  4. Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren
    6.5k
vis update
33 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • I Ibot
    @thomas-braun sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.22.1
    /usr/bin/node
    v12.22.1
    /usr/bin/npm
    6.14.12
    nodejs:
      Installiert:           12.22.1-1nodesource1
      Installationskandidat: 12.22.1-1nodesource1
      Versionstabelle:
     *** 12.22.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    @ibot
    iobroker update
    iobroker upgrade
    Wenn das nicht funktioniert:
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    I 2 Antworten Letzte Antwort
      @ibot
      iobroker update
      iobroker upgrade
      cd /opt/iobroker
      I Offline
      I Offline
      Ibot
      na dem Upgrade Befehl kommt:
      Error: Cannot find module 'mime'
      Require stack:
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          at Module.require (internal/modules/cjs/loader.js:887:19)
          at require (internal/modules/cjs/helpers.js:74:18)
          at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l        ib/setup/setupUpload.js:525:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:211:28
          at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.j        s:2557:9)
          at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setu        p/setupUpgrade.js:205:13)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:419:21
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.        js:223:55 {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js'        ,
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js        ',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      MOD EDIT: CODE TAGS KORRIGIERT
        @ibot
        iobroker update
        iobroker upgrade
        cd /opt/iobroker
        I Offline
        I Offline
        Ibot
        nach:cd /opt/iobroker
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.12
        > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:56,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/system updated
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.js-controller@3.2.16
        added 254 packages from 265 contributors, removed 6 packages, updated 1 package and moved 16 packages in 96.989s
        13 packages are looking for funding
          run `npm fund` for details
           │      New major version of npm available! 6.14.12 → 7.10.0      │
           │   Changelog: https://github.com/npm/cli/releases/tag/v7.10.0   │
           │               Run npm install -g npm to update!                │
        • I Ibot
          > node-gyp rebuild
          > node rebuild.js
          > node-gyp rebuild
          @ibot
          Und?
          I 1 Antwort Letzte Antwort
            @ibot
            Und?
            I Offline
            I Offline
            Ibot
            iobroker ist über die webobefläche nicht mehr ereichbar soll ich das npm Update durchführen?
            • I Ibot
              @ibot
              Auf gar keinen Fall!
              Das macht es nur schlimmer.
              npm wird nur über den Paketmanager aktualisiert, im Zuge eine Updates von nodejs.
              iobroker status
              iobroker list adapters
              iobroker list instances
                @ibot
                iobroker status
                I Offline
                I Offline
                Ibot
                iobroker status
                pi@raspberrypi:/opt/iobroker $ iobroker status
                Objects type: file
                States  type: file
                pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                system.adapter.admin                   : admin          - v4.2.1
                system.adapter.discovery               : discovery      - v2.6.1
                system.adapter.flot                    : flot           - v1.10.6
                system.adapter.history                 : history        - v1.9.12
                system.adapter.info                    : info           - v1.7.14
                system.adapter.javascript              : javascript     - v5.0.14
                system.adapter.mqtt                    : mqtt           - v2.3.5
                system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                system.adapter.node-red                : node-red       - v2.2.0
                system.adapter.rpi2                    : rpi2           - v1.2.0
                system.adapter.sonoff                  : sonoff         - v2.4.0
                system.adapter.vis                     : vis            - v1.3.4
                system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                system.adapter.web                     : web            - v3.3.0
                system.adapter.yahka                   : yahka          - v0.12.0
                pi@raspberrypi:/opt/iobroker $ iobroker list instances
                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                  system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                + instance is alive
                • I Ibot
                  iobroker status
                  Objects type: file
                  States  type: file
                  + instance is alive
                  @ibot
                  Sollte eigentlich laufen. Welche Meldungen bekommst du?
                  HomoranH I 2 Antworten Letzte Antwort
                    @ibot
                    sehe ich auch so!
                    @Ibot
                    hast du mal den Browsercache gelöscht?
                      @ibot
                      I Offline
                      I Offline
                      Ibot
                      Im Browser steht
                      Cannot GET /
                      • I Ibot
                        Im Browser steht
                        Cannot GET /
                        @ibot sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
                        Starte den Pi mal sauber durch:
                        iobroker stop
                        sudo reboot
                        Und BrowserCache löschen, wie @Homoran schon sagte.
                          sehe ich auch so!
                          @Ibot
                          I Offline
                          I Offline
                          Ibot
                          Hallo, ja habe ich sobald ich das Backup zurückspiele ist über den Browser auch alles wieder ereichbar
                          • I Ibot
                            @ibot
                            Was für ein Backup?
                            Lösch mal den npm cache
                            cd /opt/iobroker
                            npm cache clean --force
                            • I Ibot
                              von Backup hat niemand was gesagt!
                                @ibot
                                Was für ein Backup?
                                cd /opt/iobroker
                                I Offline
                                I Offline
                                Ibot
                                ich habe mit dem Iobroker Tool vorab ein Backup erstellt. Nach dem Neustart ist Iobroker wieder ereichbar und Vis ist auch aktuell Top Npm Cache trotzdem noch löschen?
                                • I Ibot
                                  @ibot
                                  Nö, wenn alles läuft lass die Finger davon.
                                  Was liefert denn jetzt ein
                                  iobroker update
                                  iobroker upgrade
                                    @ibot
                                    iobroker update
                                    iobroker upgrade
                                    I Offline
                                    I Offline
                                    Ibot
                                    iobroker update iobroker upgrade
                                    alles schick
                                    pi@raspberrypi:~ $ iobroker update
                                    hash unchanged, use cached sources
                                    update done
                                    Adapter    "admin"         : 4.2.1    , installed 4.2.1
                                    Adapter    "alarm"         : 2.0.0
                                    Adapter    "alexa2"        : 3.8.1
                                    Adapter    "alias-manager" : 1.0.0
                                    Adapter    "alpha2"        : 1.0.0
                                    Adapter    "amazon-dash"   : 1.1.0
                                    Adapter    "artnet"        : 1.2.2
                                    Adapter    "asterisk"      : 1.0.6
                                    Adapter    "asuswrt"       : 1.0.1
                                    Adapter    "b-control-em"  : 0.2.1
                                    Adapter    "backitup"      : 2.1.0
                                    Adapter    "beckhoff"      : 1.4.0
                                    Adapter    "benq"          : 0.2.4
                                    Adapter    "binance"       : 1.1.3
                                    Adapter    "ble"           : 0.12.0
                                    Adapter    "bmw"           : 1.3.3
                                    Adapter    "bosesoundtouch": 0.9.3
                                    Adapter    "botvac"        : 1.0.0
                                    Adapter    "bring"         : 1.7.7
                                    Adapter    "broadlink2"    : 2.0.3
                                    Adapter    "bsblan"        : 0.2.2
                                    Adapter    "bshb"          : 0.1.13
                                    Adapter    "bydbatt"       : 1.0.3
                                    Adapter    "chromecast"    : 2.3.1
                                    Adapter    "cloud"         : 4.0.10
                                    Adapter    "comfoair"      : 1.1.3
                                    Adapter    "contactid"     : 1.0.2
                                    Adapter    "coronavirus-statistics": 0.6.3
                                    Adapter    "countdown"     : 1.1.0
                                    Adapter    "cul"           : 1.3.4
                                    Adapter    "daikin"        : 1.3.0
                                    Adapter    "daswetter"     : 3.0.4
                                    Adapter    "deconz"        : 1.3.11
                                    Adapter    "denon"         : 1.10.4
                                    Adapter    "device-reminder": 1.0.6
                                    Adapter    "devices"       : 0.3.16
                                    Adapter    "digitalstrom"  : 2.0.5
                                    Adapter    "discovergy"    : 0.5.4
                                    Adapter    "discovery"     : 2.6.1    , installed 2.6.1
                                    Adapter    "divera247"     : 0.0.10
                                    Adapter    "doorio"        : 1.1.4
                                    Adapter    "ds18b20"       : 1.4.0
                                    Adapter    "dwd"           : 2.7.5
                                    Adapter    "easee"         : 0.1.2
                                    Adapter    "ebus"          : 2.2.4
                                    Adapter    "echarts"       : 0.4.11
                                    Adapter    "ecovacs-deebot": 1.1.1
                                    Adapter    "egigeozone"    : 0.1.2
                                    Adapter    "ekey"          : 1.1.0
                                    Adapter    "email"         : 1.0.9
                                    Adapter    "emby"          : 1.0.2
                                    Adapter    "energymanager" : 1.2.3
                                    Adapter    "enet"          : 1.0.1
                                    Adapter    "epson_ecotank_et_2750": 0.0.4
                                    Adapter    "epson_stylus_px830": 0.2.1
                                    Adapter    "exchangerates" : 0.0.14
                                    Adapter    "fahrplan"      : 1.0.5
                                    Adapter    "fakeroku"      : 0.2.1
                                    Adapter    "fb-checkpresence": 1.1.0
                                    Adapter    "feiertage"     : 1.0.17
                                    Adapter    "fhem"          : 1.5.3
                                    Adapter    "find-my-iphone": 0.2.15
                                    Adapter    "firetv"        : 1.0.0
                                    Adapter    "flot"          : 1.10.6   , installed 1.10.6
                                    Adapter    "followthesun"  : 0.3.3
                                    Adapter    "foobar2000"    : 2.0.4
                                    Adapter    "fritzbox"      : 0.2.1
                                    Adapter    "fritzdect"     : 2.1.11
                                    Adapter    "fronius"       : 1.0.5
                                    Adapter    "frontier_silicon": 0.0.10
                                    Adapter    "fuelpricemonitor": 0.2.2
                                    Adapter    "fullcalendar"  : 1.1.0
                                    Adapter    "fullybrowser"  : 2.0.8
                                    Adapter    "g-homa"        : 0.5.3
                                    Adapter    "geofency"      : 1.0.3
                                    Adapter    "go-e"          : 1.0.0
                                    Adapter    "growatt"       : 1.0.1
                                    Adapter    "gruenbeck"     : 0.0.29
                                    Adapter    "haassohn"      : 1.0.3
                                    Adapter    "habpanel"      : 0.4.3
                                    Adapter    "haier"         : 1.0.4
                                    Adapter    "ham"           : 4.0.1
                                    Adapter    "ham-wemo"      : 1.1.1
                                    Adapter    "harmony"       : 1.2.2
                                    Adapter    "heatingcontrol": 2.2.0
                                    Adapter    "heos"          : 1.7.7
                                    Adapter    "heytech"       : 1.0.0
                                    Adapter    "hid"           : 0.1.17
                                    Adapter    "history"       : 1.9.12   , installed 1.9.12
                                    Adapter    "hm-rega"       : 3.0.16
                                    Adapter    "hm-rpc"        : 1.14.35
                                    Adapter    "hmip"          : 1.9.0
                                    Adapter    "homeconnect"   : 0.0.32
                                    Adapter    "homee"         : 1.1.0
                                    Adapter    "homepilot"     : 1.0.3
                                    Adapter    "hp-ilo"        : 1.0.6
                                    Adapter    "hs100"         : 2.0.3
                                    Adapter    "hue"           : 3.5.2
                                    Adapter    "hue-extended"  : 2.0.0
                                    Adapter    "i2c"           : 1.2.0
                                    Adapter    "ical"          : 1.7.4
                                    Adapter    "icons-addictive-flavour-png": 0.1.0
                                    Adapter    "icons-fatcow-hosting": 0.1.0
                                    Adapter    "icons-icons8"  : 0.0.1
                                    Adapter    "icons-material-png": 0.1.0
                                    Adapter    "icons-material-svg": 0.1.0
                                    Adapter    "icons-mfd-png" : 1.0.2
                                    Adapter    "icons-mfd-svg" : 1.0.2
                                    Adapter    "icons-open-icon-library-png": 0.1.2
                                    Adapter    "icons-ultimate-png": 1.0.1
                                    Adapter    "influxdb"      : 1.9.4
                                    Adapter    "info"          : 1.7.14   , installed 1.7.14
                                    Adapter    "innogy-smarthome": 0.3.6
                                    Adapter    "iogo"          : 0.6.5
                                    Adapter    "iot"           : 1.8.16
                                    Adapter    "iqontrol"      : 1.6.4
                                    Adapter    "jarvis"        : 2.1.0
                                    Adapter    "javascript"    : 5.0.14   , installed 5.0.14
                                    Adapter    "jeelink"       : 0.1.0
                                    Controller "js-controller" : 3.2.16   , installed 3.2.16
                                    Adapter    "kecontact"     : 1.1.1
                                    Adapter    "klf200"        : 1.0.1
                                    Adapter    "km200"         : 1.1.6
                                    Adapter    "knmi-weather"  : 1.0.0
                                    Adapter    "knx"           : 1.0.39
                                    Adapter    "kodi"          : 2.0.5
                                    Adapter    "kostal-piko-ba": 1.1.5
                                    Adapter    "kress"         : 2.5.5
                                    Adapter    "lametric"      : 1.2.0
                                    Adapter    "landroid"      : 1.0.3
                                    Adapter    "lcn"           : 1.0.2
                                    Adapter    "legrand-ecocompteur": 1.0.0
                                    Adapter    "letrika_comgw" : 0.0.5
                                    Adapter    "lgtv"          : 1.1.10
                                    Adapter    "lgtv-rs"       : 0.1.1
                                    Adapter    "lgtv11"        : 1.0.5
                                    Adapter    "lifx"          : 0.1.0
                                    Adapter    "lightify"      : 0.2.16
                                    Adapter    "link"          : 0.5.10
                                    Adapter    "linkeddevices" : 1.4.2
                                    Adapter    "linktap"       : 0.1.8
                                    Adapter    "linux-control" : 1.1.2
                                    Adapter    "logparser"     : 1.1.0
                                    Adapter    "lovelace"      : 1.0.16
                                    Adapter    "loxone"        : 2.1.0
                                    Adapter    "luftdaten"     : 1.0.2
                                    Adapter    "lupusec"       : 1.3.4
                                    Adapter    "luxtronik1"    : 0.3.0
                                    Adapter    "material"      : 0.13.9
                                    Adapter    "maxcube"       : 1.0.2
                                    Adapter    "maxcul"        : 1.3.1
                                    Adapter    "mbus"          : 2.3.4
                                    Adapter    "mclighting"    : 0.1.2
                                    Adapter    "megad"         : 1.2.1
                                    Adapter    "megadd"        : 0.2.0
                                    Adapter    "megaesp"       : 0.1.0
                                    Adapter    "melcloud"      : 1.0.6
                                    Adapter    "mercedesme"    : 0.0.50
                                    Adapter    "mercury"       : 0.1.4
                                    Adapter    "meross"        : 1.5.1
                                    Adapter    "meteoalarm"    : 1.1.3
                                    Adapter    "midea"         : 0.0.6
                                    Adapter    "miele"         : 0.1.5
                                    Adapter    "mielecloudservice": 2.0.3
                                    Adapter    "mihome"        : 1.3.7
                                    Adapter    "mihome-lamp"   : 1.1.0
                                    Adapter    "mihome-plug"   : 0.2.1
                                    Adapter    "mihome-vacuum" : 2.1.1
                                    Adapter    "mikrotik"      : 1.0.16
                                    Adapter    "milight"       : 0.3.6
                                    Adapter    "milight-smart-light": 1.2.0
                                    Adapter    "minuvis"       : 1.4.0
                                    Adapter    "mobile"        : 1.0.1
                                    Adapter    "modbus"        : 3.2.6
                                    Adapter    "moma"          : 1.2.8
                                    Adapter    "mpd"           : 1.0.6
                                    Adapter    "mqtt"          : 2.3.5    , installed 2.3.5
                                    Adapter    "mqtt-client"   : 1.3.1
                                    Adapter    "musiccast"     : 0.1.5
                                    Adapter    "mydlink"       : 1.1.7
                                    Adapter    "mysensors"     : 2.0.1
                                    Adapter    "nanoleaf-lightpanels": 1.2.0
                                    Adapter    "net-tools"     : 0.1.2
                                    Adapter    "netatmo"       : 1.3.3
                                    Adapter    "netatmo-crawler": 0.3.9
                                    Adapter    "nibeuplink"    : 0.4.0
                                    Adapter    "nina"          : 0.0.24
                                    Adapter    "node-red"      : 2.2.0
                                    Adapter    "nuki"          : 1.4.3
                                    Adapter    "nuki-extended" : 2.3.0
                                    Adapter    "nut"           : 1.4.3
                                    Adapter    "octoprint"     : 1.0.8
                                    Adapter    "odl"           : 1.1.4
                                    Adapter    "oilfox"        : 0.0.5
                                    Adapter    "omnicomm-lls"  : 0.0.7
                                    Adapter    "onkyo"         : 2.0.3
                                    Adapter    "onvif"         : 0.4.4
                                    Adapter    "openhab"       : 1.1.0
                                    Adapter    "openligadb"    : 1.1.0
                                    Adapter    "openweathermap": 0.1.0
                                    Adapter    "opi"           : 0.1.1
                                    Adapter    "oppoplayer"    : 0.2.4
                                    Adapter    "owfs"          : 0.6.4
                                    Adapter    "owntracks"     : 1.0.0
                                    Adapter    "panasonic-viera": 1.0.2
                                    Adapter    "parser"        : 1.0.7
                                    Adapter    "paw"           : 0.0.7
                                    Adapter    "phantomjs"     : 1.1.2
                                    Adapter    "pi-hole"       : 1.3.1
                                    Adapter    "piface"        : 1.0.0
                                    Adapter    "pimatic"       : 0.3.0
                                    Adapter    "ping"          : 1.4.12
                                    Adapter    "places"        : 1.0.0
                                    Adapter    "plenticore"    : 2.1.6
                                    Adapter    "plex"          : 0.8.11
                                    Adapter    "plexconnect"   : 0.0.7
                                    Adapter    "pollenflug"    : 1.0.6
                                    Adapter    "proxmox"       : 1.2.0
                                    Adapter    "proxy"         : 1.2.2
                                    Adapter    "pushbullet"    : 0.0.11
                                    Adapter    "pushover"      : 2.0.3
                                    Adapter    "pushsafer"     : 1.0.3
                                    Adapter    "radar2"        : 1.0.9
                                    Adapter    "radiohead"     : 1.1.1
                                    Adapter    "rflink"        : 2.1.6
                                    Adapter    "rickshaw"      : 1.0.0
                                    Adapter    "ring"          : 1.1.3
                                    Adapter    "robonect"      : 0.1.3
                                    Adapter    "roomba"        : 1.1.1
                                    Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                                    Adapter    "s7"            : 1.2.4
                                    Adapter    "sainlogic"     : 0.6.6
                                    Adapter    "samsung"       : 0.2.9
                                    Adapter    "sanext"        : 0.0.5
                                    Adapter    "sayit"         : 1.12.2
                                    Adapter    "sbfspot"       : 4.0.4
                                    Adapter    "scenes"        : 2.3.6
                                    Adapter    "schoolfree"    : 0.7.0
                                    Adapter    "schwoerer-ventcube": 1.3.0
                                    Adapter    "seq"           : 0.2.10
                                    Adapter    "shelly"        : 4.0.7
                                    Adapter    "shuttercontrol": 1.1.5
                                    Adapter    "sia"           : 1.0.4
                                    Adapter    "siegenia"      : 1.1.0
                                    Adapter    "simple-api"    : 2.5.3    , installed 2.5.3
                                    Adapter    "smappee"       : 0.2.4
                                    Adapter    "smartcontrol"  : 1.2.1
                                    Adapter    "smartgarden"   : 1.0.4
                                    Adapter    "smartmeter"    : 3.2.0
                                    Adapter    "snips"         : 1.5.1
                                    Adapter    "snmp"          : 0.5.0
                                    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                                    Adapter    "solarlog"      : 2.0.2
                                    Adapter    "solarviewdatareader": 0.2.1
                                    Adapter    "solarwetter"   : 1.0.0
                                    Adapter    "sonnen"        : 1.7.1
                                    Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
                                    Adapter    "sonos"         : 2.1.1
                                    Adapter    "sony-bravia"   : 1.0.1
                                    Adapter    "spotify-premium": 1.0.0
                                    Adapter    "sql"           : 1.15.5
                                    Adapter    "squeezebox"    : 1.0.0
                                    Adapter    "squeezeboxrpc" : 1.3.4
                                    Adapter    "starline"      : 1.1.3
                                    Adapter    "statistics"    : 1.0.2
                                    Adapter    "stiebel-isg"   : 1.6.0
                                    Adapter    "sunnyportal"   : 0.1.5
                                    Adapter    "swiss-weather-api": 0.3.2
                                    Adapter    "synology"      : 0.1.20
                                    Adapter    "systeminfo"    : 0.3.1
                                    Adapter    "tahoma"        : 0.3.2
                                    Adapter    "tankerkoenig"  : 2.0.5
                                    Adapter    "telegram"      : 1.8.0
                                    Adapter    "terminal"      : 0.1.2
                                    Adapter    "tesla-motors"  : 0.4.2
                                    Adapter    "text2command"  : 2.0.7
                                    Adapter    "tinker"        : 1.1.0
                                    Adapter    "tr-064"        : 4.2.11
                                    Adapter    "traccar"       : 0.0.7
                                    Adapter    "tradfri"       : 2.7.1
                                    Adapter    "trashschedule" : 1.1.1
                                    Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                    Adapter    "tuya"          : 3.5.9
                                    Adapter    "tvprogram"     : 1.0.0
                                    Adapter    "tvspielfilm"   : 1.0.4
                                    Adapter    "unifi"         : 0.5.8
                                    Adapter    "upnp"          : 1.0.17
                                    Adapter    "vaillant"      : 0.0.11
                                    Adapter    "valloxmv"      : 1.1.2
                                    Adapter    "vcard"         : 0.0.9
                                    Adapter    "velux"         : 0.0.7
                                    Adapter    "viessmann"     : 1.3.3
                                    Adapter    "virtualpowermeter": 1.4.2
                                    Adapter    "vis"           : 1.3.8    , installed 1.3.8
                                    Adapter    "vis-bars"      : 0.1.4
                                    Adapter    "vis-canvas-gauges": 0.1.5
                                    Adapter    "vis-colorpicker": 1.2.0
                                    Adapter    "vis-fancyswitch": 1.1.0
                                    Adapter    "vis-google-fonts": 0.1.0
                                    Adapter    "vis-history"   : 1.0.0
                                    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                                    Adapter    "vis-icontwo"   : 0.60.0
                                    Adapter    "vis-inventwo"  : 2.8.3
                                    Adapter    "vis-jqui-mfd"  : 1.0.12
                                    Adapter    "vis-justgage"  : 1.0.2
                                    Adapter    "vis-keyboard"  : 0.0.2
                                    Adapter    "vis-lcars"     : 1.0.4
                                    Adapter    "vis-map"       : 1.0.4
                                    Adapter    "vis-material-advanced": 1.6.0
                                    Adapter    "vis-metro"     : 1.1.2
                                    Adapter    "vis-players"   : 0.1.6
                                    Adapter    "vis-plumb"     : 1.0.2
                                    Adapter    "vis-rgraph"    : 0.0.2
                                    Adapter    "vis-timeandweather": 1.1.7
                                    Adapter    "vis-weather"   : 2.5.2
                                    Adapter    "volumio"       : 0.1.2
                                    Adapter    "volvo"         : 0.0.3
                                    Adapter    "vr200"         : 1.0.0
                                    Adapter    "vw-connect"    : 0.0.30
                                    Adapter    "weatherunderground": 3.3.0
                                    Adapter    "web"           : 3.3.0    , installed 3.3.0
                                    Adapter    "weishaupt-wem" : 0.0.9
                                    Adapter    "whatsapp-cmb"  : 0.1.6
                                    Adapter    "wiffi-wz"      : 2.2.0
                                    Adapter    "wifilight"     : 1.1.0
                                    Adapter    "windows-control": 0.1.5
                                    Adapter    "wled"          : 0.5.6
                                    Adapter    "wm-bus"        : 0.1.12
                                    Adapter    "wolf"          : 1.2.1
                                    Adapter    "worx"          : 1.3.0
                                    Adapter    "xbox"          : 0.7.7
                                    Adapter    "xs1"           : 1.0.2
                                    Adapter    "yahka"         : 0.12.0   , installed 0.12.0
                                    Adapter    "yamaha"        : 0.4.0
                                    Adapter    "yeelight-2"    : 1.0.3
                                    Adapter    "youtube"       : 1.0.3
                                    Adapter    "yr"            : 2.0.3
                                    Adapter    "zigbee"        : 1.4.4
                                    Adapter    "zont"          : 0.5.3
                                    Adapter    "zwave2"        : 1.8.11
                                    pi@raspberrypi:~ $ iobroker upgrade
                                    Adapter "admin"          is up to date.
                                    Adapter "alarm"          is not installed.
                                    Adapter "alexa2"         is not installed.
                                    Adapter "alias-manager"  is not installed.
                                    Adapter "alpha2"         is not installed.
                                    Adapter "amazon-dash"    is not installed.
                                    Adapter "artnet"         is not installed.
                                    Adapter "asterisk"       is not installed.
                                    Adapter "asuswrt"        is not installed.
                                    Adapter "b-control-em"   is not installed.
                                    Adapter "backitup"       is not installed.
                                    Adapter "beckhoff"       is not installed.
                                    Adapter "benq"           is not installed.
                                    Adapter "binance"        is not installed.
                                    Adapter "ble"            is not installed.
                                    Adapter "bmw"            is not installed.
                                    Adapter "bosesoundtouch" is not installed.
                                    Adapter "botvac"         is not installed.
                                    Adapter "bring"          is not installed.
                                    Adapter "broadlink2"     is not installed.
                                    Adapter "bsblan"         is not installed.
                                    Adapter "bshb"           is not installed.
                                    Adapter "bydbatt"        is not installed.
                                    Adapter "chromecast"     is not installed.
                                    Adapter "cloud"          is not installed.
                                    Adapter "comfoair"       is not installed.
                                    Adapter "contactid"      is not installed.
                                    Adapter "coronavirus-statistics" is not installed.
                                    Adapter "countdown"      is not installed.
                                    Adapter "cul"            is not installed.
                                    Adapter "daikin"         is not installed.
                                    Adapter "daswetter"      is not installed.
                                    Adapter "deconz"         is not installed.
                                    Adapter "denon"          is not installed.
                                    Adapter "device-reminder" is not installed.
                                    Adapter "devices"        is not installed.
                                    Adapter "digitalstrom"   is not installed.
                                    Adapter "discovergy"     is not installed.
                                    Adapter "discovery"      is up to date.
                                    Adapter "divera247"      is not installed.
                                    Adapter "doorio"         is not installed.
                                    Adapter "ds18b20"        is not installed.
                                    Adapter "dwd"            is not installed.
                                    Adapter "easee"          is not installed.
                                    Adapter "ebus"           is not installed.
                                    Adapter "echarts"        is not installed.
                                    Adapter "ecovacs-deebot" is not installed.
                                    Adapter "egigeozone"     is not installed.
                                    Adapter "ekey"           is not installed.
                                    Adapter "email"          is not installed.
                                    Adapter "emby"           is not installed.
                                    Adapter "energymanager"  is not installed.
                                    Adapter "enet"           is not installed.
                                    Adapter "epson_ecotank_et_2750" is not installed.
                                    Adapter "epson_stylus_px830" is not installed.
                                    Adapter "exchangerates"  is not installed.
                                    Adapter "fahrplan"       is not installed.
                                    Adapter "fakeroku"       is not installed.
                                    Adapter "fb-checkpresence" is not installed.
                                    Adapter "feiertage"      is not installed.
                                    Adapter "fhem"           is not installed.
                                    Adapter "find-my-iphone" is not installed.
                                    Adapter "firetv"         is not installed.
                                    Adapter "flot"           is up to date.
                                    Adapter "followthesun"   is not installed.
                                    Adapter "foobar2000"     is not installed.
                                    Adapter "fritzbox"       is not installed.
                                    Adapter "fritzdect"      is not installed.
                                    Adapter "fronius"        is not installed.
                                    Adapter "frontier_silicon" is not installed.
                                    Adapter "fuelpricemonitor" is not installed.
                                    Adapter "fullcalendar"   is not installed.
                                    Adapter "fullybrowser"   is not installed.
                                    Adapter "g-homa"         is not installed.
                                    Adapter "geofency"       is not installed.
                                    Adapter "go-e"           is not installed.
                                    Adapter "growatt"        is not installed.
                                    Adapter "gruenbeck"      is not installed.
                                    Adapter "haassohn"       is not installed.
                                    Adapter "habpanel"       is not installed.
                                    Adapter "haier"          is not installed.
                                    Adapter "ham"            is not installed.
                                    Adapter "ham-wemo"       is not installed.
                                    Adapter "harmony"        is not installed.
                                    Adapter "heatingcontrol" is not installed.
                                    Adapter "heos"           is not installed.
                                    Adapter "heytech"        is not installed.
                                    Adapter "hid"            is not installed.
                                    Adapter "history"        is up to date.
                                    Adapter "hm-rega"        is not installed.
                                    Adapter "hm-rpc"         is not installed.
                                    Adapter "hmip"           is not installed.
                                    Adapter "homeconnect"    is not installed.
                                    Adapter "homee"          is not installed.
                                    Adapter "homepilot"      is not installed.
                                    Adapter "hp-ilo"         is not installed.
                                    Adapter "hs100"          is not installed.
                                    Adapter "hue"            is not installed.
                                    Adapter "hue-extended"   is not installed.
                                    Adapter "i2c"            is not installed.
                                    Adapter "ical"           is not installed.
                                    Adapter "icons-addictive-flavour-png" is not installed.
                                    Adapter "icons-fatcow-hosting" is not installed.
                                    Adapter "icons-icons8"   is not installed.
                                    Adapter "icons-material-png" is not installed.
                                    Adapter "icons-material-svg" is not installed.
                                    Adapter "icons-mfd-png"  is not installed.
                                    Adapter "icons-mfd-svg"  is not installed.
                                    Adapter "icons-open-icon-library-png" is not installed.
                                    Adapter "icons-ultimate-png" is not installed.
                                    Adapter "influxdb"       is not installed.
                                    Adapter "info"           is up to date.
                                    Adapter "innogy-smarthome" is not installed.
                                    Adapter "iogo"           is not installed.
                                    Adapter "iot"            is not installed.
                                    Adapter "iqontrol"       is not installed.
                                    Adapter "jarvis"         is not installed.
                                    Adapter "javascript"     is up to date.
                                    Adapter "jeelink"        is not installed.
                                    Adapter "kecontact"      is not installed.
                                    Adapter "klf200"         is not installed.
                                    Adapter "km200"          is not installed.
                                    Adapter "knmi-weather"   is not installed.
                                    Adapter "knx"            is not installed.
                                    Adapter "kodi"           is not installed.
                                    Adapter "kostal-piko-ba" is not installed.
                                    Adapter "kress"          is not installed.
                                    Adapter "lametric"       is not installed.
                                    Adapter "landroid"       is not installed.
                                    Adapter "lcn"            is not installed.
                                    Adapter "legrand-ecocompteur" is not installed.
                                    Adapter "letrika_comgw"  is not installed.
                                    Adapter "lgtv"           is not installed.
                                    Adapter "lgtv-rs"        is not installed.
                                    Adapter "lgtv11"         is not installed.
                                    Adapter "lifx"           is not installed.
                                    Adapter "lightify"       is not installed.
                                    Adapter "link"           is not installed.
                                    Adapter "linkeddevices"  is not installed.
                                    Adapter "linktap"        is not installed.
                                    Adapter "linux-control"  is not installed.
                                    Adapter "logparser"      is not installed.
                                    Adapter "lovelace"       is not installed.
                                    Adapter "loxone"         is not installed.
                                    Adapter "luftdaten"      is not installed.
                                    Adapter "lupusec"        is not installed.
                                    Adapter "luxtronik1"     is not installed.
                                    Adapter "material"       is not installed.
                                    Adapter "maxcube"        is not installed.
                                    Adapter "maxcul"         is not installed.
                                    Adapter "mbus"           is not installed.
                                    Adapter "mclighting"     is not installed.
                                    Adapter "megad"          is not installed.
                                    Adapter "megadd"         is not installed.
                                    Adapter "megaesp"        is not installed.
                                    Adapter "melcloud"       is not installed.
                                    Adapter "mercedesme"     is not installed.
                                    Adapter "mercury"        is not installed.
                                    Adapter "meross"         is not installed.
                                    Adapter "meteoalarm"     is not installed.
                                    Adapter "midea"          is not installed.
                                    Adapter "miele"          is not installed.
                                    Adapter "mielecloudservice" is not installed.
                                    Adapter "mihome"         is not installed.
                                    Adapter "mihome-lamp"    is not installed.
                                    Adapter "mihome-plug"    is not installed.
                                    Adapter "mihome-vacuum"  is not installed.
                                    Adapter "mikrotik"       is not installed.
                                    Adapter "milight"        is not installed.
                                    Adapter "milight-smart-light" is not installed.
                                    Adapter "minuvis"        is not installed.
                                    Adapter "mobile"         is not installed.
                                    Adapter "modbus"         is not installed.
                                    Adapter "moma"           is not installed.
                                    Adapter "mpd"            is not installed.
                                    Adapter "mqtt"           is up to date.
                                    Adapter "mqtt-client"    is not installed.
                                    Adapter "musiccast"      is not installed.
                                    Adapter "mydlink"        is not installed.
                                    Adapter "mysensors"      is not installed.
                                    Adapter "nanoleaf-lightpanels" is not installed.
                                    Adapter "net-tools"      is not installed.
                                    Adapter "netatmo"        is not installed.
                                    Adapter "netatmo-crawler" is not installed.
                                    Adapter "nibeuplink"     is not installed.
                                    Adapter "nina"           is not installed.
                                    Adapter "node-red"       is not installed.
                                    Adapter "nuki"           is not installed.
                                    Adapter "nuki-extended"  is not installed.
                                    Adapter "nut"            is not installed.
                                    Adapter "octoprint"      is not installed.
                                    Adapter "odl"            is not installed.
                                    Adapter "oilfox"         is not installed.
                                    Adapter "omnicomm-lls"   is not installed.
                                    Adapter "onkyo"          is not installed.
                                    Adapter "onvif"          is not installed.
                                    Adapter "openhab"        is not installed.
                                    Adapter "openligadb"     is not installed.
                                    Adapter "openweathermap" is not installed.
                                    Adapter "opi"            is not installed.
                                    Adapter "oppoplayer"     is not installed.
                                    Adapter "owfs"           is not installed.
                                    Adapter "owntracks"      is not installed.
                                    Adapter "panasonic-viera" is not installed.
                                    Adapter "parser"         is not installed.
                                    Adapter "paw"            is not installed.
                                    Adapter "phantomjs"      is not installed.
                                    Adapter "pi-hole"        is not installed.
                                    Adapter "piface"         is not installed.
                                    Adapter "pimatic"        is not installed.
                                    Adapter "ping"           is not installed.
                                    Adapter "places"         is not installed.
                                    Adapter "plenticore"     is not installed.
                                    Adapter "plex"           is not installed.
                                    Adapter "plexconnect"    is not installed.
                                    Adapter "pollenflug"     is not installed.
                                    Adapter "proxmox"        is not installed.
                                    Adapter "proxy"          is not installed.
                                    Adapter "pushbullet"     is not installed.
                                    Adapter "pushover"       is not installed.
                                    Adapter "pushsafer"      is not installed.
                                    Adapter "radar2"         is not installed.
                                    Adapter "radiohead"      is not installed.
                                    Adapter "rflink"         is not installed.
                                    Adapter "rickshaw"       is not installed.
                                    Adapter "ring"           is not installed.
                                    Adapter "robonect"       is not installed.
                                    Adapter "roomba"         is not installed.
                                    Adapter "rpi2"           is up to date.
                                    Adapter "s7"             is not installed.
                                    Adapter "sainlogic"      is not installed.
                                    Adapter "samsung"        is not installed.
                                    Adapter "sanext"         is not installed.
                                    Adapter "sayit"          is not installed.
                                    Adapter "sbfspot"        is not installed.
                                    Adapter "scenes"         is not installed.
                                    Adapter "schoolfree"     is not installed.
                                    Adapter "schwoerer-ventcube" is not installed.
                                    Adapter "seq"            is not installed.
                                    Adapter "shelly"         is not installed.
                                    Adapter "shuttercontrol" is not installed.
                                    Adapter "sia"            is not installed.
                                    Adapter "siegenia"       is not installed.
                                    Adapter "simple-api"     is up to date.
                                    Adapter "smappee"        is not installed.
                                    Adapter "smartcontrol"   is not installed.
                                    Adapter "smartgarden"    is not installed.
                                    Adapter "smartmeter"     is not installed.
                                    Adapter "snips"          is not installed.
                                    Adapter "snmp"           is not installed.
                                    Adapter "socketio"       is up to date.
                                    Adapter "solarlog"       is not installed.
                                    Adapter "solarviewdatareader" is not installed.
                                    Adapter "solarwetter"    is not installed.
                                    Adapter "sonnen"         is not installed.
                                    Adapter "sonoff"         is up to date.
                                    Adapter "sonos"          is not installed.
                                    Adapter "sony-bravia"    is not installed.
                                    Adapter "spotify-premium" is not installed.
                                    Adapter "sql"            is not installed.
                                    Adapter "squeezebox"     is not installed.
                                    Adapter "squeezeboxrpc"  is not installed.
                                    Adapter "starline"       is not installed.
                                    Adapter "statistics"     is not installed.
                                    Adapter "stiebel-isg"    is not installed.
                                    Adapter "sunnyportal"    is not installed.
                                    Adapter "swiss-weather-api" is not installed.
                                    Adapter "synology"       is not installed.
                                    Adapter "systeminfo"     is not installed.
                                    Adapter "tahoma"         is not installed.
                                    Adapter "tankerkoenig"   is not installed.
                                    Adapter "telegram"       is not installed.
                                    Adapter "terminal"       is not installed.
                                    Adapter "tesla-motors"   is not installed.
                                    Adapter "text2command"   is not installed.
                                    Adapter "tinker"         is not installed.
                                    Adapter "tr-064"         is not installed.
                                    Adapter "traccar"        is not installed.
                                    Adapter "tradfri"        is not installed.
                                    Adapter "trashschedule"  is not installed.
                                    Adapter "tunnelbroker-endpoint-updater" is not installed.
                                    Adapter "tuya"           is not installed.
                                    Adapter "tvprogram"      is not installed.
                                    Adapter "tvspielfilm"    is not installed.
                                    Adapter "unifi"          is not installed.
                                    Adapter "upnp"           is not installed.
                                    Adapter "vaillant"       is not installed.
                                    Adapter "valloxmv"       is not installed.
                                    Adapter "vcard"          is not installed.
                                    Adapter "velux"          is not installed.
                                    Adapter "viessmann"      is not installed.
                                    Adapter "virtualpowermeter" is not installed.
                                    Adapter "vis"            is up to date.
                                    Adapter "vis-bars"       is not installed.
                                    Adapter "vis-canvas-gauges" is not installed.
                                    Adapter "vis-colorpicker" is not installed.
                                    Adapter "vis-fancyswitch" is not installed.
                                    Adapter "vis-google-fonts" is not installed.
                                    Adapter "vis-history"    is not installed.
                                    Adapter "vis-hqwidgets"  is up to date.
                                    Adapter "vis-icontwo"    is not installed.
                                    Adapter "vis-inventwo"   is not installed.
                                    Adapter "vis-jqui-mfd"   is not installed.
                                    Adapter "vis-justgage"   is not installed.
                                    Adapter "vis-keyboard"   is not installed.
                                    Adapter "vis-lcars"      is not installed.
                                    Adapter "vis-map"        is not installed.
                                    Adapter "vis-material-advanced" is not installed.
                                    Adapter "vis-metro"      is not installed.
                                    Adapter "vis-players"    is not installed.
                                    Adapter "vis-plumb"      is not installed.
                                    Adapter "vis-rgraph"     is not installed.
                                    Adapter "vis-timeandweather" is not installed.
                                    Adapter "vis-weather"    is not installed.
                                    Adapter "volumio"        is not installed.
                                    Adapter "volvo"          is not installed.
                                    Adapter "vr200"          is not installed.
                                    Adapter "vw-connect"     is not installed.
                                    Adapter "weatherunderground" is not installed.
                                    Adapter "web"            is up to date.
                                    Adapter "weishaupt-wem"  is not installed.
                                    Adapter "whatsapp-cmb"   is not installed.
                                    Adapter "wiffi-wz"       is not installed.
                                    Adapter "wifilight"      is not installed.
                                    Adapter "windows-control" is not installed.
                                    Adapter "wled"           is not installed.
                                    Adapter "wm-bus"         is not installed.
                                    Adapter "wolf"           is not installed.
                                    Adapter "worx"           is not installed.
                                    Adapter "xbox"           is not installed.
                                    Adapter "xs1"            is not installed.
                                    Adapter "yahka"          is up to date.
                                    Adapter "yamaha"         is not installed.
                                    Adapter "yeelight-2"     is not installed.
                                    Adapter "youtube"        is not installed.
                                    Adapter "yr"             is not installed.
                                    Adapter "zigbee"         is not installed.
                                    Adapter "zont"           is not installed.
                                    Adapter "zwave2"         is not installed.
                                    • I Ibot
                                      alles schick
                                      update done
                                      @ibot
                                      Gut.
                                        @ibot
                                        Gut.
                                        I Offline
                                        I Offline
                                        Ibot
                                        Besten Dank!
                                        • I Ibot
                                          ich hoffe es ist nicht das Tool das ich befürchte
