  4. EVCC wird nicht grün
23 Beiträge 3 Kommentatoren 151 Aufrufe 2 Beobachtet
  • K Online
    K Online
    Karl-Heinz1
    schrieb zuletzt editiert von
    Script v.2026-08-30
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 11 (bullseye)
    Static hostname: raspberrypi
    Icon name: computer
    Kernel: Linux 6.1.21-v8+
    Architecture: arm64
    OS is similar to:
    Model : Raspberry Pi 400 Rev 1.1
    Docker : false
    Virtualization : none
    Unknown
    Kernel : aarch64
    Userland : 64bit
    System was installed 1442 days ago (on 2022-09-22).
    Systemuptime and Load:
    19:45:20 up 2:03, 2 users, load average: 4.74, 2.22, 1.54
    CPU threads : 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to
    be updated to the latest stable release 'trixie' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
    Local time: Thu 2026-09-03 19:45:21 CEST
    Universal time: Thu 2026-09-03 17:45:21 UTC
    RTC time: n/a
    NTP service: active
    RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input
    render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server: Unknown
    Display-Manager: * lightdm.service - Light Display Manager
    Desktop:
    Session: tty
    Boot Target: multi-user.target
    *** MEMORY ***
    total used free shared buff/cache
    available
    Mem: 3.8G 1.9G 974M 1.0M 924M
    1.8G
    Swap: 99M 0B 99M
    Total: 3.9G 1.9G 1.1G
    Active iob-Instances: 24
    3794 M total memory
    1895 M used memory
    2151 M active memory
    518 M inactive memory
    974 M free memory
    76 M buffer memory
    848 M swap cache
    99 M total swap
    0 M used swap
    99 M free swap
    *** top - Table Of Processes ***
    top - 19:45:23 up 2:03, 2 users, load average: 4.74, 2.22, 1.54
    Tasks: 194 total, 1 running, 193 sleeping, 0 stopped, 0 zombie
    %Cpu(s): 4.2 us, 2.8 sy, 0.0 ni, 93.0 id, 0.0 wa, 0.0 hi, 0.0 si,
    0.0 st
    MiB Mem : 3794.3 total, 973.9 free, 1895.8 used, 924.7 buff/
    cache
    MiB Swap: 100.0 total, 100.0 free, 0.0 used. 1821.9 avail
    Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 29G 17G 11G 62% /
    devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
    tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
    tmpfs tmpfs 759M 1.3M 758M 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/mmcblk0p1 vfat 255M 32M 223M 13% /boot
    tmpfs tmpfs 380M 16K 380M 1% /run/user/1000
    Messages concerning filesystems in dmesg (Last 15 lines only):
    Show mounted filesystems:
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat
    rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname
    =mixed,errors=remount-ro
    /var:
    4.1G /var/
    3.1G /var/log
    3.0G /var/log/journal/79e438becaf044e4ab8664814f73dec8
    757M /var/cache
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    170M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    4.6G /opt/iobroker/iobroker-data/
    3.5G /opt/iobroker/iobroker-data/history
    994M /opt/iobroker/iobroker-data/files
    493M /opt/iobroker/iobroker-data/files/javascript.admin
    461M /opt/iobroker/iobroker-data/files/javascript.admin/static
    43M /opt/iobroker/iobroker-data/files/iot.admin/static/js/
    main.c9e0f545.js.map
    26M /opt/iobroker/iobroker-data/files/echarts/static/js/
    main.41cee985.js.map
    26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/
    24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/
    main.6a71b34c.js.map
    24M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/
    main.70a15e1f.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B00332GV-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B0043WH9-if00-port0
    /dev/serial/by-id/usb-FTDI_USB_Serial_Converter_FTB6SPL3-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs v20.20.2
    /usr/bin/node v20.20.2
    /usr/bin/npm 10.8.2
    /usr/bin/npx 10.8.2
    ✓ Node.js installation is correct
    nodejs:
    Installed: 20.20.2-1nodesource1
    Candidate: 20.20.2-1nodesource1
    Version table:
    *** 20.20.2-1nodesource1 1001
    500 https://deb.nodesource.com/node_20.x nodistro/main arm64
    Packages
    100 /var/lib/dpkg/status
    20.20.1-1nodesource1 1001
    Packages
    20.20.0-1nodesource1 1001
    Packages
    20.19.6-1nodesource1 1001
    Packages
    20.19.5-1nodesource1 1001
    Packages
    20.19.4-1nodesource1 1001
    Packages
    20.19.3-1nodesource1 1001
    Packages
    20.19.2-1nodesource1 1001
    Packages
    20.19.1-1nodesource1 1001
    Packages
    20.19.0-1nodesource1 1001
    Packages
    20.18.3-1nodesource1 1001
    Packages
    20.18.2-1nodesource1 1001
    Packages
    20.18.1-1nodesource1 1001
    Packages
    20.18.0-1nodesource1 1001
    Packages
    20.17.0-1nodesource1 1001
    Packages
    20.16.0-1nodesource1 1001
    Packages
    20.15.1-1nodesource1 1001
    Packages
    20.15.0-1nodesource1 1001
    Packages
    20.14.0-1nodesource1 1001
    Packages
    20.13.1-1nodesource1 1001
    Packages
    20.13.0-1nodesource1 1001
    Packages
    20.12.2-1nodesource1 1001
    Packages
    20.12.1-1nodesource1 1001
    Packages
    20.12.0-1nodesource1 1001
    Packages
    20.11.1-1nodesource1 1001
    Packages
    20.11.0-1nodesource1 1001
    Packages
    20.10.0-1nodesource1 1001
    Packages
    20.9.0-1nodesource1 1001
    Packages
    20.8.1-1nodesource1 1001
    Packages
    20.8.0-1nodesource1 1001
    Packages
    20.7.0-1nodesource1 1001
    Packages
    20.6.1-1nodesource1 1001
    Packages
    20.6.0-1nodesource1 1001
    Packages
    20.5.1-1nodesource1 1001
    Packages
    20.5.0-1nodesource1 1001
    Packages
    20.4.0-1nodesource1 1001
    Packages
    20.3.1-1nodesource1 1001
    Packages
    20.3.0-1nodesource1 1001
    Packages
    20.2.0-1nodesource1 1001
    Packages
    20.1.0-1nodesource1 1001
    Packages
    20.0.0-1nodesource1 1001
    Packages
    12.22.12~dfsg-1~deb11u8 500
    500 http://security.debian.org/debian-security bullseye-
    security/main arm64 Packages
    12.22.12~dfsg-1~deb11u4 500
    500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    Vulnerabilities detected in the Node.js version!
    node:fs:2380
    return binding.writeFileUtf8(
    Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-
    my-node-vulnerable/schedule.etag'
    at Object.writeFileSync (node:fs:2380:20)
    at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-
    node-vulnerable/is-vulnerable.js:82:12)
    at Object.onceWrapper (node:events:639:26)
    at ClientRequest.emit (node:events:524:28)
    at HTTPParser.parserOnIncomingClient [as onIncoming]
    (node:_http_client:702:27)
    at HTTPParser.parserOnHeadersComplete (node:_http_common:118:17)
    at TLSSocket.socketOnData (node:_http_client:544:22)
    at TLSSocket.emit (node:events:524:28)
    at addChunk (node:internal/streams/readable:561:12)
    at readableAddChunkPushByteMode (node:internal/streams/
    readable:512:3) {
    errno: -13,
    code: 'EACCES',
    syscall: 'open',
    path: '/home/iobroker/node_modules/is-my-node-vulnerable/
    schedule.etag'
    Node.js v20.20.2
    npm notice
    npm notice New major version of npm available! 10.8.2 -> 12.0.2
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v12.0.2
    npm notice To update run: npm install -g npm@12.0.2
    npm notice
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Hosts:
    raspberrypi raspberrypi (version: 6.0.11, hostname: raspberrypi
    , alive, uptime: 7413)
    Core adapters versions
    js-controller: 6.0.11
    admin: 7.8.23
    javascript: 8.8.2
    nodejs modules from github: 1
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://
    git@github.com/ioBroker/ioBroker.icons-open-icon-library-
    png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    Adapter State
    + system.adapter.admin.0 : admin :
    raspberrypi - enabled, port: 8081, bind:
    0.0.0.0, run as: admin
    + system.adapter.backitup.0 : backitup :
    + system.adapter.chromecast.0 : chromecast :
    system.adapter.cloud.0 : cloud :
    raspberrypi - disabled
    + system.adapter.discovery.0 : discovery :
    + system.adapter.ds18b20.0 : ds18b20 :
    + system.adapter.echarts.0 : echarts :
    + system.adapter.evcc.0 : evcc :
    raspberrypi - enabled, port: 7070
    system.adapter.flot.0 : flot :
    + system.adapter.growatt.0 : growatt :
    + system.adapter.history.0 : history :
    system.adapter.icons-material-png.0 : icons-material-png :
    system.adapter.icons-mfd-svg.0 : icons-mfd-svg :
    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-
    png: raspberrypi - disabled
    system.adapter.icons-ultimate-png.0 : icons-ultimate-png :
    + system.adapter.iot.0 : iot :
    + system.adapter.jarvis.0 : jarvis :
    + system.adapter.javascript.0 : javascript :
    + system.adapter.modbus.0 : modbus :
    + system.adapter.mqtt.0 : mqtt :
    raspberrypi - enabled, port: 1883, bind:
    0.0.0.0
    + system.adapter.net-tools.0 : net-tools :
    + system.adapter.node-red.0 : node-red :
    raspberrypi - enabled, port: 1880, bind:
    0.0.0.0
    + system.adapter.pushover.0 : pushover :
    + system.adapter.shelly.0 : shelly :
    raspberrypi - enabled, port: 1882, bind:
    0.0.0.0
    + system.adapter.shelly.1 : shelly :
    0.0.0.0
    + system.adapter.simple-api.0 : simple-api :
    raspberrypi - enabled, port: 8087, bind:
    + system.adapter.smartcontrol.0 : smartcontrol :
    + system.adapter.sonoff.0 : sonoff :
    0.0.0.0
    system.adapter.telegram.0 : telegram :
    raspberrypi - disabled, port: 8443, bind:
    0.0.0.0
    system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges :
    system.adapter.vis-colorpicker.0 : vis-colorpicker :
    system.adapter.vis-justgage.0 : vis-justgage :
    system.adapter.vis-material-advanced.0 : vis-material-advanced :
    system.adapter.vis-materialdesign.0 : vis-materialdesign :
    system.adapter.vis-rgraph.0 : vis-rgraph :
    system.adapter.vis.0 : vis :
    + system.adapter.web.0 : web :
    raspberrypi - enabled, port: 8082, bind:
    + instance is alive
    0.0.0.0
    0.0.0.0
    0.0.0.0
    0.0.0.0
    0.0.0.0
    ioBroker-Repositories
    ───────┬──────────────┐ │ (index) │ name │ url
    │ auto upgrade │ ├─────────┼──────────┼────────────────────────────────────────────────── ───────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'
    │ false │
    │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-
    latest.json' │ false │ └─────────┴──────────┴──────────────────────────────────────────────────
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    ─────────────────┬──────────┬────────────────┐ │ (index) │ id │ name
    │ version │ upgrade policy │ ├─────────┼──────────────────────────────────────────────┼────────────── ─────────────────┼──────────┼────────────────┤ │ 0 │ 'system.adapter.admin' │ 'admin'
    │ '7.8.23' │ 'none' │
    │ 1 │ 'system.adapter.backitup' │ 'backitup'
    │ '3.0.20' │ 'none' │
    │ 2 │ 'system.adapter.chromecast' │ 'chromecast'
    │ '3.4.1' │ 'none' │
    │ 3 │ 'system.adapter.cloud' │ 'cloud'
    │ '5.0.1' │ 'none' │
    │ 4 │ 'system.adapter.discovery' │ 'discovery'
    │ '5.0.0' │ 'none' │
    │ 5 │ 'system.adapter.ds18b20' │ 'ds18b20'
    │ '2.0.5' │ 'none' │
    │ 6 │ 'system.adapter.echarts' │ 'echarts'
    │ '1.9.2' │ 'none' │
    │ 7 │ 'system.adapter.evcc' │ 'evcc'
    │ '0.2.4' │ 'none' │
    │ 8 │ 'system.adapter.flot' │ 'flot'
    │ '1.12.0' │ 'none' │
    │ 9 │ 'system.adapter.growatt' │ 'growatt'
    │ '3.3.1' │ 'none' │
    │ 10 │ 'system.adapter.history' │ 'history'
    │ '3.0.1' │ 'none' │
    │ 11 │ 'system.adapter.icons-material-png' │ 'icons-
    material-png' │ '0.1.0' │ 'none' │
    │ 12 │ 'system.adapter.icons-mfd-svg' │ 'icons-mfd-
    svg' │ '1.2.0' │ 'none' │
    │ 13 │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-
    icon-library-png' │ '0.1.3' │ 'none' │
    │ 14 │ 'system.adapter.icons-ultimate-png' │ 'icons-
    ultimate-png' │ '1.0.1' │ 'none' │
    │ 15 │ 'system.adapter.iot' │ 'iot'
    │ '3.4.2' │ 'none' │
    │ 16 │ 'system.adapter.jarvis' │ 'jarvis'
    │ '3.1.8' │ 'none' │
    │ 17 │ 'system.adapter.javascript' │ 'javascript'
    │ '8.8.2' │ 'none' │
    │ 18 │ 'system.adapter.modbus' │ 'modbus'
    │ '6.3.2' │ 'none' │
    │ 19 │ 'system.adapter.mqtt' │ 'mqtt'
    │ '6.1.1' │ 'none' │
    │ 20 │ 'system.adapter.net-tools' │ 'net-tools'
    │ '1.0.11' │ 'none' │
    │ 21 │ 'system.adapter.node-red' │ 'node-red'
    │ '5.2.1' │ 'none' │
    │ 22 │ 'system.adapter.pushover' │ 'pushover'
    │ '4.1.0' │ 'none' │
    │ 23 │ 'system.adapter.shelly' │ 'shelly'
    │ '8.2.1' │ 'none' │
    │ 24 │ 'system.adapter.simple-api' │ 'simple-api'
    │ '2.8.0' │ 'none' │
    │ 25 │ 'system.adapter.smartcontrol' │
    'smartcontrol' │ '2.0.1' │ 'none' │
    │ 26 │ 'system.adapter.socketio' │ 'socketio'
    │ '6.7.1' │ 'none' │
    │ 27 │ 'system.adapter.sonoff' │ 'sonoff'
    │ '3.1.2' │ 'none' │
    │ 28 │ 'system.adapter.telegram' │ 'telegram'
    │ '3.9.0' │ 'none' │
    │ 29 │ 'system.adapter.vis' │ 'vis'
    │ '1.5.6' │ 'none' │
    │ 30 │ 'system.adapter.vis-2-widgets-gauges' │ 'vis-2-
    widgets-gauges' │ '1.1.0' │ 'none' │
    │ 31 │ 'system.adapter.vis-colorpicker' │ 'vis-
    colorpicker' │ '2.0.3' │ 'none' │
    │ 32 │ 'system.adapter.vis-justgage' │ 'vis-
    justgage' │ '2.1.7' │ 'none' │
    │ 33 │ 'system.adapter.vis-material-advanced' │ 'vis-
    material-advanced' │ '1.7.4' │ 'none' │
    │ 34 │ 'system.adapter.vis-materialdesign' │ 'vis-
    materialdesign' │ '0.5.9' │ 'none' │
    │ 35 │ 'system.adapter.vis-rgraph' │ 'vis-rgraph'
    │ '0.0.2' │ 'none' │
    │ 36 │ 'system.adapter.web' │ 'web'
    │ '6.3.1' │ 'none' │
    │ 37 │ 'system.adapter.ws' │ 'ws'
    │ '2.6.2' │ 'none' │ └─────────┴──────────────────────────────────────────────┴──────────────
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter "admin" : 8.0.11 , installed 7.8.23 [Updatable]
    Adapter "backitup" : 4.0.3 , installed 3.0.20 [Updatable]
    Adapter "chromecast" : 4.2.0 , installed 3.4.1 [Updatable]
    Adapter "cloud" : 6.0.1 , installed 5.0.1 [Updatable]
    Adapter "discovery" : 5.0.0 , installed 5.0.0
    Adapter "ds18b20" : 3.1.1 , installed 2.0.5 [Updatable]
    Adapter "echarts" : 3.1.0 , installed 1.9.2 [Updatable]
    Adapter "evcc" : 0.2.4 , installed 0.2.4
    Adapter "growatt" : 3.3.1 , installed 3.3.1
    Adapter "history" : 4.0.0 , installed 3.0.1 [Updatable]
    Adapter "icons-material-png": 0.1.0, installed 0.1.0
    Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "iot" : 6.0.3 , installed 3.4.2 [Updatable]
    Adapter "jarvis" : 3.1.8 , installed 3.1.8
    Adapter "javascript" : 10.1.3 , installed 8.8.2 [Updatable]
    Controller "js-controller": 7.2.2 , installed 6.0.11 [Updatable]
    Adapter "modbus" : 8.0.3 , installed 6.3.2 [Updatable]
    Adapter "mqtt" : 6.1.4 , installed 6.1.1 [Updatable]
    Adapter "net-tools" : 1.2.3 , installed 1.0.11 [Updatable]
    Adapter "node-red" : 6.0.7 , installed 5.2.1 [Updatable]
    Adapter "pushover" : 5.0.0 , installed 4.1.0 [Updatable]
    Adapter "shelly" : 10.6.1 , installed 8.2.1 [Updatable]
    Adapter "simple-api" : 3.0.7 , installed 2.8.0 [Updatable]
    Adapter "smartcontrol" : 2.0.1 , installed 2.0.1
    Adapter "socketio" : 7.1.3 , installed 6.7.1 [Updatable]
    Adapter "sonoff" : 3.3.0 , installed 3.1.2 [Updatable]
    Adapter "telegram" : 5.0.5 , installed 3.9.0 [Updatable]
    Adapter "vis" : 1.5.6 , installed 1.5.6
    Adapter "vis-2-widgets-gauges": 2.0.2, installed 1.1.0 [Updatable]
    Adapter "vis-colorpicker": 2.1.0 , installed 2.0.3 [Updatable]
    Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
    Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
    Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
    Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
    Adapter "web" : 8.0.0 , installed 6.3.1 [Updatable]
    Adapter "ws" : 4.1.0 , installed 2.6.2 [Updatable]
    Objects and States
    Objects: 4866
    States: 4366
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security
    InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Get:6 https://dl.evcc.io/public/evcc/stable/deb/debian bullseye
    InRelease
    Fetched 11.7 kB in 2s (7071 B/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State Recv-Q Send-Q Local Address:Port Peer
    Address:PortProcess
    udp UNCONN 0 0 0.0.0.0:mdns 0.0.0.0:*
    users:(("evcc",pid=2475,fd=22))
    users:(("evcc",pid=2475,fd=3))
    users:(("io.chromecast.0",pid=1379,fd=28))
    users:(("avahi-daemon",pid=406,fd=12))
    udp UNCONN 0 0 0.0.0.0:60818 0.0.0.0:*
    users:(("avahi-daemon",pid=406,fd=14))
    udp UNCONN 0 0 0.0.0.0:5683 0.0.0.0:*
    users:(("io.shelly.1",pid=1485,fd=29))
    udp UNCONN 0 0 0.0.0.0:1900 0.0.0.0:*
    users:(("evcc",pid=2475,fd=26))
    users:(("evcc",pid=2475,fd=25))
    users:(("evcc",pid=2475,fd=24))
    udp UNCONN 0 0 0.0.0.0:bootpc 0.0.0.0:*
    users:(("dhcpcd",pid=513,fd=13))
    udp UNCONN 0 0 *:mdns *:*
    users:(("evcc",pid=2475,fd=23))
    users:(("evcc",pid=2475,fd=6))
    users:(("avahi-daemon",pid=406,fd=13))
    udp UNCONN 0 0 *:dhcpv6-client *:*
    users:(("dhcpcd",pid=513,fd=16))
    udp UNCONN 0 0 *:60545 *:*
    users:(("avahi-daemon",pid=406,fd=15))
    tcp LISTEN 0 128 0.0.0.0:ssh 0.0.0.0:*
    users:(("sshd",pid=669,fd=3))
    tcp LISTEN 0 511 0.0.0.0:8400 0.0.0.0:*
    users:(("io.jarvis.0",pid=1623,fd=27))
    tcp LISTEN 0 5 0.0.0.0:5900 0.0.0.0:*
    users:(("vncserver-x11-c",pid=662,fd=12))
    tcp LISTEN 0 128 127.0.0.1:ipp 0.0.0.0:*
    users:(("cupsd",pid=600,fd=7))
    tcp LISTEN 0 511 0.0.0.0:1882 0.0.0.0:*
    users:(("io.shelly.0",pid=1465,fd=29))
    tcp LISTEN 0 511 0.0.0.0:1883 0.0.0.0:*
    users:(("io.sonoff.0",pid=1500,fd=32))
    tcp LISTEN 0 511 0.0.0.0:1880 0.0.0.0:*
    users:(("node-red",pid=1402,fd=36))
    tcp LISTEN 0 511 127.0.0.1:9000 0.0.0.0:*
    users:(("iobroker.js-con",pid=607,fd=25))
    tcp LISTEN 0 511 127.0.0.1:9001 0.0.0.0:*
    users:(("iobroker.js-con",pid=607,fd=19))
    tcp LISTEN 0 128 [::]:ssh [::]:*
    users:(("sshd",pid=669,fd=4))
    tcp LISTEN 0 4096 *:7070 *:*
    users:(("evcc",pid=2475,fd=12))
    tcp LISTEN 0 4096 *:4712 *:*
    users:(("evcc",pid=2475,fd=10))
    tcp LISTEN 0 4096 *:8887 *:*
    users:(("evcc",pid=2475,fd=9))
    tcp LISTEN 0 5 [::]:5900 [::]:*
    users:(("vncserver-x11-c",pid=662,fd=11))
    tcp LISTEN 0 128 [::1]:ipp [::]:*
    users:(("cupsd",pid=600,fd=6))
    tcp LISTEN 0 511 *:8087 *:*
    users:(("io.simple-api.0",pid=1731,fd=26))
    tcp LISTEN 0 511 *:8082 *:*
    users:(("io.web.0",pid=1668,fd=27))
    tcp LISTEN 0 511 *:tproxy *:*
    users:(("io.admin.0",pid=1235,fd=27))
    2026-09-03 19:46:52.099 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Total_Summe:
    {"val":18369,"ack":true,"ts":1788457612096,"q":0,"from":"system.adapter.
    sonoff.0","user":"system.user.admin","lc":1788456340684}
    2026-09-03 19:46:52.102 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1","common":
    {"role":"value","read":true,"write":false,"type":"number","name":"DVES_3
    E7859 SENSOR.SML Curr_p1"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.103 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.153 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p1:
    {"val":0,"ack":true,"ts":1788457612148,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243462981}
    2026-09-03 19:46:52.159 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2","common":
    E7859 SENSOR.SML Curr_p2"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.159 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.207 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p2:
    {"val":0,"ack":true,"ts":1788457612204,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243463081}
    2026-09-03 19:46:52.210 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3","common":
    E7859 SENSOR.SML Curr_p3"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.211 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.259 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Curr_p3:
    {"val":0,"ack":true,"ts":1788457612256,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243463181}
    2026-09-03 19:46:52.262 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1","common":
    E7859 SENSOR.SML Volt_p1"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.262 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.311 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p1:
    {"val":0,"ack":true,"ts":1788457612308,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243463273}
    2026-09-03 19:46:52.314 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2","common":
    E7859 SENSOR.SML Volt_p2"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.315 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.364 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p2:
    {"val":0,"ack":true,"ts":1788457612360,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243463333}
    2026-09-03 19:46:52.367 - debug: sonoff.0 (1500) process task:
    {"type":"addObject","id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","data
    ":{"_id":"sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3","common":
    E7859 SENSOR.SML Volt_p3"},"native":{},"type":"state"},"cbArg":0}
    2026-09-03 19:46:52.368 - debug: sonoff.0 (1500) Set state after task:
    2026-09-03 19:46:52.419 - debug: sonoff.0 (1500) stateChange
    sonoff.0.DVES_3E7859.SENSOR.SML.Volt_p3:
    {"val":0,"ack":true,"ts":1788457612416,"q":0,"from":"system.adapter.sono
    ff.0","user":"system.user.admin","lc":1721243463393}
    2026-09-03 19:46:53.254 - debug: sonoff.0 (1500) Client [DVES_571961]
    pingreq
    2026-09-03 19:46:53.362 - debug: sonoff.0 (1500) Client [DVES_3E7859]
    pingreq
    2026-09-03 19:46:54.105 - info: shelly.0 (1465) [authEnabled]
    192.168.178.43 (shellyplus1 / shellyplus1-80646fd8df60 /
    shellyplus1#80646fd8df60#1): This device is not protected via restricted
    login (see adapter documentation for details)
    2026-09-03 19:46:54.155 - info: shelly.0 (1465) [authEnabled]
    192.168.178.53 (shellyplus1 / shellyplus1-7c87ce725954 /
    shellyplus1#7c87ce725954#1): This device is not protected via restricted
    2026-09-03 19:46:54.533 - info: shelly.1 (1485) [authEnabled]
    192.168.178.64 (shellyplug-s / shellyplug-s-3CE90ED7361F / SHPLG-
    S#3CE90ED7361F#1): This device is not protected via restricted login
    2026-09-03 19:46:54.557 - info: shelly.0 (1465) [authEnabled]
    192.168.178.81 (shellyplus1 / shellyplus1-7c87ce63d85c /
    shellyplus1#7c87ce63d85c#1): This device is not protected via restricted
    ============= Mark until here for C&P =============
    iob diag has finished.
    pi@raspbe
    • K Karl-Heinz1
      Script v.2026-08-30
      *** BASE SYSTEM ***
      Icon name: computer
      Architecture: arm64
      OS is similar to:
      Docker : false
      Unknown
      Kernel : aarch64
      Userland : 64bit
      CPU threads : 4
      Current issues:
      RTC time: n/a
      NTP service: active
      RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session: tty
      *** MEMORY ***
      available
      1.8G
      Swap: 99M 0B 99M
      3794 M total memory
      1895 M used memory
      974 M free memory
      76 M buffer memory
      848 M swap cache
      99 M total swap
      0 M used swap
      99 M free swap
      0.0 st
      cache
      Mem
      *** FILESYSTEM ***
      /var:
      4.1G /var/
      3.1G /var/log
      757M /var/cache
      USB-Devices by-id:
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      nodejs:
      Version table:
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      Packages
      node:fs:2380
      readable:512:3) {
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      schedule.etag'
      Node.js v20.20.2
      npm notice
      npm notice
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Hosts:
      admin: 7.8.23
      javascript: 8.8.2
      Adapter State
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      + instance is alive
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      0.0.0.0
      │ false │
      Objects and States
      Objects: 4866
      States: 4366
      InRelease
      InRelease
      Address:PortProcess
      pingreq
      pingreq
      pi@raspbe
      @Karl-Heinz1 sagte:
      Also nodejs@22 installieren, ioBroker vollständig updaten, davon ein Backup ziehen, Betriebssystem komplett neuinstallieren, Backup wieder einspielen, fertig.
      • K Online
        K Online
        Karl-Heinz1
        als erstes nodejs instalieren
        sudo apt install -y nodejs npm
        ist das so OK
