    2. hstkai
    H
    • Posts 8
    hstkai
    @hstkai
    hstkai Follow
    Latest posts made by hstkai
    • RE: Skripte unregelmäßig ausgeführt / Objektwerte (Null)
      @hstkai
      hier das ausführliche
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
      Hardware Vendor :
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.1.0
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       14:42:50 up 7 days,  3:29,  0 users,  load average: 4.85, 5.20, 4.31
      CPU threads: 4
      *** Time and Time Zones ***
      Tue Sep 19 12:42:50 UTC 2023
      Tue Sep 19 14:42:50 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             15G        6.6G        1.2G        378M        8.1G        8.3G
      Swap:            23G         11M         23G
      Total:           39G        6.6G         24G
              15900 M total memory
               6632 M used memory
               3495 M active memory
               9580 M inactive memory
               1178 M free memory
               2315 M buffer memory
               5773 M swap cache
              23447 M total swap
                 11 M used swap
              23435 M free swap
      *** FILESYSTEM ***
      Filesystem            Type     Size  Used Avail Use% Mounted on
      overlay               overlay  2.8T  2.2T  681G  77% /
      tmpfs                 tmpfs     64M     0   64M   0% /dev
      tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
      shm                   tmpfs     64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev1 ext4     2.8T  2.2T  681G  77% /opt/iobroker
      tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
      tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
      tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
      tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET           SOURCE        FSTYPE OPTIONS
      /opt/iobroker    /dev/mapper/cachedev1[/Docker/iobroker-data]        ext4   rw,relatime,noacl,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/1de3f931a553bbd177e7c3176ab904017e83ca751e690bbb7c40087ddf674703/resolv.conf] ext4   rw,relatime,noacl,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/1de3f931a553bbd177e7c3176ab904017e83ca751e690bbb7c40087ddf674703/hostname]    ext4   rw,relatime,noacl,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/1de3f931a553bbd177e7c3176ab904017e83ca751e690bbb7c40087ddf674703/hosts]       ext4   rw,relatime,noacl,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      4.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      634M    /opt/iobroker/iobroker-data/
      431M    /opt/iobroker/iobroker-data/files
      135M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      31M     /opt/iobroker/iobroker-data/states.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.3 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: typescript@5.1.6 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! invalid: cli@1.0.1 /opt/iobroker/node_modules/cli
      npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-09-19T12_43_01_396Z-debug-0.log
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   7
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
      + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
      + system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 -  enabled
        system.adapter.history.0                : history               : iobroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 - disabled, port: 8001
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "device-reminder": 2.0.1  , installed 2.0.1
      Adapter    "discovery"    : 4.0.0    , installed 4.0.0
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "history"      : 3.0.0    , installed 2.2.6  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "klf200"       : 1.0.1    , installed 1.0.1
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
      Adapter    "openligadb"   : 1.3.4    , installed 1.3.4
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pushover"     : 3.0.4    , installed 3.0.4
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
      Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.3
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Objects and States
      Objects:        19665
      States:         16973
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 192.168.178.100:12001   0.0.0.0:*               LISTEN      1000       55206816   -
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       202303     -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       203360     -
      tcp        0      0 127.0.0.11:45161        0.0.0.0:*               LISTEN      0          147778     -
      tcp        0      0 192.168.178.100:12010   0.0.0.0:*               LISTEN      1000       55208023   -
      tcp        0      0 192.168.178.100:18701   0.0.0.0:*               LISTEN      1000       55207952   -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       55141599   -
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       215832     -
      tcp6       0      0 :::8000                 :::*                    LISTEN      1000       268332     -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       55119163   -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       54903017   -
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       54893949   -
      udp        0      0 127.0.0.11:47990        0.0.0.0:*                           0          147777     -
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       214485     -
      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1000       226960     -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       232117     -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       217057     -
      udp        0      0 0.0.0.0:36548           0.0.0.0:*                           1000       229025     -
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       54888106   -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       213967     -
      2023-09-19 14:44:06.972  - info: radar2.0 (499) debug: ChangeState ack:true of Ich._nHere = 4153
      2023-09-19 14:44:07.024  - info: radar2.0 (499) debug: ChangeState ack:true of Fritzbox._nHere = 25207
      2023-09-19 14:44:07.032  - info: radar2.0 (499) debug: ChangeState ack:true of Kai._nHere = 668
      2023-09-19 14:44:07.036  - info: radar2.0 (499) debug: radar2 found here (Ich, Fritzbox, Kai)
      2023-09-19 14:44:07.036  - info: radar2.0 (499) debug: and who here (Fritzbox, Kai)
      2023-09-19 14:44:07.037  - info: radar2.0 (499) debug: and not here (HP_ENVY_4504, Annett, Samsung)
      2023-09-19 14:44:07.037  - info: radar2.0 (499) debug: radar2 found uBT's: []
      2023-09-19 14:44:07.038  - info: radar2.0 (499) debug: radar2 found uIP's: []
      2023-09-19 14:44:07.360  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
      2023-09-19 14:44:07.780  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
      2023-09-19 14:44:07.840  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
      2023-09-19 14:44:07.844  - warn: shelly.0 (506) [authEnabled] 192.168.178.177 (shellyplug-s / shellyplug-s-083A8DC30DAD / SHPLG-S#083A8DC30DAD#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:08.087  - warn: shelly.0 (506) [authEnabled] 192.168.178.57 (shelly1 / shelly1-E20174 / SHSW-1#E20174#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:08.093  - warn: shelly.0 (506) [authEnabled] 192.168.178.93 (shelly1pm / shelly1pm-485519CB710A / SHSW-PM#485519CB710A#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:08.649  - warn: shelly.0 (506) [authEnabled] 192.168.178.80 (shellydimmer2 / shellydimmer2-E09806967117 / SHDM-2#E09806967117#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:09.331  - warn: shelly.0 (506) [authEnabled] 192.168.178.195 (shellyplug-s / shellyplug-s-083A8DC33514 / SHPLG-S#083A8DC33514#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:12.385  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
      2023-09-19 14:44:12.459  - warn: shelly.0 (506) [authEnabled] 192.168.178.40 (shellyswitch25 / shellyswitch25-E5E49E / SHSW-25#E5E49E#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:12.793  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
      2023-09-19 14:44:12.880  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
      2023-09-19 14:44:14.215  - warn: shelly.0 (506) [authEnabled] 192.168.178.56 (shellyswitch25 / shellyswitch25-E8DB84A979A7 / SHSW-25#E8DB84A979A7#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:15.357  - warn: shelly.0 (506) [authEnabled] 192.168.178.196 (shellyplug-s / shellyplug-s-083A8DC1686A / SHPLG-S#083A8DC1686A#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:15.718  - warn: shelly.0 (506) [authEnabled] 192.168.178.82 (shelly1 / shelly1-84CCA8A56528 / SHSW-1#84CCA8A56528#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:15.751  - warn: shelly.0 (506) [authEnabled] 192.168.178.160 (shelly1 / shelly1-E0E9CF / SHSW-1#E0E9CF#1): This device is not protected via restricted login (see adapter documentation for details)
      2023-09-19 14:44:17.358  - info: enigma2.0 (32582) State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
      H
      hstkai
      @codierknecht
      iob diag sagt:
                           v.2023-06-20
      model name      : Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.1.0
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     1
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Mem:             15G        6.7G        1.1G        378M        8.1G        8.2G
      Swap:            23G         11M         23G
      Total:           39G        6.7G         24G
      Active iob-Instances:   41
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                19665
      States:                 16973
      Size of iob-Database:
      24M     /opt/iobroker/iobroker-data/states.jsonl
      Was die Auslastung angeht.. iobroker läuft im Docker auf einem QNAP Server. Bei ca. 40% Auslastung sind das die einzelnen Prozesse
      H
      hstkai
      @codierknecht
      Schwach aufgestellt ... denke ich nicht.
      Adapter und System ist auch aktuell.
      H
      hstkai
      @codierknecht
      Bei den Fragezeichen hab ich mir nur hinterlegt, welcher State welche Zahl hat.
      H
      hstkai
      Hier ist das Skript, wo die Steuerung nicht mehr funktioniert.
      Objekte bei der Selektion
      Objekte bei der Selektion nach 30 sek Warten
      H
      hstkai
    • Skripte unregelmäßig ausgeführt / Objektwerte (Null)
      Hallo, ich habe seit ein paar Tagen Probleme mit einigen Skripten, die nur noch mehr oder weniger zuverlässig ausgeführt werden. Ich weiß jetzt leider nicht wo ich ansetzen soll zur Lösung. Aufgefallen ist mir nur, wenn ich im Blockly eine Objekt ID auswähle und sich der Objektbaum aufbaut, alle Werte auf (Null) stehen, in rot. Nach ca. 30 Sekunden erscheinen die tatsächlichen Werte. Wenn ich über den Tab Objekte den Objektbaum aufrufe, sind alle Werte sofort da.
      Bitte sagt mir, was Ihr noch an Input braucht um mir helfen zu können. 🙂
      H
      hstkai
    • RE: Problem Yeelight Adapter, Licht geht alleine an
      Niemand einen Ratschlag für mich?
      Hier ist mal der Log vom Adapter nach dem Ausschalten
      yeelight-2.0	2020-01-01 22:20:30.384	debug	(12634) DEVICE FOUND SET NOTIFY STATE: {"name":"ceiling3-0x0000000005efac33","ip":"192.168.178.49","port":"55443","smart_name":"Deckenlampe","type":"ceiling3","id":"0x0000000005efac33"}
      yeelight-2.0	2020-01-01 22:20:30.382	debug	(12634) NOTIFY MESSAGE: from: 0x0000000005efac33, message: {"method":"props","params":{"power":"on"}}
      yeelight-2.0	2020-01-01 22:20:30.377	debug	(12634) RESPONSE MESSAGE: from: 0x0000000005efac33, id: 43, result:[ok]}
      yeelight-2.0	2020-01-01 22:20:30.367	debug	(12634) SEND STATE: id:0x0000000005efac33, state: power, value: true
      yeelight-2.0	2020-01-01 22:20:30.329	debug	(12634) DEVICE FOUND IN CONFIG: {"name":"ceiling3-0x0000000005efac33","ip":"192.168.178.49","port":"55443","smart_name":"Deckenlampe","type":"ceiling3","id":"0x0000000005efac33"}
      yeelight-2.0	2020-01-01 22:20:30.328	debug	(12634) RESPONSE MESSAGE: from: 0x0000000005efac33, id: 42, result:[off,100,,2,4000]}
      Woher kann die Zeile 4 stammen?
      Dazu nochmal aus der Ereignisliste
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.power	true	true	yeelight-2.0	2020-01-01 22:20:30.389	2020-01-01 22:20:30.361
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.power	true	false	javascript.0	2020-01-01 22:20:30.361	2020-01-01 22:20:30.361
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.ct	"4000"	true	yeelight-2.0	2020-01-01 22:20:30.339	2020-01-01 21:43:16.534
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.color_mode	false	true	yeelight-2.0	2020-01-01 22:20:30.337	2019-11-22 18:03:16.293
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.active_bright	"100"	true	yeelight-2.0	2020-01-01 22:20:30.336	2020-01-01 22:20:30.336
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.power	false	true	yeelight-2.0	2020-01-01 22:20:30.334	2020-01-01 22:20:00.237
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.power	false	true	yeelight-2.0	2020-01-01 22:20:00.301	2020-01-01 22:20:00.237
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.power	false	false	javascript.0	2020-01-01 22:20:00.237	2020-01-01 22:20:00.237
      stateChange	yeelight-2.0.ceiling3-0x0000000005efac33.control.active_bright	0	false	web.0	2020-01-01 22:20:00.216	2020-01-01 22:20:00.216
      Zeilen 3-6 sind mir unerklärlich woher das kommt.
      H
      hstkai
    • Problem Yeelight Adapter, Licht geht alleine an
      irgendwie macht sich der Adapter bei meiner Ceiling Light 480 selbstständig.
      Über eine Visualisierung steuere ich den Level mit drei Schaltern, einer macht Level +10, einer macht Level -10 und einer macht Level auf 0. Alles geht soweit, betätige ich den Level 0 Schalter geht die Lampe auch aus.
      Was ich aber nicht verstehe... kurze Zeit später geht die Lampe von alleine auf den letzten Level-Wert und ist an.
      Was mache ich falsch?
      VG
      H
      hstkai
