@wendy2702 fehlen noch irgendwelche Angaben .... ?
Danke u. Gruß
Stefan
Latest posts made by Kochenmitmusik
RE: no connection to databases possibleposted in ioBroker Allgemein
@wendy2702 said in no connection to databases possible:
which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs ls -la /opt/iobroker
Objects type: file States type: redis rock64@rock64:~$ iobroker -v 3.2.14 rock64@rock64:~$ iobroker list instances + system.adapter.admin.0 : admin : rock64 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : rock64 - enabled + system.adapter.backitup.0 : backitup : rock64 - enabled + system.adapter.countdown.0 : countdown : rock64 - disabled + system.adapter.cul.0 : cul : rock64 - enabled, port: 23 + system.adapter.daswetter.0 : daswetter : rock64 - disabled + system.adapter.discovery.0 : discovery : rock64 - disabled system.adapter.dwd.0 : dwd : rock64 - disabled system.adapter.habpanel.0 : habpanel : rock64 - disabled + system.adapter.ham.0 : ham : rock64 - enabled + system.adapter.harmony.0 : harmony : rock64 - enabled + system.adapter.history.0 : history : rock64 - enabled + system.adapter.hm-rega.0 : hm-rega : rock64 - enabled + system.adapter.hm-rpc.0 : hm-rpc : rock64 - enabled, port: 12001 + system.adapter.hm-rpc.1 : hm-rpc : rock64 - enabled, port: 12010 system.adapter.hm-rpc.2 : hm-rpc : rock64 - disabled, port: 0 + system.adapter.hm-rpc.3 : hm-rpc : rock64 - enabled, port: 18701 + system.adapter.hm-rpc.4 : hm-rpc : rock64 - enabled, port: 12010 + system.adapter.hue.0 : hue : rock64 - enabled, port: 80 + system.adapter.ical.0 : ical : rock64 - disabled + system.adapter.iot.0 : iot : rock64 - enabled + system.adapter.javascript.0 : javascript : rock64 - enabled system.adapter.mihome.0 : mihome : rock64 - disabled, port: 9898, bind: 0.0.0.0 system.adapter.mobile.0 : mobile : rock64 - disabled system.adapter.nanoleaf-lightpanels.0 : nanoleaf-lightpanels : rock64 - disabled, port: 16021 system.adapter.netatmo-crawler.0 : netatmo-crawler : rock64 - disabled + system.adapter.nuki-extended.1 : nuki-extended : rock64 - disabled system.adapter.nuki.0 : nuki : rock64 - disabled system.adapter.openweathermap.0 : openweathermap : rock64 - disabled + system.adapter.ping.0 : ping : rock64 - enabled + system.adapter.plex.0 : plex : rock64 - enabled + system.adapter.pushover.0 : pushover : rock64 - enabled + system.adapter.scenes.0 : scenes : rock64 - enabled + system.adapter.socketio.0 : socketio : rock64 - disabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.spotify-premium.0 : spotify-premium : rock64 - disabled system.adapter.synology.0 : synology : rock64 - disabled, port: 5000 + system.adapter.tradfri.0 : tradfri : rock64 - disabled + system.adapter.tuya.0 : tuya : rock64 - enabled system.adapter.unifi.0 : unifi : rock64 - disabled system.adapter.vis-bars.0 : vis-bars : rock64 - disabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : rock64 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : rock64 - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : rock64 - disabled system.adapter.vis-lcars.0 : vis-lcars : rock64 - disabled system.adapter.vis-metro.0 : vis-metro : rock64 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : rock64 - disabled system.adapter.vis-weather.0 : vis-weather : rock64 - disabled system.adapter.vis.0 : vis : rock64 - disabled + system.adapter.web.0 : web : rock64 - disabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.windows-control.0 : windows-control : rock64 - enabled + system.adapter.yahka.0 : yahka : rock64 - enabled system.adapter.yr.0 : yr : rock64 - enabled + instance is alive rock64@rock64:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v10.24.0 /usr/bin/node v10.24.0 /usr/bin/npm 6.14.11 nodejs: Installed: 10.24.0-1nodesource1 Candidate: 10.24.0-1nodesource1 Version table: *** 10.24.0-1nodesource1 500 500 https://deb.nodesource.com/node_10.x stretch/main arm64 Packages 100 /var/lib/dpkg/status 4.8.2~dfsg-1 500 500 http://cdn.debian.net/debian stretch/main arm64 Packages rock64@rock64:~$ ls -la /opt/iobroker total 112 drwxrwxrwx+ 6 iobroker iobroker 4096 Mar 16 08:30 . drwxr-xr-x 3 root root 4096 Nov 19 2018 .. -rwxrwxrwx+ 1 iobroker iobroker 109 Feb 28 09:26 .npmrc -rwxrwxrwx+ 1 iobroker iobroker 208 Feb 28 09:27 INSTALLER_INFO.txt drwxrwxr-x+ 2 iobroker iobroker 4096 Mar 17 09:00 backups -rwxrwxrwx+ 1 iobroker iobroker 297 Nov 19 2018 install.sh lrwxrwxrwx 1 iobroker iobroker 22 Feb 28 09:27 iob -> /opt/iobroker/iobroker -rwxr-xr-x+ 1 iobroker iobroker 305 Feb 28 09:27 iobroker drwxrwxrwx+ 11 iobroker iobroker 4096 Mar 17 13:06 iobroker-data -rwxrwxrwx+ 1 iobroker iobroker 92 Nov 19 2018 killall.sh drwxrwxrwx+ 2 iobroker iobroker 4096 Mar 17 13:06 log drwxrwxrwx+ 947 iobroker iobroker 36864 Mar 16 08:30 node_modules -rwxrwxrwx+ 1 iobroker iobroker 12666 Nov 19 2018 package-lock.json -rwxrwxrwx+ 1 iobroker iobroker 2427 Mar 16 08:30 package.json -rwxrwxrwx+ 1 iobroker iobroker 5693 Feb 8 08:06 reinstall.js -rwxrwxrwx+ 1 iobroker iobroker 709 Nov 19 2018 reinstall.sh -
@wendy2702 Sorry aber wie ? gibt es da ein Befehl?
kann mein HOSTS Controller nicht mehr updaten.
nach Eingabe von:
- cd /opt/iobroker
- iobroker stop
- iobroker update kommt folgende Fehlermeldung: no connection to databases possible
Meine Verwahrungsorte: http://download.iobroker.net/sources-dist.json
Alle Rechte sind vorhanden.Danke u. Gruß
Stefan -
RE: Blockly Problemposted in Blockly
1.2.2021, 10:36:37.067 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Stehlampe.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.068 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Stehlampe.level, state={"val":0,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.069 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Tisch.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.070 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Tisch.level, state={"val":5,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.071 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Hue_lightstrip_Wohnzimmer_Reck.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.072 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Hue_lightstrip_Wohnzimmer_Reck.level, state={"val":5,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.074 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Lightstrip_Wohnzimmer.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.075 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Lightstrip_Wohnzimmer.level, state={"val":5,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.076 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Rote_Lampe.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.077 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Rote_Lampe.level, state={"val":5,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:37.096 [warn ]: javascript.0 (24308) at Object.<anonymous> (script.js.common.Plex_AppleTV:15:5) 1.2.2021, 10:36:37.108 [warn ]: javascript.0 (24308) at Object.<anonymous> (script.js.common.Plex_AppleTV:16:5) 1.2.2021, 10:36:41.386 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Stehlampe.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.387 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Stehlampe.level, state={"val":90,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.388 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Tisch.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.390 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Tisch.level, state={"val":90,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.391 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Hue_lightstrip_Wohnzimmer_Reck.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.392 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Hue_lightstrip_Wohnzimmer_Reck.level, state={"val":90,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.394 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Lightstrip_Wohnzimmer.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.395 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Lightstrip_Wohnzimmer.level, state={"val":90,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.396 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Rote_Lampe.on, state={"val":true,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.397 [warn ]: javascript.0 (24308) script.js.common.Plex_AppleTV: setForeignState(id=hue.0.Philips_hue.Rote_Lampe.level, state={"val":90,"ack":false,"c":"script.js.common.Plex_AppleTV"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist 1.2.2021, 10:36:41.402 [warn ]: javascript.0 (24308) at Object.<anonymous> (script.js.common.Plex_AppleTV:28:5) 1.2.2021, 10:36:41.410 [warn ]: javascript.0 (24308) at Object.<anonymous> (script.js.common.Plex_AppleTV:29:5) -
Plex Adapter
habe das Problem bei Play (media.resume) das Licht nicht gedämmt wird. Bei Pause (media.pause) geht das Licht wie gewollt auf 90%)
Gruß und euch ein schönes WE.
RE: [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testenposted in Tester
Erhalte beim Pairing folgende Fehler:
<code>pi@ioBroker-Pi:~ $ sudo npm install -g node-appletv > sodium@2.0.3 preinstall /usr/lib/node_modules/node-appletv/node_modules/sodium > node install.js --preinstall Static libsodium was not found at /usr/lib/node_modules/node-appletv/node_modules/sodium/deps/build/lib/libsodium so compiling libsodium from source. libtool is required, but wasn't found on this system Makefile:61: die Regel für Ziel „libsodium“ scheiterte make: *** [libsodium] Fehler 1 /usr/lib/node_modules/node-appletv/node_modules/sodium/install.js:287 throw new Error(cmdLine + ' exited with code ' + code); ^ Error: make libsodium exited with code 2 at ChildProcess. <anonymous>(/usr/lib/node_modules/node-appletv/node_modules/sodium/install.js:287:19) at emitTwo (events.js:126:13) at ChildProcess.emit (events.js:214:7) at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12) npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! sodium@2.0.3 preinstall: `node install.js --preinstall` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the sodium@2.0.3 preinstall script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-08-24T12_39_20_931Z-debug.log /code]</anonymous></code> -
kann mir mal eine behilflich sein wie ich dieses Plugin (AppleTV) : https://www.npmjs.com/package/homebridge-theater-mode installiere?
Mein Wemo Plugin läuft:
{ "description": "Add configuration for your accessories or platforms according to the docs of the plugins.", "accessories": [], "platforms": [ { "platform": "BelkinWeMo", "name": "WeMo Platform" } ] }Danke.
