pi@raspberrypi:~ $ iobroker -v
3.3.15
Latest posts made by Ibot
RE: Neue Adapter Installation schlägt fehlposted in Error/Bug
Systemdata Bitte Ausfüllen Hardwaresystem: PI4 Arbeitsspeicher: 4GB Festplattenart: USB Stick Betriebssystem: Linux Node-Version: 12.22.5 Nodejs-Version: NPM-Version: V6.14.14 Installationsart: Skript Image genutzt: Ja Ort/Name der Imagedatei: Link Der Versuch eine neue Instanz zu Installieren schlägt immer fehl und der IO Broker ist dann auch nicht mehr ereichbar auch Neustart hilft nicht nur nach dem Einspielen eines Backups ist alles wie vorher
$ iobroker add alias-manager --host raspberrypi NPM version: 6.14.14 npm install iobroker.alias-manager@1.2.3 --loglevel error --prefix "/opt/iobroker" (System call) host.raspberrypi install adapter alias-manager Uncaught Rejection: Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:525:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:790:28 at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2567:9) at Install.installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:786:13) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:720:33 at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:239:55 ERROR: Process exited with code 6Nach der versuchten Inst. liefert IO Broker Status
pi@raspberrypi:~ $ iobroker status internal/modules/cjs/loader.js:818 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) at internal/main/run_main_module.js:17:47 { code: 'MODULE_NOT_FOUND', requireStack: [] }Bekomme den IoBroker nur durch einspielen eins Backups wieder zum Laufen
der Befehl:which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs liefert
pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs /usr/bin/nodejs v12.22.5 /usr/bin/node v12.22.5 /usr/bin/npm 6.14.14 nodejs: Installed: 12.22.5-1nodesource1 Candidate: 12.22.5-1nodesource1 Version table: *** 12.22.5-1nodesource1 500 500 https://deb.nodesource.com/node_12.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages -
RE: Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisierenposted in Error/Bug
@homoran bewusst nicht ,finde das Tool an sich sehr hilfreich für nicht so Professionelle
@homoran das von elzershark
@thomas-braun sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
iobroker update iobroker upgrade
alles schickpi@raspberrypi:~ $ iobroker update Used repository: Stable (default) hash unchanged, use cached sources update done Adapter "admin" : 4.2.1 , installed 4.2.1 Adapter "alarm" : 2.0.0 Adapter "alexa2" : 3.8.1 Adapter "alias-manager" : 1.0.0 Adapter "alpha2" : 1.0.0 Adapter "amazon-dash" : 1.1.0 Adapter "artnet" : 1.2.2 Adapter "asterisk" : 1.0.6 Adapter "asuswrt" : 1.0.1 Adapter "b-control-em" : 0.2.1 Adapter "backitup" : 2.1.0 Adapter "beckhoff" : 1.4.0 Adapter "benq" : 0.2.4 Adapter "binance" : 1.1.3 Adapter "ble" : 0.12.0 Adapter "bmw" : 1.3.3 Adapter "bosesoundtouch": 0.9.3 Adapter "botvac" : 1.0.0 Adapter "bring" : 1.7.7 Adapter "broadlink2" : 2.0.3 Adapter "bsblan" : 0.2.2 Adapter "bshb" : 0.1.13 Adapter "bydbatt" : 1.0.3 Adapter "chromecast" : 2.3.1 Adapter "cloud" : 4.0.10 Adapter "comfoair" : 1.1.3 Adapter "contactid" : 1.0.2 Adapter "coronavirus-statistics": 0.6.3 Adapter "countdown" : 1.1.0 Adapter "cul" : 1.3.4 Adapter "daikin" : 1.3.0 Adapter "daswetter" : 3.0.4 Adapter "deconz" : 1.3.11 Adapter "denon" : 1.10.4 Adapter "device-reminder": 1.0.6 Adapter "devices" : 0.3.16 Adapter "digitalstrom" : 2.0.5 Adapter "discovergy" : 0.5.4 Adapter "discovery" : 2.6.1 , installed 2.6.1 Adapter "divera247" : 0.0.10 Adapter "doorio" : 1.1.4 Adapter "ds18b20" : 1.4.0 Adapter "dwd" : 2.7.5 Adapter "easee" : 0.1.2 Adapter "ebus" : 2.2.4 Adapter "echarts" : 0.4.11 Adapter "ecovacs-deebot": 1.1.1 Adapter "egigeozone" : 0.1.2 Adapter "ekey" : 1.1.0 Adapter "email" : 1.0.9 Adapter "emby" : 1.0.2 Adapter "energymanager" : 1.2.3 Adapter "enet" : 1.0.1 Adapter "epson_ecotank_et_2750": 0.0.4 Adapter "epson_stylus_px830": 0.2.1 Adapter "exchangerates" : 0.0.14 Adapter "fahrplan" : 1.0.5 Adapter "fakeroku" : 0.2.1 Adapter "fb-checkpresence": 1.1.0 Adapter "feiertage" : 1.0.17 Adapter "fhem" : 1.5.3 Adapter "find-my-iphone": 0.2.15 Adapter "firetv" : 1.0.0 Adapter "flot" : 1.10.6 , installed 1.10.6 Adapter "followthesun" : 0.3.3 Adapter "foobar2000" : 2.0.4 Adapter "fritzbox" : 0.2.1 Adapter "fritzdect" : 2.1.11 Adapter "fronius" : 1.0.5 Adapter "frontier_silicon": 0.0.10 Adapter "fuelpricemonitor": 0.2.2 Adapter "fullcalendar" : 1.1.0 Adapter "fullybrowser" : 2.0.8 Adapter "g-homa" : 0.5.3 Adapter "geofency" : 1.0.3 Adapter "go-e" : 1.0.0 Adapter "growatt" : 1.0.1 Adapter "gruenbeck" : 0.0.29 Adapter "haassohn" : 1.0.3 Adapter "habpanel" : 0.4.3 Adapter "haier" : 1.0.4 Adapter "ham" : 4.0.1 Adapter "ham-wemo" : 1.1.1 Adapter "harmony" : 1.2.2 Adapter "heatingcontrol": 2.2.0 Adapter "heos" : 1.7.7 Adapter "heytech" : 1.0.0 Adapter "hid" : 0.1.17 Adapter "history" : 1.9.12 , installed 1.9.12 Adapter "hm-rega" : 3.0.16 Adapter "hm-rpc" : 1.14.35 Adapter "hmip" : 1.9.0 Adapter "homeconnect" : 0.0.32 Adapter "homee" : 1.1.0 Adapter "homepilot" : 1.0.3 Adapter "hp-ilo" : 1.0.6 Adapter "hs100" : 2.0.3 Adapter "hue" : 3.5.2 Adapter "hue-extended" : 2.0.0 Adapter "i2c" : 1.2.0 Adapter "ical" : 1.7.4 Adapter "icons-addictive-flavour-png": 0.1.0 Adapter "icons-fatcow-hosting": 0.1.0 Adapter "icons-icons8" : 0.0.1 Adapter "icons-material-png": 0.1.0 Adapter "icons-material-svg": 0.1.0 Adapter "icons-mfd-png" : 1.0.2 Adapter "icons-mfd-svg" : 1.0.2 Adapter "icons-open-icon-library-png": 0.1.2 Adapter "icons-ultimate-png": 1.0.1 Adapter "influxdb" : 1.9.4 Adapter "info" : 1.7.14 , installed 1.7.14 Adapter "innogy-smarthome": 0.3.6 Adapter "iogo" : 0.6.5 Adapter "iot" : 1.8.16 Adapter "iqontrol" : 1.6.4 Adapter "jarvis" : 2.1.0 Adapter "javascript" : 5.0.14 , installed 5.0.14 Adapter "jeelink" : 0.1.0 Controller "js-controller" : 3.2.16 , installed 3.2.16 Adapter "kecontact" : 1.1.1 Adapter "klf200" : 1.0.1 Adapter "km200" : 1.1.6 Adapter "knmi-weather" : 1.0.0 Adapter "knx" : 1.0.39 Adapter "kodi" : 2.0.5 Adapter "kostal-piko-ba": 1.1.5 Adapter "kress" : 2.5.5 Adapter "lametric" : 1.2.0 Adapter "landroid" : 1.0.3 Adapter "lcn" : 1.0.2 Adapter "legrand-ecocompteur": 1.0.0 Adapter "letrika_comgw" : 0.0.5 Adapter "lgtv" : 1.1.10 Adapter "lgtv-rs" : 0.1.1 Adapter "lgtv11" : 1.0.5 Adapter "lifx" : 0.1.0 Adapter "lightify" : 0.2.16 Adapter "link" : 0.5.10 Adapter "linkeddevices" : 1.4.2 Adapter "linktap" : 0.1.8 Adapter "linux-control" : 1.1.2 Adapter "logparser" : 1.1.0 Adapter "lovelace" : 1.0.16 Adapter "loxone" : 2.1.0 Adapter "luftdaten" : 1.0.2 Adapter "lupusec" : 1.3.4 Adapter "luxtronik1" : 0.3.0 Adapter "material" : 0.13.9 Adapter "maxcube" : 1.0.2 Adapter "maxcul" : 1.3.1 Adapter "mbus" : 2.3.4 Adapter "mclighting" : 0.1.2 Adapter "megad" : 1.2.1 Adapter "megadd" : 0.2.0 Adapter "megaesp" : 0.1.0 Adapter "melcloud" : 1.0.6 Adapter "mercedesme" : 0.0.50 Adapter "mercury" : 0.1.4 Adapter "meross" : 1.5.1 Adapter "meteoalarm" : 1.1.3 Adapter "midea" : 0.0.6 Adapter "miele" : 0.1.5 Adapter "mielecloudservice": 2.0.3 Adapter "mihome" : 1.3.7 Adapter "mihome-lamp" : 1.1.0 Adapter "mihome-plug" : 0.2.1 Adapter "mihome-vacuum" : 2.1.1 Adapter "mikrotik" : 1.0.16 Adapter "milight" : 0.3.6 Adapter "milight-smart-light": 1.2.0 Adapter "minuvis" : 1.4.0 Adapter "mobile" : 1.0.1 Adapter "modbus" : 3.2.6 Adapter "moma" : 1.2.8 Adapter "mpd" : 1.0.6 Adapter "mqtt" : 2.3.5 , installed 2.3.5 Adapter "mqtt-client" : 1.3.1 Adapter "musiccast" : 0.1.5 Adapter "mydlink" : 1.1.7 Adapter "mysensors" : 2.0.1 Adapter "nanoleaf-lightpanels": 1.2.0 Adapter "net-tools" : 0.1.2 Adapter "netatmo" : 1.3.3 Adapter "netatmo-crawler": 0.3.9 Adapter "nibeuplink" : 0.4.0 Adapter "nina" : 0.0.24 Adapter "node-red" : 2.2.0 Adapter "nuki" : 1.4.3 Adapter "nuki-extended" : 2.3.0 Adapter "nut" : 1.4.3 Adapter "octoprint" : 1.0.8 Adapter "odl" : 1.1.4 Adapter "oilfox" : 0.0.5 Adapter "omnicomm-lls" : 0.0.7 Adapter "onkyo" : 2.0.3 Adapter "onvif" : 0.4.4 Adapter "openhab" : 1.1.0 Adapter "openligadb" : 1.1.0 Adapter "openweathermap": 0.1.0 Adapter "opi" : 0.1.1 Adapter "oppoplayer" : 0.2.4 Adapter "owfs" : 0.6.4 Adapter "owntracks" : 1.0.0 Adapter "panasonic-viera": 1.0.2 Adapter "parser" : 1.0.7 Adapter "paw" : 0.0.7 Adapter "phantomjs" : 1.1.2 Adapter "pi-hole" : 1.3.1 Adapter "piface" : 1.0.0 Adapter "pimatic" : 0.3.0 Adapter "ping" : 1.4.12 Adapter "places" : 1.0.0 Adapter "plenticore" : 2.1.6 Adapter "plex" : 0.8.11 Adapter "plexconnect" : 0.0.7 Adapter "pollenflug" : 1.0.6 Adapter "proxmox" : 1.2.0 Adapter "proxy" : 1.2.2 Adapter "pushbullet" : 0.0.11 Adapter "pushover" : 2.0.3 Adapter "pushsafer" : 1.0.3 Adapter "radar2" : 1.0.9 Adapter "radiohead" : 1.1.1 Adapter "rflink" : 2.1.6 Adapter "rickshaw" : 1.0.0 Adapter "ring" : 1.1.3 Adapter "robonect" : 0.1.3 Adapter "roomba" : 1.1.1 Adapter "rpi2" : 1.2.0 , installed 1.2.0 Adapter "s7" : 1.2.4 Adapter "sainlogic" : 0.6.6 Adapter "samsung" : 0.2.9 Adapter "sanext" : 0.0.5 Adapter "sayit" : 1.12.2 Adapter "sbfspot" : 4.0.4 Adapter "scenes" : 2.3.6 Adapter "schoolfree" : 0.7.0 Adapter "schwoerer-ventcube": 1.3.0 Adapter "seq" : 0.2.10 Adapter "shelly" : 4.0.7 Adapter "shuttercontrol": 1.1.5 Adapter "sia" : 1.0.4 Adapter "siegenia" : 1.1.0 Adapter "simple-api" : 2.5.3 , installed 2.5.3 Adapter "smappee" : 0.2.4 Adapter "smartcontrol" : 1.2.1 Adapter "smartgarden" : 1.0.4 Adapter "smartmeter" : 3.2.0 Adapter "snips" : 1.5.1 Adapter "snmp" : 0.5.0 Adapter "socketio" : 3.1.4 , installed 3.1.4 Adapter "solarlog" : 2.0.2 Adapter "solarviewdatareader": 0.2.1 Adapter "solarwetter" : 1.0.0 Adapter "sonnen" : 1.7.1 Adapter "sonoff" : 2.4.0 , installed 2.4.0 Adapter "sonos" : 2.1.1 Adapter "sony-bravia" : 1.0.1 Adapter "spotify-premium": 1.0.0 Adapter "sql" : 1.15.5 Adapter "squeezebox" : 1.0.0 Adapter "squeezeboxrpc" : 1.3.4 Adapter "starline" : 1.1.3 Adapter "statistics" : 1.0.2 Adapter "stiebel-isg" : 1.6.0 Adapter "sunnyportal" : 0.1.5 Adapter "swiss-weather-api": 0.3.2 Adapter "synology" : 0.1.20 Adapter "systeminfo" : 0.3.1 Adapter "tahoma" : 0.3.2 Adapter "tankerkoenig" : 2.0.5 Adapter "telegram" : 1.8.0 Adapter "terminal" : 0.1.2 Adapter "tesla-motors" : 0.4.2 Adapter "text2command" : 2.0.7 Adapter "tinker" : 1.1.0 Adapter "tr-064" : 4.2.11 Adapter "traccar" : 0.0.7 Adapter "tradfri" : 2.7.1 Adapter "trashschedule" : 1.1.1 Adapter "tunnelbroker-endpoint-updater": 0.0.1 Adapter "tuya" : 3.5.9 Adapter "tvprogram" : 1.0.0 Adapter "tvspielfilm" : 1.0.4 Adapter "unifi" : 0.5.8 Adapter "upnp" : 1.0.17 Adapter "vaillant" : 0.0.11 Adapter "valloxmv" : 1.1.2 Adapter "vcard" : 0.0.9 Adapter "velux" : 0.0.7 Adapter "viessmann" : 1.3.3 Adapter "virtualpowermeter": 1.4.2 Adapter "vis" : 1.3.8 , installed 1.3.8 Adapter "vis-bars" : 0.1.4 Adapter "vis-canvas-gauges": 0.1.5 Adapter "vis-colorpicker": 1.2.0 Adapter "vis-fancyswitch": 1.1.0 Adapter "vis-google-fonts": 0.1.0 Adapter "vis-history" : 1.0.0 Adapter "vis-hqwidgets" : 1.1.7 , installed 1.1.7 Adapter "vis-icontwo" : 0.60.0 Adapter "vis-inventwo" : 2.8.3 Adapter "vis-jqui-mfd" : 1.0.12 Adapter "vis-justgage" : 1.0.2 Adapter "vis-keyboard" : 0.0.2 Adapter "vis-lcars" : 1.0.4 Adapter "vis-map" : 1.0.4 Adapter "vis-material-advanced": 1.6.0 Adapter "vis-metro" : 1.1.2 Adapter "vis-players" : 0.1.6 Adapter "vis-plumb" : 1.0.2 Adapter "vis-rgraph" : 0.0.2 Adapter "vis-timeandweather": 1.1.7 Adapter "vis-weather" : 2.5.2 Adapter "volumio" : 0.1.2 Adapter "volvo" : 0.0.3 Adapter "vr200" : 1.0.0 Adapter "vw-connect" : 0.0.30 Adapter "weatherunderground": 3.3.0 Adapter "web" : 3.3.0 , installed 3.3.0 Adapter "weishaupt-wem" : 0.0.9 Adapter "whatsapp-cmb" : 0.1.6 Adapter "wiffi-wz" : 2.2.0 Adapter "wifilight" : 1.1.0 Adapter "windows-control": 0.1.5 Adapter "wled" : 0.5.6 Adapter "wm-bus" : 0.1.12 Adapter "wolf" : 1.2.1 Adapter "worx" : 1.3.0 Adapter "xbox" : 0.7.7 Adapter "xs1" : 1.0.2 Adapter "yahka" : 0.12.0 , installed 0.12.0 Adapter "yamaha" : 0.4.0 Adapter "yeelight-2" : 1.0.3 Adapter "youtube" : 1.0.3 Adapter "yr" : 2.0.3 Adapter "zigbee" : 1.4.4 Adapter "zont" : 0.5.3 Adapter "zwave2" : 1.8.11 pi@raspberrypi:~ $ iobroker upgrade Adapter "admin" is up to date. Adapter "alarm" is not installed. Adapter "alexa2" is not installed. Adapter "alias-manager" is not installed. Adapter "alpha2" is not installed. Adapter "amazon-dash" is not installed. Adapter "artnet" is not installed. Adapter "asterisk" is not installed. Adapter "asuswrt" is not installed. Adapter "b-control-em" is not installed. Adapter "backitup" is not installed. Adapter "beckhoff" is not installed. Adapter "benq" is not installed. Adapter "binance" is not installed. Adapter "ble" is not installed. Adapter "bmw" is not installed. Adapter "bosesoundtouch" is not installed. Adapter "botvac" is not installed. Adapter "bring" is not installed. Adapter "broadlink2" is not installed. Adapter "bsblan" is not installed. Adapter "bshb" is not installed. Adapter "bydbatt" is not installed. Adapter "chromecast" is not installed. Adapter "cloud" is not installed. Adapter "comfoair" is not installed. Adapter "contactid" is not installed. Adapter "coronavirus-statistics" is not installed. Adapter "countdown" is not installed. Adapter "cul" is not installed. Adapter "daikin" is not installed. Adapter "daswetter" is not installed. Adapter "deconz" is not installed. Adapter "denon" is not installed. Adapter "device-reminder" is not installed. Adapter "devices" is not installed. Adapter "digitalstrom" is not installed. Adapter "discovergy" is not installed. Adapter "discovery" is up to date. Adapter "divera247" is not installed. Adapter "doorio" is not installed. Adapter "ds18b20" is not installed. Adapter "dwd" is not installed. Adapter "easee" is not installed. Adapter "ebus" is not installed. Adapter "echarts" is not installed. Adapter "ecovacs-deebot" is not installed. Adapter "egigeozone" is not installed. Adapter "ekey" is not installed. Adapter "email" is not installed. Adapter "emby" is not installed. Adapter "energymanager" is not installed. Adapter "enet" is not installed. Adapter "epson_ecotank_et_2750" is not installed. Adapter "epson_stylus_px830" is not installed. Adapter "exchangerates" is not installed. Adapter "fahrplan" is not installed. Adapter "fakeroku" is not installed. Adapter "fb-checkpresence" is not installed. Adapter "feiertage" is not installed. Adapter "fhem" is not installed. Adapter "find-my-iphone" is not installed. Adapter "firetv" is not installed. Adapter "flot" is up to date. Adapter "followthesun" is not installed. Adapter "foobar2000" is not installed. Adapter "fritzbox" is not installed. Adapter "fritzdect" is not installed. Adapter "fronius" is not installed. Adapter "frontier_silicon" is not installed. Adapter "fuelpricemonitor" is not installed. Adapter "fullcalendar" is not installed. Adapter "fullybrowser" is not installed. Adapter "g-homa" is not installed. Adapter "geofency" is not installed. Adapter "go-e" is not installed. Adapter "growatt" is not installed. Adapter "gruenbeck" is not installed. Adapter "haassohn" is not installed. Adapter "habpanel" is not installed. Adapter "haier" is not installed. Adapter "ham" is not installed. Adapter "ham-wemo" is not installed. Adapter "harmony" is not installed. Adapter "heatingcontrol" is not installed. Adapter "heos" is not installed. Adapter "heytech" is not installed. Adapter "hid" is not installed. Adapter "history" is up to date. Adapter "hm-rega" is not installed. Adapter "hm-rpc" is not installed. Adapter "hmip" is not installed. Adapter "homeconnect" is not installed. Adapter "homee" is not installed. Adapter "homepilot" is not installed. Adapter "hp-ilo" is not installed. Adapter "hs100" is not installed. Adapter "hue" is not installed. Adapter "hue-extended" is not installed. Adapter "i2c" is not installed. Adapter "ical" is not installed. Adapter "icons-addictive-flavour-png" is not installed. Adapter "icons-fatcow-hosting" is not installed. Adapter "icons-icons8" is not installed. Adapter "icons-material-png" is not installed. Adapter "icons-material-svg" is not installed. Adapter "icons-mfd-png" is not installed. Adapter "icons-mfd-svg" is not installed. Adapter "icons-open-icon-library-png" is not installed. Adapter "icons-ultimate-png" is not installed. Adapter "influxdb" is not installed. Adapter "info" is up to date. Adapter "innogy-smarthome" is not installed. Adapter "iogo" is not installed. Adapter "iot" is not installed. Adapter "iqontrol" is not installed. Adapter "jarvis" is not installed. Adapter "javascript" is up to date. Adapter "jeelink" is not installed. Adapter "kecontact" is not installed. Adapter "klf200" is not installed. Adapter "km200" is not installed. Adapter "knmi-weather" is not installed. Adapter "knx" is not installed. Adapter "kodi" is not installed. Adapter "kostal-piko-ba" is not installed. Adapter "kress" is not installed. Adapter "lametric" is not installed. Adapter "landroid" is not installed. Adapter "lcn" is not installed. Adapter "legrand-ecocompteur" is not installed. Adapter "letrika_comgw" is not installed. Adapter "lgtv" is not installed. Adapter "lgtv-rs" is not installed. Adapter "lgtv11" is not installed. Adapter "lifx" is not installed. Adapter "lightify" is not installed. Adapter "link" is not installed. Adapter "linkeddevices" is not installed. Adapter "linktap" is not installed. Adapter "linux-control" is not installed. Adapter "logparser" is not installed. Adapter "lovelace" is not installed. Adapter "loxone" is not installed. Adapter "luftdaten" is not installed. Adapter "lupusec" is not installed. Adapter "luxtronik1" is not installed. Adapter "material" is not installed. Adapter "maxcube" is not installed. Adapter "maxcul" is not installed. Adapter "mbus" is not installed. Adapter "mclighting" is not installed. Adapter "megad" is not installed. Adapter "megadd" is not installed. Adapter "megaesp" is not installed. Adapter "melcloud" is not installed. Adapter "mercedesme" is not installed. Adapter "mercury" is not installed. Adapter "meross" is not installed. Adapter "meteoalarm" is not installed. Adapter "midea" is not installed. Adapter "miele" is not installed. Adapter "mielecloudservice" is not installed. Adapter "mihome" is not installed. Adapter "mihome-lamp" is not installed. Adapter "mihome-plug" is not installed. Adapter "mihome-vacuum" is not installed. Adapter "mikrotik" is not installed. Adapter "milight" is not installed. Adapter "milight-smart-light" is not installed. Adapter "minuvis" is not installed. Adapter "mobile" is not installed. Adapter "modbus" is not installed. Adapter "moma" is not installed. Adapter "mpd" is not installed. Adapter "mqtt" is up to date. Adapter "mqtt-client" is not installed. Adapter "musiccast" is not installed. Adapter "mydlink" is not installed. Adapter "mysensors" is not installed. Adapter "nanoleaf-lightpanels" is not installed. Adapter "net-tools" is not installed. Adapter "netatmo" is not installed. Adapter "netatmo-crawler" is not installed. Adapter "nibeuplink" is not installed. Adapter "nina" is not installed. Adapter "node-red" is not installed. Adapter "nuki" is not installed. Adapter "nuki-extended" is not installed. Adapter "nut" is not installed. Adapter "octoprint" is not installed. Adapter "odl" is not installed. Adapter "oilfox" is not installed. Adapter "omnicomm-lls" is not installed. Adapter "onkyo" is not installed. Adapter "onvif" is not installed. Adapter "openhab" is not installed. Adapter "openligadb" is not installed. Adapter "openweathermap" is not installed. Adapter "opi" is not installed. Adapter "oppoplayer" is not installed. Adapter "owfs" is not installed. Adapter "owntracks" is not installed. Adapter "panasonic-viera" is not installed. Adapter "parser" is not installed. Adapter "paw" is not installed. Adapter "phantomjs" is not installed. Adapter "pi-hole" is not installed. Adapter "piface" is not installed. Adapter "pimatic" is not installed. Adapter "ping" is not installed. Adapter "places" is not installed. Adapter "plenticore" is not installed. Adapter "plex" is not installed. Adapter "plexconnect" is not installed. Adapter "pollenflug" is not installed. Adapter "proxmox" is not installed. Adapter "proxy" is not installed. Adapter "pushbullet" is not installed. Adapter "pushover" is not installed. Adapter "pushsafer" is not installed. Adapter "radar2" is not installed. Adapter "radiohead" is not installed. Adapter "rflink" is not installed. Adapter "rickshaw" is not installed. Adapter "ring" is not installed. Adapter "robonect" is not installed. Adapter "roomba" is not installed. Adapter "rpi2" is up to date. Adapter "s7" is not installed. Adapter "sainlogic" is not installed. Adapter "samsung" is not installed. Adapter "sanext" is not installed. Adapter "sayit" is not installed. Adapter "sbfspot" is not installed. Adapter "scenes" is not installed. Adapter "schoolfree" is not installed. Adapter "schwoerer-ventcube" is not installed. Adapter "seq" is not installed. Adapter "shelly" is not installed. Adapter "shuttercontrol" is not installed. Adapter "sia" is not installed. Adapter "siegenia" is not installed. Adapter "simple-api" is up to date. Adapter "smappee" is not installed. Adapter "smartcontrol" is not installed. Adapter "smartgarden" is not installed. Adapter "smartmeter" is not installed. Adapter "snips" is not installed. Adapter "snmp" is not installed. Adapter "socketio" is up to date. Adapter "solarlog" is not installed. Adapter "solarviewdatareader" is not installed. Adapter "solarwetter" is not installed. Adapter "sonnen" is not installed. Adapter "sonoff" is up to date. Adapter "sonos" is not installed. Adapter "sony-bravia" is not installed. Adapter "spotify-premium" is not installed. Adapter "sql" is not installed. Adapter "squeezebox" is not installed. Adapter "squeezeboxrpc" is not installed. Adapter "starline" is not installed. Adapter "statistics" is not installed. Adapter "stiebel-isg" is not installed. Adapter "sunnyportal" is not installed. Adapter "swiss-weather-api" is not installed. Adapter "synology" is not installed. Adapter "systeminfo" is not installed. Adapter "tahoma" is not installed. Adapter "tankerkoenig" is not installed. Adapter "telegram" is not installed. Adapter "terminal" is not installed. Adapter "tesla-motors" is not installed. Adapter "text2command" is not installed. Adapter "tinker" is not installed. Adapter "tr-064" is not installed. Adapter "traccar" is not installed. Adapter "tradfri" is not installed. Adapter "trashschedule" is not installed. Adapter "tunnelbroker-endpoint-updater" is not installed. Adapter "tuya" is not installed. Adapter "tvprogram" is not installed. Adapter "tvspielfilm" is not installed. Adapter "unifi" is not installed. Adapter "upnp" is not installed. Adapter "vaillant" is not installed. Adapter "valloxmv" is not installed. Adapter "vcard" is not installed. Adapter "velux" is not installed. Adapter "viessmann" is not installed. Adapter "virtualpowermeter" is not installed. Adapter "vis" is up to date. Adapter "vis-bars" is not installed. Adapter "vis-canvas-gauges" is not installed. Adapter "vis-colorpicker" is not installed. Adapter "vis-fancyswitch" is not installed. Adapter "vis-google-fonts" is not installed. Adapter "vis-history" is not installed. Adapter "vis-hqwidgets" is up to date. Adapter "vis-icontwo" is not installed. Adapter "vis-inventwo" is not installed. Adapter "vis-jqui-mfd" is not installed. Adapter "vis-justgage" is not installed. Adapter "vis-keyboard" is not installed. Adapter "vis-lcars" is not installed. Adapter "vis-map" is not installed. Adapter "vis-material-advanced" is not installed. Adapter "vis-metro" is not installed. Adapter "vis-players" is not installed. Adapter "vis-plumb" is not installed. Adapter "vis-rgraph" is not installed. Adapter "vis-timeandweather" is not installed. Adapter "vis-weather" is not installed. Adapter "volumio" is not installed. Adapter "volvo" is not installed. Adapter "vr200" is not installed. Adapter "vw-connect" is not installed. Adapter "weatherunderground" is not installed. Adapter "web" is up to date. Adapter "weishaupt-wem" is not installed. Adapter "whatsapp-cmb" is not installed. Adapter "wiffi-wz" is not installed. Adapter "wifilight" is not installed. Adapter "windows-control" is not installed. Adapter "wled" is not installed. Adapter "wm-bus" is not installed. Adapter "wolf" is not installed. Adapter "worx" is not installed. Adapter "xbox" is not installed. Adapter "xs1" is not installed. Adapter "yahka" is up to date. Adapter "yamaha" is not installed. Adapter "yeelight-2" is not installed. Adapter "youtube" is not installed. Adapter "yr" is not installed. Adapter "zigbee" is not installed. Adapter "zont" is not installed. Adapter "zwave2" is not installed. -
ich habe mit dem Iobroker Tool vorab ein Backup erstellt. Nach dem Neustart ist Iobroker wieder ereichbar und Vis ist auch aktuell Top Npm Cache trotzdem noch löschen? -
Hallo, ja habe ich sobald ich das Backup zurückspiele ist über den Browser auch alles wieder ereichbar -
Im Browser stehtCannot GET /
