    2. Koenigpils
    K
    • Posts 8
    Koenigpils
    @Koenigpils
    Koenigpils Follow
    Latest posts made by Koenigpils
    • RE: [Frage] Samsung Klimaanlage Adapter
      @schranzistor
      Hallo iobroker
      Ich brauche Hilfe komme alleine nicht weiter.
      Homebridge mit plugin ist installiert aber ich kann unter Objekte keine Klimaanlage finden.
      Für Tipps währe ich sehr dankbar.
      2022-03-30 14:11:42.992 - error: javascript.0 (800) Alias subscription error. Please check your alias definitions: sourceId=system.adapter.ham.0.inputCount, sourceObj={"_id":"system.adapter.ham.0.inputCount","type":"state","common":{"name":"ham.0 events input counter","desc":"State's inputs in 15 seconds","type":"number","read":true,"write":false,"role":"state","unit":"events/15 seconds"},"native":{},"from":"system.adapter.ham.0","ts":1648624294193,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
      2022-03-30 16:02:27.453 - info: host.iobroker-pi "system.adapter.ham.0" enabled
      2022-03-30 16:02:27.727 - info: host.iobroker-pi instance system.adapter.ham.0 started with pid 11727
      2022-03-30 16:02:32.348 - info: ham.0 (11727) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.19.0, js-controller: 4.0.21
      2022-03-30 16:02:32.406 - info: ham.0 (11727) Need to install/update homebridge@1.3.4
      2022-03-30 16:02:32.409 - info: ham.0 (11727) npm install homebridge@1.3.4 --production --loglevel error (System call)
      2022-03-30 16:03:46.259 - info: ham.0 (11727) + homebridge@1.3.4
      added 291 packages from 163 contributors and audited 292 packages in 67.465s
      2022-03-30 16:03:47.664 - info: ham.0 (11727)
      50 packages are looking for funding
      run npm fund for details
      2022-03-30 16:03:47.668 - info: ham.0 (11727) found 0 vulnerabilities
      2022-03-30 16:03:47.737 - info: ham.0 (11727) Install/Update the following Libraries: homebridge-samsung-air-conditioner-smart-things
      2022-03-30 16:03:47.739 - info: ham.0 (11727) Install/Update homebridge-samsung-air-conditioner-smart-things
      2022-03-30 16:03:47.740 - info: ham.0 (11727) All Libraries installed/updated
      2022-03-30 16:13:59.632 - info: host.iobroker-pi stopInstance system.adapter.ham.0 (force=false, process=true)
      2022-03-30 16:13:59.648 - info: ham.0 (11727) Got terminate signal TERMINATE_YOURSELF
      2022-03-30 16:13:59.649 - info: host.iobroker-pi stopInstance system.adapter.ham.0 send kill signal
      2022-03-30 16:13:59.653 - info: ham.0 (11727) cleaned everything up...
      2022-03-30 16:13:59.668 - info: ham.0 (11727) terminating
      2022-03-30 16:13:59.671 - info: ham.0 (11727) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-03-30 16:14:00.315 - info: host.iobroker-pi instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-03-30 16:14:02.798 - info: host.iobroker-pi instance system.adapter.ham.0 started with pid 12639
      2022-03-30 16:14:08.197 - info: ham.0 (12639) starting. Version 4.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v14.19.0, js-controller: 4.0.21
      2022-03-30 16:14:08.286 - info: ham.0 (12639) Need to install/update homebridge@1.3.4
      2022-03-30 16:14:08.294 - info: ham.0 (12639) Install/Update the following Libraries: homebridge-samsung-air-conditioner-smart-things
      2022-03-30 16:14:08.296 - info: ham.0 (12639) Install/Update homebridge-samsung-air-conditioner-smart-things
      2022-03-30 16:14:08.299 - info: ham.0 (12639) All Libraries installed/updated
      2022-03-30 16:39:46.032 - info: info.0 (1204) Reading/updating systemdata.
      2022-03-30 16:39:47.517 - info: info.0 (1204) cpu Temp res = {"main":55.844,"cores":[],"max":55.844,"socket":[],"chipset":null}
      2022-03-30 16:47:50.887 - info: admin.0 (2425) Request actual repository...
      2022-03-30 16:4
      K
      Koenigpils
    • RE: Modbus Adapter: Poll error count e3dc S10
      @koenigpils
      Hallo Wendy
      Habe es hinbekommen
      Pollzeit 60000ms
      Vielen Dank für deine Unterstützung. 👍
      K
      Koenigpils
      @wendy2702
      Geht wieder ,tausend Dank
      64 bytes from 192.168.8.44: icmp_seq=1 ttl=255 time=3.90 ms
      64 bytes from 192.168.8.44: icmp_seq=2 ttl=255 time=5.49 ms
      64 bytes from 192.168.8.44: icmp_seq=3 ttl=255 time=4.07 ms
      64 bytes from 192.168.8.44: icmp_seq=4 ttl=255 time=4.13 ms
      64 bytes from 192.168.8.44: icmp_seq=5 ttl=255 time=3.16 ms
      64 bytes from 192.168.8.44: icmp_seq=6 ttl=255 time=2.89 ms
      64 bytes from 192.168.8.44: icmp_seq=7 ttl=255 time=13.9 ms
      64 bytes from 192.168.8.44: icmp_seq=8 ttl=255 time=3.43 ms
      64 bytes from 192.168.8.44: icmp_seq=9 ttl=255 time=3.79 ms
      64 bytes from 192.168.8.44: icmp_seq=10 ttl=255 time=3.56 ms
      64 bytes from 192.168.8.44: icmp_seq=11 ttl=255 time=4.80 ms
      64 bytes from 192.168.8.44: icmp_seq=12 ttl=255 time=8.21 ms
      64 bytes from 192.168.8.44: icmp_seq=13 ttl=255 time=3.36 ms
      64 bytes from 192.168.8.44: icmp_seq=14 ttl=255 time=4.06 ms
      64 bytes from 192.168.8.44: icmp_seq=15 ttl=255 time=9.30 ms
      64 bytes from 192.168.8.44: icmp_seq=16 ttl=255 time=3.81 ms
      64 bytes from 192.168.8.44: icmp_seq=17 ttl=255 time=3.49 ms
      64 bytes from 192.168.8.44: icmp_seq=18 ttl=255 time=4.31 ms
      64 bytes from 192.168.8.44: icmp_seq=19 ttl=255 time=4.69 ms
      64 bytes from 192.168.8.44: icmp_seq=20 ttl=255 time=3.88 ms
      64 bytes from 192.168.8.44: icmp_seq=21 ttl=255 time=6.50 ms
      64 bytes from 192.168.8.44: icmp_seq=22 ttl=255 time=5.00 ms
      64 bytes from 192.168.8.44: icmp_seq=23 ttl=255 time=18.5 ms
      64 bytes from 192.168.8.44: icmp_seq=24 ttl=255 time=4.39 ms
      64 bytes from 192.168.8.44: icmp_seq=25 ttl=255 time=6.01 ms
      64 bytes from 192.168.8.44: icmp_seq=26 ttl=255 time=48.7 ms
      64 bytes from 192.168.8.44: icmp_seq=27 ttl=255 time=3.15 ms
      64 bytes from 192.168.8.44: icmp_seq=28 ttl=255 time=4.83 ms
      64 bytes from 192.168.8.44: icmp_seq=29 ttl=255 time=4.71 ms
      64 bytes from 192.168.8.44: icmp_seq=30 ttl=255 time=3.19 ms
      64 bytes from 192.168.8.44: icmp_seq=31 ttl=255 time=5.28 ms
      64 bytes from 192.168.8.44: icmp_seq=32 ttl=255 time=3.74 ms
      64 bytes from 192.168.8.44: icmp_seq=33 ttl=255 time=18.8 ms
      MOD Edit: Log in Code Tags
      K
      Koenigpils
      @wendy2702
      habe den Mac erst seit kurzen, ich weiss nicht wie ich da hinkomme.
      K
      Koenigpils
      @wendy2702
      Komme nicht mehr auf meinen Paspy
      The fingerprint for the ED25519 key sent by the remote host is
      SHA256:otCrXLnicRgAwbenAvIfyWvrpov7E6eEK7VZNBjXiJM.
      Please contact your system administrator.
      Add correct host key in /Users/achimpassiep/.ssh/known_hosts to get rid of this message.
      Offending ECDSA key in /Users/achimpassiep/.ssh/known_hosts:3
      Host key for 192.168.8.35 has changed and you have requested strict checking.
      Host key verification failed.
      achimpassiep@Mac-mini-von-Achim ~ %
      Last login: Sun Mar 13 17:56:00 on ttys000
      achimpassiep@Mac-mini-von-Achim ~ % ssh pi@192.168.8.35
      @    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
      IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
      Someone could be eavesdropping on you right now (man-in-the-middle attack)!
      It is also possible that a host key has just been changed.
      K
      Koenigpils
      @wendy2702
      Neustart habe ich schon öfter gemacht.
      Ich hoffe das ich die Pingzeiten richt darstelle.
      Last login: Sun Mar 13 17:39:00 on ttys000
      achimpassiep@Mac-mini-von-Achim ~ % ping 192.168.8.44
      PING 192.168.8.44 (192.168.8.44): 56 data bytes
      64 bytes from 192.168.8.44: icmp_seq=0 ttl=255 time=7.551 ms
      64 bytes from 192.168.8.44: icmp_seq=1 ttl=255 time=12.303 ms
      64 bytes from 192.168.8.44: icmp_seq=2 ttl=255 time=7.255 ms
      64 bytes from 192.168.8.44: icmp_seq=3 ttl=255 time=111.964 ms
      64 bytes from 192.168.8.44: icmp_seq=4 ttl=255 time=7.291 ms
      64 bytes from 192.168.8.44: icmp_seq=5 ttl=255 time=9.604 ms
      64 bytes from 192.168.8.44: icmp_seq=6 ttl=255 time=4.741 ms
      64 bytes from 192.168.8.44: icmp_seq=7 ttl=255 time=7.498 ms
      64 bytes from 192.168.8.44: icmp_seq=8 ttl=255 time=6.295 ms
      64 bytes from 192.168.8.44: icmp_seq=9 ttl=255 time=6.520 ms
      64 bytes from 192.168.8.44: icmp_seq=10 ttl=255 time=6.082 ms
      64 bytes from 192.168.8.44: icmp_seq=11 ttl=255 time=9.055 ms
      64 bytes from 192.168.8.44: icmp_seq=12 ttl=255 time=7.106 ms
      64 bytes from 192.168.8.44: icmp_seq=13 ttl=255 time=6.613 ms
      64 bytes from 192.168.8.44: icmp_seq=14 ttl=255 time=27.431 ms
      64 bytes from 192.168.8.44: icmp_seq=15 ttl=255 time=7.738 ms
      64 bytes from 192.168.8.44: icmp_seq=16 ttl=255 time=6.470 ms
      64 bytes from 192.168.8.44: icmp_seq=17 ttl=255 time=18.053 ms
      64 bytes from 192.168.8.44: icmp_seq=18 ttl=255 time=44.237 ms
      64 bytes from 192.168.8.44: icmp_seq=19 ttl=255 time=8.979 ms
      64 bytes from 192.168.8.44: icmp_seq=20 ttl=255 time=7.036 ms
      64 bytes from 192.168.8.44: icmp_seq=21 ttl=255 time=9.036 ms
      64 bytes from 192.168.8.44: icmp_seq=22 ttl=255 time=6.447 ms
      64 bytes from 192.168.8.44: icmp_seq=23 ttl=255 time=13.222 ms
      64 bytes from 192.168.8.44: icmp_seq=24 ttl=255 time=7.086 ms
      K
      Koenigpils
      @wendy2702
      Hallo
      Das ist TCP an einem PE 11
      K
      Koenigpils
      @meisterf said in Modbus Adapter: Poll error count e3dc S10:
      Ichh abe den Fehler auch - der Adapter liefert ordentliche Werte, aber er müllt auch das log zu:
      K
      Koenigpils
