@wendy2702 Habe jetzt nochmal einen neuen Benutzer angelegt. Überall Haken gesetzt ohne Erfolg.
Adapter gelöscht und neu installiert.
fb-checkpresence.0 2021-03-07 20:29:50.688 info (9051) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 1 Min. - interval members: 60 s
fb-checkpresence.0 2021-03-07 20:29:50.653 info (9051) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
host.raspberrypi4 2021-03-07 20:29:49.097 info instance system.adapter.fb-checkpresence.0 started with pid 9051
host.raspberrypi4 2021-03-07 20:29:46.593 info instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
fb-checkpresence.0 2021-03-07 20:29:45.974 info (9032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
fb-checkpresence.0 2021-03-07 20:29:45.973 info (9032) terminating
fb-checkpresence.0 2021-03-07 20:29:45.972 error (9032) onUnload: TypeError: Cannot read property 'exitRequest' of null
host.raspberrypi4 2021-03-07 20:29:45.970 info stopInstance system.adapter.fb-checkpresence.0 send kill signal
fb-checkpresence.0 2021-03-07 20:29:45.970 info (9032) Got terminate signal TERMINATE_YOURSELF
host.raspberrypi4 2021-03-07 20:29:45.960 info stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
fb-checkpresence.0 2021-03-07 20:29:11.060 info (9032) start fb-checkpresence: ip-address: "fritz.box" - interval devices: 1 Min. - interval members: 60 s
fb-checkpresence.0 2021-03-07 20:29:11.027 info (9032) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.21.0, js-controller: 3.2.16
host.raspberrypi4 2021-03-07 20:29:09.651 info instance system.adapter.fb-checkpresence.0 started with pid 9032
host.raspberrypi4 2021-03-07 20:29:07.060 info instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
fb-checkpresence.0 2021-03-07 20:29:06.478 info (9003) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
fb-checkpresence.0 2021-03-07 20:29:06.476 info (9003) terminating
fb-checkpresence.0 2021-03-07 20:29:06.475 error (9003) onUnload: TypeError: Cannot read property 'exitRequest' of null
MOD EDIT: LOG IN CODE TAGS </>
