    2. andre1000
    A
    • Topics 13
    • Posts 35
    andre1000
    @andre1000
    35
    andre1000 Follow
    Latest posts made by andre1000
    • Zigbee Adapter Brightness wird nicht gesendet
      Moin,
      ich habe ein Problem mit dem Zigbee Adapter. Es werden keine Brightness Befehle an Dimmer umgesetzt. Habe dies mit unterschiedlichen Zigbee Dimmern probiert. Es ist jeweils das gleiche Problem
      Zigbee Adpter: v1.10.3
      Zigbee Dimmer: TS0052_2 und QS-Zigbee-D02-TRIAC-2C-LN
      Log File:
      zigbee.0  2024-10-10 21:43:27.999	debug	Stack trace for null: Error: At least one of "brightness" or "state" must have a value: '{"brightness_l1":43}' at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/converters/toZigbee.ts:1063:23) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:754:52 at processTicksAndRejections (node:internal/process/task_queues:95:5)
      zigbee.0  2024-10-10 21:43:27.998	error	Send command to 0xa4c138bb20d870fa failed with no error code (undefined)
      zigbee.0  2024-10-10 21:43:27.997	debug	convert brightness_l1, 43, {"brightness_l1":17,"transition_time":5,"brightness_l2":0,"transition":5,"brightness":43}
      zigbee.0  2024-10-10 21:43:27.996	debug	publishFromState : 0xa4c138bb20d870fa TS0052_2 [{"stateDesc":{"id":"brightness_l1","name":"Brightness l1","role":"level.dimmer","write":true,"read":true,"type":"number","min":0,"max":100,"inOptions":true,"epname":"l1","setattr":"brightness","readable":true,"writable":true},"value":17,"index":0,"timeout":0}]
      zigbee.0  2024-10-10 21:43:27.994	debug	Change state 'brightness_l1' at device 0xa4c138bb20d870fa type 'TS0052_2'
      zigbee.0  2024-10-10 21:43:27.900	debug	User stateChange zigbee.0.a4c138bb20d870fa.brightness_l1 {"val":17,"ack":false,"ts":1728589407899,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1728589407899}
      zigbee.0  2024-10-10 21:43:27.897	debug	SetState_typed : converting "17" for zigbee.0.a4c138bb20d870fa.brightness_l1 from string to number
      Im letzten Jahr hat es funktioniert. Ich weiß leider nicht mehr, welche Version ich da hatte.
      Vielen Dank für die Hilfe,
      André
      A
      andre1000
    • Wiegand Fingerprint TCP/IP
      ich möchte gerne mehrere Fingerprintsensoren gemeinsam verwalten. Wichtig ist mir dabei, dass ich den Fingerprint zentral über einen Server auf die anderen Sensoren verteilen kann. Ist dies über das Wiegand Protokoll überhaupt möglich?
      Habe mir folgenden Geräte vorgestellt:
      Controller: https://www.amazon.de/-/en/Dongyang-Wiegand-Network-Control-Controller/dp/B07SR3C24C?th=1
      Fingerprintsensor: https://www.conrad.de/de/p/sygonix-sy-4760958-fingerprint-rfid-zugangssystem-unterputz-12-v-dc-18-v-dc-ip66-2380479.html
      Im nächsten Schritt suche ich dann noch einen Zugang zu iobroker. Aber eins nach dem anderen.
      Danke,
      André
      A
      andre1000
    • Instanz bei Systemstart deaktivieren
      Moin zusammen,
      ich habe aktuell das Problem, dass bei einem Neustart des iobroker Recheners eine Instanz (History) für eine lange Zeit einen sehr hohen CPU Leistung in Anspruch nimmt und teilweise einen Absturz provoziet.
      Dieses Problem möchte ich separat lösen. Benötige aber bis dahin eine Lösung, um das System am Laufen zu halten.
      Nun zu meiner Frage:
      Ist es möglich, eine Instanz so zu deklarieren, dass diese beim Starten vom iobroker deaktiviert ist? Dann kann ich diese dann nach einer gewissen Zeit übe ein Javascript starten - Dies funktioniert bereits gut.
      Danke für die Unterstützung.
      André
      A
      andre1000
    • RE: Alexa 2.1 - Anmeldung nicht möglich
      @thomas-braun Jupp, Alexa in der Version 3.8.1
      A
      andre1000
    • Alexa 2.1 - Anmeldung nicht möglich
      Moin zusammen,
      habe folgendes Problem. Nach Installation des Alexa2.1 Adapters möchte ich mich mit meinem Account anmelden. Dazu bietet der Adapter einen Link an. Wenn ich diesen Starte, dann kann ich mich bei Amazon anmelden. Jedoch wird anschließend auf eine nichtvorhandene Seite weitergeleitet. Somit wurden auch keine Daten in den Adapter übertragen. Hat jemand eine Idee, wie ich das Problem beseitigen / umgehen kann?
      Danke für die Hilfe,
      André
      A
      andre1000
    • SONOS Gruppierung
      Moin zusammen,
      ich habe ein Problem mit der Steuerung von einzelnen Lautsprechern einer Gruppe.
      Wenn ich die Lautstärke des coordinators über "volume" ändere, dann lässt sich dieser nicht ändern. Ich habe mir die Daten mal protokolliert. Hier ist ersichtlich, dass der Wert durch den Adapter wieder zurückgesetzt wird.
      Wert	Bestätigt	Quelle	        Zeit
      4 	false 	        sonos.0 	2021-03-22 21:17:17.552
      10 	false 	        sonos.0 	2021-03-22 21:17:17.509
      10 	false 	        admin.0 	2021-03-22 21:17:17.356
      4 	false 	        sonos.0 	2021-03-22 21:17:13.749
      10 	false 	        sonos.0 	2021-03-22 21:17:13.649
      10 	false 	        admin.0 	2021-03-22 21:17:13.548
      4 	false 	        sonos.0 	2021-03-22 21:17:09.088
      Bei den anderen Lautsprechen funktioniert es.
      Ich habe es mit Sonos 2.0.1 und 2.1.1 getestet.
      Über die Sonos App funktioniert es.
      André
      A
      andre1000
    • RE: Latenzzeit beim Schreiben eines Zustandes
      Ich habe redis installiert. Nach dem ersten Test sah es wirklich super aus. Antwortzeit nach ca. 10ms. Jetzt zwei Stunden später ist die Zeit auf ca. 35ms angestiegen. Werde morgen mal das geasmte System neu starten und dann berichten.
      @Homoran die SSD ist direkt am SATA Anschluss dran.
      posted in JavaScript
      A
      andre1000
      Redis habe ich noch nicht ausprobiert. Hier wage ich mich aktuell noch nicht ran.
      Am BananaPI habe ich eine SSD Platte auf der das gesamte System läüft. Gesamtprozessorlast ('system.host.BPI-M1-ioBroker.load') liegt im Schnitt bei 85% und RAM ('system.host.BPI-M1-ioBroker.mem') bei 35% bei den Instanzen wird für den js-.controller 80MB angezeigt..
      Existiert eine gute Anleitung, wie ich Redis einfach in ioBroker implementiert bekomme und im js.controller anspreche?
      A
      andre1000
      ja, es stimmt, der erste Trigger kommt von NodeRed. Nur danach habe ich mehrere js gesteuerte Zustandstrigger.
      Hier mals kurz der Ablauf bei mir:
      • Taster wird von Steuerung erfasst und per CAN gesendet
        Daten kommen
      • von CAN über NodeRed in ioBroker
      • Anaylse welcher Taster betätigt wurde
      • Änderung des Zustandes in ioBroker
      • Erstellen des CAN-Objektes für das Schalten
      • Übertragen des Zustandes an NodeRed
      All dies mach ich über Zustände. Aus diesem Grunde habe ich mit dem Zeitversatz ein paar Probleme.
      A
      andre1000
      mein Projekt ist noch ziemlich übersichtlich. Ich nutze nodered als Interface zu den Steuerungen, die per CAN angesprochen werden.
      Beim Ausführen des Testscripts wurde kein weiteres Script getriggert.
      Allgemein hat js.controller som um die 40 Triggerbedinungen, die jeweils mit getState und setState arbeiten. Jedoch werden von diesen Triggerbedingungen maximal 4 parallel ausgeführt.
      ioBroker läuft auf einem BananaPi M1.
      Ich hoffe hiermit konnte ich das System ausreichend zu beschreiben.
      A
      andre1000
