  4. [gelöst]RFLink Adapter installation
    5.8k
5 Beiträge 3 Kommentatoren 929 Aufrufe
    thps
    Hallo Forum,
    leider bekomme ich den RFLink Adapter nicht installiert. Bei der Installation werden mir etliche Fehler geworfen:
    ! $ ./iobroker add rflink
    ! npm install iobroker.rflink –production --prefix "/opt/iobroker" (System call)
    ! npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3 because of error: { Error: not found: git
    ! npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN
    ! addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! npm
    ! WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit
    ! at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47 because of error: { Error: not found: git
    ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
    ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-avrgirl-31bc3a47: undefined
    ! node-pre-gyp
    ! ERR!
    ! Tried to download(404): https://github.com/tessel/node-usb/rele ... arm.tar.gz
    ! node-pre-gyp ERR!
    ! Pre-built binaries not found for usb@1.3.1 and node@6.12.3 (node-v48 ABI, glibc) (falling back to source compile with node-gyp)
    ! gyp
    ! WARN
    ! EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"
    ! gyp WARN
    ! EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
    ! make: *** Keine Regel vorhanden, um das Ziel �../.node-gyp/6.12.3/include/node/common.gypi�, ben�tigt von �Makefile�, zu erstellen. Schluss.
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack at emitTwo (events.js:106:13)
    ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    ! gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
    ! gyp ERR! cwd /opt/iobroker/node_modules/usb
    ! gyp ERR! node -v v6.12.3
    ! gyp ERR! node-gyp -v v3.4.0
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! build error
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16)
    ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
    ! node-pre-gyp ERR! System Linux 4.9.59-v7+
    ! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
    ! node-pre-gyp ERR! node -v v6.12.3
    ! node-pre-gyp ERR! node-pre-gyp -v v0.6.39
    ! node-pre-gyp ERR! not ok
    ! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.12.3 (node-v48 ABI) (falling back to source compile with node-gyp)
    ! gyp
    ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"
    ! gyp ERR! build error
    ! gyp
    ! gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
    ! gyp ERR! cwd /opt/iobroker/node_modules/serialport
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
    ! node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    ! npm
    ! WARN optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: stk500@git://github.com/noopkat/js-stk500v1.git#avrgirl (node_modules/avrgirl-arduino/node_modules/stk500):
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    ! npm ERR! Linux 4.9.59-v7+
    ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
    ! npm ERR!
    ! npm v3.10.10npm ERR!
    ! code ELIFECYCLE
    ! npm
    ! ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
    ! npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! npm
    ! ERR! If you do, this is most likely a problem with the serialport package,npm ERR! not with npm itself.
    ! npm ERR! Tell the author that this fails on your system:
    ! npm ERR! node-pre-gyp install --fallback-to-build
    ! npm ERR! You can get information on how to open an issue for this project with:
    ! npm ERR! npm bugs serialport
    ! npm ERR! Or if that isn't available, you can get their info via:
    ! npm ERR! npm owner ls serialport
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /home/npm-debug.log
    ! host.ioBroker install adapter rflink
    ! npm install iobroker.rflink --production --prefix "/opt/iobroker" (System call)
    ! npm
    ! npm
    ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-api-updates-0f82caf3: undefined
    ! node-pre-gyp ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... arm.tar.gz
    ! node-pre-gyp ERR! Pre-built binaries not found for usb@1.3.1 and node@6.12.3 (node-v48 ABI, glibc) (falling back to source compile with node-gyp)
    ! gyp
    ! WARN EACCES
    ! user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
    ! gyp
    ! ERR!
    ! build error
    ! gyp
    ! ERR!
    ! ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack
    ! at emitTwo (events.js:106:13)gyp
    ! ERR!
    ! stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding"
    ! gyp ERR!
    ! node-gyp -v v3.4.0gyp ERR! not ok
    ! node-pre-gyp
    ! ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp
    ! ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.12.3 (node-v48 ABI) (falling back to source compile with node-gyp)
    ! gyp
    ! gyp
    ! ERR! build error
    ! gyp
    ! gyp ERR!
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp ERR! System Linux 4.9.59-v7+
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
    ! gyp ERR! not ok
    ! Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp ERR! System Linux 4.9.59-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    ! node-pre-gyp ERR! node-pre-gyp -v v0.6.32node-pre-gyp ERR! not ok
    ! npm
    ! npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
    ! npm
    ! ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v6.12.3
    ! npm ERR! npm v3.10.10
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
    ! npm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! If you do, this is most likely a problem with the serialport package,
    ! npm ERR! not with npm itself.
    ! npm
    ! WARN
    ! addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! npm WARN
    ! npm
    ! addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! npm
    ! node-pre-gyp
    ! ERR! Tried to download(404): https://github.com/tessel/node-usb/rele ... arm.tar.gz node-pre-gyp
    ! ERR!
    ! gyp
    ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
    ! gyp
    ! ERR! build error
    ! gyp
    ! gyp ERR! not ok
    ! node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
    ! node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    ! node-pre-gyp
    ! ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.12.3 (node-v48 ABI) (falling back to source compile with node-gyp)
    ! gyp
    ! gyp
    ! ERR!
    ! build error
    ! gyp
    ! ERR!
    ! stack
    ! Error: make failed with exit code: 2gyp ERR!
    ! stack
    ! at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR!
    ! gyp ERR!
    ! gyp
    ! ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp ERR! System Linux 4.9.59-v7+
    ! gyp
    ! ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"gyp
    ! ERR! cwd /opt/iobroker/node_modules/serialportgyp ERR! node -v v6.12.3
    ! gyp ERR! not ok
    ! node-pre-gyp
    ! ERR! stack
    ! node-pre-gyp ERR!
    ! stack at maybeClose (internal/child_process.js:920:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
    ! node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
    ! node-pre-gyp ERR!
    ! node -v v6.12.3node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    ! npm WARN
    ! optional SKIPPING OPTIONAL DEPENDENCY: browser-serialport@git://github.com/noopkat/browser-serialport.git#api-updates (node_modules/avrgirl-arduino/node_modules/browser-serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
    ! npm ERR!
    ! ERROR: host.ioBroker Cannot install rflink
    ! ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    Hat jemand eine Idee? Der Server schein das Repository oder Teile davon nicht zu erreichen.
    Viele Grüße
    THPS
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Die Meldung klinkt als ob du kein gut installiert hast?
      Send from mobile device
      Das schöne ios hat Auto Korrektur zum k****
      Wer Schreibfehler findet darf sie behalten oder auf eBay verkaufen, mindest Umsatz 10% für die community
        @thps:
        Hat jemand eine Idee? `
        Ja!
        @thps:
        Error: not found: git `
        sudo apt-get install git
        Rainer
          thps
          Da hätte ich auch selber drauf kommen können:roll: . Vielen Dank euch
          • DutchmanD Offline
            DutchmanD Offline
            Dutchman
            @thps:
            Da hätte ich auch selber drauf kommen können:roll: . Vielen Dank euch `
            :) Thema gelöst? Dann bitte [gelöst] davor setzen
