  4. RPI 2 V2.4 läßt sich nicht installieren
    6.4k
14 Beiträge 5 Kommentatoren 603 Aufrufe 4 Beobachtet
    plc
    Hallo, auf meinem Raspi Pi5 ist aktuell Node js v22,21.0 und npm v11.62. Bei der Installation bekomme ich folgende Ausgabe.
    $ iobroker add rpi2 --host rasppi5
    Installing iobroker.rpi2@2.4.0... (System call)
    npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioInput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:14:17: error: expected primary-expression before ‘line’npm error 14 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:19:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~npm error | gpiod::linenpm error In file included from /usr/include/gpiodcxx/chip.hpp:21,npm error from /usr/include/gpiod.hpp:27,npm error from ../cpp/opengpio.cpp:3:npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:19:58: error: ‘DIRECTION_INPUT’ is not a member of ‘gpiod::line_request’npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:28:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:30:22: error: ‘line’ is not capturednpm error 30 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:28:66: note: the lambda has no capture-defaultnpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:34:52: error: ‘line’ is not capturednpm error 34 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:33:67: note: the lambda has no capture-defaultnpm error 33 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioOutput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:49:17: error: expected primary-expression before ‘line’npm error 49 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:54:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:54:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:63:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:66:9: error: ‘line’ is not capturednpm error 66 | line.set_value(value); });npm error | ^~~~npm error ../cpp/opengpio.cpp:63:66: note: the lambda has no capture-defaultnpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:69:52: error: ‘line’ is not capturednpm error 69 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:68:67: note: the lambda has no capture-defaultnpm error 68 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:81:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 81 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:92:17: error: expected primary-expression before ‘line’npm error 92 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:100:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:100:58: error: ‘EVENT_BOTH_EDGES’ is not a member of ‘gpiod::line_request’npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:109:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:111:22: error: ‘line’ is not capturednpm error 111 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:109:66: note: the lambda has no capture-defaultnpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:115:11: error: ‘struct WatchContext’ has no member named ‘line’npm error 115 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:127:25: error: expected primary-expression before ‘line’npm error 127 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:131:33: error: ‘line’ is not capturednpm error 131 | bool hasEvent = line.event_wait(chrono::milliseconds(1));npm error | ^~~~npm error ../cpp/opengpio.cpp:124:10: note: the lambda has no capture-defaultnpm error 124 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp:134:28: error: ‘line_event’ is not a member of ‘gpiod’; did you mean ‘info_event’?npm error 134 | gpiod::line_event event = line.event_read();npm error | ^~~~~~~~~~npm error | info_eventnpm error ../cpp/opengpio.cpp:135:34: error: ‘event’ was not declared in this scope; did you mean ‘servent’?npm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~npm error | serventnpm error ../cpp/opengpio.cpp:135:61: error: ‘gpiod::line_event’ has not been declarednpm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~~~~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:147:19: error: ‘struct WatchContext’ has no member named ‘line’npm error 147 | data->line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:168:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 168 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioPwm(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:196:17: error: expected primary-expression before ‘line’npm error 196 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:201:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:201:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:213:11: error: ‘struct PwmContext’ has no member named ‘line’npm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:213:18: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 213 | data->line = line;npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:224:25: error: expected primary-expression before ‘line’npm error 224 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:264:17: error: ‘line’ is not capturednpm error 264 | line.set_value(true);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:278:17: error: ‘line’ is not capturednpm error 278 | line.set_value(false);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:327:25: error: expected primary-expression before ‘line’npm error 327 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:328:13: error: ‘line’ is not capturednpm error 328 | line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp:324:10: note: the lambda has no capture-defaultnpm error 324 | [](uv_work_t *req, int status)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.47+rpt-rpi-2712npm error gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v22.21.0npm error gyp ERR! node-gyp -v v11.4.2npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-22T11_44_39_541Z-debug-0.log
    host.raspberrypi5 Cannot install iobroker.rpi2@2.4.0: 1
    ERROR: Process exited with code 25
    wie ich lese ist wohl ein falsches npm? wie installiere ich ein passendes npm? Oder fehlt mir sonst noch was?
    Danke im Voraus.
    • P plc
      Danke im Voraus.
      @plc
      RaspberryOS 13 Trixie am Start?
      Falls ja, dann versuch mal diesen Fork via GitHub/URL einzuspielen:
      https://github.com/Grothesk242/ioBroker.rpi2
      P 1 Antwort Letzte Antwort
        @plc
        plc
        @thomas-braun Vielen Dank. Es hat unktioniert.
          airjk
          Wie genau hast du rpi2 installiert bekommen?
          • A airjk
            @airjk
            Den Fork habe ich gelöscht, die Änderungen sind wieder im Hauptzweig.
            Also ganz normal installieren.
              airjk
              Hat bei mir leider nicht funktioniert mit der aktuellen Installation. Ich habe genau dieselbe Fehlermeldung erhalten und weiß nicht, was da nicht zusammen passt.
              Thomas BraunT mcm1957M HomoranH 3 Antworten Letzte Antwort
              • A airjk
                @airjk
                Wie schaut denn deine Kiste aus? Die Ausgabe von
                iob diag
                sagt dir das.
                • A airjk
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @airjk sagte:
                  Welche Version hast du versucht auf welcher Hardware / OS zu installieren?
                  Debian Trixie braucht version 3.0.0
                  https://github.com/iobroker-community-adapters/ioBroker.rpi2?tab=readme-ov-file#300-2025-11-28
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • A airjk
                    @airjk sagte:
                    Bitte mehr Informationen in Form von logs, iob diag und sonstigen harten Fakten
                      airjk
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                      Operating System: Debian GNU/Linux 13 (trixie)
                      ```bash
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.12.75+rpt-rpi-v8
                          Architecture: arm64
                      OS is similar to:
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       16:12:18 up 1 day,  4:59,  1 user,  load average: 0.40, 0.25, 0.22
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'trixie'!
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** TIME AND TIMEZONES ***
                                     Local time: Wed 2026-04-08 16:12:18 BST
                                 Universal time: Wed 2026-04-08 15:12:18 UTC
                                       RTC time: n/a
                                      Time zone: Europe/London (BST, +0100)
                                    NTP service: active
                                RTC in local TZ: no
                      Timezone is probably wrong. Please configure it with system admin tools or by running 'iobroker fix'
                      *** Users and Groups ***
                      User that called 'iob diag':
                      jkuban
                      HOME=/home/jkuban
                      GROUPS=jkuban adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/jkuban
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server:         false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            8.2G        3.5G        980M         12M        3.9G        4.7G
                      Swap:           2.1G          0B        2.1G
                      Total:           10G        3.5G        3.1G
                      Active iob-Instances:   35
                               7820 M total memory
                               3353 M used memory
                               3294 M active memory
                               3057 M inactive memory
                                934 M free memory
                                242 M buffer memory
                               3437 M swap cache
                               2047 M total swap
                                  0 M used swap
                               2047 M free swap
                      top - 16:12:18 up 1 day,  4:59,  1 user,  load average: 0.40, 0.25, 0.22
                      Tasks: 217 total,   1 running, 216 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  2.1 us,  2.1 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   7820.7 total,    933.8 free,   3353.8 used,   3680.3 buff/cache
                      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4466.9 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.6G     0  3.6G   0% /dev
                      tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
                      /dev/mmcblk0p2 ext4       15G   11G  3.4G  76% /
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                      tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
                      /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                      tmpfs          tmpfs     783M  8.0K  783M   1% /run/user/1000
                      [Tue Apr  7 11:12:39 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                      [Tue Apr  7 11:12:39 2026] EXT4-fs (mmcblk0p2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                      [Tue Apr  7 11:12:42 2026] EXT4-fs (mmcblk0p2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                      Show mounted filesystems:
                      TARGET           SOURCE         FSTYPE OPTIONS
                      /                /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      2.7G    /var/
                      462M    /var/cache
                      456M    /var/cache/apt
                      326M    /var/cache/apt/archives
                      181M    /var/lib
                      Archived and active journals take up 8M in the file system.
                      /opt/iobroker/backups:
                      695M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      1.6G    /opt/iobroker/iobroker-data/
                      1.1G    /opt/iobroker/iobroker-data/history
                      422M    /opt/iobroker/iobroker-data/files
                      88M     /opt/iobroker/iobroker-data/files/vis-2
                      77M     /opt/iobroker/iobroker-data/files/vis
                      32M     /opt/iobroker/iobroker-data/objects.jsonl
                      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      11M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js
                      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                      USB-Devices by-id:
                      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                      please always prefer the links 'by-id':
                      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D30CJHUD-if00-port0
                      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D30CJHT1-if00-port0
                      No nvbackup.json found.
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v22.22.2
                      /usr/bin/node           v22.22.2
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      ✓ Node.js installation is correct
                      nodejs:
                        Installed: 22.22.2-1nodesource1
                        Candidate: 22.22.2-1nodesource1
                        Version table:
                       *** 22.22.2-1nodesource1 1001
                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                              100 /var/lib/dpkg/status
                           22.22.1-1nodesource1 1001
                           22.22.0-1nodesource1 1001
                           22.21.0-1nodesource1 1001
                           22.20.0-1nodesource1 1001
                           22.19.0-1nodesource1 1001
                           22.18.0-1nodesource1 1001
                           22.17.1-1nodesource1 1001
                           22.17.0-1nodesource1 1001
                           22.16.0-1nodesource1 1001
                           22.15.1-1nodesource1 1001
                           22.15.0-1nodesource1 1001
                           22.14.0-1nodesource1 1001
                           22.13.1-1nodesource1 1001
                           22.13.0-1nodesource1 1001
                           22.12.0-1nodesource1 1001
                           22.11.0-1nodesource1 1001
                           22.10.0-1nodesource1 1001
                           22.9.0-1nodesource1 1001
                           22.8.0-1nodesource1 1001
                           22.7.0-1nodesource1 1001
                           22.6.0-1nodesource1 1001
                           22.5.1-1nodesource1 1001
                           22.5.0-1nodesource1 1001
                           22.4.1-1nodesource1 1001
                           22.4.0-1nodesource1 1001
                           22.3.0-1nodesource1 1001
                           22.2.0-1nodesource1 1001
                           22.1.0-1nodesource1 1001
                           22.0.0-1nodesource1 1001
                           20.19.2+dfsg-1+deb13u2 500
                              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                           20.19.2+dfsg-1 500
                              500 http://deb.debian.org/debian trixie/main arm64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 90129)
                      Core adapters versions
                      js-controller:  7.0.7
                      admin:          7.7.22
                      javascript:     9.0.18
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                      + system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              -  enabled, port: 8899
                      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                      + system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                      + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.notification-manager.0   : notification-manager  : raspberrypi                              -  enabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                      + system.adapter.radar-trap.0             : radar-trap            : raspberrypi                              -  enabled
                        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
                        system.adapter.schoolfree.1             : schoolfree            : raspberrypi                              -  enabled
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                      + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                      + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
                        system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: raspberrypi                              - disabled
                      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.7.22   , installed 7.7.22
                      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                      Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
                      Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                      Adapter    "email"        : 2.0.4    , installed 2.0.4
                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                      Adapter    "growatt"      : 3.3.1    , installed 3.3.1
                      Adapter    "ham"          : 5.3.1    , installed 5.3.1
                      Adapter    "ical"         : 1.19.7   , installed 1.19.7
                      Adapter    "iot"          : 5.0.12   , installed 5.0.12
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                      Adapter    "notification-manager": 1.3.0, installed 1.3.0
                      Adapter    "ping"         : 1.7.9    , installed 1.7.9
                      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                      Adapter    "pvforecast"   : 5.1.0    , installed 5.1.0
                      Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
                      Adapter    "schoolfree"   : 1.1.13   , installed 1.1.13
                      Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "tvprogram"    : 4.0.2    , installed 4.0.2
                      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
                      Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "web"          : 8.0.0    , installed 8.0.0
                      Adapter    "worx"         : 3.2.7    , installed 3.2.7
                      Adapter    "ws"           : 4.0.0    , installed 4.0.0
                      Objects and States
                      Objects:        8452
                      States:         7171
                      Hit:1 http://deb.debian.org/debian trixie InRelease
                      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Reading package lists...
                      Pending systemupdates: 3
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       104735     15060/io.mqtt.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       102889     14679/iobroker.js-c
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       103491     14679/iobroker.js-c
                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       107098     15503/io.jarvis.0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5251       1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7479       878/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       103594     14699/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       104406     15357/io.web.0
                      tcp6       0      0 :::3040                 :::*                    LISTEN      1001       108550     15611/io.radar-trap
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          5252       1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          7489       878/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       104992     15239/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       104993     15239/io.tuya.0
                      udp        0      0 0.0.0.0:56914           0.0.0.0:*                           101        7285       648/avahi-daemon: r
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1294       1/init
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       104112     15003/io.ham.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        7283       648/avahi-daemon: r
                      udp6       0      0 :::52892                :::*                                101        7286       648/avahi-daemon: r
                      udp6       0      0 :::111                  :::*                                0          1295       1/init
                      udp6       0      0 fe80::d4c1:6673:215:546 :::*                                0          7543       684/NetworkManager
                      udp6       0      0 :::5353                 :::*                                101        7284       648/avahi-daemon: r
                        airjk
                        iob install rpi2
                        NPM version: 10.9.7
                        npm error code 1
                        npm error       |                 ^~~~
                        npm error       |         ^~~~
                        npm error       |           ^~~~
                        npm error       |                                                              ^~~~
                        npm error       |           ^~~~
                        npm error       |                      ^~~~
                        npm error       |        ^
                        npm error       |                                                              ^~~~
                        npm error       |                                                    ^~~~
                        npm error       |        ^
                        npm error       |                                                              ^~~~
                        npm error       |                 ^~~~
                        npm error       |         ^~~~
                        npm error       |           ^~~~
                        npm error       |                                                              ^~~~
                        npm error       |           ^~~~
                        npm error       |         ^~~~
                        npm error       |        ^
                        npm error       |                                                              ^~~~
                        npm error       |                                                    ^~~~
                        npm error       |        ^
                        npm error       |                                                              ^~~~
                        npm error       |            ^~~~
                        npm error       |           ^~~~
                        npm error       |                 ^~~~
                        npm error       |         ^~~~
                        npm error       |           ^~~~
                        npm error       |                                                              ^~~~
                        npm error       |           ^~~~
                        npm error       |                      ^~~~
                        npm error       |        ^
                        npm error       |                                                              ^~~~
                        npm error       |           ^~~~
                        npm error       |                         ^~~~
                        npm error       |                                 ^~~~
                        npm error       |          ^
                        npm error       |                                                              ^~~~
                        npm error       |                                  ^~~~~
                        npm error       |                                  servent
                        npm error       |                   ^~~~
                        npm error       |            ^~~~
                        npm error       |           ^~~~
                        npm error       |                 ^~~~
                        npm error       |         ^~~~
                        npm error       |           ^~~~
                        npm error       |           ^~~~
                        npm error       |                  ^~~~
                        npm error       |           ^~~~
                        npm error       |                         ^~~~
                        npm error       |                 ^~~~
                        npm error       |          ^
                        npm error       |                  ^~~~
                        npm error       |                 ^~~~
                        npm error       |          ^
                        npm error       |                  ^~~~
                        npm error       |                         ^~~~
                        npm error       |             ^~~~
                        npm error       |          ^
                        npm error       |                  ^~~~
                        npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)
                        npm error gyp ERR! System Linux 6.12.75+rpt-rpi-v8
                        npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        npm error gyp ERR! node -v v22.22.2
                        npm error gyp ERR! node-gyp -v v11.5.0
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-08T15_15_18_417Z-debug-0.log
                        host.raspberrypi Cannot install iobroker.rpi2@2.4.0: 1
                        • A airjk
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          jkuban
                          HOME=/home/jkuban
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           2.1G          0B        2.1G
                                   7820 M total memory
                                   3353 M used memory
                                    934 M free memory
                                    242 M buffer memory
                                   3437 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.7G    /var/
                          462M    /var/cache
                          456M    /var/cache/apt
                          181M    /var/lib
                          USB-Devices by-id:
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.22
                          javascript:     9.0.18
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        8452
                          States:         7171
                          @airjk sagte:
                          Wohnst du in London?
                          Sonst stimmt deine Systemzeit nicht
                          @airjk sagte:
                          @airjk sagte:
                          Nicht viel, aber bitte updaten.
                          • A airjk
                            iob install rpi2
                            NPM version: 10.9.7
                            npm error code 1
                            npm error       |                 ^~~~
                            npm error       |         ^~~~
                            npm error       |           ^~~~
                            npm error       |                                                              ^~~~
                            npm error       |           ^~~~
                            npm error       |                      ^~~~
                            npm error       |        ^
                            npm error       |                                                              ^~~~
                            npm error       |                                                    ^~~~
                            npm error       |        ^
                            npm error       |                                                              ^~~~
                            npm error       |                 ^~~~
                            npm error       |         ^~~~
                            npm error       |           ^~~~
                            npm error       |                                                              ^~~~
                            npm error       |           ^~~~
                            npm error       |         ^~~~
                            npm error       |        ^
                            npm error       |                                                              ^~~~
                            npm error       |                                                    ^~~~
                            npm error       |        ^
                            npm error       |                                                              ^~~~
                            npm error       |            ^~~~
                            npm error       |           ^~~~
                            npm error       |                 ^~~~
                            npm error       |         ^~~~
                            npm error       |           ^~~~
                            npm error       |                                                              ^~~~
                            npm error       |           ^~~~
                            npm error       |                      ^~~~
                            npm error       |        ^
                            npm error       |                                                              ^~~~
                            npm error       |           ^~~~
                            npm error       |                         ^~~~
                            npm error       |                                 ^~~~
                            npm error       |          ^
                            npm error       |                                                              ^~~~
                            npm error       |                                  ^~~~~
                            npm error       |                                  servent
                            npm error       |                   ^~~~
                            npm error       |            ^~~~
                            npm error       |           ^~~~
                            npm error       |                 ^~~~
                            npm error       |         ^~~~
                            npm error       |           ^~~~
                            npm error       |           ^~~~
                            npm error       |                  ^~~~
                            npm error       |           ^~~~
                            npm error       |                         ^~~~
                            npm error       |                 ^~~~
                            npm error       |          ^
                            npm error       |                  ^~~~
                            npm error       |                 ^~~~
                            npm error       |          ^
                            npm error       |                  ^~~~
                            npm error       |                         ^~~~
                            npm error       |             ^~~~
                            npm error       |          ^
                            npm error       |                  ^~~~
                            @airjk sagte:
                            host.raspberrypi Cannot install iobroker.rpi2@ 2.4.0 : 1
                            @mcm1957 sagte:
                            • A airjk
                              iob install rpi2
                              NPM version: 10.9.7
                              npm error code 1
                              npm error       |                 ^~~~
                              npm error       |         ^~~~
                              npm error       |           ^~~~
                              npm error       |                                                              ^~~~
                              npm error       |           ^~~~
                              npm error       |                      ^~~~
                              npm error       |        ^
                              npm error       |                                                              ^~~~
                              npm error       |                                                    ^~~~
                              npm error       |        ^
                              npm error       |                                                              ^~~~
                              npm error       |                 ^~~~
                              npm error       |         ^~~~
                              npm error       |           ^~~~
                              npm error       |                                                              ^~~~
                              npm error       |           ^~~~
                              npm error       |         ^~~~
                              npm error       |        ^
                              npm error       |                                                              ^~~~
                              npm error       |                                                    ^~~~
                              npm error       |        ^
                              npm error       |                                                              ^~~~
                              npm error       |            ^~~~
                              npm error       |           ^~~~
                              npm error       |                 ^~~~
                              npm error       |         ^~~~
                              npm error       |           ^~~~
                              npm error       |                                                              ^~~~
                              npm error       |           ^~~~
                              npm error       |                      ^~~~
                              npm error       |        ^
                              npm error       |                                                              ^~~~
                              npm error       |           ^~~~
                              npm error       |                         ^~~~
                              npm error       |                                 ^~~~
                              npm error       |          ^
                              npm error       |                                                              ^~~~
                              npm error       |                                  ^~~~~
                              npm error       |                                  servent
                              npm error       |                   ^~~~
                              npm error       |            ^~~~
                              npm error       |           ^~~~
                              npm error       |                 ^~~~
                              npm error       |         ^~~~
                              npm error       |           ^~~~
                              npm error       |           ^~~~
                              npm error       |                  ^~~~
                              npm error       |           ^~~~
                              npm error       |                         ^~~~
                              npm error       |                 ^~~~
                              npm error       |          ^
                              npm error       |                  ^~~~
                              npm error       |                 ^~~~
                              npm error       |          ^
                              npm error       |                  ^~~~
                              npm error       |                         ^~~~
                              npm error       |             ^~~~
                              npm error       |          ^
                              npm error       |                  ^~~~
                              @airjk
                              Die Zeitzone richtig setzen.
                              Installier die Beta-Version des Adapters.
