journal/975f88af903e429d801d3a42a88d9cde/system.journal corrupted or uncleanly shut down, renaming and replacing.
      [Thu Jun  2 18:52:29 2022] usb 1-1.3: Device not responding to setup address.
      [Thu Jun  2 18:52:29 2022] usb 1-1.3: device not accepting address 5, error -71
      [Thu Jun  2 18:52:29 2022] usb 1-1.3: new full-speed USB device number 6 using xhci_hcd
      [Thu Jun  2 18:52:29 2022] usb 1-1.3: device not accepting address 6, error -71
      [Thu Jun  2 18:52:29 2022] usb 1-1-port3: unable to enumerate USB device
      [Thu Jun  2 18:52:30 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [Thu Jun  2 18:52:30 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      [Thu Jun  2 18:52:30 2022] mc: Linux media interface: v0.10
      [Thu Jun  2 18:52:30 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [Thu Jun  2 18:52:30 2022] videodev: Linux video capture interface: v2.00
      [Thu Jun  2 18:52:30 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [Thu Jun  2 18:52:30 2022] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
      [Thu Jun  2 18:52:30 2022] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [Thu Jun  2 18:52:30 2022] [vc_sm_connected_init]: start
      [Thu Jun  2 18:52:30 2022] [vc_sm_connected_init]: installed successfully
      [Thu Jun  2 18:52:30 2022] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
      [Thu Jun  2 18:52:30 2022] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] bcm2835_audio bcm2835_audio: card created with 8 channels
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [Thu Jun  2 18:52:30 2022] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
      [Thu Jun  2 18:52:30 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
      [Thu Jun  2 18:52:30 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:52:30 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
      [Thu Jun  2 18:52:30 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
      [Thu Jun  2 18:52:30 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
      [Thu Jun  2 18:52:30 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
      [Thu Jun  2 18:52:31 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
      [Thu Jun  2 18:52:31 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:52:31 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
      [Thu Jun  2 18:52:31 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
      [Thu Jun  2 18:52:31 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [Thu Jun  2 18:52:31 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [Thu Jun  2 18:52:31 2022] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
      [Thu Jun  2 18:52:31 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
      [Thu Jun  2 18:52:31 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
      [Thu Jun  2 18:52:31 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [Thu Jun  2 18:52:31 2022] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
      [Thu Jun  2 18:52:31 2022] usbcore: registered new interface driver brcmfmac
      [Thu Jun  2 18:52:31 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
      [Thu Jun  2 18:52:31 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
      [Thu Jun  2 18:52:32 2022] random: crng init done
      [Thu Jun  2 18:52:32 2022] random: 7 urandom warning(s) missed due to ratelimiting
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
      [Thu Jun  2 18:52:32 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:52:32 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
      [Thu Jun  2 18:52:32 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
      [Thu Jun  2 18:52:32 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
      [Thu Jun  2 18:52:32 2022] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
      [Thu Jun  2 18:52:32 2022] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input5
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
      [Thu Jun  2 18:52:32 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
      [Thu Jun  2 18:52:32 2022] vc4-drm gpu: [drm] Cannot find any crtc or sizes
      [Thu Jun  2 18:52:33 2022] uart-pl011 fe201000.serial: no DMA platform data
      [Thu Jun  2 18:52:33 2022] Adding 102396k swap on /var/swap.  Priority:-2 extents:5 across:241664k SSFS
      [Thu Jun  2 18:52:33 2022] 8021q: 802.1Q VLAN Support v1.8
      [Thu Jun  2 18:52:34 2022] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
      [Thu Jun  2 18:52:34 2022] bcmgenet fd580000.ethernet eth0: Link is Down
      [Thu Jun  2 18:52:38 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
      [Thu Jun  2 18:52:38 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [Thu Jun  2 18:52:38 2022] systemd-journald[135]: File /var/log/journal/975f88af903e429d801d3a42a88d9cde/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
      [Thu Jun  2 18:52:39 2022] systemd-journald[135]: File /var/log/journal/975f88af903e429d801d3a42a88d9cde/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
      [Thu Jun  2 18:52:39 2022] Bluetooth: Core ver 2.22
      [Thu Jun  2 18:52:39 2022] NET: Registered PF_BLUETOOTH protocol family
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI device and connection manager initialized
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI socket layer initialized
      [Thu Jun  2 18:52:39 2022] Bluetooth: L2CAP socket layer initialized
      [Thu Jun  2 18:52:39 2022] Bluetooth: SCO socket layer initialized
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI UART driver ver 2.3
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI UART protocol H4 registered
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [Thu Jun  2 18:52:39 2022] Bluetooth: HCI UART protocol Broadcom registered
      [Thu Jun  2 18:52:39 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [Thu Jun  2 18:52:40 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [Thu Jun  2 18:52:40 2022] Bluetooth: BNEP filters: protocol multicast
      [Thu Jun  2 18:52:40 2022] Bluetooth: BNEP socket layer initialized
      [Thu Jun  2 18:52:40 2022] NET: Registered PF_ALG protocol family
      [Thu Jun  2 18:52:40 2022] cryptd: max_cpu_qlen set to 1000
      [Thu Jun  2 18:52:56 2022] cam-dummy-reg: disabling
      [Thu Jun  2 19:05:48 2022] usb 1-1.3: new full-speed USB device number 7 using xhci_hcd
      [Thu Jun  2 19:05:49 2022] usb 1-1.3: device descriptor read/64, error -32
      [Thu Jun  2 19:05:49 2022] usb 1-1.3: new full-speed USB device number 8 using xhci_hcd
      [Thu Jun  2 19:05:49 2022] usb 1-1-port3: attempt power cycle
      [Thu Jun  2 19:05:50 2022] usb 1-1.3: new full-speed USB device number 9 using xhci_hcd
      [Thu Jun  2 19:05:50 2022] usb 1-1.3: Device not responding to setup address.
      [Thu Jun  2 19:05:51 2022] usb 1-1.3: device not accepting address 9, error -71
      [Thu Jun  2 19:05:51 2022] usb 1-1.3: new full-speed USB device number 10 using xhci_hcd
      [Thu Jun  2 19:05:51 2022] usb 1-1.3: Device not responding to setup address.
      [Thu Jun  2 19:05:51 2022] usb 1-1.3: device not accepting address 10, error -71
      [Thu Jun  2 19:05:51 2022] usb 1-1-port3: unable to enumerate USB device
      P
      Prince3k
      @prince3k
      Schau es dir mit stabilerem Netzteil nochmal an. Ich vermute, das könnte dann anders aussehen.
      Das Netzteil hat nun dahingehend geholfen, dass der Voltagefehler Vergangenheit ist, vielen Dank.
      Leider erhalte ich mit
      weiterhin
      ls: cannot access '/dev/serial/by-id': No such file or directory
      [Thu Jun  2 18:30:08 2022] Booting Linux on physical CPU 0x0
      [Thu Jun  2 18:30:08 2022] Linux version 5.15.32-v7l+ (dom@buildbot) (arm-linux-                              gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for U                              buntu) 2.34) #1538 SMP Thu Mar 31 19:39:41 BST 2022
      [Thu Jun  2 18:30:08 2022] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), c                              r=30c5383d
      [Thu Jun  2 18:30:08 2022] CPU: div instructions available: patching division co                              de
      [Thu Jun  2 18:30:08 2022] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruc                              tion cache
      [Thu Jun  2 18:30:08 2022] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.                              1
      [Thu Jun  2 18:30:08 2022] random: fast init done
      [Thu Jun  2 18:30:08 2022] Memory policy: Data cache writealloc
      [Thu Jun  2 18:30:08 2022] Reserved memory: created CMA memory pool at 0x0000000                              01ac00000, size 320 MiB
      [Thu Jun  2 18:30:08 2022] OF: reserved mem: initialized node linux,cma, compati                              ble id shared-dma-pool
      [Thu Jun  2 18:30:08 2022] Zone ranges:
      [Thu Jun  2 18:30:08 2022]   DMA      [mem 0x0000000000000000-0x000000002fffffff                              ]
      [Thu Jun  2 18:30:08 2022]   Normal   empty
      [Thu Jun  2 18:30:08 2022]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff                              ]
      [Thu Jun  2 18:30:08 2022] Movable zone start for each node
      [Thu Jun  2 18:30:08 2022] Early memory node ranges
      [Thu Jun  2 18:30:08 2022]   node   0: [mem 0x0000000000000000-0x000000003b3ffff                              f]
      [Thu Jun  2 18:30:08 2022]   node   0: [mem 0x0000000040000000-0x00000000fbfffff                              f]
      [Thu Jun  2 18:30:08 2022] Initmem setup node 0 [mem 0x0000000000000000-0x000000                              00fbffffff]
      [Thu Jun  2 18:30:08 2022] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65                              536
      [Thu Jun  2 18:30:08 2022] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
      [Thu Jun  2 18:30:08 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [Thu Jun  2 18:30:08 2022] Built 1 zonelists, mobility grouping on.  Total pages                              : 1011008
      [Thu Jun  2 18:30:08 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0                               snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC                              :A6:32:19:03:5B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=t                              tyS0,115200 console=tty1 root=PARTUUID=ff98ab5b-02 rootfstype=ext4 fsck.repair=y                              es rootwait
      [Thu Jun  2 18:30:08 2022] Dentry cache hash table entries: 131072 (order: 7, 52                              4288 bytes, linear)
      [Thu Jun  2 18:30:08 2022] Inode-cache hash table entries: 65536 (order: 6, 2621                              44 bytes, linear)
      [Thu Jun  2 18:30:08 2022] mem auto-init: stack:off, heap alloc:off, heap free:o                              ff
      [Thu Jun  2 18:30:08 2022] software IO TLB: mapped [mem 0x0000000014890000-0x000                              0000018890000] (64MB)
      [Thu Jun  2 18:30:08 2022] Memory: 3601328K/4050944K available (10240K kernel co                              de, 1390K rwdata, 3292K rodata, 2048K init, 590K bss, 121936K reserved, 327680K                               cma-reserved, 3264512K highmem)
      [Thu Jun  2 18:30:08 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, No                              des=1
      [Thu Jun  2 18:30:08 2022] ftrace: allocating 35355 entries in 104 pages
      [Thu Jun  2 18:30:08 2022] ftrace: allocated 104 pages with 3 groups
      [Thu Jun  2 18:30:08 2022] trace event string verifier disabled
      [Thu Jun  2 18:30:08 2022] rcu: Hierarchical RCU implementation.
      [Thu Jun  2 18:30:08 2022]      Rude variant of Tasks RCU enabled.
      [Thu Jun  2 18:30:08 2022]      Tracing variant of Tasks RCU enabled.
      [Thu Jun  2 18:30:08 2022] rcu: RCU calculated value of scheduler-enlistment del                              ay is 10 jiffies.
      [Thu Jun  2 18:30:08 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [Thu Jun  2 18:30:08 2022] GIC: Using split EOI/Deactivate mode
      [Thu Jun  2 18:30:08 2022] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-co                              ntroller@7ef00100, parent irq: 25)
      [Thu Jun  2 18:30:08 2022] random: get_random_bytes called from start_kernel+0x5                              74/0x758 with crng_init=1
      [Thu Jun  2 18:30:08 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [Thu Jun  2 18:30:08 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff                               max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [Thu Jun  2 18:30:08 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps                               every 4398046511102ns
      [Thu Jun  2 18:30:08 2022] Switching to timer-based delay loop, resolution 18ns
      [Thu Jun  2 18:30:08 2022] Console: colour dummy device 80x30
      [Thu Jun  2 18:30:08 2022] printk: console [tty1] enabled
      [Thu Jun  2 18:30:08 2022] Calibrating delay loop (skipped), value calculated us                              ing timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [Thu Jun  2 18:30:08 2022] pid_max: default: 32768 minimum: 301
      [Thu Jun  2 18:30:08 2022] LSM: Security Framework initializing
      [Thu Jun  2 18:30:08 2022] Mount-cache hash table entries: 2048 (order: 1, 8192                               bytes, linear)
      [Thu Jun  2 18:30:08 2022] Mountpoint-cache hash table entries: 2048 (order: 1,                               8192 bytes, linear)
      [Thu Jun  2 18:30:08 2022] cgroup: Disabling memory control group subsystem
      [Thu Jun  2 18:30:08 2022] CPU: Testing write buffer coherency: ok
      [Thu Jun  2 18:30:08 2022] CPU0: Spectre BHB: using loop workaround
      [Thu Jun  2 18:30:08 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [Thu Jun  2 18:30:08 2022] Setting up static identity map for 0x200000 - 0x20003                              c
      [Thu Jun  2 18:30:08 2022] rcu: Hierarchical SRCU implementation.
      [Thu Jun  2 18:30:08 2022] smp: Bringing up secondary CPUs ...
      [Thu Jun  2 18:30:08 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [Thu Jun  2 18:30:08 2022] CPU1: Spectre BHB: using loop workaround
      [Thu Jun  2 18:30:08 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [Thu Jun  2 18:30:08 2022] CPU2: Spectre BHB: using loop workaround
      [Thu Jun  2 18:30:08 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [Thu Jun  2 18:30:08 2022] CPU3: Spectre BHB: using loop workaround
      [Thu Jun  2 18:30:08 2022] smp: Brought up 1 node, 4 CPUs
      [Thu Jun  2 18:30:08 2022] SMP: Total of 4 processors activated (432.00 BogoMIPS                              ).
      [Thu Jun  2 18:30:08 2022] CPU: All CPU(s) started in HYP mode.
      [Thu Jun  2 18:30:08 2022] CPU: Virtualization extensions available.
      [Thu Jun  2 18:30:08 2022] devtmpfs: initialized
      [Thu Jun  2 18:30:08 2022] VFP support v0.3: implementor 41 architecture 3 part                               40 variant 8 rev 0
      [Thu Jun  2 18:30:08 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0x                              ffffffff, max_idle_ns: 19112604462750000 ns
      [Thu Jun  2 18:30:08 2022] futex hash table entries: 1024 (order: 4, 65536 bytes                              , linear)
      [Thu Jun  2 18:30:08 2022] pinctrl core: initialized pinctrl subsystem
      [Thu Jun  2 18:30:08 2022] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [Thu Jun  2 18:30:08 2022] DMA: preallocated 1024 KiB pool for atomic coherent a                              llocations
      [Thu Jun  2 18:30:08 2022] audit: initializing netlink subsys (disabled)
      [Thu Jun  2 18:30:08 2022] audit: type=2000 audit(0.040:1): state=initialized au                              dit_enabled=0 res=1
      [Thu Jun  2 18:30:08 2022] thermal_sys: Registered thermal governor 'step_wise'
      [Thu Jun  2 18:30:08 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4                               watchpoint registers.
      [Thu Jun  2 18:30:08 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [Thu Jun  2 18:30:08 2022] Serial: AMBA PL011 UART driver
      [Thu Jun  2 18:30:08 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [Thu Jun  2 18:30:08 2022] raspberrypi-firmware soc:firmware: Attached to firmwa                              re from 2022-03-24T13:19:26, variant start
      [Thu Jun  2 18:30:08 2022] raspberrypi-firmware soc:firmware: Firmware hash is e                              5a963efa66a1974127860b42e913d2374139ff5
      [Thu Jun  2 18:30:08 2022] Kprobes globally optimized
      [Thu Jun  2 18:30:08 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dma                              chans=0x1
      [Thu Jun  2 18:30:08 2022] vgaarb: loaded
      [Thu Jun  2 18:30:08 2022] SCSI subsystem initialized
      [Thu Jun  2 18:30:08 2022] usbcore: registered new interface driver usbfs
      [Thu Jun  2 18:30:08 2022] usbcore: registered new interface driver hub
      [Thu Jun  2 18:30:08 2022] usbcore: registered new device driver usb
      [Thu Jun  2 18:30:08 2022] usb_phy_generic phy: supply vcc not found, using dumm                              y regulator
      [Thu Jun  2 18:30:08 2022] pps_core: LinuxPPS API ver. 1 registered
      [Thu Jun  2 18:30:08 2022] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 R                              odolfo Giometti <giometti@linux.it>
      [Thu Jun  2 18:30:08 2022] PTP clock support registered
      [Thu Jun  2 18:30:08 2022] clocksource: Switched to clocksource arch_sys_counter
      [Thu Jun  2 18:30:08 2022] VFS: Disk quotas dquot_6.6.0
      [Thu Jun  2 18:30:08 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 4                              096 bytes)
      [Thu Jun  2 18:30:08 2022] FS-Cache: Loaded
      [Thu Jun  2 18:30:08 2022] CacheFiles: Loaded
      [Thu Jun  2 18:30:08 2022] NET: Registered PF_INET protocol family
      [Thu Jun  2 18:30:08 2022] IP idents hash table entries: 16384 (order: 5, 131072                               bytes, linear)
      [Thu Jun  2 18:30:08 2022] tcp_listen_portaddr_hash hash table entries: 512 (ord                              er: 0, 6144 bytes, linear)
      [Thu Jun  2 18:30:08 2022] TCP established hash table entries: 8192 (order: 3, 3                              2768 bytes, linear)
      [Thu Jun  2 18:30:08 2022] TCP bind hash table entries: 8192 (order: 4, 65536 by                              tes, linear)
      [Thu Jun  2 18:30:08 2022] TCP: Hash tables configured (established 8192 bind 81                              92)
      [Thu Jun  2 18:30:08 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, l                              inear)
      [Thu Jun  2 18:30:08 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 byt                              es, linear)
      [Thu Jun  2 18:30:08 2022] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [Thu Jun  2 18:30:08 2022] RPC: Registered named UNIX socket transport module.
      [Thu Jun  2 18:30:08 2022] RPC: Registered udp transport module.
      [Thu Jun  2 18:30:08 2022] RPC: Registered tcp transport module.
      [Thu Jun  2 18:30:08 2022] RPC: Registered tcp NFSv4.1 backchannel transport mod                              ule.
      [Thu Jun  2 18:30:08 2022] PCI: CLS 0 bytes, default 64
      [Thu Jun  2 18:30:09 2022] hw perfevents: enabled with armv7_cortex_a7 PMU drive                              r, 7 counters available
      [Thu Jun  2 18:30:09 2022] Initialise system trusted keyrings
      [Thu Jun  2 18:30:09 2022] workingset: timestamp_bits=14 max_order=20 bucket_ord                              er=6
      [Thu Jun  2 18:30:09 2022] zbud: loaded
      [Thu Jun  2 18:30:09 2022] FS-Cache: Netfs 'nfs' registered for caching
      [Thu Jun  2 18:30:09 2022] NFS: Registering the id_resolver key type
      [Thu Jun  2 18:30:09 2022] Key type id_resolver registered
      [Thu Jun  2 18:30:09 2022] Key type id_legacy registered
      [Thu Jun  2 18:30:09 2022] nfs4filelayout_init: NFSv4 File Layout Driver Registe                              ring...
      [Thu Jun  2 18:30:09 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver                               Registering...
      [Thu Jun  2 18:30:09 2022] Key type asymmetric registered
      [Thu Jun  2 18:30:09 2022] Asymmetric key parser 'x509' registered
      [Thu Jun  2 18:30:09 2022] bounce: pool size: 64 pages
      [Thu Jun  2 18:30:09 2022] Block layer SCSI generic (bsg) driver version 0.4 loa                              ded (major 247)
      [Thu Jun  2 18:30:09 2022] io scheduler mq-deadline registered
      [Thu Jun  2 18:30:09 2022] io scheduler kyber registered
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d5000                              00 ranges:
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie:   No bus range found for /sc                              b/pcie@7d500000, using [bus 00-ff]
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063                              fffffff -> 0x00c0000000
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00b                              fffffff -> 0x0400000000
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (S                              SC)
      [Thu Jun  2 18:30:09 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:                              00
      [Thu Jun  2 18:30:09 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
      [Thu Jun  2 18:30:09 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0                              x63fffffff] (bus address [0xc0000000-0xffffffff])
      [Thu Jun  2 18:30:09 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [Thu Jun  2 18:30:09 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
      [Thu Jun  2 18:30:09 2022] PCI: bus0: Fast back to back transfers disabled
      [Thu Jun  2 18:30:09 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [Thu Jun  2 18:30:09 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000ff                              f 64bit]
      [Thu Jun  2 18:30:09 2022] pci 0000:01:00.0: PME# supported from D0 D3cold
      [Thu Jun  2 18:30:09 2022] PCI: bus1: Fast back to back transfers disabled
      [Thu Jun  2 18:30:09 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x                              6000fffff]
      [Thu Jun  2 18:30:09 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x                              600000fff 64bit]
      [Thu Jun  2 18:30:09 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
      [Thu Jun  2 18:30:09 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x                              6000fffff]
      [Thu Jun  2 18:30:09 2022] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [Thu Jun  2 18:30:09 2022] pcieport 0000:00:00.0: PME: Signaling with IRQ 77
      [Thu Jun  2 18:30:09 2022] iproc-rng200 fe104000.rng: hwrng registered
      [Thu Jun  2 18:30:09 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_                              size:0x40000000(1024 MiB)
      [Thu Jun  2 18:30:09 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Regist                              ers at 0xfe200000
      [Thu Jun  2 18:30:09 2022] brd: module loaded
      [Thu Jun  2 18:30:09 2022] loop: module loaded
      [Thu Jun  2 18:30:09 2022] Loading iSCSI transport class v2.0-870.
      [Thu Jun  2 18:30:09 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [Thu Jun  2 18:30:09 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver r8152
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver lan78xx
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver smsc95xx
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assign                              ed bus number 1
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci vers                              ion 0x100 quirks 0x00003c0000000890
      [Thu Jun  2 18:30:09 2022] usb usb1: New USB device found, idVendor=1d6b, idProd                              uct=0002, bcdDevice= 5.15
      [Thu Jun  2 18:30:09 2022] usb usb1: New USB device strings: Mfr=3, Product=2, S                              erialNumber=1
      [Thu Jun  2 18:30:09 2022] usb usb1: Product: xHCI Host Controller
      [Thu Jun  2 18:30:09 2022] usb usb1: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
      [Thu Jun  2 18:30:09 2022] usb usb1: SerialNumber: 0000:01:00.0
      [Thu Jun  2 18:30:09 2022] hub 1-0:1.0: USB hub found
      [Thu Jun  2 18:30:09 2022] hub 1-0:1.0: 1 port detected
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assign                              ed bus number 2
      [Thu Jun  2 18:30:09 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpe                              ed
      [Thu Jun  2 18:30:09 2022] usb usb2: New USB device found, idVendor=1d6b, idProd                              uct=0003, bcdDevice= 5.15
      [Thu Jun  2 18:30:09 2022] usb usb2: New USB device strings: Mfr=3, Product=2, S                              erialNumber=1
      [Thu Jun  2 18:30:09 2022] usb usb2: Product: xHCI Host Controller
      [Thu Jun  2 18:30:09 2022] usb usb2: Manufacturer: Linux 5.15.32-v7l+ xhci-hcd
      [Thu Jun  2 18:30:09 2022] usb usb2: SerialNumber: 0000:01:00.0
      [Thu Jun  2 18:30:09 2022] hub 2-0:1.0: USB hub found
      [Thu Jun  2 18:30:09 2022] hub 2-0:1.0: 4 ports detected
      [Thu Jun  2 18:30:09 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [Thu Jun  2 18:30:09 2022] dwc_otg: FIQ enabled
      [Thu Jun  2 18:30:09 2022] dwc_otg: NAK holdoff enabled
      [Thu Jun  2 18:30:09 2022] dwc_otg: FIQ split-transaction FSM enabled
      [Thu Jun  2 18:30:09 2022] Module dwc_common_port init
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver uas
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver usb-storage
      [Thu Jun  2 18:30:09 2022] mousedev: PS/2 mouse device common for all mice
      [Thu Jun  2 18:30:09 2022] sdhci: Secure Digital Host Controller Interface drive                              r
      [Thu Jun  2 18:30:09 2022] sdhci: Copyright(c) Pierre Ossman
      [Thu Jun  2 18:30:09 2022] sdhci-pltfm: SDHCI platform and OF driver helper
      [Thu Jun  2 18:30:09 2022] ledtrig-cpu: registered to indicate activity on CPUs
      [Thu Jun  2 18:30:09 2022] hid: raw HID events driver (C) Jiri Kosina
      [Thu Jun  2 18:30:09 2022] usbcore: registered new interface driver usbhid
      [Thu Jun  2 18:30:09 2022] usbhid: USB HID core driver
      [Thu Jun  2 18:30:09 2022] Initializing XFRM netlink socket
      [Thu Jun  2 18:30:09 2022] NET: Registered PF_PACKET protocol family
      [Thu Jun  2 18:30:09 2022] Key type dns_resolver registered
      [Thu Jun  2 18:30:09 2022] Registering SWP/SWPB emulation handler
      [Thu Jun  2 18:30:09 2022] registered taskstats version 1
      [Thu Jun  2 18:30:09 2022] Loading compiled-in X.509 certificates
      [Thu Jun  2 18:30:09 2022] Key type ._fscrypt registered
      [Thu Jun  2 18:30:09 2022] Key type .fscrypt registered
      [Thu Jun  2 18:30:09 2022] Key type fscrypt-provisioning registered
      [Thu Jun  2 18:30:09 2022] uart-pl011 fe201000.serial: there is not valid maps f                              or state default
      [Thu Jun  2 18:30:09 2022] uart-pl011 fe201000.serial: cts_event_workaround enab                              led
      [Thu Jun  2 18:30:09 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34                              , base_baud = 0) is a PL011 rev2
      [Thu Jun  2 18:30:09 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog ti                              mer
      [Thu Jun  2 18:30:09 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power d                              omains driver
      [Thu Jun  2 18:30:09 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [Thu Jun  2 18:30:09 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [Thu Jun  2 18:30:09 2022] of_cfs_init
      [Thu Jun  2 18:30:09 2022] of_cfs_init: OK
      [Thu Jun  2 18:30:09 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc]                               using ADMA
      [Thu Jun  2 18:30:09 2022] Waiting for root device PARTUUID=ff98ab5b-02...
      [Thu Jun  2 18:30:09 2022] mmc0: new ultra high speed DDR50 SDHC card at address                               aaaa
      [Thu Jun  2 18:30:09 2022] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
      [Thu Jun  2 18:30:09 2022] mmc1: new high speed SDIO card at address 0001
      [Thu Jun  2 18:30:09 2022]  mmcblk0: p1 p2
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on reado                              nly filesystem
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): write access will be enabled dur                              ing recovery
      [Thu Jun  2 18:30:09 2022] usb 1-1: new high-speed USB device number 2 using xhc                              i_hcd
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): recovery complete
      [Thu Jun  2 18:30:09 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered                               data mode. Opts: (null). Quota mode: none.
      [Thu Jun  2 18:30:09 2022] VFS: Mounted root (ext4 filesystem) readonly on devic                              e 179:2.
      [Thu Jun  2 18:30:09 2022] usb 1-1: New USB device found, idVendor=2109, idProdu                              ct=3431, bcdDevice= 4.21
      [Thu Jun  2 18:30:09 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, Se                              rialNumber=0
      [Thu Jun  2 18:30:09 2022] usb 1-1: Product: USB2.0 Hub
      [Thu Jun  2 18:30:09 2022] devtmpfs: mounted
      [Thu Jun  2 18:30:09 2022] hub 1-1:1.0: USB hub found
      [Thu Jun  2 18:30:09 2022] hub 1-1:1.0: 4 ports detected
      [Thu Jun  2 18:30:09 2022] Freeing unused kernel image (initmem) memory: 2048K
      [Thu Jun  2 18:30:09 2022] Run /sbin/init as init process
      [Thu Jun  2 18:30:09 2022]   with arguments:
      [Thu Jun  2 18:30:09 2022]     /sbin/init
      [Thu Jun  2 18:30:09 2022]   with environment:
      [Thu Jun  2 18:30:09 2022]     HOME=/
      [Thu Jun  2 18:30:09 2022]     TERM=linux
      [Thu Jun  2 18:30:10 2022] systemd[1]: System time before build time, advancing                               clock.
      [Thu Jun  2 18:30:10 2022] NET: Registered PF_INET6 protocol family
      [Thu Jun  2 18:30:10 2022] Segment Routing with IPv6
      [Thu Jun  2 18:30:10 2022] In-situ OAM (IOAM) with IPv6
      [Thu Jun  2 18:30:10 2022] systemd[1]: systemd 247.3-7+rpi1 running in system mo                              de. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +                              GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +P                              CRE2 default-hierarchy=unified)
      [Thu Jun  2 18:30:10 2022] systemd[1]: Detected architecture arm.
      [Thu Jun  2 18:30:10 2022] systemd[1]: Set hostname to <iobroker-pi-main>.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Queued start job for default target Multi                              -User System.
      [Thu Jun  2 18:30:11 2022] random: systemd: uninitialized urandom read (16 bytes                               read)
      [Thu Jun  2 18:30:11 2022] systemd[1]: Created slice system-getty.slice.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Created slice system-modprobe.slice.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Created slice system-systemd\x2dfsck.slic                              e.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Created slice User and Session Slice.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Started Dispatch Password Requests to Con                              sole Directory Watch.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Started Forward Password Requests to Wall                               Directory Watch.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Set up automount Arbitrary Executable Fil                              e Formats File System Automount Point.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Reached target Local Encrypted Volumes.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Reached target Paths.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Reached target Slices.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Reached target Swap.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on Syslog Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on fsck to fsckd communication                               Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on initctl Compatibility Named                               Pipe.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on Journal Audit Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on Journal Socket (/dev/log).
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on Journal Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on udev Control Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Listening on udev Kernel Socket.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Condition check resulted in Huge Pages Fi                              le System being skipped.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting POSIX Message Queue File System.                              ..
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting RPC Pipe File System...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting Kernel Debug File System...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting Kernel Trace File System...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Condition check resulted in Kernel Module                               supporting RPCSEC_GSS being skipped.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Restore / save the current clock                              ...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Set the console keyboard layout.                              ..
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Create list of static device nod                              es for the current kernel...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Load Kernel Module configfs...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Load Kernel Module drm...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Load Kernel Module fuse...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Condition check resulted in Set Up Additi                              onal Binary Formats being skipped.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting File System Check on Root Device                              ...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Journal Service...
      [Thu Jun  2 18:30:11 2022] fuse: init (API version 7.34)
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Load Kernel Modules...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Coldplug All udev Devices...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted POSIX Message Queue File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted RPC Pipe File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted Kernel Debug File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted Kernel Trace File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Create list of static device nod                              es for the current kernel.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Restore / save the current clock                              .
      [Thu Jun  2 18:30:11 2022] systemd[1]: modprobe@configfs.service: Succeeded.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Load Kernel Module configfs.
      [Thu Jun  2 18:30:11 2022] systemd[1]: modprobe@drm.service: Succeeded.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Load Kernel Module drm.
      [Thu Jun  2 18:30:11 2022] systemd[1]: modprobe@fuse.service: Succeeded.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Load Kernel Module fuse.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Load Kernel Modules.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting FUSE Control File System...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounting Kernel Configuration File System                              ...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Started File System Check Daemon to repor                              t status.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Apply Kernel Variables...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted FUSE Control File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Mounted Kernel Configuration File System.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished Apply Kernel Variables.
      [Thu Jun  2 18:30:11 2022] systemd[1]: Finished File System Check on Root Device                              .
      [Thu Jun  2 18:30:11 2022] systemd[1]: Starting Remount Root and Kernel File Sys                              tems...
      [Thu Jun  2 18:30:11 2022] systemd[1]: Started Journal Service.
      [Thu Jun  2 18:30:11 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota                               mode: none.
      [Thu Jun  2 18:30:12 2022] systemd-journald[134]: Received client request to flu                              sh runtime journal.
      [Thu Jun  2 18:30:12 2022] systemd-journald[134]: File /var/log/journal/975f88af                              903e429d801d3a42a88d9cde/system.journal corrupted or uncleanly shut down, renami                              ng and replacing.
      [Thu Jun  2 18:30:12 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem init                              ialised: Registers at 0xfeb00000 length 0x00010000
      [Thu Jun  2 18:30:12 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem                               initialised: Registers at 0xfeb10000 length 0x00001000
      [Thu Jun  2 18:30:12 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem init                              ialised: Registers at 0xfeb20000 length 0x00010000
      [Thu Jun  2 18:30:12 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initia                              lised: Registers at 0xfeb30000 length 0x00010000
      [Thu Jun  2 18:30:13 2022] vc_sm_cma: module is from the staging directory, the                               quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] usb 1-1.4: new full-speed USB device number 3 using x                              hci_hcd
      [Thu Jun  2 18:30:13 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory driv                              er
      [Thu Jun  2 18:30:13 2022] [vc_sm_connected_init]: start
      [Thu Jun  2 18:30:13 2022] snd_bcm2835: module is from the staging directory, th                              e quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] [vc_sm_connected_init]: installed successfully
      [Thu Jun  2 18:30:13 2022] usb 1-1.4: device descriptor read/64, error -32
      [Thu Jun  2 18:30:13 2022] mc: Linux media interface: v0.10
      [Thu Jun  2 18:30:13 2022] bcm2835_audio bcm2835_audio: card created with 8 chan                              nels
      [Thu Jun  2 18:30:13 2022] videodev: Linux video capture interface: v2.00
      [Thu Jun  2 18:30:13 2022] bcm2835_mmal_vchiq: module is from the staging direct                              ory, the quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] bcm2835_isp: module is from the staging directory, th                              e quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] bcm2835_v4l2: module is from the staging directory, t                              he quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] bcm2835_codec: module is from the staging directory,                               the quality is unknown, you have been warned.
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de                              v/video10
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node output[0] regist                              ered as /dev/video13
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de                              v/video11
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node capture[0] regis                              tered as /dev/video14
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node capture[1] regis                              tered as /dev/video15
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de                              v/video12
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de                              v/video18
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registe                              red as /dev/video16
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Register output node 0 with                               media controller
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Register capture node 1 with                               media controller
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Register capture node 2 with                               media controller
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Register capture node 3 with                               media controller
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node output[0] regist                              ered as /dev/video20
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node capture[0] regis                              tered as /dev/video21
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node capture[1] regis                              tered as /dev/video22
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Device node stats[2] registe                              red as /dev/video23
      [Thu Jun  2 18:30:13 2022] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Device registered as /de                              v/video31
      [Thu Jun  2 18:30:13 2022] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
      [Thu Jun  2 18:30:13 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4                              ])
      [Thu Jun  2 18:30:13 2022] usb 1-1.4: new full-speed USB device number 4 using x                              hci_hcd
      [Thu Jun  2 18:30:13 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:30:13 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc                              /rc0
      [Thu Jun  2 18:30:13 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input0
      [Thu Jun  2 18:30:13 2022] brcmstb-i2c fef04500.i2c:  @97500hz registered in pol                              ling mode
      [Thu Jun  2 18:30:13 2022] brcmstb-i2c fef09500.i2c:  @97500hz registered in pol                              ling mode
      [Thu Jun  2 18:30:13 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d                               on minor 1
      [Thu Jun  2 18:30:13 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input1
      [Thu Jun  2 18:30:14 2022] usb 1-1-port4: attempt power cycle
      [Thu Jun  2 18:30:14 2022] cfg80211: Loading compiled-in X.509 certificates for                               regulatory database
      [Thu Jun  2 18:30:14 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9                              cea7'
      [Thu Jun  2 18:30:14 2022] cfg80211: loaded regulatory.db is malformed or signat                              ure is missing/invalid
      [Thu Jun  2 18:30:14 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4                              ])
      [Thu Jun  2 18:30:14 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:30:14 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc                              /rc0
      [Thu Jun  2 18:30:14 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input2
      [Thu Jun  2 18:30:14 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
      [Thu Jun  2 18:30:14 2022] usb 1-1.4: new full-speed USB device number 5 using x                              hci_hcd
      [Thu Jun  2 18:30:14 2022] usb 1-1.4: Device not responding to setup address.
      [Thu Jun  2 18:30:14 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac                              43455-sdio for chip BCM4345/6
      [Thu Jun  2 18:30:14 2022] brcmfmac mmc1:0001:1: Direct firmware load for brcm/b                              rcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
      [Thu Jun  2 18:30:14 2022] usbcore: registered new interface driver brcmfmac
      [Thu Jun  2 18:30:14 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input3
      [Thu Jun  2 18:30:15 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac                              43455-sdio for chip BCM4345/6
      [Thu Jun  2 18:30:15 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6                               wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
      [Thu Jun  2 18:30:15 2022] usb 1-1.4: device not accepting address 5, error -71
      [Thu Jun  2 18:30:15 2022] random: crng init done
      [Thu Jun  2 18:30:15 2022] random: 7 urandom warning(s) missed due to ratelimiti                              ng
      [Thu Jun  2 18:30:15 2022] usb 1-1.4: new full-speed USB device number 6 using x                              hci_hcd
      [Thu Jun  2 18:30:15 2022] usb 1-1.4: Device not responding to setup address.
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4                              ])
      [Thu Jun  2 18:30:15 2022] Registered IR keymap rc-cec
      [Thu Jun  2 18:30:15 2022] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc                              /rc0
      [Thu Jun  2 18:30:15 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input4
      [Thu Jun  2 18:30:15 2022] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/                              rc0/input5
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [v                              c4])
      [Thu Jun  2 18:30:15 2022] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc                              /rc1
      [Thu Jun  2 18:30:15 2022] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/                              rc1/input6
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [v                              c4])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4                              ])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_                              ops [vc4])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_                              ops [vc4])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_                              ops [vc4])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_                              ops [vc4])
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_                              ops [vc4])
      [Thu Jun  2 18:30:15 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor                               0
      [Thu Jun  2 18:30:15 2022] vc4-drm gpu: [drm] Cannot find any crtc or sizes
      [Thu Jun  2 18:30:15 2022] usb 1-1.4: device not accepting address 6, error -71
      [Thu Jun  2 18:30:15 2022] usb 1-1-port4: unable to enumerate USB device
      [Thu Jun  2 18:30:16 2022] uart-pl011 fe201000.serial: no DMA platform data
      [Thu Jun  2 18:30:16 2022] 8021q: 802.1Q VLAN Support v1.8
      [Thu Jun  2 18:30:16 2022] Adding 102396k swap on /var/swap.  Priority:-2 extent                              s:5 across:241664k SSFS
      [Thu Jun  2 18:30:16 2022] bcmgenet fd580000.ethernet: configuring instance for                               external RGMII (RX delay)
      [Thu Jun  2 18:30:16 2022] bcmgenet fd580000.ethernet eth0: Link is Down
      [Thu Jun  2 18:30:21 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/F                              ull - flow control rx/tx
      [Thu Jun  2 18:30:21 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes rea                              dy
      [Thu Jun  2 18:30:22 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (                              syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time                              _ms instead
      [Thu Jun  2 18:30:22 2022] Bluetooth: Core ver 2.22
      [Thu Jun  2 18:30:22 2022] NET: Registered PF_BLUETOOTH protocol family
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI device and connection manager initiali                              zed
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI socket layer initialized
      [Thu Jun  2 18:30:22 2022] Bluetooth: L2CAP socket layer initialized
      [Thu Jun  2 18:30:22 2022] Bluetooth: SCO socket layer initialized
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI UART driver ver 2.3
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI UART protocol H4 registered
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI UART protocol Three-wire (H5) register                              ed
      [Thu Jun  2 18:30:22 2022] Bluetooth: HCI UART protocol Broadcom registered
      [Thu Jun  2 18:30:23 2022] systemd-journald[134]: File /var/log/journal/975f88af                              903e429d801d3a42a88d9cde/user-1001.journal corrupted or uncleanly shut down, ren                              aming and replacing.
      [Thu Jun  2 18:30:23 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [Thu Jun  2 18:30:23 2022] Bluetooth: BNEP filters: protocol multicast
      [Thu Jun  2 18:30:23 2022] Bluetooth: BNEP socket layer initialized
      [Thu Jun  2 18:30:23 2022] NET: Registered PF_ALG protocol family
      [Thu Jun  2 18:30:23 2022] cryptd: max_cpu_qlen set to 1000
      [Thu Jun  2 18:30:39 2022] cam-dummy-reg: disabling
      [Thu Jun  2 18:38:23 2022] usb 1-1.4: new full-speed USB device number 7 using x                              hci_hcd
      [Thu Jun  2 18:38:23 2022] usb 1-1.4: device descriptor read/64, error -32
      [Thu Jun  2 18:38:23 2022] usb 1-1.4: new full-speed USB device number 8 using x                              hci_hcd
      [Thu Jun  2 18:38:24 2022] usb 1-1.4: device descriptor read/64, error -32
      [Thu Jun  2 18:38:24 2022] usb 1-1-port4: attempt power cycle
      [Thu Jun  2 18:38:24 2022] usb 1-1.4: new full-speed USB device number 9 using x                              hci_hcd
      [Thu Jun  2 18:38:24 2022] usb 1-1.4: Device not responding to setup address.
      [Thu Jun  2 18:38:25 2022] usb 1-1.4: Device not responding to setup address.
      [Thu Jun  2 18:38:25 2022] usb 1-1.4: device not accepting address 9, error -71
      [Thu Jun  2 18:38:25 2022] usb 1-1.4: new full-speed USB device number 10 using                               xhci_hcd
      [Thu Jun  2 18:38:25 2022] usb 1-1.4: device not accepting address 10, error -71
      [Thu Jun  2 18:38:25 2022] usb 1-1-port4: unable to enumerate USB device
      P
      Prince3k
    • RE: [gelöst]zigbee ..serial/by-id => no such file or directory
      war es ja auch, habe noch andere Raspi Netzteile, aber alle mit bis zu 3,1 A.
      Danke aber für den Hinweis.
      P
      Prince3k
      [Tue May 31 23:50:54 2022] usb 1-1.4: Device not responding to setup address.
      [Tue May 31 23:50:54 2022] usb 1-1.4: device not accepting address 12, error -71
      [Tue May 31 23:50:54 2022] usb 1-1-port4: unable to enumerate USB device
      [Tue May 31 23:50:57 2022] hwmon hwmon1: Voltage normalised
      [Tue May 31 23:54:59 2022] hwmon hwmon1: Undervoltage detected!
      [Tue May 31 23:55:30 2022] hwmon hwmon1: Voltage normalised
      [Tue May 31 23:57:55 2022] hwmon hwmon1: Undervoltage detected!
      [Tue May 31 23:58:02 2022] hwmon hwmon1: Voltage normalised
      [Tue May 31 23:59:48 2022] usb 1-1.2: new full-speed USB device number 13 using xhci_hcd
      [Tue May 31 23:59:48 2022] usb 1-1.2: device descriptor read/64, error -32
      [Tue May 31 23:59:48 2022] usb 1-1.2: new full-speed USB device number 14 using xhci_hcd
      [Tue May 31 23:59:49 2022] usb 1-1.2: device descriptor read/64, error -32
      [Tue May 31 23:59:49 2022] usb 1-1-port2: attempt power cycle
      [Tue May 31 23:59:50 2022] usb 1-1.2: new full-speed USB device number 15 using xhci_hcd
      [Tue May 31 23:59:50 2022] usb 1-1.2: Device not responding to setup address.
      [Tue May 31 23:59:50 2022] usb 1-1.2: device not accepting address 15, error -71
      [Tue May 31 23:59:50 2022] usb 1-1.2: new full-speed USB device number 16 using xhci_hcd
      [Tue May 31 23:59:51 2022] usb 1-1.2: device not accepting address 16, error -71
      [Tue May 31 23:59:51 2022] usb 1-1-port2: unable to enumerate USB device
      P
      Prince3k
      5V und 3 A, also bestell ich gleich mal eins mit 4 A
      P
      Prince3k
