    2. gdow1895
    G
    • Posts 61
    gdow1895
    @gdow1895
    61
    gdow1895 Follow
    Best posts made by gdow1895
    • RE: GELÖST-Backitup auf Raspi verbindet sich nicht mit Synology
      @glasfaser
      DANKE!!!
      Auch an alle anderen, die mir die ganze Zeit über mit Rat und Tat geholfen haben. Ich vermute, dass sich tatsächlich ein Problem auf der Synology eingeschlichen hatte (vielleicht beim Update auf die DSM 6.2.4?!)
      -> Lösung: Synology Backup durchgeführt -> Synology zurückgesetzt -> DSM neu installiert -> Benutzer und Ordner neu eingerichtet -> Berechtigungen geprüft -> funktioniert 🙂 🙂 🙂
      Hier noch die finalen Logs. 1) ioBroker und 2) Homematic-CCU
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****"}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.56/backups/iobroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.raspberrypi4-iob 2643 states saved
      [DEBUG] [iobroker] - host.raspberrypi4-iob 2777 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_01_01-21_35_15_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2022_01_01-21_35_15_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"01. Januar 2022 um 21:35 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2022_01_01-21_35_15_backupiobroker.tar.gz"],"errors":{},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"01. Januar 2022 um 21:35 Uhr"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/iobroker","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
      Started ccu ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****"}
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=backupuser,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.56/backups/ccu /opt/iobroker/backups"
      [DEBUG] [ccu] - CCU-Backup started ...
      [DEBUG] [ccu] start with {"type":"creator","time":"01:30","debugging":true,"everyXDays":"3","deleteBackupAfter":0,"signedCertificates":true,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"host":"192.168.178.61","user":"Admin","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [ccu] - CCU Version: 3.61.6
      [DEBUG] [ccu] - Requesting backup from CCU
      [DEBUG] [ccu] - CCU-Backup for is finish
      [DEBUG] [ccu] - done
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","ccuEvents":[],"deleteBackupAfter":0}
      [DEBUG] [historyHTML] start with {"type":"creator","time":"01:30","debugging":true,"everyXDays":"3","deleteBackupAfter":0,"signedCertificates":true,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/homematic_2022_01_01-21_41_13_3.61.6_backupiobroker.tar.sbk"],"errors":{},"done":["mount","ccu"],"types":["homematic"]},"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"01. Januar 2022 um 21:41 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"host":"192.168.178.61","user":"Admin","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"01:30","debugging":true,"everyXDays":"3","deleteBackupAfter":0,"signedCertificates":true,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","context":{"fileNames":["/opt/iobroker/backups/homematic_2022_01_01-21_41_13_3.61.6_backupiobroker.tar.sbk"],"errors":{},"done":["mount","ccu"],"types":["homematic"]},"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"01. Januar 2022 um 21:41 Uhr"},"host":"192.168.178.61","user":"Admin","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.178.56","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backups/ccu","dirMinimal":"backups/iobroker","user":"backupuser","pass":"****","backupDir":"/opt/iobroker/backups","ccuEvents":[]}
      [EXIT] 0
      G
      gdow1895
    Latest posts made by gdow1895
      @homoran sagte in GELÖST-Backitup auf Raspi verbindet sich nicht mit Synology:
      @gdow1895 sagte in Backitup auf Raspi verbindet sich nicht mit Synology:
      das hätte wahrscheinlich gereicht
      Leider nicht. Ich weiß gar nicht wie oft ich im ganzen Prozess Ordner und Benutzer neu angelegt habe.. 🙂 Aber egal, jetzt funktioniert es ja!
      G
      gdow1895
      @glasfaser
      DANKE!!!
      [EXIT] 0
      Started ccu ...
      [EXIT] 0
      G
      gdow1895
      @glasfaser Daumen drücken... Einstellungen sind geändert und der Adapter ist neu gestartet. Bis jetzt noch keine Fehlermeldung. Werde noch ein paar Minuten warten, manchmal kamen die verzögert. Danach werde ich mal manuell die Backups auslösen.
      G
      gdow1895
      @Glasfaser Soooo, wie schon geschrieben DSM 7 ist installiert und die ersten Setups neu aufgesetzt.
      showmount zeigt nun folgendes:
      pi@raspberrypi4-iob:~ $ showmount -e 192.168.178.56
      Export list for 192.168.178.56:
      /volume1/backups 192.168.178.47
      EDIT: Damit sollte doch jetzt auch die SMB/CIFS-Verbindung klappen, oder?
      G
      gdow1895
      SMB-Version: Stört aber auch nicht wenn ich es drin lasse oder? Für das funktionierende Backup mit der Fritz!Box ist ja 3.1.1 eingestellt.
      /etc/hosts: Dann lasse ich es raus
      @Glasfaser Nein, auch nicht bei alle Pakete. Scheint ein Paket ab DSM-7 zu sein
      G
      gdow1895
      @glasfaser Das Paket gibt es nicht unter meiner DSM Version (DSM 6.2.4-25556 Update 2)
      G
      gdow1895
      @thomas-braun Weiter oben waren bspw. @da_Woody und @Glasfaser ja schon sehr fleißig mit dem Abgleich der Einstellungen, was aber bisher leider nicht geholfen hat 😞
      Wenn du die SMB-Versionen meinst habe ich SMB 1.0 bis SMB 3.0 auf der Synology aktiviert.
      Soll ich denn mal noch die IP-Adresse unter /etc/hosts eintragen?
      G
      gdow1895
      @thomas-braun Schade... 😞
      G
      gdow1895
      @thomas-braun Wie kann ich das überprüfen? Die Bedienoberfläche sagt mir ja, dass SMB aktiviert ist...
      G
      gdow1895
      @thomas-braun Das ist das Ergebnis für meine Fritz!Box:
      pi@raspberrypi4-iob:~ $ smbclient -L 192.168.178.1 -U backup
      Unable to initialize messaging context
      Enter WORKGROUP\backup's password:
      	Sharename       Type      Comment
      	IPC$            IPC       IPC Service
      	FRITZ.NAS       Disk      FRITZ!Box
      Reconnecting with SMB1 for workgroup listing.
      	Server               Comment
      	Workgroup            Master
      EDIT: Ich habe mir für die Fritz!Box (192.168.178.1) und die Synology (192.168.178.56) unterschiedliche Benutzer angelegt, um nicht durcheinander zu kommen...
      G
      gdow1895
