  4. Exception bei Installation Harmony Adapter
4 Beiträge 3 Kommentatoren 1.1k Aufrufe
    Stmiko
    Würde gerne den Harmony Adapter testen. Leider bekomme ich ihn nicht installiert.
    Folgende exception wird geworfen:
    ` > iobroker 2015-08-15 19:33:37 info exit 25
    iobroker 2015-08-15 19:33:37 info Cannot install iobroker.harmony: 1
    iobroker 2015-08-15 19:33:37 info code 0
    iobroker 2015-08-15 19:33:37 info npm ERR! not ok
    iobroker 2015-08-15 19:33:37 info Additional logging details can be found in:npm ERR! /opt/npm-debug.log
    iobroker 2015-08-15 19:33:37 info ERR!
    iobroker 2015-08-15 19:33:37 info ERR! npm
    iobroker 2015-08-15 19:33:36 info npm ERR! type non_object_property_call
    iobroker 2015-08-15 19:33:36 info npm ERR! node -v v0.10.22npm ERR! npm -v 1.3.14
    iobroker 2015-08-15 19:33:36 info npm ERR! cwd /opt
    iobroker 2015-08-15 19:33:36 info npm ERR! command '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'iobroker.harmony' '–production' '--prefix' '/opt/iobroker'
    iobroker 2015-08-15 19:33:36 info npm ERR! System Linux 4.0.9-v7+
    iobroker 2015-08-15 19:33:36 info npm ERR! or email it to:
    iobroker 2015-08-15 19:33:36 info npm ERR! If you need help, you may report this log at:
    iobroker 2015-08-15 19:33:36 info npm ERR! at _stream_readable.js:920:16
    iobroker 2015-08-15 19:33:36 info npm ERR! at IncomingMessage.EventEmitter.emit (events.js:117:20)
    iobroker 2015-08-15 19:33:36 info npm ERR! at IncomingMessage. (/usr/local/lib/node_modules/npm/node_modules/request/request.js:824:12)
    iobroker 2015-08-15 19:33:36 info npm ERR! at Request.EventEmitter.emit (events.js:117:20)
    iobroker 2015-08-15 19:33:36 info npm ERR! at Request. (/usr/local/lib/node_modules/npm/node_modules/request/request.js:873:14)
    iobroker 2015-08-15 19:33:36 info at Request.self.callback (/usr/local/lib/node_modules/npm/node_modules/request/request.js:129:22)npm ERR! at Request.EventEmitter.emit (events.js:98:17)
    iobroker 2015-08-15 19:33:36 info npm ERR! at RegClient. (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:252:14)
    iobroker 2015-08-15 19:33:36 info npm ERR! at RegClient. (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:119:29)npm ERR! at cb (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/request.js:158:9)
    iobroker 2015-08-15 19:33:36 info npm ERR! TypeError: Cannot call method 'match' of undefined
    iobroker 2015-08-15 19:33:36 info npm http 404 https://registry.npmjs.org/iobroker.harmony
    iobroker 2015-08-15 19:33:36 info http GET https://registry.npmjs.org/iobroker.harmony
    iobroker 2015-08-15 19:33:33 info npm install iobroker.harmony --production --prefix '/opt/iobroker' (System call)
    iobroker 2015-08-15 19:33:31 info add harmony `
    Danke für jede Hilfe!
    iobroker auf Intel NUC mit Proxmox LXC und Raspi3+
    • BluefoxB Offline
      BluefoxB Offline
      Vermutlich hat Pman noch nicht auf npm das gelegt.
      Momentan kannst du nur manuell installieren:
      cd /opt/iobroker
      npm install https://github.com/Pmant/ioBroker.harmony/tarball/master
      iobroker add harmony
        Stmiko
        Prima….das hat funktioniert......vielen Dank :D
          Pman
          Ich mache den npm publish sobald die Channel Struktur funktioniert, ausprobieren und berichten kannst du gerne schon.
