    2. mrbredon
    • Posts 6
    mrbredon
    @mrbredon
    12
    mrbredon Follow
    Latest posts made by mrbredon
    • RE: Adapter Update funktioniert nicht
      @mrbredon
      Mach mal von der konsole aus ein ping auf 8.8.8.8 und auf www.google.com
      Vielen Dank für den Tip.
      Problem ist anscheinen gelöst, hatte mich in der dhcpcd.conf vertippt und eine falsche IP Adresse für den Nameserver eingetragen.
      ping auf 8.8.8.8 ging, ping auf www.google.com nicht...
      mrbredon
      @mrbredon said in Adapter Update funktioniert nicht:
       /home/iobroker/.npm/_logs
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli '/usr/bin/node',
      1 verbose cli '/usr/bin/npm',
      1 verbose cli 'install',
      1 verbose cli 'iobroker.shelly@3.3.5',
      1 verbose cli '--loglevel',
      1 verbose cli 'error',
      1 verbose cli '--prefix',
      1 verbose cli '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.4
      3 info using node@v12.17.0
      4 verbose npm-session f26c9451252e1adf
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 warn registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/iobroker.shelly failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
      8 warn registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
      9 http fetch GET 200 https://registry.npmjs.org/iobroker.shelly 10129ms (from cache)
      10 silly registry:manifest no matching version for iobroker.shelly@3.3.5 in the cache. Forcing revalidation.
      11 silly fetchPackageMetaData error for iobroker.shelly@3.3.5 request to https://registry.npmjs.org/iobroker.shelly failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
      12 timing stage:rollbackFailedOptional Completed in 2ms
      13 timing stage:runTopLevelLifecycles Completed in 32458ms
      14 verbose type system
      15 verbose stack FetchError: request to https://registry.npmjs.org/iobroker.shelly failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
      15 verbose stack at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
      15 verbose stack at ClientRequest.emit (events.js:315:20)
      15 verbose stack at TLSSocket.socketErrorListener (_http_client.js:426:9)
      15 verbose stack at TLSSocket.emit (events.js:315:20)
      15 verbose stack at emitErrorNT (internal/streams/destroy.js:92:8)
      15 verbose stack at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
      15 verbose stack at processTicksAndRejections (internal/process/task_queues.js:84:21)
      16 verbose cwd /opt/iobroker
      17 verbose Linux 4.19.97-v7l+
      18 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.shelly@3.3.5" "--loglevel" "error" "--prefix" "/opt/iobroker"
      19 verbose node v12.17.0
      20 verbose npm v6.14.4
      21 error code EAI_AGAIN
      22 error errno EAI_AGAIN
      23 error request to https://registry.npmjs.org/iobroker.shelly failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
      24 verbose exit [ 1, true ]
      mrbredon
      Welcher?
      "Update JS-Controller auf 3.1.6 schlägt fehl"
      Warum dann hier noch mal?
      Bin mir nicht sicher ob die zwei Themen zusammenhängen.
      Was passiert nach leeren des Browsercaches ?
      Das Gleiche, keine Änderung
      Beispiel Adapter Shelly vorher 3.3.4, Update soll auf 3.3.5.
      Hinterher immer noch 3.3.4
      Was steht im log?
      $ ./iobroker upgrade shelly
      Update shelly from @3.3.4 to @3.3.5
      NPM version: 6.14.4npm install iobroker.shelly@3.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code EAI_AGAINnpm ERR! errno EAI_AGAINnpm ERR! request to https://registry.npmjs.org/iobroker.shelly failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.orgnpm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-11T08_32_39_848Z-debug.log
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
      Adapter "shelly" updated
      process exited with code 0
      mrbredon
    • Adapter Update funktioniert nicht
      wie bereits im entsprechenden Thread beschrieben kann ich den JS controller nicht updaten.
      Zusätzlich dazu habe ich das Problem, dass kein einziges Adapter-Update funktioniert.
      Derzeit habe ich 14 Update die upgedated werden können.
      Das Update lässt sich starten, ended Erfolgreich (mit code 0) aber wurde nicht durchgeführt.
      Die Versionsnummer bleibt unverändert.
      Auch neue Adapter lassen sich nicht erstellen.
      Aufgefallen ist mir das erstmals nachdem ich einen neuen Rooter installiert hat.
      Der iobroker läuft auf einem Raspberry 4 und hat durch den neuen Rooter eine andere IP Adresse bekommen.
      Kann das zusammenhängen ?
      Wie könnte ich das testen ?
      Danke für Eure Hilfe ?
      Axel
      mrbredon
    • RE: Update JS-Controller auf 3.1.6 schlägt fehl
      @Homoran
      Ja, gleiche Meldung
      mrbredon
      @arteck
      Gibt es hierzu was Neues ?
      Läuft der Server wieder ?
      Hab das gleiche Problem, kann auch keine Adapter installieren oder updaten...
      mrbredon
