  4. Update auf Node.js 22.x / Webinterface nicht erreichbar
    5.4k
61 Beiträge 8 Kommentatoren 2.0k Aufrufe 6 Beobachtet
  • Kirk1701K Offline
    Kirk1701K Offline
    Kirk1701
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.87+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     22:54:28 up 7 min,  2 users,  load average: 0.16, 0.09, 0.04
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-05-15 22:54:28 CEST
               Universal time: Fri 2026-05-15 20:54:28 UTC
                     RTC time: Fri 2026-05-15 20:54:28
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    ole
    HOME=/home/ole
    GROUPS=ole adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.5G        320M        7.4G        7.6M        876M        8.1G
    Swap:           536M          0B        536M
    Total:          9.0G        320M        7.9G
    Active iob-Instances:   1
             8063 M total memory
              306 M used memory
              332 M active memory
              528 M inactive memory
             7010 M free memory
              103 M buffer memory
              731 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 22:54:29 up 7 min,  2 users,  load average: 0.16, 0.09, 0.04
    Tasks: 189 total,   2 running, 187 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.1 total,   7010.2 free,    306.5 used,    835.5 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7756.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  7.3M  800M   1% /run
    /dev/nvme0n1p2 ext4       49G   17G   30G  36% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   57M  454M  12% /boot/firmware
    /dev/nvme0n1p5 ext4      121G   49G   65G  43% /media/datenbank
    /dev/nvme0n1p6 ext4      768G  4.4G  725G   1% /media/netzlaufwerk
    /dev/sda3      ext4      229G  9.8G  207G   5% /media/backup
    tmpfs          tmpfs     807M     0  807M   0% /run/user/0
    [Fri May 15 22:47:07 2026] EXT4-fs (nvme0n1p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Fri May 15 22:47:08 2026] EXT4-fs (nvme0n1p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    [Fri May 15 22:47:09 2026] EXT4-fs (nvme0n1p5): mounted filesystem 84687914-2c0f-4e9c-b265-7f0c6b67738c r/w with ordered data mode. Quota mode: none.
    [Fri May 15 22:47:09 2026] EXT4-fs (nvme0n1p6): mounted filesystem 1b39ae94-4c8e-4850-8299-c94430d599ed r/w with ordered data mode. Quota mode: none.
    [Fri May 15 22:47:11 2026] EXT4-fs (sda3): mounted filesystem 5b51390b-9db6-45dc-9bb3-f73b70ab26dd r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                SOURCE         FSTYPE OPTIONS
    /                     /dev/nvme0n1p2 ext4   rw,noatime
    |-/boot/firmware      /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/media/datenbank    /dev/nvme0n1p5 ext4   rw,noatime
    |-/media/netzlaufwerk /dev/nvme0n1p6 ext4   rw,noatime
    `-/media/backup       /dev/sda3      ext4   rw,noatime
    /var:
    8.6G    /var/
    4.0G    /var/log/journal/bd1a48426931463390bea39187d39d65
    4.0G    /var/log
    3.9G    /var/cache/apt
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    23M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    137M    /opt/iobroker/iobroker-data/
    73M     /opt/iobroker/iobroker-data/files
    54M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    9.4M    /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-NCiLc44Q.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u2 500
         18.20.4+dfsg-1~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 472650)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.8.23
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Objects and States
    Objects:        7561
    States:         6528
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 1s (13.2 kB/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6741       807/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6565       704/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6740       807/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          6739       807/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6567       704/sshd: /usr/sbin
    tcp6       0      0 :::445                  :::*                    LISTEN      0          6738       807/smbd
    udp        0      0 192.168.10.255:137      0.0.0.0:*                           0          5555       790/nmbd
    udp        0      0 192.168.10.8:137        0.0.0.0:*                           0          5554       790/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          5542       790/nmbd
    udp        0      0 192.168.10.255:138      0.0.0.0:*                           0          5557       790/nmbd
    udp        0      0 192.168.10.8:138        0.0.0.0:*                           0          5556       790/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          5543       790/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       588/avahi-daemon: r
    udp        0      0 0.0.0.0:39005           0.0.0.0:*                           104        2932       588/avahi-daemon: r
    udp6       0      0 fe80::60bd:9f11:16c:546 :::*                                0          6755       646/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        2931       588/avahi-daemon: r
    udp6       0      0 :::54898                :::*                                104        2933       588/avahi-daemon: r
    2026-05-15 20:52:34.578  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 send kill signal
    2026-05-15 20:52:34.578  - info: host.raspberrypi stopInstance system.adapter.mqtt.0 send kill signal
    2026-05-15 20:52:34.578  - info: host.raspberrypi stopInstance system.adapter.sonoff.0 send kill signal
    2026-05-15 20:52:34.578  - info: host.raspberrypi stopInstance system.adapter.modbus.0 send kill signal
    2026-05-15 20:52:34.578  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    2026-05-15 20:52:34.583  - info: modbus.0 (1080) terminating
    2026-05-15 20:52:34.584  - info: modbus.0 (1080) Terminated (NO_ERROR): Without reason
    2026-05-15 20:52:34.608  - info: mqtt.0 (184754) Client [rtl_433-5758ffff] connection closed: closed
    2026-05-15 20:52:34.992  - info: rpi2.0 (1011) terminating
    2026-05-15 20:52:34.995  - info: modbus.0 (1080) terminating
    2026-05-15 20:52:35.001  - info: sonoff.0 (1062) terminating
    2026-05-15 20:52:35.001  - info: discovery.0 (1110) terminating
    2026-05-15 20:52:35.005  - info: mqtt.0 (184754) terminating
    2026-05-15 20:52:35.014  - info: admin.0 (921) terminating
    2026-05-15 20:52:35.023  - info: backitup.0 (996) terminating
    2026-05-15 20:52:35.099  - info: host.raspberrypi instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.116  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.157  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.157  - info: host.raspberrypi instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.188  - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.201  - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.215  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.227  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
    2026-05-15 20:52:35.228  - info: host.raspberrypi All instances are stopped.
    2026-05-15 20:52:35.387  - info: host.raspberrypi terminated
    iob diag has finished.
    ole@raspberrypi:~ $
    • Kirk1701K Kirk1701
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      ole
      HOME=/home/ole
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:           536M          0B        536M
               8063 M total memory
                306 M used memory
                332 M active memory
               7010 M free memory
                103 M buffer memory
                731 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      8.6G    /var/
      4.0G    /var/log
      3.9G    /var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.8.23
      Adapter State
      + instance is alive
      Objects and States
      Objects:        7561
      States:         6528
      ole@raspberrypi:~ $
      @Kirk1701
      Und was steht in
      systemctl status iobroker.service
      geschrieben?
      • Kirk1701K Offline
        Kirk1701K Offline
        Kirk1701
        ole@raspberrypi:~ $ systemctl status iobroker.service
        ○ iobroker.service - ioBroker Server
             Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
             Active: inactive (dead)
               Docs: http://iobroker.net
        ole@raspberrypi:~ $
        Sieht eigentlich gut aus?!?
          ole@raspberrypi:~ $
          @Kirk1701 sagte:
          Naja, tot sieht für mich nicht gut aus...
          • Kirk1701K Offline
            Kirk1701K Offline
            Kirk1701
            oh, habe mich von der grünen Farbe verwirren lassen...
            aber Port ist schon 8081?
              ole@raspberrypi:~ $
              @Kirk1701 sagte:
              systemctl start iobroker
              • Kirk1701K Offline
                Kirk1701K Offline
                Kirk1701
                ole@raspberrypi:~ $
                ole@raspberrypi:~ $
                ole@raspberrypi:~ $
                ole@raspberrypi:~ $
                ole@raspberrypi:~ $
                ole@raspberrypi:~ $ systemctl start iobroker
                ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                Authentication is required to start 'iobroker.service'.
                Authenticating as: ,,, (ole)
                Password:
                ==== AUTHENTICATION COMPLETE ====
                Seit drei Minuten...
                PS: Grafana ist nun auch tot
                • Kirk1701K Offline
                  Kirk1701K Offline
                  Kirk1701
                  Also seit 8min startet der Service nun....ich denke das ist für einen Pi5 schon sehr lange.
                    @Kirk1701
                    Dann mach eine zweite Session auf und schau was der Service treibt.
                    • Kirk1701K Offline
                      Kirk1701K Offline
                      Kirk1701
                      root@raspberrypi:~# su - ole
                           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                      lines 1-4/4 (END)...skipping...
                      würde sagen "dead".
                        würde sagen "dead".
                        @Kirk1701 sagte:
                        root@raspberrypi
                        Und damit bin ich dann raus.
                        Du kapierst es eh nicht.
                        • Kirk1701K Offline
                          Kirk1701K Offline
                          Kirk1701
                          schrieb am zuletzt editiert von Kirk1701
                          hää, ich wechsel doch immer brav den Nutzer?
                          root ist eben in Putty bei mir so gespeichert.
                          • Kirk1701K Offline
                            Kirk1701K Offline
                            Kirk1701
                            ok, dann steht wohl jetzt eine Neuinstallation an....wegen einem Update 😖
                              @Kirk1701
                              Dann lass diesmal den Scheiß mit dem root sein...
                              RaspberryOS kennt kein Login als root. Da macht alles der erste eingerichtete user (ggfls. per sudo).
                              • Kirk1701K Offline
                                Kirk1701K Offline
                                Kirk1701
                                Ok, danke @thomas-braun
                                Ich werden dann mal ein Backup einspielen.
                                Vielleicht kannst du mir noch in zwei Sätzen erklären wo diese "root" Phobie her kommt? Mich nervt das auch das ich bei PI OS immer erst root anlegen muss und die ssh config anpassen muss damit ich mich überhaupt als root einloggen kann.
                                Und jetzt kann man nicht mal mehr Programme als root installieren?
                                Wie gesagt, ich bin da wohl nicht "mehr" auf Stand.
                                OliverIOO HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @Kirk1701
                                  Aus Sicherheitsgründen kann man sich in vielen Linux Betriebssystemen nicht mehr als Root anmelden. D.h. das Konto hat kein Passwort.
                                  Der erste User, der das System anliegt, kommt in die Admin Gruppe und kann dadurch per sudo einzelne Prozesse mit root rechten starten.
                                  Wenn man dann mit sudo einen Prozess startet, muss man sein eigenes Passwort noch mal eingeben.
                                  Das ganze einrichten passiert eigentlich,
                                  Zumindest bei Debian und Raspian automatisch während der Installation.
                                  Meine Adapter und Widgets
                                  Links im Profil
                                    @Kirk1701 sagte:
                                    Es gibt keine root-Phobie.
                                    Abgesehen von dem Sicherheitsaspekt kann die Nutzung von root die Rechtestruktur in dem System verändern, so wie es jetzt bei dir passiert ist und der Systemuser iobroker Dinge nicht mehr ausführen kann.
                                      @Kirk1701 sagte:
                                      Genau DAS ist ja dein falscher Umgang damit. Macht man seit vielen Jahren / Jahrzehnten nicht mehr. Das ist nicht von den Erstellern der Distribution 'vergessen' worden und muss jetzt von dir korrigiert werden.
                                      • Kirk1701K Offline
                                        Kirk1701K Offline
                                        Kirk1701
                                        Ok,
                                        ich habe jetzt ein Backup eingespielt und die Box läuft wieder.
                                        Wie bekomme ich den iobroker denn jetzt auf die neueste Version? Nach dem Einspielen des Backups ist nun diese Version aktuell.
                                          Ok,
                                          @Kirk1701
                                          Mittels
                                          iob nodejs-update
                                          Natürlich als user ausgeführt, NICHT als root!
