    2. icke2002
    I
    • Posts 37
    icke2002
    @icke2002
    37
    icke2002 Follow
    Best posts made by icke2002
    • RE: Anfrage zu solax Adapter für Solax X1 Mini 1.5 G4
      @simatec
      solaxRequest: {"success":true,"exception":"Query success!","result":{"inverterSN":"XXXXXXXXXXXXX","sn":"XXXXXXXXXX","acpower":1124,"yieldtoday":1.9,"yieldtotal":62.5,"feedinpower":780,"feedinenergy":33.37,"consumeenergy":153.33,"inverterType":"22","inverterStatus":"102","uploadTime":"2024-06-27 11:00:01","powerdc1":1145,"batStatus":null},"code":0}
      request-result: {"success":true,"exception":"Query success!","result":{"inverterSN":"XXXXXXXXXXXXX","sn":"XXXXXXXXXX","acpower":1124,"yieldtoday":1.9,"yieldtotal":62.5,"feedinpower":780,"feedinenergy":33.37,"consumeenergy":153.33,"feedinpowerM2":null,"soc":null,"peps1":null,"peps2":null,"peps3":null,"inverterType":"22","inverterStatus":"102","uploadTime":"2024-06-27 11:00:01","batPower":null,"powerdc1":1145,"powerdc2":0,"powerdc3":0,"powerdc4":0,"batStatus":null},"code":0}
      local request: {"sn":"XXXXXXXXXX","ver":"3.015.02","type":22,"Data":[2311,48,4998,1129,1206,0,0,10,95,0,2,0,0,1149,0,0,0,0,0,625,0,19,1500,62,54,0,1,0,1372,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,796,0,3338,0,15333,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"Information":[1.5,22,"XXXXXXXXXXXXXX",8,0.21,0,0.23,0,0,1]}
      I
      icke2002
    Latest posts made by icke2002
      @simatec sieht erstmal ganz gut aus. Die Bedeutung von feedinenergy könnte (Gesamteinspeisung sein?) und totalFeed (diesen Wert kann ich im Moment gar nicht zuordnen?) erschließt sich mir noch nicht.
      I
      icke2002
      @simatec Was mir noch aufgefallen ist:
      1. der Wert für Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte vom Wert her Total Feed-in Energy entsprechen.
        2.Total Feed-in Energy ist ebenfalls um den Faktor 10 zu hoch und sollte der tägliche Feed-in Energy sein.
      den Rest versuche ich morgen bei Sonnenschein nochmal überprüfen - eventuell gleich mit Version 0.9.9
      I
      icke2002
      @simatec consumeenergy ist noch um den Faktor 10 zu hoch - sollte ca. 154 kWh sein.
      I
      icke2002
      @homoran ich weiss leider nicht, wie es besser geht - es wird noch dem Einfügen immer auf resized gesetzt?
      I
      icke2002
      @simatec schein erstmal ok zu sein - werde ich morgen nochmal prüfen, wenn mehr Sonne ist.
      Ich will das Ganze dann sowieso auf einer Raspi4 zum Laufen bringen. Ich habe heute auf jeden Fall viel gelernt - danke nochmal!
      I
      icke2002
      @simatec
      I
      icke2002
      @simatec nach der git -Installation konnte ich den Adapter installieren und jetzt läuft es!
      Super - Danke!👍 👍 👍
      I
      icke2002
      @homoran Ich hatte gesucht - aber nicht gefunden - Danke für den Tip. Nach Neustart lief die Installation!👍 😳
      I
      icke2002
      @homoran ok - danke - wie kann ich das Problem als newbee lösen?
      I
      icke2002
      @simatec Wird leider immer schlimmer!?
      Die Version 0.9.7 von npm lässt sich installieren - fehlt bei mir irgendetwas?
      Punkt 13 und 18 - 23 - ich verstehe es nicht!
      0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
      1 info using npm@10.7.0
      2 info using node@v20.15.0
      3 silly config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc
      4 silly config:load:file:C:\ioBroker\.npmrc
      5 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc
      6 silly config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc
      7 verbose title npm install simatec/ioBroker.solax
      8 verbose argv "install" "simatec/ioBroker.solax"
      9 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-
      10 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      13 verbose stack Error: An unknown git error occurred
      13 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
      13 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
      13 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      14 verbose cwd C:\ioBroker
      15 verbose Windows_NT 10.0.19045
      16 verbose node v20.15.0
      17 verbose npm  v10.7.0
      18 error code ENOENT
      19 error syscall spawn git
      20 error path git
      21 error errno -4058
      22 error enoent An unknown git error occurred
      23 error enoent This is related to npm not being able to find a file.
      23 error enoent
      24 verbose exit -4058
      25 verbose code -4058
      26 silly unfinished npm timer reify 1719507201733
      27 silly unfinished npm timer reify:loadTrees 1719507201739
      28 silly unfinished npm timer idealTree:userRequests 1719507201999
      29 error A complete log of this run can be found in: C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2024-06-27T16_53_21_153Z-debug-0.log
      I
      icke2002
