    2. Coolbeer
    C
    • Posts 22
    Coolbeer
    @Coolbeer
    22
    Coolbeer Follow
    Latest posts made by Coolbeer
    • RE: Update JS controller Fehlgeschlagen
      @thomas-braun said in Update JS controller Fehlgeschlagen:
      iobroker upgrade all
      Hat geholfen.....Danke
      Werde ein paar Donate spenden
      C
      Coolbeer
      pi@raspberrypi-iob:/opt/iobroker $ iobroker update
      Used repository: stable
      Adapter    "admin"        : 6.2.22   , installed 6.2.22
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "history"      : 2.2.0    , installed 1.9.14 [Updatable]
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.14.24 [Updatable]
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
      Adapter    "jarvis"       : 3.0.13   , installed 3.0.13
      Adapter    "javascript"   : 6.0.3    , installed 4.8.4  [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "mpd"          : 1.0.6    , installed 1.0.6
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "openweathermap": 0.3.0   , installed 0.1.0  [Updatable]
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "socketio"     : 4.2.0    , installed 3.0.13 [Updatable]
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 4.3.0    , installed 3.1.0  [Updatable]
      MOD-EDIT: Code in code-tags gesetzt! 😡
      C
      Coolbeer
      io brocker Admin update abgebrochen 😞
      kein zugriff mehr 😞
      C
      Coolbeer
      IO Brocker läuft erst mal 🙂 Danke
      C
      Coolbeer
      Alles durchgelaufen
      pi@raspberrypi-iob:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:        Die Datei existiert bereits
      pi@raspberrypi-iob:~ $ uname -m && type -P nodejs node npm && nodejs -v && node        -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/nul        l && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.15.0
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
      /home/pi
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_16.x buster InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.17.1-deb-1nodesource1
        Installationskandidat: 16.17.1-deb-1nodesource1
        Versionstabelle:
       *** 16.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
      C
      Coolbeer
      Lasse das apt upgrade auch noch durchlaufen
      C
      Coolbeer
      sudo apt-get update --allow-releaseinfo-change
      ..dann hats geklappt
      C
      Coolbeer
      Node.js 16 lässt sich nicht installieren.
      Es kommem folgende Meldungen ??
      pi@raspberrypi-iob:/opt/iobroker $ pi@raspberrypi-iob:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
      ## Installing the NodeSource Node.js 16.x repo...
      ## Populating apt-get cache...
      + apt-get update
      OK:1 https://deb.nodesource.com/node_12.x buster InRelease
      Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
      Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »oldstable« geändert.
      N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
      E: Für das Depot »http://raspbian.raspberrypi.org/raspbian-bash: pi@raspberrypi-iob:/opt/iobroker: Datei oder Verzeichnis nicht gefunden
       buster InRelease« wurde der »Suite«-Wert von »stable« in »oldstable« geändert.
      Error executing command, exiting
      C
      Coolbeer
    • Update JS controller Fehlgeschlagen
      Es kann anscheinend Canvas nicht installiert werden. Kann jemand helfen ?
      Hier die Fehlermeldungen.
      pi@raspberrypi-iob:/opt/iobroker $ npm install iobroker.js-controller
      > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > canvas@2.10.1 install /opt/iobroker/node_modules/canvas
      > node-pre-gyp install --fallback-to-build --update-binary
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.1/canvas-v2.10.1-node-v72-linux-glibc-arm.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for canvas@2.10.1 and node@12.22.12 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.10.1/canvas-v2.10.1-node-v72-linux-glibc-arm.tar.gz
      Package cairo was not found in the pkg-config search path.
      Perhaps you should add the directory containing `cairo.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'cairo' found
      gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      gyp ERR! System Linux 5.4.79-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--update-binary" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v12.22.12
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --update-binary --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
      node-pre-gyp ERR! System Linux 5.4.79-v7l+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--update-binary"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v12.22.12
      node-pre-gyp ERR! node-pre-gyp -v v1.0.10
      node-pre-gyp ERR! not ok
      > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Successfully migrated 2991 objects to Redis Sets
      object _design/system updated
        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\n+kv4rqH/aK6CY1LKKa3jft9Tsl+P77C83p8uWdDgVk7ZSajwnoUx\r\n-----END RSA PRIVATE KEY-----\r\n",
        "defaultPublic": "-----BEG....
      =\r\n-----END CERTIFICATE-----\r\n"
      Update certificate defaultPrivate
      The object "system.certificates" was updated successfully.
      Update certificate defaultPublic
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.8 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.8: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.10.1 (node_modules/canvas):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.10.1 install: `node-pre-gyp install --fallback-to-build --update-binary`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      + iobroker.js-controller@4.0.23
      updated 1 package in 46.994s
      49 packages are looking for funding
        run `npm fund` for details
      MOD-EDIT: Code in code-tags gesetzt und Zertifikat entfernt
      C
      Coolbeer
    • RE: Analogwert wird nicht angezeigt Modul - HMW-IO-12-Sw14-DR
      @coolbeer Jetzt werd ich mich mal mit Brockly befassen. Ich möchte nur den Wert in % Füllstand darstellen. Später folgt die VIS.
      C
      Coolbeer
