@thomas-braun Kompletter PI? Habe noch mehr darauf laufen...
Gibt es keine Alternative?
Latest posts made by Chris-D 0
RE: IoBroker reagiert nicht mehrposted in Error/Bug
@thomas-braun Danke für den Hinweis. Wie genau mache ich das?
Mein IOBROKER ist nicht mehr erreichbar.
Morgens aufgewacht und IOBROKER ist nicht mehr erreichbar.
IOBROKER FIx hat auch nicht geholfen.pi@raspberrypi:~ $ iobroker update node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: []IOB Diag Ausgabe wie folgt:
======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 10 (buster) Kernel: Linux 5.10.103-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 30 node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob roker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:1 5) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma in:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v16.20.2 /usr/bin/node v16.20.2 /usr/bin/npm 8.19.4 /usr/local/bin/npx 7.20.3 /usr/bin/corepack 0.17.0 Recommended versions are nodejs and npm *** nodejs is NOT correctly installed *** Wrong installation path detected. This needs to be fixed. Please check https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian for more information on how to fix these errors. MEMORY: total used free shared buff/cache available Mem: 3.8G 87M 3.3G 8.0M 438M 3.6G Swap: 99M 0B 99M Total: 3.9G 87M 3.4G node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Active iob-Instances: 0 node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } ioBroker Core: js-controller node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } admin node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } ioBroker Status: Status admin and web instance: node:internal/modules/cjs/loader:1031 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15) at Function.Module._load (node:internal/modules/cjs/loader:873:27) at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) at node:internal/main/run_main_module:22:47 { code: 'MODULE_NOT_FOUND', requireStack: [] } Objects: 0 States: 0 Size of iob-Database: 14M /opt/iobroker/iobroker-data/objects.jsonl 7.6M /opt/iobroker/iobroker-data/objects.json.migrated 7.6M /opt/iobroker/iobroker-data/objects.json.bak.migrated 0 /opt/iobroker/iobroker-data/objects.json.broken 8.1M /opt/iobroker/iobroker-data/states.jsonl 1020K /opt/iobroker/iobroker-data/states.json.migrated 1020K /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.brokenWas kann ich machen?
VIS will Passwort habenposted in Visualisierung
Beim Klicken auf ein beliebiges Widget will der VIS Editor ein Passwort haben. Ich habe aber keins eingerichtet - siehe Screenshot
Jemand eine Idee? -
RE: VIS und HAP Panel laden nichtposted in Visualisierung
@wendy2702 Gestern konnte ich beim WEB und Socket.io Adapter ein Update einspielen, danach ging es. Danke für Eure Hilfe
@wendy2702 Naja aber ich habe ja die Vermutung, dass ich downgraden (und nicht wie auf deinem Foto upgraden) muss und nicht upgraden wegen Kompatibilität. Hier nochmal das Foto:
@wendy2702 In Iobroker direkt? Muss ich heute Abend mal gucken
danke dir
