  3. Einsteigerfragen
  4. Installation
  5. ESPHome fordert neue Pillow Version
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Installation
49 Beiträge 6 Kommentatoren 2.5k Aufrufe 5 Beobachtet
    bernd33-1
    schrieb am zuletzt editiert von bernd33-1
    #41
    Ok, neu installiert:
    iob repo unset stable
    iob repo set beta
    iob update
    iob add esphome --host raspi5 --debug
    iob repo unset beta
    iob repo set stable
    iob update
    Hier das IOB DEBUG. Unter Adapter State ist der esphome aufgeführt aber unter Installed ioBroker-Adapters nicht.
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspi5
           Icon name: computer
              Kernel: Linux 6.18.29+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-05-14 17:25:18 CEST
               Universal time: Thu 2026-05-14 15:25:18 UTC
                     RTC time: Thu 2026-05-14 15:25:18
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    bernd
    HOME=/home/bernd
    GROUPS=bernd adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/bernd
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.2G        2.1G        1.2G         24M        1.2G        2.1G
    Swap:           2.1G          0B        2.1G
    Total:          6.4G        2.1G        3.3G
    Active iob-Instances:   17
             4045 M total memory
             2007 M used memory
             1968 M active memory
              666 M inactive memory
             1101 M free memory
               99 M buffer memory
             1005 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 17:25:18 up 31 min,  1 user,  load average: 0.28, 0.30, 0.32
    Tasks: 184 total,   1 running, 183 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4045.1 total,   1099.2 free,   2009.8 used,   1105.9 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   2035.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     810M   14M  796M   2% /run
    /dev/sda2      ext4      229G  7.6G  212G   4% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     2.0G  9.2M  2.0G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    tmpfs          tmpfs     405M   32K  405M   1% /run/user/1000
    [Thu May 14 16:53:41 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Thu May 14 16:53:41 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Thu May 14 16:53:42 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    245M    /var/cache
    240M    /var/cache/apt
    186M    /var/lib
    146M    /var/lib/apt/lists
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    42M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    364M    /opt/iobroker/iobroker-data/
    166M    /opt/iobroker/iobroker-data/files
    107M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_16-30_objects.jsonl.gz
    4.4M    /opt/iobroker/iobroker-data/backup-objects/2026-05-14_14-30_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi5              raspi5 (version: 7.0.7, hostname: raspi5        , alive, uptime: 1892)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
      system.adapter.cloud.0                  : cloud                 : raspi5                                   - disabled
      system.adapter.devices.0                : devices               : raspi5                                   -  enabled
      system.adapter.discovery.0              : discovery             : raspi5                                   - disabled
    + system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
    + system.adapter.esphome.0                : esphome               : raspi5                                   -  enabled
      system.adapter.feiertage.0              : feiertage             : raspi5                                   -  enabled
    + system.adapter.history.0                : history               : raspi5                                   -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
    + system.adapter.hmip.0                   : hmip                  : raspi5                                   -  enabled
      system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
    + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : raspi5                                   -  enabled
    + system.adapter.telegram.0               : telegram              : raspi5                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
      system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
    + system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 192.168.0.5, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "cloud"        : 6.0.1    , installed 6.0.1
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        3308
    States:         2447
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9227       1244/io.mqtt.0
    tcp        0      0 192.168.0.5:2010        0.0.0.0:*               LISTEN      1001       6027       1096/io.hm-rpc.1
    tcp        0      0 192.168.0.5:2001        0.0.0.0:*               LISTEN      1001       8497       1080/io.hm-rpc.0
    tcp        0      0 192.168.0.5:8082        0.0.0.0:*               LISTEN      1001       8710       1260/io.web.0
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       18746      3411/python3
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7681       900/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6846       900/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4350       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5775       913/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8877       1404/io.admin.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          4351       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5777       913/sshd: /usr/sbin
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       18752      3411/python3
    udp        0      0 192.168.0.5:5353        0.0.0.0:*                           1001       18751      3411/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18747      3411/python3
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5022       699/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2573       1/init
    udp        0      0 0.0.0.0:57922           0.0.0.0:*                           101        5024       699/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                101        5023       699/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          4352       1/init
    udp6       0      0 :::48012                :::*                                101        5025       699/avahi-daemon: r
    2026-05-14 17:22:16.520  - info: esphome.0 (3333) [ESPHome - Console] 2026-05-14 17:22:16,519 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
    2026-05-14 17:22:42.946  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
    2026-05-14 17:22:42.947  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
    2026-05-14 17:22:56.934  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
    2026-05-14 17:23:02.496  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
    2026-05-14 17:23:18.835  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
    2026-05-14 17:23:30.720  - info: admin.0 (1404) <== Disconnect system.user.admin from ::ffff:192.168.0.79 admin
    2026-05-14 17:23:51.002  - info: host.raspi5 stopInstance system.adapter.esphome.0 (force=false, process=true)
    2026-05-14 17:23:51.005  - info: esphome.0 (3333) Got terminate signal TERMINATE_YOURSELF
    2026-05-14 17:23:51.006  - info: esphome.0 (3333) terminating
    2026-05-14 17:23:51.007  - info: esphome.0 (3333) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-14 17:23:51.046  - info: host.raspi5 stopInstance system.adapter.esphome.0 send kill signal
    2026-05-14 17:23:51.509  - info: esphome.0 (3333) terminating
    2026-05-14 17:23:51.530  - info: host.raspi5 instance system.adapter.esphome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-05-14 17:23:54.852  - info: host.raspi5 instance system.adapter.esphome.0 in version "0.6.3" started with pid 3390
    2026-05-14 17:23:55.615  - info: esphome.0 (3390) starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.22.2, js-controller: 7.0.7
    2026-05-14 17:23:56.199  - info: esphome.0 (3390) Native Integration of ESPHome Dashboard enabled, making environment ready
    2026-05-14 17:23:56.696  - info: esphome.0 (3390) Starting ESPHome Dashboard
    2026-05-14 17:23:56.699  - warn: esphome.0 (3390) Auto Discovery disabled, new devices (or IP changes) will NOT be detected automatically!
    2026-05-14 17:23:56.994  - info: esphome.0 (3390) [ESPHome - Console] 2026-05-14 17:23:56,994 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir /opt/iobroker/iobroker-data/esphome.0...
    2026-05-14 17:24:30.989  - info: admin.0 (1404) ==> Connected system.user.admin from ::ffff:192.168.0.79
    2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.3_Heizbedarf: Es gibt kein Heizbedarf
    2026-05-14 17:25:19.698  - info: javascript.0 (996) script.js.common.Heizung.ZweipunktregelungThermostate.NinaZimmer: Aktivität Nina Zimmer
      #42
      Was kommt beiiob install esphome@0.6.3 --debug?
      Wenn etwas wie "ist bereits installiert kommt:
      iob upgrade esphome@0.6.3 --debug
      B 1 Antwort Letzte Antwort
        bernd33-1
        #43
        @Homoran sagte:
        adapter "esphome" already installed. Use "upgrade" to upgrade to a newer version.
        und
        Adapter "esphome" is not in the repository and cannot be updated.
        Ok, ich muss auf beta umstellen? Gemacht. Und dann der Ablauf:
        bernd@raspi5:~ $ iob repo unset stable
        Repository "stable" deactivated.
        Active repo(s):
        bernd@raspi5:~ $ iob repo set beta
        Repository "beta" set as active.
        Active repo(s): beta
        bernd@raspi5:~ $ iob update
        Used repository: beta
        Adapter    "admin"        : 7.8.24   , installed 7.8.23 [Updatable]
        Adapter    "backitup"     : 3.3.17   , installed 3.3.14 [Updatable]
        Adapter    "devices"      : 2.0.12   , installed 1.2.14 [Updatable]
        Adapter    "esphome"      : 0.6.3    , installed 0.6.3
        Adapter    "feiertage"    : 1.4.0    , installed 1.3.0  [Updatable]
        Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.1  [Updatable]
        Adapter    "ical"         : 1.20.1   , installed 1.20.0 [Updatable]
        Adapter    "javascript"   : 9.2.2    , installed 9.0.18 [Updatable]
        Controller "js-controller": 7.1.2    , installed 7.0.7  [Updatable]
        Adapter    "ping"         : 2.2.2    , installed 1.7.9  [Updatable]
        Adapter    "trashschedule": 5.3.0    , installed 3.3.0  [Updatable]
        Adapter    "web"          : 8.1.0    , installed 8.0.0  [Updatable]
        Adapter    "ws"           : 4.1.0    , installed 4.0.0  [Updatable]
        Adapter    "zigbee"       : 3.4.3    , installed 3.3.5  [Updatable]
        bernd@raspi5:~ $ iob upgrade esphome@0.6.3 --debug
        Would you like to reinstall version 0.6.3 of esphome now? [(y)es, (n)o]: y
        Update esphome from @0.6.3 to @0.6.3
        Uninstall npm packet "iobroker.esphome" for a clean re-installation
        removed 106 packages in 2s
        190 packages are looking for funding
          run `npm fund` for details
        NPM version: 10.9.7
        Installing iobroker.esphome@0.6.3... (System call)
        npm warn deprecated @mongodb-js/zstd@1.2.2: 1.x versions of this package are deprecated, please use 2.x instead
        npm warn deprecated @mongodb-js/zstd-linux-arm64-gnu@1.2.2: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
        added 105 packages in 7s
        198 packages are looking for funding
        Updating objects from io-package.json for adapter "esphome" with version "0.6.3"
        upload [26] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
        upload [20] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [19] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [18] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [17] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [16] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [15] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [14] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [13] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPHomeDashboardUrl.png img/ESPHomeDashboardUrl.png image/png
        upload [12] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPhomeDashboardIP.png img/ESPhomeDashboardIP.png image/png
        upload [11] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionIssue.png img/connectionIssue.png image/png
        upload [10] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionOK.png img/connectionOK.png image/png
        upload [9] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
        upload [8] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTabEmpty.png img/deviceTabEmpty.png image/png
        upload [7] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTree.png img/deviceTree.png image/png
        upload [6] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/flashFromThisComputer.png img/flashFromThisComputer.png image/png
        upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/proxy.png img/proxy.png image/png
        upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
        upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
        upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/tsconfig.json tsconfig.json application/json
        upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
        bernd@raspi5:~ $
        bernd@raspi5:~ $
        bernd@raspi5:~ $ iob repo unset beta
        Repository "beta" deactivated.
        Active repo(s):
        bernd@raspi5:~ $ iob repo set stable
        Repository "stable" set as active.
        • B bernd33-1
          @Homoran sagte:
          und
          Active repo(s):
          NPM version: 10.9.7
          bernd@raspi5:~ $
          bernd@raspi5:~ $
          Active repo(s):
          #44
          @bernd33-1 und wie läuft es jetzt?
            bernd33-1
            #45
            @Homoran Es Läuft. Hab den Adapter jetzt ja 2 mal deinstalliert und dann neu installiert.
            Es kommen nun nach der Installation auch nichtmehr die Fehlermeldungen die ich am Anfang dieses Threads gepostet hab. Scheint zu passen :-)
            • B bernd33-1
              #46
              Dann lass es jetzt so.
              Auf meinem Testsystem wird die Version allerdings ausgegeben:
              thomas@testpi:~ $ iob list adapters
              │ (index) │ id                          │ name         │ version  │ upgrade policy │
              │ 0       │ 'system.adapter.admin'      │ 'admin'      │ '7.8.23' │ 'none'         │
              │ 1       │ 'system.adapter.backitup'   │ 'backitup'   │ '3.3.14' │ 'none'         │
              │ 2       │ 'system.adapter.discovery'  │ 'discovery'  │ '5.0.0'  │ 'none'         │
              │ 3       │ 'system.adapter.esphome'    │ 'esphome'    │ '0.6.3'  │ 'none'         │
              │ 4       │ 'system.adapter.javascript' │ 'javascript' │ '9.0.18' │ 'none'         │
              │ 5       │ 'system.adapter.rpi2'       │ 'rpi2'       │ '3.0.2'  │ 'none'         │
              │ 6       │ 'system.adapter.web'        │ 'web'        │ '8.0.0'  │ 'none'         │
              │ 7       │ 'system.adapter.ws'         │ 'ws'         │ '4.0.0'  │ 'none'         │
              thomas@testpi:~ $
                thomas@testpi:~ $
                #47
                @Thomas-Braun sagte:
                Vielleicht hilft bei @bernd33-1 noch ein iob upload esphome
                  bernd33-1
                  #48
                  Ich lass es mal jetzt so laufen und beobachte das ganze. Ausschauen tut es jetzt jedenfalls gut.
                  Danke für die tatkräftige Unterstützung! :-)
                    michelm16
                    #49
                    heute gab es das offizielle Update auf die V0.7.0.
                    Damit war bei mir der gleiche Fehler wie hier oben beschrieben gelöst.
                    VG, Michael
