  3. Einsteigerfragen
  4. script Fehler nach update
    5.3k
22 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    Seide Th
    Guten Morgen, ich habe gerade die Updates durchgeführt und jetzt läuft das Protokoll mit folgender Meldung voll:
    javascript.0
    	2025-12-04 11:18:23.863	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    Ich kann nicht feststellen welches Script den Fehler auslöst.
    Anbei die Ausgabe von iob diag:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.3 LTS
     Static hostname: vm-iobroker02
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: vmware
              Kernel: Linux 6.8.0-88-generic
        Architecture: x86-64
     Hardware Vendor: VMware, Inc.
      Hardware Model: VMware Virtual Platform
    Firmware Version: 6.00
       Firmware Date: Wed 2018-12-12
        Firmware Age: 6y 11month 3w 2d
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i7-4790T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : vmware
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:21:03 up  1:53,  1 user,  load average: 1.30, 0.69, 0.38
    CPU threads: 5
    *** LIFE CYCLE STATUS ***
    Operating System is the current Ubuntu LTS release codenamed 'noble'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-12-04 11:21:04 CET
               Universal time: Thu 2025-12-04 10:21:04 UTC
                     RTC time: Thu 2025-12-04 10:21:03
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thorsten
    HOME=/home/thorsten
    GROUPS=thorsten adm cdrom sudo dip plugdev lxd iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             10G        6.5G        1.8G        1.3M        2.4G        3.9G
    Swap:           6.4G         12K        6.4G
    Total:           16G        6.5G        8.3G
    Active iob-Instances:   25
             9944 M total memory
             6190 M used memory
             6775 M active memory
             1016 M inactive memory
             1727 M free memory
              101 M buffer memory
             2193 M swap cache
             6143 M total swap
                0 M used swap
             6143 M free swap
    top - 11:21:04 up  1:53,  1 user,  load average: 1.30, 0.69, 0.38
    Tasks: 291 total,   2 running, 289 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 21.3 us,  1.1 sy,  0.0 ni, 69.7 id,  7.9 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   9944.9 total,   1727.0 free,   6190.3 used,   2295.7 buff/cache
    MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   3754.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                                     Type   Size  Used Avail Use% Mounted on
    tmpfs                                          tmpfs  995M  1.3M  994M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv              ext4    90G   48G   38G  56% /
    tmpfs                                          tmpfs  4.9G     0  4.9G   0% /dev/shm
    tmpfs                                          tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                                      ext4   974M  197M  711M  22% /boot
    //192.168.11.10/raspberry-backup/vm-iobroker02 cifs   913G  780G  134G  86% /opt/iobroker/backups
    //192.168.11.10/backup-iobroker/Oberhausen     cifs   913G  780G  134G  86% /opt/iobroker/backups
    tmpfs                                          tmpfs  995M   20K  995M   1% /run/user/1000
    [Thu Dec  4 09:28:08 2025] EXT4-fs (dm-0): mounted filesystem 53351748-d0c9-4f18-a788-eaf4d09ada71 ro with ordered data mode. Quota mode: none.
    [Thu Dec  4 09:28:11 2025] EXT4-fs (dm-0): re-mounted 53351748-d0c9-4f18-a788-eaf4d09ada71 r/w. Quota mode: none.
    [Thu Dec  4 09:28:14 2025] EXT4-fs (sda2): mounted filesystem b659c5e2-3fa3-497d-9256-b5203061160b r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                    SOURCE                                         FSTYPE   OPTIONS
    /                         /dev/mapper/ubuntu--vg-ubuntu--lv              ext4     rw,relatime
    |-/opt/iobroker/backups   //192.168.11.10/raspberry-backup/vm-iobroker02 cifs     rw,relatime,vers=2.0,cache=strict,upcall_target=app,username=backitup-vm,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.11.10,file_mode=0664,dir_mode=0775,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    | `-/opt/iobroker/backups //192.168.11.10/backup-iobroker/Oberhausen     cifs     rw,relatime,vers=2.0,cache=strict,upcall_target=app,username=Smarthome,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.11.10,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    |-/snap/btop/924          /dev/loop0                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/btop/935          /dev/loop1                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2959       /dev/loop2                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2976       /dev/loop3                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core24/1196       /dev/loop6                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/2682       /dev/loop5                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/2669       /dev/loop4                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core24/1225       /dev/loop7                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/lxd/32662         /dev/loop8                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/25202       /dev/loop10                                    squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/25577       /dev/loop11                                    squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/lxd/36554         /dev/loop9                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    `-/boot                   /dev/sda2                                      ext4     rw,relatime
    /var:
    35G     /var/
    32G     /var/lib
    31G     /var/lib/influxdb/data/iobroker/autogen
    Archived and active journals take up 2.3G in the file system.
    /opt/iobroker/backups:
    142G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    718M    /opt/iobroker/iobroker-data/
    253M    /opt/iobroker/iobroker-data/files
    199M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    152M    /opt/iobroker/iobroker-data/states.jsonl
    84M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/objects.json.migrated
    13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 100
            100 /var/lib/dpkg/status
         18.19.1+dfsg-6ubuntu5 500
            500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    vm-iobroker02       vm-iobroker02 (version: 7.0.7, hostname: vm-iobroker02 , alive, uptime: 6730)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : vm-iobroker02                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : vm-iobroker02                            -  enabled
    + system.adapter.bydhvs.0                 : bydhvs                : vm-iobroker02                            -  enabled
      system.adapter.daswetter.0              : daswetter             : vm-iobroker02                            - disabled
      system.adapter.daswetter.1              : daswetter             : vm-iobroker02                            - disabled
      system.adapter.daswetter.2              : daswetter             : vm-iobroker02                            - disabled
    + system.adapter.discovery.0              : discovery             : vm-iobroker02                            -  enabled
    + system.adapter.email.0                  : email                 : vm-iobroker02                            -  enabled
      system.adapter.email.1                  : email                 : vm-iobroker02                            - disabled
    + system.adapter.energiefluss.0           : energiefluss          : vm-iobroker02                            -  enabled
      system.adapter.evcc.0                   : evcc                  : vm-iobroker02                            - disabled, port: 7070
    + system.adapter.go-e.0                   : go-e                  : vm-iobroker02                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : vm-iobroker02                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : vm-iobroker02                            -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : vm-iobroker02                            - disabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : vm-iobroker02                            -  enabled, port: 12010
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: vm-iobroker02                            -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : vm-iobroker02                            -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : vm-iobroker02                            -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : vm-iobroker02                            -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : vm-iobroker02                            -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : vm-iobroker02                            -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : vm-iobroker02                            -  enabled
    + system.adapter.influxdb.0               : influxdb              : vm-iobroker02                            -  enabled, port: 8086
      system.adapter.iqontrol.0               : iqontrol              : vm-iobroker02                            - disabled
    + system.adapter.javascript.0             : javascript            : vm-iobroker02                            -  enabled
    + system.adapter.lovelace.0               : lovelace              : vm-iobroker02                            -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : vm-iobroker02                            -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : vm-iobroker02                            -  enabled, port: 8883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : vm-iobroker02                            - disabled
      system.adapter.pi-hole.0                : pi-hole               : vm-iobroker02                            - disabled
      system.adapter.ping.0                   : ping                  : vm-iobroker02                            - disabled
    + system.adapter.plenticore.0             : plenticore            : vm-iobroker02                            -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : vm-iobroker02                            -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.squeezebox.0             : squeezebox            : vm-iobroker02                            - disabled, port: 9090
      system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : vm-iobroker02                            - disabled, port: 9000
    + system.adapter.synology.0               : synology              : vm-iobroker02                            -  enabled, port: 5000
      system.adapter.tesla-motors.0           : tesla-motors          : vm-iobroker02                            - disabled
    + system.adapter.tesla-motors.1           : tesla-motors          : vm-iobroker02                            -  enabled
    + system.adapter.tr-064.0                 : tr-064                : vm-iobroker02                            -  enabled
    + system.adapter.unifi.0                  : unifi                 : vm-iobroker02                            -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : vm-iobroker02                            -  enabled
      system.adapter.viessmannapi.1           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.2           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.3           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.4           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : vm-iobroker02                            -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : vm-iobroker02                            -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : vm-iobroker02                            -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : vm-iobroker02                            -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : vm-iobroker02                            -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : vm-iobroker02                            -  enabled
      system.adapter.vis-metro.0              : vis-metro             : vm-iobroker02                            -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : vm-iobroker02                            -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : vm-iobroker02                            -  enabled
      system.adapter.vis.0                    : vis                   : vm-iobroker02                            -  enabled
    + system.adapter.web.0                    : web                   : vm-iobroker02                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name                │ url                                                     │ auto upgrade │
    │ 0       │ 'sicherung-default' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'sicherung-lastet'  │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable'            │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 3       │ 'beta'              │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
    Adapter    "daswetter"    : 3.2.8    , installed 3.1.16 [Updatable]
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "evcc"         : 0.2.3    , installed 0.2.3
    Adapter    "go-e"         : 1.0.41   , installed 1.0.29 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.1    , installed 5.0.1
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "net-tools"    : 1.2.3    , installed 0.2.0  [Updatable]
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "squeezeboxrpc": 1.6.2    , installed 1.6.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        125610
    States:         107661
    Hit:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
    Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      101        7932       986/systemd-resolve
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          13006      1589/perl
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14933      1760/io.sonoff.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       12068      1788/io.mqtt.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13377      1684/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       10720      1684/iobroker.js-co
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      115        12977      1531/influxd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8913       1/init
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1694       1/init
    tcp        0      0 192.168.11.182:12010    0.0.0.0:*               LISTEN      1001       15449      1807/io.hm-rpc.2
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        7930       986/systemd-resolve
    tcp        0      0 192.168.11.182:18701    0.0.0.0:*               LISTEN      1001       15442      1796/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6029       1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1695       1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13640      1919/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11045      1706/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      115        13080      1531/influxd
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       15041      1982/io.lovelace.0
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           101        7931       986/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        7929       986/systemd-resolve
    udp        0      0 192.168.11.182:68       0.0.0.0:*                           100        5005       846/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4213       1/init
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          13007      1589/perl
    udp6       0      0 :::111                  :::*                                0          4214       1/init
    2025-12-04 11:21:24.287  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:24.288  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:26.668  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:26.904  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:26.944  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:29.282  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:32.051  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:34.581  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:34.582  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:35.835  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:37.522  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:37.524  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:37.892  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:40.772  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:41.788  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:41.791  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:49.163  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:49.330  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:52.853  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:53.853  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:21:57.950  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:22:02.006  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:22:05.765  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-04 11:22:09.737  - warn: javascript.0 (2214) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    iob diag has finished.
    thorsten@vm-iobroker02:~$
    VG
    • mcm1957M Offline
      mcm1957M Offline
      mcm1957
      siehe https://github.com/ioBroker/ioBroker.javascript/issues/2065
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • S Seide Th
        javascript.0
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 5
                      NTP service: active
                  RTC in local TZ: no
        thorsten
        HOME=/home/thorsten
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           6.4G         12K        6.4G
                 9944 M total memory
                 6190 M used memory
                 1727 M free memory
                  101 M buffer memory
                 2193 M swap cache
                 6143 M total swap
                    0 M used swap
                 6143 M free swap
        *** FILESYSTEM ***
        /var:
        35G     /var/
        32G     /var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        125610
        States:         107661
        Pending Updates: 0
        VG
        @Seide-Th sagte in script Fehler nach update:
        gar keins.
        Wahrscheinlich wurde der genannte Datenpunkt gerade erst angelegt.
        Dann kann diese Meldung einmalig kommen.
        • S Seide Th
          javascript.0
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 5
                        NTP service: active
                    RTC in local TZ: no
          thorsten
          HOME=/home/thorsten
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           6.4G         12K        6.4G
                   9944 M total memory
                   6190 M used memory
                   1727 M free memory
                    101 M buffer memory
                   2193 M swap cache
                   6143 M total swap
                      0 M used swap
                   6143 M free swap
          *** FILESYSTEM ***
          /var:
          35G     /var/
          32G     /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        125610
          States:         107661
          Pending Updates: 0
          VG
          Welche? Das für nodejs aber nicht.
          iob nodejs-update
          durchführen. Die anderen iob-Adapter auch auf Stand bringen.
            Seide Th
            Ok, das Update von node.js habe ich durchgeführt und bin jetzt auf 24.11.1, auch unter Global ist kein Skript gespeichert.
            Datenpunkte habe ich die letzten Tage auch nicht angelegt.
            Die Meldungen kommen jetzt alle 4 Sek.
            • S Seide Th
              22 ist die Empfehlung. Und das sollte auch so von nodejs-update eingespielt worden sein. Warum hast du da nun 24 am Start?
              • S Seide Th
                nicht du, der Adapter hat möglicherweise
                angelegt.
                  Seide Th
                  @Thomas-Braun weil ich ein update durchführen sollte...
                  dachte im debug war doch 22.x zu sehen und darum bin ich auf 24 gegangen
                  • S Seide Th
                    @Seide-Th
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    Ganz klar node20 via Paketmanager in der Paketdatenbank eingetragen. Es fehlt allerdings das nodesource-Repo. Aber auch das würde 'iob nodejs-update' richtig anlegen, wenn du denn nicht irgendwas anderes machen würdest.
                    • S Seide Th
                      wie hast du das denn gemacht?
                      mit
                      @Thomas-Braun sagte in script Fehler nach update:
                      iob nodejs-update
                      durchführen
                      aber wohl nicht.
                        mit
                        iob nodejs-update
                        durchführen
                        aber wohl nicht.
                        Seide Th
                        @Homoran ok, sorry. soll ich es jetzt auf 22.x ändern, bzw. geht es noch?
                        • S Seide Th
                          @Seide-Th
                          Ja....
                          iob nodejs-update
                          ausführen. Das sollte alles wieder gerade biegen. Wie haste nodejs@24 denn nun installiert?
                            @Seide-Th
                            Ja....
                            iob nodejs-update
                            Seide Th
                            @Thomas-Braun mit
                            iobroker stop
                            curl -fsSL https://deb.nodesource.com/setup_24.x | sudo bash -
                            sudo apt-get install -y nodejs
                            dann
                            node –v
                            iobroker start
                            so hatte ich es mir mal aufgeschrieben (war da aber noch mit 22.x) habe halt im Internet mal geschaut welche Version jetzt aktuell ist
                            • S Seide Th
                              @Thomas-Braun mit
                              iobroker stop
                              dann
                              node –v
                              iobroker start
                              @Seide-Th
                              Jein, ich würde das immer per
                              iob nodejs-update
                              machen.
                              • S Seide Th
                                @Thomas-Braun mit
                                iobroker stop
                                dann
                                node –v
                                iobroker start
                                das war einmal, bei vorherigem korrekten anlegen der Repos.
                                Jetzt macht der dir extra von @thomas-braun genannte Befehl alles, incl. der Prüfung welche Version für ioBroker empfohlen ist.
                                S 2 Antworten Letzte Antwort
                                  Seide Th
                                  @Homoran ok danke. Das macht es für die User auch leichter :-)
                                  Ich habe den Befahl ausgeführt und auch die VM neu gestarte, bei der Versionsabfrage mit
                                  node --version
                                  kommt aber
                                  thorsten@vm-iobroker02:~$ node --version
                                  v24.11.1
                                  Ist das dann ok, oder muss ich mir noch Gedanken machen?
                                  Die Fehlermeldungen im LOG scheinen aber weg zu sein.
                                  Besten Dank dafür schon mal
                                    Seide Th
                                    @Homoran sorry, aber die LOG kommen doch noch, zu früh gefreut
                                    v7.7.19
                                    03
                                    Log-Größe: 540 B
                                    Zeit
                                    javascript.0
                                    	2025-12-06 12:11:18.625	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                    javascript.0
                                    	2025-12-06 12:11:14.541	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                    javascript.0
                                    	2025-12-06 12:11:10.375	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                    • S Seide Th
                                      node --version
                                      kommt aber
                                      v24.11.1
                                      Ist das dann ok
                                      Nein, das ist nicht okay, da sollte nodejs@22 gemeldet werden.
                                      Du hast da irgendwas total krummes angestellt.
                                      Die vollständige Ausgabe von
                                      iob diag
                                      bitte.
                                        Ist das dann ok
                                        iob diag
                                        bitte.
                                        Seide Th
                                        @Thomas-Braun kommt:
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                            Firmware Age: 6y 11month 3w 4d
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         12:45:04 up 40 min,  1 user,  load average: 1.28, 0.54, 0.47
                                        CPU threads: 5
                                                       Local time: Sat 2025-12-06 12:45:05 CET
                                                   Universal time: Sat 2025-12-06 11:45:05 UTC
                                                         RTC time: Sat 2025-12-06 11:45:05
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        thorsten
                                        HOME=/home/thorsten
                                        iobroker
                                        HOME=/home/iobroker
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             10G        6.9G        2.4G        991K        1.4G        3.5G
                                        Swap:           6.4G        112M        6.3G
                                        Total:           16G        7.0G        8.7G
                                                 9944 M total memory
                                                 6609 M used memory
                                                 1760 M active memory
                                                 5439 M inactive memory
                                                 2307 M free memory
                                                   62 M buffer memory
                                                 1225 M swap cache
                                                 6143 M total swap
                                                  107 M used swap
                                                 6036 M free swap
                                        top - 12:45:05 up 40 min,  1 user,  load average: 1.28, 0.54, 0.47
                                        Tasks: 294 total,   2 running, 292 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 21.2 us,  2.5 sy,  0.0 ni, 71.2 id,  5.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   9944.9 total,   2306.0 free,   6610.3 used,   1288.7 buff/cache
                                        MiB Swap:   6144.0 total,   6036.4 free,    107.6 used.   3334.6 avail Mem
                                        *** FILESYSTEM ***
                                        //192.168.11.10/raspberry-backup/vm-iobroker02 cifs   768G  664G  105G  87% /opt/iobroker/backups
                                        [Sat Dec  6 12:04:12 2025] EXT4-fs (dm-0): mounted filesystem 53351748-d0c9-4f18-a788-eaf4d09ada71 ro with ordered data mode. Quota mode: none.
                                        [Sat Dec  6 12:04:16 2025] EXT4-fs (dm-0): re-mounted 53351748-d0c9-4f18-a788-eaf4d09ada71 r/w. Quota mode: none.
                                        [Sat Dec  6 12:04:18 2025] EXT4-fs (sda2): mounted filesystem b659c5e2-3fa3-497d-9256-b5203061160b r/w with ordered data mode. Quota mode: none.
                                        |-/snap/core24/1225     /dev/loop8                                     squashfs ro,nodev,relatime,errors=continue,threads=single
                                        |-/snap/lxd/32662       /dev/loop7                                     squashfs ro,nodev,relatime,errors=continue,threads=single
                                        /var:
                                        35G     /var/
                                        32G     /var/lib
                                        Archived and active journals take up 2.2G in the file system.
                                        0       /opt/iobroker/backups/
                                        697M    /opt/iobroker/iobroker-data/
                                        200M    /opt/iobroker/iobroker-data/backup-objects
                                        124M    /opt/iobroker/iobroker-data/states.jsonl
                                        90M     /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/nodejs         v24.11.1
                                        /usr/bin/node           v24.11.1
                                        /usr/bin/npm            11.6.2
                                        /usr/bin/npx            11.6.2
                                        /usr/bin/corepack       0.34.2
                                        nodejs:
                                          Installed: 24.11.1-1nodesource1
                                          Candidate: 24.11.1-1nodesource1
                                          Version table:
                                         *** 24.11.1-1nodesource1 100
                                             22.21.0-1nodesource1 600
                                                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                             22.20.0-1nodesource1 600
                                             22.19.0-1nodesource1 600
                                             22.18.0-1nodesource1 600
                                             22.17.1-1nodesource1 600
                                             22.17.0-1nodesource1 600
                                             22.16.0-1nodesource1 600
                                             22.15.1-1nodesource1 600
                                             22.15.0-1nodesource1 600
                                             22.14.0-1nodesource1 600
                                             22.13.1-1nodesource1 600
                                             22.13.0-1nodesource1 600
                                             22.12.0-1nodesource1 600
                                             22.11.0-1nodesource1 600
                                             22.10.0-1nodesource1 600
                                             22.9.0-1nodesource1 600
                                             22.8.0-1nodesource1 600
                                             22.7.0-1nodesource1 600
                                             22.6.0-1nodesource1 600
                                             22.5.1-1nodesource1 600
                                             22.5.0-1nodesource1 600
                                             22.4.1-1nodesource1 600
                                             22.4.0-1nodesource1 600
                                             22.3.0-1nodesource1 600
                                             22.2.0-1nodesource1 600
                                             22.1.0-1nodesource1 600
                                             22.0.0-1nodesource1 600
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        vm-iobroker02       vm-iobroker02 (version: 7.0.7, hostname: vm-iobroker02 , alive, uptime: 2399)
                                        admin:          7.7.19
                                        javascript:     9.0.11
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        125612
                                        States:         107662
                                        Hit:2 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
                                        Hit:3 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
                                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          9129       1385/perl
                                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       11098      1735/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15642      1715/io.sonoff.0
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       10134      1534/iobroker.js-co
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13747      1534/iobroker.js-co
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9585       1/init
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5086       1/init
                                        tcp        0      0 192.168.11.182:12010    0.0.0.0:*               LISTEN      1001       15624      1744/io.hm-rpc.2
                                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        8749       997/systemd-resolve
                                        tcp        0      0 192.168.11.182:18701    0.0.0.0:*               LISTEN      1001       14122      1724/io.hm-rpc.0
                                        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      101        8751       997/systemd-resolve
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      115        9119       1333/influxd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          1815       1/init
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          3477       1/init
                                        tcp6       0      0 :::8091                 :::*                    LISTEN      1001       14151      1908/io.lovelace.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      115        14383      1333/influxd
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14107      1652/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14198      1830/io.web.0
                                        udp        0      0 127.0.0.54:53           0.0.0.0:*                           101        8750       997/systemd-resolve
                                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        8748       997/systemd-resolve
                                        udp        0      0 192.168.11.182:68       0.0.0.0:*                           100        6680       834/systemd-network
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5087       1/init
                                        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          9130       1385/perl
                                        udp6       0      0 :::111                  :::*                                0          2897       1/init
                                        2025-12-06 12:45:34.797  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:35.288  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:37.558  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:37.559  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:38.290  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:39.768  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:40.676  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:44.375  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:44.398  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:44.775  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:45.906  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:45.967  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:51.754  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:51.837  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:51.863  - error: tesla-motors.1 (1792) Error: WebSocket is not open: readyState 0 (CONNECTING)
                                        2025-12-06 12:45:54.309  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:56.184  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:56.224  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:45:59.030  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:46:00.738  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:46:03.926  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:46:08.052  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:46:12.224  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        2025-12-06 12:46:16.471  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        • S Seide Th
                                          ```bash
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                   Chassis: vm 🖴
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          CPU threads: 5
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          thorsten
                                          HOME=/home/thorsten
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                                   9944 M total memory
                                                   6609 M used memory
                                                   2307 M free memory
                                                     62 M buffer memory
                                                   1225 M swap cache
                                                   6143 M total swap
                                                    107 M used swap
                                                   6036 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          35G     /var/
                                          32G     /var/lib
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            11.6.2
                                          /usr/bin/npx            11.6.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.7.19
                                          javascript:     9.0.11
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        125612
                                          States:         107662
                                          Pending Updates: 0
                                          Das nodesource-Repository wurde nicht über den Befehl
                                          iob nodejs-update
                                          angelegt. Das sähe dann anders aus.
                                          Führ das doch bitte mal aus und lass dir nodejs darüber einrichten...
                                          Die ioBroker-Adapter auf Stand bringen.
