  4. Zwave Adapter ROt + Fehlermeldung
    5.6k
4 Beiträge 2 Kommentatoren 569 Aufrufe
  • J Offline
    juergen123
    Moin zusammen,
    bin totaler zwave iobroker noob :-)
    Hab mein ioBroker aufgesetzt zwave installiert leider ist der Adapter im UI immer rot:
    Adapter ist eineGEN5 ZW090-C von Aeotec
    Raspi 3
    Fehlermdeldung
    host.ioBroker	2017-11-25 07:20:24.381	info	Restart adapter system.adapter.zwave.0 because enabled
    host.ioBroker	2017-11-25 07:20:24.381	error	instance system.adapter.zwave.0 terminated with code 0 (OK)
    Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Object.Module._extensions..js (module.js:579:10)
    Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Module._compile (module.js:570:32)
    Caught	2017-11-25 07:20:24.380	error	by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
    Caught	2017-11-25 07:20:24.379	error	by controller[0]: at require (internal/module.js:20:19)
    Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Module.require (module.js:497:17)
    Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Function.Module._load (module.js:438:3)
    Caught	2017-11-25 07:20:24.379	error	by controller[0]: at tryModuleLoad (module.js:446:12)
    Caught	2017-11-25 07:20:24.379	error	by controller[0]: at Module.load (module.js:487:32)
    Caught	2017-11-25 07:20:24.378	error	by controller[0]: at Object.Module._extensions..node (module.js:597:18)
    Caught	2017-11-25 07:20:24.378	error	by controller[0]: at Error (native)
    Caught	2017-11-25 07:20:24.377	error	by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2017-11-25 07:20:24.340	info	terminating
    zwave.0	2017-11-25 07:20:24.259	error	at Object.Module._extensions..js (module.js:579:10)
    zwave.0	2017-11-25 07:20:24.259	error	at Module._compile (module.js:570:32)
    zwave.0	2017-11-25 07:20:24.259	error	at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
    zwave.0	2017-11-25 07:20:24.259	error	at require (internal/module.js:20:19)
    zwave.0	2017-11-25 07:20:24.259	error	at Module.require (module.js:497:17)
    zwave.0	2017-11-25 07:20:24.259	error	at Function.Module._load (module.js:438:3)
    zwave.0	2017-11-25 07:20:24.259	error	at tryModuleLoad (module.js:446:12)
    zwave.0	2017-11-25 07:20:24.259	error	at Module.load (module.js:487:32)
    zwave.0	2017-11-25 07:20:24.259	error	at Object.Module._extensions..node (module.js:597:18)
    zwave.0	2017-11-25 07:20:24.259	error	at Error (native)
    zwave.0	2017-11-25 07:20:24.259	error	Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2017-11-25 07:20:24.257	error	uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
    zwave.0	2017-11-25 07:20:24.111	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v6.12.0
    host.ioBroker	2017-11-25 07:20:22.653	info	instance system.adapter.zwave.0 started with pid 2762
    host.ioBroker	2017-11-25 07:19:52.636	info	Restart adapter system.adapter.zwave.0 because enabled
    Was mach ich falsch?
    gruß
    Jürgen
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      @juergen123:
      gruß
      Jürgen `
      Du liest dir die readme nicht durch [emoji6]
       Known issues
      If you get the following (or similar) error after starting the adapter
      you can fix it by running
      sudo ldconfig
      or
      sudo ldconfig /usr/local
      or
      sudo ldconfig /usr/local/lib64
      https://github.com/ioBroker/ioBroker.zw … /README.md
      Send from mobile device
      • J Offline
        juergen123
        Vielen Dank, hat sofort geklappt.
        Wie bekomm ich es hin das bei eimem KNX befehl das RGB Band angeht?
        ![](</s><URL url=)https://i.imgur.com/PLeR1qp.png" />
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Schau die mal die docu zu scenen oder blockly an damit kan man derartige Events erstellen.
          Sollte es nicht klappen bitten einen neuen thread mit deiner Frage und was du probiert hat ;)
