  4. Conbee 2 Probleme mit Erreichbarkeit
30 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • Michael SchmittM Offline
    Michael Schmitt
    schrieb am zuletzt editiert von Michael Schmitt
    Pi 4 - 4gb - Trixie - 64bit
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.12.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:42:47 up 36 min,  2 users,  load average: 0.55, 0.30, 0.31
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-03-07 15:42:47 CET
               Universal time: Sat 2026-03-07 14:42:47 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marvman67
    HOME=/home/marvman67
    GROUPS=marvman67 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/marvman67
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.2G        1.3G         10M        543M        1.8G
    Swap:           2.1G          0B        2.1G
    Total:          6.1G        2.2G        3.4G
    Active iob-Instances:   20
             3795 M total memory
             2124 M used memory
             2163 M active memory
              208 M inactive memory
             1239 M free memory
               58 M buffer memory
              460 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 15:42:48 up 36 min,  2 users,  load average: 0.55, 0.30, 0.31
    Tasks: 212 total,   1 running, 211 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.1 us,  2.1 sy,  0.0 ni, 93.8 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.7 total,   1238.0 free,   2125.8 used,    519.0 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1669.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  750M   2% /run
    /dev/sda2      ext4      229G  6.9G  213G   4% /
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.9G  660K  1.9G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
    [Sat Mar  7 15:05:54 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sat Mar  7 15:05:54 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Sat Mar  7 15:05:57 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    231M    /var/cache
    225M    /var/cache/apt
    187M    /var/lib
    145M    /var/lib/apt/lists
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    46M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    318M    /opt/iobroker/iobroker-data/
    178M    /opt/iobroker/iobroker-data/files
    115M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    5.1M    /opt/iobroker/iobroker-data/states.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2706986-if00
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 2212)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : Raspberry                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberry                                -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
    + system.adapter.deconz.0                 : deconz                : Raspberry                                -  enabled, port: 80
      system.adapter.devices.0                : devices               : Raspberry                                - disabled
    + system.adapter.email.0                  : email                 : Raspberry                                -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberry                                -  enabled
    + system.adapter.history.0                : history               : Raspberry                                -  enabled
      system.adapter.ical.0                   : ical                  : Raspberry                                -  enabled
      system.adapter.iot.0                    : iot                   : Raspberry                                - disabled
    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
    + system.adapter.matter.0                 : matter                : Raspberry                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberry                                -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberry                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberry                                -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
    + system.adapter.telegram.0               : telegram              : Raspberry                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberry                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
    + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.6    , installed 1.0.0
    Adapter    "rpi2"         : 2.4.0    , installed 3.0.1
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        5966
    States:         4429
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://phoscon.de/apt/deconz generic InRelease
    Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       10533      1607/io.socketio.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7742       1135/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6899       1135/iobroker.js-co
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3648       1/init
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       945        631/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7713       1148/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       946        631/deCONZ
    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       6737       631/deCONZ
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       11275      1595/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9003       1639/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7836       1197/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       8558       1205/io.admin.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          139        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7715       1148/sshd: /usr/sbi
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11488      1579/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10578      1579/io.matter.0
    udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       8970       1477/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        814        627/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       10577      1579/io.matter.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       12098      2014/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7641       631/deCONZ
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5190       1/init
    udp        0      0 0.0.0.0:51581           0.0.0.0:*                           101        816        627/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                1001       11489      1579/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       10581      1579/io.matter.0
    udp6       0      0 :::5353                 :::*                                101        815        627/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1001       10576      1579/io.matter.0
    udp6       0      0 :::52931                :::*                                101        817        627/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       12101      2014/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       12100      2014/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       12099      2014/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          5191       1/init
    udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          7733       822/NetworkManager
    Name: Bewegungsmelder_CZ reachable
    Wert: true
    Sensor ist wieder erreichbar
    2026-03-07 15:16:04.868  - info: javascript.0 (1303) script.js.common.Wichtig.Sensor_erreichbar: telegram[Michael]: Kanal ID: deconz.0.Sensors.131
    Wert: true
    2026-03-07 15:16:06.876  - info: javascript.0 (1303) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
    Wert: false
    Adapter NICHT erreichbar
    2026-03-07 15:16:28.717  - info: javascript.0 (1303) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
    Wert: true
    Adapter ist wieder erreichbar
    2026-03-07 15:19:31.135  - info: javascript.0 (1303) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Fenster_CZ wurde geöffnet.
    2026-03-07 15:19:31.639  - info: fritzdect.0 (1539) DECT ID: 133560175984 identified for command (hkrmode) : 1
    2026-03-07 15:19:32.639  - info: fritzdect.0 (1539) DECT ID: 099950696353 identified for command (hkrmode) : 1
    2026-03-07 15:19:33.140  - info: fritzdect.0 (1539) DECT ID: 133560170728 identified for command (hkrmode) : 1
    2026-03-07 15:20:08.555  - info: javascript.0 (1303) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Fenster_CZ wurde wieder geschlossen.
    2026-03-07 15:20:09.059  - info: fritzdect.0 (1539) DECT ID: 133560175984 identified for command (hkrmode) : 0
    2026-03-07 15:20:10.092  - info: fritzdect.0 (1539) DECT ID: 099950696353 identified for command (hkrmode) : 0
    2026-03-07 15:20:10.559  - info: fritzdect.0 (1539) DECT ID: 133560170728 identified for command (hkrmode) : 0
    2026-03-07 15:30:00.040  - info: host.Raspberry instance system.adapter.ical.0 in version "1.18.1" started with pid 2667
    2026-03-07 15:30:09.612  - info: host.Raspberry instance system.adapter.ical.0 having pid 2667 terminated with code 0 (NO_ERROR)
    2026-03-07 15:35:02.883  - info: admin.0 (1197) ==> Connected system.user.admin from ::ffff:192.168.178.29
    2026-03-07 15:35:08.586  - info: admin.0 (1197) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
    Edit: das einzige was ich ändern mußte war nach dem Update von Phoscon, den Websocket Port zu 441. Wegen der erreichbarkeit zum Deconz Adapter
      Michael Schmitt
      was mir nach aufgefallen ist. Kurz vor der Störung stand im Log immer
      2026-03-06 20:30:47.671 - info: admin.0 (1215) Adapter rating updated
      2026-03-06 20:30:54.319 - info: admin.1 (1222) Adapter rating updated
      (vielleicht nur Zufall)
      • Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        Also es scheint alles in Ordnung zu sein. Dann bleibt noch der von dir verlinkte Bug.
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • Michael SchmittM Michael Schmitt
          Script v.2026-01-31
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          marvman67
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   3795 M total memory
                   2124 M used memory
                   1239 M free memory
                     58 M buffer memory
                    460 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          231M    /var/cache
          225M    /var/cache/apt
          187M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5966
          States:         4429
          Wert: true
          Wert: true
          Wert: false
          Wert: true
          @Michael-Schmitt sagte in Conbee 2 Probleme mit Erreichbarkeit:
          da hängt aber auch noch die 443!
            Michael Schmitt
            und wie bekomme ich das Luder weg ?
            /usr/lib/systemd/system
            deconz.service
            Description=deCONZ: ZigBee gateway -- REST API
            Wants=deconz-init.service
            StartLimitIntervalSec=0
            [Service]
            User=1000
            ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --ws-port=441
            Restart=on-failure
            RestartSec=30
            AmbientCapabilities=CAP_NET_BIND_SERVICE CAP_KILL CAP_SYS_BOOT CAP_SYS_TIME
            [Install]
            WantedBy=multi-user.target
              Michael Schmitt
              ist der Port 443 für Deconz zwingend notwendig wenn man sich nur im eigenen Lan befindet ?
                Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                @Michael-Schmitt 443 bzw. jetzt 441 ist für die websocket Verbindung für den Adapter nötig.
                  Michael Schmitt
                  aber wie Homoran bemerkt hat ist der Port 443 (ist für https) von Deconz ja auch noch aktiv
                    Michael Schmitt
                    ich hab dann mal die KI gefragt und folgendes gemacht
                    sudo ss -tulpn | grep :443
                    Ergebniss:
                    tcp   LISTEN 0      64                        0.0.0.0:443        0.0.0.0:*    users:(("deCONZ",pid=631,fd=9))
                    KI:
                    Das Ergebnis ist eindeutig:
                    deCONZ (PID 631) belegt den Port 443 weiterhin als Standard-HTTPS-Port
                    Das wurde mir dann vorgeschlagen:
                    Schritt-für-Schritt Lösung:
                        Den "echten" Override anlegen:
                        Systemd-Units in /usr/lib/ werden oft von Updates überschrieben. Nutze diesen Befehl, um die Parameter sicher zu erzwingen:
                        bash
                        sudo systemctl edit deconz.service
                        Verwende Code mit Vorsicht.
                        Diesen Block exakt so einfügen:
                        (Das erste leere ExecStart= ist zwingend notwendig, um den Standardbefehl zu löschen!)
                        ini
                        [Service]
                        ExecStart=
                        ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 --https-port=0 --ws-port=441
                        Dienst neu laden und prüfen:
                        bash
                        sudo systemctl daemon-reload
                        bash
                        sudo systemctl restart deconz
                        Kontrolle:
                        Führe systemctl status deconz erneut aus. In der untersten Zeile (CGroup) muss jetzt --https-port=0 stehen.
                    Ergebniss systemctl status deconz:
                    marvman67@Raspberry:/usr/lib/systemd/system $ systemctl status deconz
                    ● deconz.service - deCONZ: ZigBee gateway -- REST API
                         Loaded: loaded (/usr/lib/systemd/system/deconz.service; enabled; preset: enabled)
                         Active: active (running) since Sat 2026-03-07 19:17:57 CET; 2min 14s ago
                     Invocation: 08511c86cf4944728f298053919a491d
                       Main PID: 13718 (deCONZ)
                          Tasks: 9 (limit: 3924)
                            CPU: 8.313s
                         CGroup: /system.slice/deconz.service
                                 └─13718 /usr/bin/deCONZ -platform minimal --http-port=80 --https-port=0 --ws-port=441
                    Mar 07 19:17:57 Raspberry systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
                    Mar 07 19:17:58 Raspberry deCONZ[13718]: This plugin does not support propagateSizeHints()
                    Mar 07 19:18:02 Raspberry deCONZ[13718]: This plugin does not support propagateSizeHints()
                    KI:
                    Perfekt, jetzt ist die Konfiguration sauber! In der
                    CGroup-Zeile steht nun korrekt --https-port=0. Damit ist Port 443 jetzt definitiv frei und deCONZ konzentriert sich nur noch auf Port 80 und den Websocket auf 441.
                    Das sollte die Stabilität deines Systems bereits deutlich erhöhen, da keine Port-Konflikte mehr auftreten können.
                    Hier noch ein Iob diag
                    ```bash
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                     22:42:59 up  7:37,  1 user,  load average: 0.29, 0.25, 0.21
                    CPU threads: 4
                    Current issues:
                                   Local time: Sat 2026-03-07 22:42:59 CET
                               Universal time: Sat 2026-03-07 21:42:59 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    marvman67
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            4.0G        2.4G        923M         12M        762M        1.6G
                    Swap:           2.1G          0B        2.1G
                    Total:          6.1G        2.4G        3.1G
                             3795 M total memory
                             2287 M used memory
                             2271 M active memory
                              455 M inactive memory
                              880 M free memory
                               75 M buffer memory
                              651 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    top - 22:42:59 up  7:37,  1 user,  load average: 0.29, 0.25, 0.21
                    Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  2.2 us,  2.2 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3795.7 total,    879.1 free,   2288.5 used,    727.3 buff/cache
                    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1507.2 avail Mem
                    *** FILESYSTEM ***
                    tmpfs          tmpfs     1.9G  3.1M  1.9G   1% /tmp
                    /var:
                    2.5G    /var/
                    231M    /var/cache
                    225M    /var/cache/apt
                    187M    /var/lib
                    52M     /opt/iobroker/backups/
                    342M    /opt/iobroker/iobroker-data/
                    44M     /opt/iobroker/iobroker-data/objects.jsonl
                    6.2M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 27414)
                    admin:          7.7.22
                    javascript:     9.0.18
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5966
                    States:         4429
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       88320      13718/deCONZ
                    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       89111      13718/deCONZ
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       97693      15242/io.admin.0
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       89523      14050/io.deconz.0
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       88332      13718/deCONZ
                    udp6       0      0 :::1900                 :::*                                1001       89526      14050/io.deconz.0
                    udp6       0      0 :::1900                 :::*                                1001       89525      14050/io.deconz.0
                    udp6       0      0 :::1900                 :::*                                1001       89524      14050/io.deconz.0
                    2026-03-07 21:00:07.334  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3C29B1AFC identified for command (toggle) : false
                    2026-03-07 21:00:07.336  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3BC66DC91 identified for command (toggle) : false
                    2026-03-07 21:00:07.791  - info: fritzdect.0 (1539) Template ID: tmpBB0A5E-3AF8DA1F4 identified for command (toggle) : false
                    2026-03-07 21:00:07.834  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3C29B2097 identified for command (toggle) : false
                    2026-03-07 21:00:07.836  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3BC66E023 identified for command (toggle) : false
                    2026-03-07 21:00:08.291  - info: fritzdect.0 (1539) Template ID: tmpBB0A5E-3AFC00222 identified for command (toggle) : false
                    2026-03-07 21:00:08.295  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3C29B1601 identified for command (toggle) : false
                    2026-03-07 21:00:08.338  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3BCEB17B3 identified for command (toggle) : false
                    2026-03-07 21:00:09.291  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3DC99993D identified for command (toggle) : true
                    2026-03-07 21:00:09.334  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3DC99ABC8 identified for command (toggle) : true
                    2026-03-07 21:00:09.337  - info: fritzdect.0 (1539) Template ID: tmpBD85CF-3DC99A393 identified for command (toggle) : true
                    2026-03-07 21:00:19.822  - info: web.0 (1639) <== Disconnect system.user.admin from ::ffff:192.168.178.27 iqontrol.0
                    2026-03-07 21:12:41.995  - info: admin.0 (15242) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
                    2026-03-07 21:12:42.071  - info: admin.0 (15242) ==> Connected system.user.admin from ::ffff:192.168.178.29
                    2026-03-07 21:12:42.102  - info: admin.0 (15242) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
                    2026-03-07 21:12:43.216  - info: admin.0 (15242) ==> Connected system.user.admin from ::ffff:192.168.178.29
                    2026-03-07 21:15:51.160  - info: admin.0 (15242) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
                    2026-03-07 21:15:57.386  - info: admin.0 (15242) ==> Connected system.user.admin from ::ffff:192.168.178.29
                    2026-03-07 21:16:41.620  - info: admin.0 (15242) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
                    2026-03-07 21:30:00.094  - info: host.Raspberry instance system.adapter.ical.0 in version "1.18.1" started with pid 20905
                    2026-03-07 21:30:09.542  - info: host.Raspberry instance system.adapter.ical.0 having pid 20905 terminated with code 0 (NO_ERROR)
                    2026-03-07 21:35:02.691  - info: admin.0 (15242) ==> Connected system.user.admin from ::ffff:192.168.178.29
                    2026-03-07 21:43:43.090  - info: admin.0 (15242) <== Disconnect system.user.admin from ::ffff:192.168.178.29 admin
                    2026-03-07 22:30:00.041  - info: host.Raspberry instance system.adapter.ical.0 in version "1.18.1" started with pid 23648
                    2026-03-07 22:30:09.679  - info: host.Raspberry instance system.adapter.ical.0 having pid 23648 terminated with code 0 (NO_ERROR)
                    Darin kann man nun sehen Deconz nutzt nur Port 80 und 441
                    Bis jetzt habe ich keine Probleme und das System Läuft sauber. (seit über 3 Std) mal schauen was morgen ist.
                      Michael Schmitt
                      bis jetzt hatte ich keine Probleme mehr ;)
                      EDIT: 17.03.26 alles läuft sauber, auch nach update + upgrade. Mal schauen was nach dem nächsten deconz update passiert.
