  4. Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren
    6.5k
vis update
33 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @ibot
    iobroker -v
    I Offline
    I Offline
    Ibot
    @wendy2702
    3.2.16
    • I Ibot
      @wendy2702
      3.2.16
      @ibot
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      liefert?
      I 1 Antwort Letzte Antwort
      • I Ibot
        Hier der Fehlercode dazu nach der Aktualisierung schmiert der komplette Iobroker ab kann ihn nur durch einspielen eines Backups wieder zu laufen bringen
        $ ./iobroker upgrade vis
        Update vis from @1.3.4 to @1.3.8
        NPM version: 6.14.12npm install iobroker.vis@1.3.8 --loglevel error --prefix "/opt/iobroker" (System call)
        ERROR: internal/modules/cjs/loader.js:818  throw err;  ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)    at Function.Module._load (internal/modules/cjs/loader.js:667:27)    at Module.require (internal/modules/cjs/loader.js:887:19)    at require (internal/modules/cjs/helpers.js:74:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:525:24)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:211:28    at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2557:9)    at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:205:13)    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:419:21    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:223:55 {  code: 'MODULE_NOT_FOUND',  requireStack: [    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js',    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js',    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'  ]}
        ERROR: process exited with code 1```
        @ibot sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
        Habe gerade für dich mal das Forum nach diesem Fehler durchsucht.
        Konnte nur "Probleme" in Zusammenhang mit einer Windows-Installation finden.
          @ibot
          liefert?
          I Offline
          I Offline
          Ibot
          @thomas-braun sagte in Vis lässt sich nicht von 1.3.4 zu 1.3.8 aktualisieren:
          /usr/bin/nodejs
          v12.22.1
          /usr/bin/node
          v12.22.1
          /usr/bin/npm
          6.14.12
          nodejs:
            Installiert:           12.22.1-1nodesource1
            Installationskandidat: 12.22.1-1nodesource1
            Versionstabelle:
           *** 12.22.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          • I Ibot
            /usr/bin/nodejs
            v12.22.1
            /usr/bin/node
            v12.22.1
            /usr/bin/npm
            6.14.12
            nodejs:
              Versionstabelle:
            @ibot
            iobroker update
            iobroker upgrade
            Wenn das nicht funktioniert:
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            I 2 Antworten Letzte Antwort
              @ibot
              iobroker update
              iobroker upgrade
              cd /opt/iobroker
              I Offline
              I Offline
              Ibot
              na dem Upgrade Befehl kommt:
              Require stack:
                  at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l        ib/setup/setupUpload.js:525:24)
                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:211:28
                  at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.j        s:2557:9)
                  at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setu        p/setupUpgrade.js:205:13)
                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.        js:419:21
                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.        js:223:55 {
                requireStack: [
                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js'        ,
                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js        ',
              MOD EDIT: CODE TAGS KORRIGIERT
                @ibot
                iobroker update
                iobroker upgrade
                cd /opt/iobroker
                I Offline
                I Offline
                Ibot
                nach:cd /opt/iobroker
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                > node-gyp rebuild
                make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                In file included from ../../nan/nan.h:56,
                                 from ../src/unix_dgram.cc:5:
                /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                       (node::addon_register_func) (regfunc),                          \
                /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                 NODE_MODULE(unix_dgram, Initialize)
                  SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                  COPY Release/unix_dgram.node
                make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                > node rebuild.js
                ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                > node-gyp rebuild
                make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                  CXX(target) Release/obj.target/diskusage/src/main.o
                                 from ../src/main.cpp:3:
                ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                 NODE_MODULE(diskusage, Init)
                  CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                  SOLINK_MODULE(target) Release/obj.target/diskusage.node
                  COPY Release/diskusage.node
                make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                object _design/system updated
                > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                > node scripts/postinstall
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                + iobroker.js-controller@3.2.16
                added 254 packages from 265 contributors, removed 6 packages, updated 1 package and moved 16 packages in 96.989s
                13 packages are looking for funding
                  run `npm fund` for details
                   │      New major version of npm available! 6.14.12 → 7.10.0      │
                   │   Changelog: https://github.com/npm/cli/releases/tag/v7.10.0   │
                   │               Run npm install -g npm to update!                │
                • I Ibot
                  > node-gyp rebuild
                  > node rebuild.js
                  > node-gyp rebuild
                  @ibot
                  Und?
                    @ibot
                    Und?
                    I Offline
                    I Offline
                    Ibot
                    iobroker ist über die webobefläche nicht mehr ereichbar soll ich das npm Update durchführen?
                    • I Ibot
                      @ibot
                      Auf gar keinen Fall!
                      Das macht es nur schlimmer.
                      npm wird nur über den Paketmanager aktualisiert, im Zuge eine Updates von nodejs.
                      iobroker status
                      iobroker list adapters
                      iobroker list instances
                        @ibot
                        iobroker status
                        I Offline
                        I Offline
                        Ibot
                        iobroker status
                        pi@raspberrypi:/opt/iobroker $ iobroker status
                        Objects type: file
                        States  type: file
                        pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                        system.adapter.admin                   : admin          - v4.2.1
                        system.adapter.discovery               : discovery      - v2.6.1
                        system.adapter.flot                    : flot           - v1.10.6
                        system.adapter.history                 : history        - v1.9.12
                        system.adapter.info                    : info           - v1.7.14
                        system.adapter.javascript              : javascript     - v5.0.14
                        system.adapter.mqtt                    : mqtt           - v2.3.5
                        system.adapter.mqtt-client             : mqtt-client    - v1.3.1
                        system.adapter.node-red                : node-red       - v2.2.0
                        system.adapter.rpi2                    : rpi2           - v1.2.0
                        system.adapter.sonoff                  : sonoff         - v2.4.0
                        system.adapter.vis                     : vis            - v1.3.4
                        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                        system.adapter.web                     : web            - v3.3.0
                        system.adapter.yahka                   : yahka          - v0.12.0
                        pi@raspberrypi:/opt/iobroker $ iobroker list instances
                          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                          system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                        + instance is alive
                        • I Ibot
                          iobroker status
                          Objects type: file
                          States  type: file
                          + instance is alive
                          @ibot
                          Sollte eigentlich laufen. Welche Meldungen bekommst du?
                          HomoranH I 2 Antworten Letzte Antwort
                            @ibot
                            sehe ich auch so!
                            @Ibot
                            hast du mal den Browsercache gelöscht?
                              @ibot
                              I Offline
                              I Offline
                              Ibot
                              Im Browser steht
                              Cannot GET /
                              • I Ibot
                                Im Browser steht
                                Cannot GET /
                                Starte den Pi mal sauber durch:
                                iobroker stop
                                sudo reboot
                                Und BrowserCache löschen, wie @Homoran schon sagte.
                                  sehe ich auch so!
                                  @Ibot
                                  I Offline
                                  I Offline
                                  Ibot
                                  Hallo, ja habe ich sobald ich das Backup zurückspiele ist über den Browser auch alles wieder ereichbar
                                  • I Ibot
                                    @ibot
                                    Was für ein Backup?
                                    Lösch mal den npm cache
                                    cd /opt/iobroker
                                    npm cache clean --force
                                    • I Ibot
                                      von Backup hat niemand was gesagt!
                                        @ibot
                                        Was für ein Backup?
                                        cd /opt/iobroker
                                        I Offline
                                        I Offline
                                        Ibot
                                        ich habe mit dem Iobroker Tool vorab ein Backup erstellt. Nach dem Neustart ist Iobroker wieder ereichbar und Vis ist auch aktuell Top Npm Cache trotzdem noch löschen?
                                        • I Ibot
                                          @ibot
                                          Nö, wenn alles läuft lass die Finger davon.
                                          Was liefert denn jetzt ein
                                          iobroker update
                                          iobroker upgrade
