  3. Einsteigerfragen
  4. script Fehler nach update
    5.3k
22 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • S Seide Th
    @Thomas-Braun kommt:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Ubuntu 24.04.3 LTS
     Static hostname: vm-iobroker02
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: vmware
              Kernel: Linux 6.8.0-88-generic
        Architecture: x86-64
     Hardware Vendor: VMware, Inc.
      Hardware Model: VMware Virtual Platform
    Firmware Version: 6.00
       Firmware Date: Wed 2018-12-12
        Firmware Age: 6y 11month 3w 4d
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i7-4790T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : vmware
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:45:04 up 40 min,  1 user,  load average: 1.28, 0.54, 0.47
    CPU threads: 5
    *** LIFE CYCLE STATUS ***
    Operating System is the current Ubuntu LTS release codenamed 'noble'!
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-12-06 12:45:05 CET
               Universal time: Sat 2025-12-06 11:45:05 UTC
                     RTC time: Sat 2025-12-06 11:45:05
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    thorsten
    HOME=/home/thorsten
    GROUPS=thorsten adm cdrom sudo dip plugdev lxd iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             10G        6.9G        2.4G        991K        1.4G        3.5G
    Swap:           6.4G        112M        6.3G
    Total:           16G        7.0G        8.7G
    Active iob-Instances:   25
             9944 M total memory
             6609 M used memory
             1760 M active memory
             5439 M inactive memory
             2307 M free memory
               62 M buffer memory
             1225 M swap cache
             6143 M total swap
              107 M used swap
             6036 M free swap
    top - 12:45:05 up 40 min,  1 user,  load average: 1.28, 0.54, 0.47
    Tasks: 294 total,   2 running, 292 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 21.2 us,  2.5 sy,  0.0 ni, 71.2 id,  5.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   9944.9 total,   2306.0 free,   6610.3 used,   1288.7 buff/cache
    MiB Swap:   6144.0 total,   6036.4 free,    107.6 used.   3334.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                                     Type   Size  Used Avail Use% Mounted on
    tmpfs                                          tmpfs  995M  1.3M  994M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv              ext4    90G   48G   38G  56% /
    tmpfs                                          tmpfs  4.9G     0  4.9G   0% /dev/shm
    tmpfs                                          tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                                      ext4   974M  197M  711M  22% /boot
    tmpfs                                          tmpfs  995M   20K  995M   1% /run/user/1000
    //192.168.11.10/raspberry-backup/vm-iobroker02 cifs   768G  664G  105G  87% /opt/iobroker/backups
    [Sat Dec  6 12:04:12 2025] EXT4-fs (dm-0): mounted filesystem 53351748-d0c9-4f18-a788-eaf4d09ada71 ro with ordered data mode. Quota mode: none.
    [Sat Dec  6 12:04:16 2025] EXT4-fs (dm-0): re-mounted 53351748-d0c9-4f18-a788-eaf4d09ada71 r/w. Quota mode: none.
    [Sat Dec  6 12:04:18 2025] EXT4-fs (sda2): mounted filesystem b659c5e2-3fa3-497d-9256-b5203061160b r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET                  SOURCE                                         FSTYPE   OPTIONS
    /                       /dev/mapper/ubuntu--vg-ubuntu--lv              ext4     rw,relatime
    |-/opt/iobroker/backups //192.168.11.10/raspberry-backup/vm-iobroker02 cifs     rw,relatime,vers=2.0,cache=strict,upcall_target=app,username=backitup-vm,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.11.10,file_mode=0664,dir_mode=0775,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    |-/snap/btop/924        /dev/loop0                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/btop/935        /dev/loop1                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2959     /dev/loop2                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/2669     /dev/loop4                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/2682     /dev/loop5                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2976     /dev/loop3                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core24/1196     /dev/loop6                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core24/1225     /dev/loop8                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/25202     /dev/loop10                                    squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/lxd/36554       /dev/loop9                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/25577     /dev/loop11                                    squashfs ro,nodev,relatime,errors=continue,threads=single
    |-/snap/lxd/32662       /dev/loop7                                     squashfs ro,nodev,relatime,errors=continue,threads=single
    `-/boot                 /dev/sda2                                      ext4     rw,relatime
    /var:
    35G     /var/
    32G     /var/lib
    31G     /var/lib/influxdb/data/iobroker/autogen
    Archived and active journals take up 2.2G in the file system.
    /opt/iobroker/backups:
    0       /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    697M    /opt/iobroker/iobroker-data/
    253M    /opt/iobroker/iobroker-data/files
    200M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    124M    /opt/iobroker/iobroker-data/states.jsonl
    90M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/objects.json.migrated
    13M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v24.11.1
    /usr/bin/node           v24.11.1
    /usr/bin/npm            11.6.2
    /usr/bin/npx            11.6.2
    /usr/bin/corepack       0.34.2
    nodejs:
      Installed: 24.11.1-1nodesource1
      Candidate: 24.11.1-1nodesource1
      Version table:
     *** 24.11.1-1nodesource1 100
            100 /var/lib/dpkg/status
         22.21.0-1nodesource1 600
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         18.19.1+dfsg-6ubuntu5 500
            500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    vm-iobroker02       vm-iobroker02 (version: 7.0.7, hostname: vm-iobroker02 , alive, uptime: 2399)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : vm-iobroker02                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : vm-iobroker02                            -  enabled
    + system.adapter.bydhvs.0                 : bydhvs                : vm-iobroker02                            -  enabled
      system.adapter.daswetter.0              : daswetter             : vm-iobroker02                            - disabled
      system.adapter.daswetter.1              : daswetter             : vm-iobroker02                            - disabled
      system.adapter.daswetter.2              : daswetter             : vm-iobroker02                            - disabled
    + system.adapter.discovery.0              : discovery             : vm-iobroker02                            -  enabled
    + system.adapter.email.0                  : email                 : vm-iobroker02                            -  enabled
      system.adapter.email.1                  : email                 : vm-iobroker02                            - disabled
    + system.adapter.energiefluss.0           : energiefluss          : vm-iobroker02                            -  enabled
      system.adapter.evcc.0                   : evcc                  : vm-iobroker02                            - disabled, port: 7070
    + system.adapter.go-e.0                   : go-e                  : vm-iobroker02                            -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : vm-iobroker02                            -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : vm-iobroker02                            -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : vm-iobroker02                            - disabled, port: 12001
    + system.adapter.hm-rpc.2                 : hm-rpc                : vm-iobroker02                            -  enabled, port: 12010
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: vm-iobroker02                            -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : vm-iobroker02                            -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : vm-iobroker02                            -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : vm-iobroker02                            -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : vm-iobroker02                            -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : vm-iobroker02                            -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : vm-iobroker02                            -  enabled
    + system.adapter.influxdb.0               : influxdb              : vm-iobroker02                            -  enabled, port: 8086
      system.adapter.iqontrol.0               : iqontrol              : vm-iobroker02                            - disabled
    + system.adapter.javascript.0             : javascript            : vm-iobroker02                            -  enabled
    + system.adapter.lovelace.0               : lovelace              : vm-iobroker02                            -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : vm-iobroker02                            -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : vm-iobroker02                            -  enabled, port: 8883, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : vm-iobroker02                            - disabled
      system.adapter.pi-hole.0                : pi-hole               : vm-iobroker02                            - disabled
      system.adapter.ping.0                   : ping                  : vm-iobroker02                            - disabled
    + system.adapter.plenticore.0             : plenticore            : vm-iobroker02                            -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : vm-iobroker02                            -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.squeezebox.0             : squeezebox            : vm-iobroker02                            - disabled, port: 9090
      system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : vm-iobroker02                            - disabled, port: 9000
    + system.adapter.synology.0               : synology              : vm-iobroker02                            -  enabled, port: 5000
      system.adapter.tesla-motors.0           : tesla-motors          : vm-iobroker02                            - disabled
    + system.adapter.tesla-motors.1           : tesla-motors          : vm-iobroker02                            -  enabled
    + system.adapter.tr-064.0                 : tr-064                : vm-iobroker02                            -  enabled
    + system.adapter.unifi.0                  : unifi                 : vm-iobroker02                            -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : vm-iobroker02                            -  enabled
      system.adapter.viessmannapi.1           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.2           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.3           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.viessmannapi.4           : viessmannapi          : vm-iobroker02                            - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : vm-iobroker02                            -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : vm-iobroker02                            -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : vm-iobroker02                            -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : vm-iobroker02                            -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : vm-iobroker02                            -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : vm-iobroker02                            -  enabled
      system.adapter.vis-metro.0              : vis-metro             : vm-iobroker02                            -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : vm-iobroker02                            -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : vm-iobroker02                            -  enabled
      system.adapter.vis.0                    : vis                   : vm-iobroker02                            -  enabled
    + system.adapter.web.0                    : web                   : vm-iobroker02                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name                │ url                                                     │ auto upgrade │
    │ 0       │ 'sicherung-default' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'sicherung-lastet'  │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'stable'            │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 3       │ 'beta'              │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
    Adapter    "daswetter"    : 3.2.8    , installed 3.1.16 [Updatable]
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "evcc"         : 0.2.3    , installed 0.2.3
    Adapter    "go-e"         : 1.0.41   , installed 1.0.29 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.1    , installed 5.0.1
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "net-tools"    : 1.2.3    , installed 0.2.0  [Updatable]
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "squeezeboxrpc": 1.6.2    , installed 1.6.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects:        125612
    States:         107662
    Hit:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          9129       1385/perl
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       11098      1735/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15642      1715/io.sonoff.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       10134      1534/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13747      1534/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9585       1/init
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5086       1/init
    tcp        0      0 192.168.11.182:12010    0.0.0.0:*               LISTEN      1001       15624      1744/io.hm-rpc.2
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        8749       997/systemd-resolve
    tcp        0      0 192.168.11.182:18701    0.0.0.0:*               LISTEN      1001       14122      1724/io.hm-rpc.0
    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      101        8751       997/systemd-resolve
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      115        9119       1333/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1815       1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3477       1/init
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       14151      1908/io.lovelace.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      115        14383      1333/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14107      1652/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14198      1830/io.web.0
    udp        0      0 127.0.0.54:53           0.0.0.0:*                           101        8750       997/systemd-resolve
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        8748       997/systemd-resolve
    udp        0      0 192.168.11.182:68       0.0.0.0:*                           100        6680       834/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5087       1/init
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          9130       1385/perl
    udp6       0      0 :::111                  :::*                                0          2897       1/init
    2025-12-06 12:45:34.797  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:35.288  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:37.558  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:37.559  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:38.290  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:39.768  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:40.676  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:44.375  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:44.398  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:44.775  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:45.906  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:45.967  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:51.754  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:51.837  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:51.863  - error: tesla-motors.1 (1792) Error: WebSocket is not open: readyState 0 (CONNECTING)
    2025-12-06 12:45:54.309  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:56.184  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:56.224  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:45:59.030  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:46:00.738  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:46:03.926  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:46:08.052  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:46:12.224  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    2025-12-06 12:46:16.471  - warn: javascript.0 (1670) State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    iob diag has finished.
    @Seide-Th sagte in script Fehler nach update:
    iob stop
    sudo apt upgrade nodejs=22.21.0-1nodesource1
    iob start
    Sollte nodejs@22 an den Start bringen.
      iob stop
      iob start
      Seide Th
      @Thomas-Braun sagte in script Fehler nach update:
      so ich habe jetzt die Version 22.x
      Die LOG Fehler sind weg, besten Dank und ein schönes WE (auch wenn das Wetter nicht optimal ist)
      VG
