  4. [gelöst] Fehler host.raspberrypi instance system.adapter.vis
3 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • F Offline
    frankie
    bei einem Start findet man im Log
    2015-08-03 23:07:40.426  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    Die Meldung ist als info gekennzeichnet, sagt aber vom Inhalt her aus, das system.adapter.vis.0 doppelt gestartet wurde.
    Falsche Einstellungen meinerseits oder Fehler?
    Frank
    Hier noch alle Meldungen eines Startes:
    ! 2015-08-03 23:06:28.411 - info: host.raspberrypi ioBroker.js-controller version 0.7.5 js-controller starting
    ! 2015-08-03 23:06:28.436 - info: host.raspberrypi Copyright © 2014-2015 bluefox, hobbyquaker
    ! 2015-08-03 23:06:28.440 - info: host.raspberrypi hostname: raspberrypi
    ! 2015-08-03 23:06:28.441 - info: host.raspberrypi ip addresses: 192.168.178.32
    ! 2015-08-03 23:06:30.240 - info: inMem-states listening on port 9000
    ! 2015-08-03 23:07:13.315 - info: inMem-objects listening on port 9001
    ! 2015-08-03 23:07:13.342 - info: host.raspberrypi InMemoryDB connected
    ! 2015-08-03 23:07:13.375 - info: host.raspberrypi 5 instances found
    ! 2015-08-03 23:07:13.379 - info: host.raspberrypi starting 5 instances
    ! 2015-08-03 23:07:13.478 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 2164
    ! 2015-08-03 23:07:18.195 - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 2179
    ! 2015-08-03 23:07:21.431 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 2235
    ! 2015-08-03 23:07:23.876 - info: hm-rpc.0 starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
    ! 2015-08-03 23:07:24.535 - info: hm-rpc.0 xmlrpc server is trying to listen on 192.168.178.32:2001
    ! 2015-08-03 23:07:24.543 - info: hm-rpc.0 xmlrpc -> 192.168.178.49:2001 init ["http://192.168.178.32:2001","hm-rpc.0"]
    ! 2015-08-03 23:07:24.681 - info: hm-rpc.0 xmlrpc <- system.listMethods ["hm-rpc.0"]
    ! 2015-08-03 23:07:24.755 - info: hm-rpc.0 xmlrpc <- listDevices ["hm-rpc.0"]
    ! 2015-08-03 23:07:24.802 - info: hm-rpc.0 xmlrpc -> 116 devices
    ! 2015-08-03 23:07:25.426 - info: host.raspberrypi instance system.adapter.web.0 started with pid 2301
    ! 2015-08-03 23:07:25.375 - info: hm-rega.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.hm-rega
    ! 2015-08-03 23:07:25.414 - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
    ! 2015-08-03 23:07:28.215 - info: admin.0 starting. Version 0.5.5 in /opt/iobroker/node_modules/iobroker.admin
    ! 2015-08-03 23:07:28.362 - info: hm-rega.0 ReGaHSS 192.168.178.49 up
    ! 2015-08-03 23:07:28.451 - info: hm-rega.0 time difference local-ccu 0s
    ! 2015-08-03 23:07:28.461 - info: admin.0 requesting all states
    ! 2015-08-03 23:07:28.471 - info: admin.0 requesting all objects
    ! 2015-08-03 23:07:28.490 - info: admin.0 http server listening on port 8081
    ! 2015-08-03 23:07:28.491 - info: admin.0 Use link "http://localhost:8081" to configure.
    ! 2015-08-03 23:07:28.565 - info: hm-rega.0 added/updated 1 favorites to enum.favorites
    ! 2015-08-03 23:07:28.665 - info: hm-rega.0 added/updated functions to enum.functions
    ! 2015-08-03 23:07:28.739 - info: hm-rega.0 added/updated rooms to enum.rooms
    ! 2015-08-03 23:07:29.256 - info: admin.0 received all states
    ! 2015-08-03 23:07:29.720 - info: admin.0 received all objects
    ! 2015-08-03 23:07:29.916 - info: hm-rega.0 got 2 programs
    ! 2015-08-03 23:07:29.974 - info: hm-rega.0 added/updated 2 programs
    ! 2015-08-03 23:07:29.976 - info: hm-rega.0 deleted 0 programs
    ! 2015-08-03 23:07:30.262 - info: hm-rega.0 got 5 variables
    ! 2015-08-03 23:07:30.328 - info: hm-rega.0 added/updated 5 variables
    ! 2015-08-03 23:07:30.332 - info: hm-rega.0 deleted 0 variables
    ! 2015-08-03 23:07:30.337 - info: hm-rega.0 request state values
    ! 2015-08-03 23:07:30.584 - info: web.0 starting. Version 0.4.2 in /opt/iobroker/node_modules/iobroker.web
    ! 2015-08-03 23:07:30.660 - info: hm-rega.0 got state values
    ! 2015-08-03 23:07:33.725 - info: web.0 socket.io server listening on port 8082
    ! 2015-08-03 23:07:33.749 - info: web.0 http server listening on port 8082
    ! 2015-08-03 23:07:33.953 - info: vis.0 starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.vis
    ! 2015-08-03 23:07:40.426 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
    Raspberry Pi 2 - Raspbian 4.1.6-v7+
    node v0.12.7 (Installation nach http://nodered.org/docs/hardware/raspberrypi.html)
    mosquitto 1.4.3
    ioBroker.js-controller 0.7.12
    • BluefoxB Offline
      BluefoxB Offline
      Eher falsche Übersetzung.
      Auf Deutsch muss es heißen:
      instance system.adapter.vis.0 wurde gestoppt, weil nur einmal ausgeführt werden muss.
      Nicht einmal laufen, sondern nur einmal ausgeführt und dann muss Adapter nicht mehr laufen.
      • F Offline
        frankie
        @Bluefox:
        Eher falsche Übersetzung. `
        :idea:
        mosquitto 1.4.3
