    2. Schöni
    • Posts 7
    Schöni
    @Schöni
    Schöni Follow
    Latest posts made by Schöni
    • RE: Installation bleibt stehen
      OK, auch mit Bookworm bleibt das Ergebunis gleich.
      Und auch die Prozedur zum fixen.
      Schönen Abend noch.
      posted in Installation
      Schöni
      @schöni ```
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: rasp-iobroker3
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 3 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:21:10 up 17 min,  1 user,  load average: 0.55, 0.61, 0.36
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-01-03 19:21:11 CET
                 Universal time: Wed 2024-01-03 18:21:11 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            909M        120M        322M        0.0K        466M        726M
      Swap:            99M          0B         99M
      Total:          1.0G        120M        422M
                909 M total memory
                120 M used memory
                181 M active memory
                310 M inactive memory
                322 M free memory
                 27 M buffer memory
                438 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       14G  2.3G   12G  18% /
      devtmpfs       devtmpfs  325M     0  325M   0% /dev
      tmpfs          tmpfs     455M     0  455M   0% /dev/shm
      tmpfs          tmpfs     182M  960K  181M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Wed Jan  3 19:03:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e6eaa33f-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jan  3 19:03:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jan  3 19:03:20 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Jan  3 19:03:23 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      485M    /var/
      182M    /var/cache
      176M    /var/cache/apt
      155M    /var/lib
      130M    /var/lib/apt/lists
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      19M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.1M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : rasp-iobroker1                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : rasp-iobroker2                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : rasp-iobroker1                           -  enabled
        system.adapter.daswetter.0              : daswetter             : rasp-iobroker1                           -  enabled
      + system.adapter.discovery.0              : discovery             : rasp-iobroker1                           -  enabled
        system.adapter.email.0                  : email                 : rasp-iobroker1                           - disabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: rasp-iobroker2                           -  enabled
      + system.adapter.fahrplan.0               : fahrplan              : rasp-iobroker2                           -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : rasp-iobroker1                           - disabled
        system.adapter.feiertage.0              : feiertage             : rasp-iobroker1                           -  enabled
        system.adapter.flot.0                   : flot                  : rasp-iobroker2                           - disabled
      + system.adapter.fritzbox.0               : fritzbox              : rasp-iobroker1                           -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : rasp-iobroker1                           -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : rasp-iobroker1                           -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : rasp-iobroker1                           -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : rasp-iobroker1                           -  enabled, port: 12010
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: rasp-iobroker1                           - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : rasp-iobroker1                           - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : rasp-iobroker1                           - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : rasp-iobroker1                           - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : rasp-iobroker1                           - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rasp-iobroker1                           - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: rasp-iobroker1                           - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : rasp-iobroker1                           - disabled
      + system.adapter.info.0                   : info                  : rasp-iobroker1                           -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : rasp-iobroker2                           -  enabled
      + system.adapter.javascript.0             : javascript            : rasp-iobroker1                           -  enabled
        system.adapter.lgtv.0                   : lgtv                  : rasp-iobroker1                           - disabled
      + system.adapter.modbus.0                 : modbus                : rasp-iobroker2                           -  enabled
      + system.adapter.modbus.1                 : modbus                : rasp-iobroker2                           -  enabled
      + system.adapter.ping.0                   : ping                  : rasp-iobroker1                           -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : rasp-iobroker1                           -  enabled
      + system.adapter.rpi2.1                   : rpi2                  : rasp-iobroker2                           -  enabled
        system.adapter.smartgarden.0            : smartgarden           : rasp-iobroker2                           - disabled
      + system.adapter.sql.0                    : sql                   : rasp-iobroker1                           -  enabled, port: 3306
      + system.adapter.stiebel-isg.0            : stiebel-isg           : rasp-iobroker2                           -  enabled
      + system.adapter.synology.0               : synology              : rasp-iobroker1                           -  enabled, port: 5001
      + system.adapter.tr-064.0                 : tr-064                : rasp-iobroker1                           -  enabled
        system.adapter.vis-bars.0               : vis-bars              : rasp-iobroker1                           - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rasp-iobroker1                           - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : rasp-iobroker1                           - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rasp-iobroker1                           - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : rasp-iobroker1                           -  enabled
        system.adapter.vis-history.0            : vis-history           : rasp-iobroker1                           - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rasp-iobroker1                           - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rasp-iobroker1                           - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : rasp-iobroker1                           - disabled
        system.adapter.vis-map.0                : vis-map               : rasp-iobroker1                           - disabled
        system.adapter.vis-metro.0              : vis-metro             : rasp-iobroker1                           - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasp-iobroker1                           - disabled
        system.adapter.vis-weather.0            : vis-weather           : rasp-iobroker2                           - disabled
        system.adapter.vis.0                    : vis                   : rasp-iobroker2                           -  enabled
      + system.adapter.web.0                    : web                   : rasp-iobroker1                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : rasp-iobroker2                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : rasp-iobroker2                           -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "discovery"    : 4.2.0    , installed 4.2.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Objects and States
      Objects:        12696
      States:         11009
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13267      510/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13269      510/sshd: /usr/sbin
      udp        0      0 0.0.0.0:37045           0.0.0.0:*                           108        3965       388/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3963       388/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12246      617/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        3964       388/avahi-daemon: r
      udp6       0      0 :::47211                :::*                                108        3966       388/avahi-daemon: r
      2024-01-03 19:20:27.112  - info: backitup.0 (656) Terminated (NO_ERROR): Without reason
      2024-01-03 19:20:27.113  - info: host.rasp-iobroker3 stopInstance system.adapter.discovery.0 send kill signal
      2024-01-03 19:20:27.114  - info: host.rasp-iobroker3 stopInstance system.adapter.backitup.0 send kill signal
      2024-01-03 19:20:27.117  - info: admin.0 (630) Terminated (NO_ERROR): Without reason
      2024-01-03 19:20:27.152  - info: discovery.0 (637) terminating
      2024-01-03 19:20:27.156  - info: discovery.0 (637) Terminated (NO_ERROR): Without reason
      2024-01-03 19:20:27.570  - info: backitup.0 (656) terminating
      2024-01-03 19:20:27.579  - info: admin.0 (630) terminating
      2024-01-03 19:20:27.583  - info: discovery.0 (637) terminating
      2024-01-03 19:20:27.776  - info: host.rasp-iobroker3 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-01-03 19:20:27.820  - info: host.rasp-iobroker3 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-01-03 19:20:27.854  - info: host.rasp-iobroker3 instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
      2024-01-03 19:20:27.856  - info: host.rasp-iobroker3 All instances are stopped.
      2024-01-03 19:20:27.930  - info: host.rasp-iobroker3 terminated
      2024-01-03 19:20:32.501  - info: host.rasp-iobroker3 iobroker.js-controller version 5.0.17 js-controller starting
      2024-01-03 19:20:32.514  - info: host.rasp-iobroker3 Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-01-03 19:20:32.516  - info: host.rasp-iobroker3 hostname: rasp-iobroker3, node: v18.19.0
      2024-01-03 19:20:32.517  - info: host.rasp-iobroker3 ip addresses: 172.18.3.219 fe80::90fa:1132:10aa:75a0
      2024-01-03 19:20:32.991  - info: host.rasp-iobroker3 connected to Objects and States
      2024-01-03 19:20:33.046  - info: host.rasp-iobroker3 Node.js version has changed from unknown to 18.19.0
      2024-01-03 19:20:33.155  - info: host.rasp-iobroker3 added notifications configuration of host
      2024-01-03 19:20:33.169  - info: host.rasp-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2024-01-03 19:20:33.612  - info: host.rasp-iobroker3 Instance system.adapter.admin.0 removed from host, clear notifications
      2024-01-03 19:20:34.792  - info: host.rasp-iobroker3 55 instances found
      2024-01-03 19:20:34.870  - warn: host.rasp-iobroker3 does not start any instances on this host
      mmmhh, stelle grad fest, daß hier noch Bullseye drauf ist.
      Blöd.
      Also nochmal von vorn...
      Schöni
      1. Session hat keinen Login Prompt erzeugt... Keine Meldungen
        Der Pi war aber im Netz sichtbar. Die Sessions waren aktiv.
      Nun habe ich einen harten Reboot durchgeführt.
      Pi wieder gestartet.
      Nodejs Version überprüft - korrekt.
      Install-fix laufen lassen.
      Danach die Installtion nochmal gestartet und 5 Minuten später war alles erfolgreich erledigt.
      Nun kann ich weiter machen.
      Sehr komisch, aber danke für die Unterstützung.
      Ralf
      Schöni
      @marc-berg
      da ist nix abgeschnitten, mehr steht nich im Terminal:
      Kann ich die Installation irgendwie abbrechen und die node-js überprüfen?
      Schöni
      @schöni
      Im Web Browser erscheint bei
      https://registry.npmjs.org/iobroker.admin/-/iobroker.admin
      die Meldung:
      Welche Alternativen?
      Schöni
      @homoran, das ist ein Pi 3B.
      Ist es denn "normal", daß die Webseite mit "ResourceNotFound" antwortet?
      An dem Punkt der Installation steht er nun seit knapp 3 Stunden...
      Schöni
    • Installation bleibt stehen
      Hallo zusammen und ein gutes Neues!
      Ich bin grade dabei meine Raspis mit neuem OS zu versehen:
      Raspberry Pi OS Lite (Bookworm)
      Nun bleibt heute die Installation nach Eingabe von "curl -sLf https://iobroker.net/install.sh | bash -" bei Punkt 3/4 stehen.
          Installing ioBroker (3/4)
      (##################) ⠇ reify:iobroker.admin: http fetch GET 200 https://registry.npmjs.org/iobroker.admin/-/iobroker.admin
      Gestern hat das ganze auf einem anderen Raspi noch funktioniert.
      Die Webseite "https://registry.npmjs.org/iobroker.admin/-/iobroker.admin" reagiert mit einem:
      code	"ResourceNotFound"
      message	"/iobroker.admin/-/iobroker.admin does not exist"
      Hier bleibt die Installation einfach stehen, kann nicht abgebrochen werden, neue SSH Session bekommt kein Login.
      Habt ihr hier Ideen, was ich falsch mache?
      Ralf
      Schöni
