  3. Einsteigerfragen
  4. Update von Debian 12 auf 13 möglich?
    5.3k
81 Beiträge 6 Kommentatoren 6.5k Aufrufe 7 Beobachtet
  • RaspiUserR RaspiUser
    @thomas-braun sagte in Update von Debian 12 auf 13 möglich?:
    @raspiuser
    Edit: Gerade nochmal selber getestet, in der Tat dauert die Installation gerade sehr lange. Da kann ich aber erstmal nix dran machen.
    Ok, ansonsten läuft ja alles, Danke für deine Zeit.
    EDIT: ... hat wieder gedauert ...
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: VM-ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1
      Virtualization: kvm
              Kernel: Linux 6.12.48+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: qemu
      Hardware Model: qemu
    Firmware Version: e0d6339-dirty-20220919_024111-d528eb931742
       Firmware Date: Tue 2014-04-01
        Firmware Age: 11y 6month 2w 6d
    OS is similar to:
    model name      : Westmere E56xx/L56xx/X56xx (Nehalem-C)
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     12:27:18 up 55 min,  1 user,  load average: 0.34, 0.19, 0.33
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-10-20 12:27:19 CEST
               Universal time: Mon 2025-10-20 10:27:19 UTC
                     RTC time: Mon 2025-10-20 10:27:19
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    raspiuser
    HOME=/home/raspiuser
    GROUPS=raspiuser adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/raspiuser
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.3G        2.7G        5.2G        3.5M        817M        5.7G
    Swap:           1.0G          0B        1.0G
    Total:          9.4G        2.7G        6.2G
    Active iob-Instances:   31
             7947 M total memory
             2538 M used memory
             2211 M active memory
              452 M inactive memory
             4914 M free memory
              128 M buffer memory
              651 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 12:27:19 up 55 min,  1 user,  load average: 0.34, 0.19, 0.33
    Tasks: 159 total,   2 running, 157 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  4.4 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7947.3 total,   4914.0 free,   2539.3 used,    779.9 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5408.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  588K  795M   1% /run
    /dev/sda1      ext4       48G  8.1G   38G  18% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  2.8M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1001
    [Mon Oct 20 11:32:16 2025] EXT4-fs (sda1): mounted filesystem b4ce8297-3803-48c4-b2a4-b0f408a6baba ro with ordered data mode. Quota mode: none.
    [Mon Oct 20 11:32:17 2025] EXT4-fs (sda1): re-mounted b4ce8297-3803-48c4-b2a4-b0f408a6baba r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.5G    /var/
    688M    /var/cache
    677M    /var/cache/apt
    586M    /var/cache/apt/archives
    565M    /var/log
    Archived and active journals take up 549.1M in the file system.
    /opt/iobroker/backups:
    20M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    300M    /opt/iobroker/iobroker-data/
    163M    /opt/iobroker/iobroker-data/files
    103M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    29M     /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    5.0M    /opt/iobroker/iobroker-data/states.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    4.2M    /opt/iobroker/iobroker-data/backup-objects/2025-10-20_09-49_objects.jsonl.gz
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.20.0
    /usr/bin/node           v22.20.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.20.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
     *** 22.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    VM-ioBroker         VM-ioBroker (version: 7.0.7, hostname: VM-ioBroker   , alive, uptime: 2539)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     2
    +-- iobroker.frontier_silicon@0.5.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.frontier_silicon.git#6fa3c2fb582cb38932bf443b38867e572874e66a)
    +-- iobroker.go-e@1.0.42 (git+ssh://git@github.com/MK-2001/ioBroker.go-e.git#d7874e9d5200daf7d104b6d805b97c1f6f14793a)
    Adapter State
    + system.adapter.admin.0                  : admin                 : VM-ioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alpha-ess.0              : alpha-ess             : VM-ioBroker                              -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : VM-ioBroker                              -  enabled
      system.adapter.awtrix-light.1           : awtrix-light          : VM-ioBroker                              - disabled
    + system.adapter.awtrix-light.2           : awtrix-light          : VM-ioBroker                              -  enabled
    + system.adapter.backitup.0               : backitup              : VM-ioBroker                              -  enabled
    + system.adapter.canbus.0                 : canbus                : VM-ioBroker                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : VM-ioBroker                              -  enabled
    + system.adapter.discovery.0              : discovery             : VM-ioBroker                              -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: VM-ioBroker                              - disabled
      system.adapter.feiertage.0              : feiertage             : VM-ioBroker                              -  enabled
    + system.adapter.frontier_silicon.0       : frontier_silicon      : VM-ioBroker                              -  enabled
    + system.adapter.go-e.0                   : go-e                  : VM-ioBroker                              -  enabled
      system.adapter.history.0                : history               : VM-ioBroker                              - disabled
    + system.adapter.hm-rega.0                : hm-rega               : VM-ioBroker                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : VM-ioBroker                              -  enabled, port: 443
      system.adapter.influxdb.0               : influxdb              : VM-ioBroker                              - disabled, port: 8086
    + system.adapter.iqontrol.0               : iqontrol              : VM-ioBroker                              -  enabled
    + system.adapter.javascript.0             : javascript            : VM-ioBroker                              -  enabled
    + system.adapter.klf200.0                 : klf200                : VM-ioBroker                              -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : VM-ioBroker                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : VM-ioBroker                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : VM-ioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.onkyo.0                  : onkyo                 : VM-ioBroker                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : VM-ioBroker                              - disabled
    + system.adapter.sainlogic.0              : sainlogic             : VM-ioBroker                              -  enabled, port: 1030, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : VM-ioBroker                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : VM-ioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : VM-ioBroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : VM-ioBroker                              -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : VM-ioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : VM-ioBroker                              -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : VM-ioBroker                              -  enabled
    + system.adapter.web.0                    : web                   : VM-ioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : VM-ioBroker                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : VM-ioBroker                              - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "canbus"       : 2.2.0    , installed 2.2.0
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "frontier_silicon": 0.5.0 , installed 0.5.0
    Adapter    "go-e"         : 1.0.41   , installed 1.0.42
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "klf200"       : 1.3.5    , installed 1.3.5
    Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
    Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:        7356
    States:         5663
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2271       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7599       742/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8449       976/exim4
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       23629      4086/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       23634      4086/iobroker.js-co
    tcp        0      0 0.0.0.0:1030            0.0.0.0:*               LISTEN      1000       23513      4789/io.sainlogic.0
    tcp        0      0 192.168.178.120:42001   0.0.0.0:*               LISTEN      1000       24036      4431/io.hm-rpc.0
    tcp        0      0 192.168.178.120:42010   0.0.0.0:*               LISTEN      1000       26443      4599/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       25250      4660/io.sonoff.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3534       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7601       742/sshd: /usr/sbin
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8450       976/exim4
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22875      4104/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       27662      4819/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       25446      4895/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       26702      4834/io.simple-api.
    udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      6665       1030/cannelloni
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6570       652/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2272       1/init
    udp6       0      0 :::111                  :::*                                0          1702       1/init
    2025-10-20 12:00:00.466  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.last_position.properties.heading: 229
    2025-10-20 12:00:00.467  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.last_position.properties.signal_quality: 9
    2025-10-20 12:00:00.467  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.last_position.properties.type: Acquire
    2025-10-20 12:00:00.467  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.last_position.properties.updated_at: 2025-10-20 08:32:39+00:00
    2025-10-20 12:00:00.467  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.preconditionning.air_conditioning.status: Disabled
    2025-10-20 12:00:00.467  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.preconditionning.air_conditioning.updated_at: 2025-09-19 15:07:10+00:00
    2025-10-20 12:00:00.468  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.preconditionning.air_conditioning.created_at: 2025-09-19 15:07:10+00:00
    2025-10-20 12:00:00.468  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.privacy.state: None
    2025-10-20 12:00:00.468  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.service.type: Electric
    2025-10-20 12:00:00.468  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.timed_odometer.updated_at: 2025-10-20 08:34:05+00:00
    2025-10-20 12:00:00.469  - info: javascript.0 (4125) script.js.4_Skripte_sonstiges.CORSA_PSA_Controller_Abfrage_Intervall: javascript.0.PSA.timed_odometer.mileage: 21262.1
    2025-10-20 12:00:51.028  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 5881
    2025-10-20 12:00:53.139  - info: luftdaten.0 (5881) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.20.0, js-controller: 7.0.7
    2025-10-20 12:00:56.408  - info: luftdaten.0 (5881) [fillSensorData] error: connect EHOSTUNREACH 192.168.178.72:80
    2025-10-20 12:00:56.443  - info: luftdaten.0 (5881) Terminated (NO_ERROR): Without reason
    2025-10-20 12:00:56.998  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 having pid 5881 terminated with code 0 (NO_ERROR)
    2025-10-20 12:01:57.146  - info: admin.0 (4104) <== Disconnect system.user.admin from ::ffff:192.168.178.95 admin
    2025-10-20 12:02:48.887  - info: admin.0 (4104) ==> Connected system.user.admin from ::ffff:192.168.178.95
    2025-10-20 12:04:51.888  - info: sonoff.0 (4660) Client [Steckdose-3-Geschirrspueler] reconnected. Old secret 1760954038018_5381 ==> New secret 1760954691886_9665
    2025-10-20 12:16:30.463  - info: admin.0 (4104) <== Disconnect system.user.admin from ::ffff:192.168.178.95 admin
    2025-10-20 12:30:51.029  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 6581
    2025-10-20 12:30:53.000  - info: luftdaten.0 (6581) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.20.0, js-controller: 7.0.7
    2025-10-20 12:30:56.278  - info: luftdaten.0 (6581) [fillSensorData] error: connect EHOSTUNREACH 192.168.178.72:80
    2025-10-20 12:30:56.294  - info: luftdaten.0 (6581) Terminated (NO_ERROR): Without reason
    2025-10-20 12:30:56.849  - info: host.VM-ioBroker instance system.adapter.luftdaten.0 having pid 6581 terminated with code 0 (NO_ERROR)
    DuffyD Offline
    DuffyD Offline
    Duffy
    #61
    @Thomas-Braun
    Hallo Thomas braun,
    ich habe gerade ein
    sudo apt update && sudo apt full-upgrade
    gemacht. Dabei hat es mir den node js von 22.21.1 zurück auf 22.21.0 gesetzt.
    Mit welchem Befehl kann ich node js wieder auf 22.21.1 bringen?
    Gruß Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.1
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    • DuffyD Duffy
      @Thomas-Braun
      Hallo Thomas braun,
      ich habe gerade ein
      Gruß Duffy
      #62
      @duffy sagte in Update von Debian 12 auf 13 möglich?:
      Gar nicht. Die Version findet sich im Moment nicht mehr in deinen Quellen.
      DuffyD 1 Antwort Letzte Antwort
        DuffyD Offline
        DuffyD Offline
        Duffy
        #63
        ahhh deshalb hat es mir die auch automatisch deinstalliert?
        Hatte was gelesen das die Schwirigkeiten gemacht haben soll was ich natürlich nicht beurteilen kann.
        VG Duffy
        Node.js: v22.23.1
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          VG Duffy
          #64
          Nein, die wurde (halb)automatisch (du hast ja zugestimmt...) entfernt, weil das Repostory eine sehr hohe Priorität hat, sodass apt immer versucht die Versionen konsistent zu halten. Zur Not auch per Downgrade einer bereits installierten Version.
          https://github.com/nodesource/distributions/issues/1897
          ist aber noch ohne Kommentar.
          • NashraN Offline
            NashraN Offline
            Nashra
            Most Active Forum Testing
            #65
            Hallo, nachdem ich auch ungestellt hatte habe ich gedacht mach mal
            ein diag.sh und dann kam dieser Eintrag.
            hier die komplette Ausgabe:
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Static hostname: ioBroker
                  Icon name: computer-container
                    Chassis: container ☐
             Virtualization: lxc
                     Kernel: Linux 6.14.11-4-pve
            OS is similar to:
            model name      : Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            18:16:16 up 10:05,  0 users,  load average: 0.47, 0.58, 0.60
            CPU threads: 4
                          Local time: Sat 2025-11-01 18:16:16 CET
                      Universal time: Sat 2025-11-01 17:16:16 UTC
                            RTC time: n/a
                         NTP service: inactive
                     RTC in local TZ: no
            jack
            HOME=/home/jack
            GROUPS=jack sudo iobroker
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/jack
            GROUPS=iobroker tty dialout audio video plugdev
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:             12G        4.8G        6.4G        3.5M        1.7G        8.1G
            Swap:             0B          0B          0B
            Total:           12G        4.8G        6.4G
            Active iob-Instances:   46
                   12288 M total memory
                    4554 M used memory
                    4616 M active memory
                    1168 M inactive memory
                    6078 M free memory
                       0 M buffer memory
                    1657 M swap cache
                       0 M total swap
                       0 M used swap
                       0 M free swap
            top - 18:16:17 up 10:05,  0 users,  load average: 0.47, 0.58, 0.60
            Tasks:  73 total,   1 running,  72 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  4.8 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  12288.0 total,   6077.5 free,   4556.2 used,   1657.3 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7731.8 avail Mem
             UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
            * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
            * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                   ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                   SUB    -> The low-level unit activation state, values depend on unit type.
            3 loaded units listed.
            dmesg: read kernel buffer failed: Operation not permitted
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--100--disk--0 ext4       21G   17G  2.6G  87% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
            tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
            tmpfs                            tmpfs     3.2G  116K  3.2G   1% /run
            tmpfs                            tmpfs     7.8G  3.3M  7.8G   1% /tmp
            /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
            /var:
            2.5G    /var/
            2.2G    /var/log
            2.1G    /var/log/journal/5cd6ef18c5fb4a33b292b16e63f26ce7
            206M    /var/cache
            Archived and active journals take up 95.4M in the file system.
            2.4G    /opt/iobroker/backups/
            2.4G    /opt/iobroker/iobroker-data/
            1.3G    /opt/iobroker/iobroker-data/files
            564M    /opt/iobroker/iobroker-data/history
            455M    /opt/iobroker/iobroker-data/backup-objects
            264M    /opt/iobroker/iobroker-data/files/vis.0
            80M     /opt/iobroker/iobroker-data/states.jsonl
            75M     /opt/iobroker/iobroker-data/objects.jsonl
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
            26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a8533ff07196ed1182936c4ce259fb3e-if00-port0
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyUSB0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/nodejs         v22.21.0
            /usr/bin/node           v22.21.0
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
             Installed: 22.21.0-1nodesource1
             Candidate: 22.21.0-1nodesource1
             Version table:
            *** 22.21.0-1nodesource1 600
                22.20.0-1nodesource1 600
                22.19.0-1nodesource1 600
                22.18.0-1nodesource1 600
                22.17.1-1nodesource1 600
                22.17.0-1nodesource1 600
                22.16.0-1nodesource1 600
                22.15.1-1nodesource1 600
                22.15.0-1nodesource1 600
                22.14.0-1nodesource1 600
                22.13.1-1nodesource1 600
                22.13.0-1nodesource1 600
                22.12.0-1nodesource1 600
                22.11.0-1nodesource1 600
                22.10.0-1nodesource1 600
                22.9.0-1nodesource1 600
                22.8.0-1nodesource1 600
                22.7.0-1nodesource1 600
                22.6.0-1nodesource1 600
                22.5.1-1nodesource1 600
                22.5.0-1nodesource1 600
                22.4.1-1nodesource1 600
                22.4.0-1nodesource1 600
                22.3.0-1nodesource1 600
                22.2.0-1nodesource1 600
                22.1.0-1nodesource1 600
                22.0.0-1nodesource1 600
                20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 20646)
            admin:          7.7.2
            javascript:     8.9.2
            nodejs modules from github:     7
            +-- iobroker.email@2.0.4 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.email.git#88ff953d4d399b08482aacb10944cb0a5a5b5090)
            +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
            +-- iobroker.labcom@0.1.4 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#0fae7c5e0f5c705838ff71922846fea7769b67fd)
            +-- iobroker.logparser@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.logparser.git#397943c5e72316bc69d0376edd29a57c6f981e03)
            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
            +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
            Adapter State
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
             system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
            + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
             system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
             system.adapter.birthdays.1              : birthdays             : ioBroker                                 -  enabled
            + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
             system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
             system.adapter.daswetter.1              : daswetter             : ioBroker                                 -  enabled
            + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
             system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
            + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
             system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
             system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
            + system.adapter.history.0                : history               : ioBroker                                 -  enabled
             system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
             system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
             system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
             system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
             system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
             system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
             system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
             system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
             system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
             system.adapter.influxdb.0               : influxdb              : ioBroker                                 - disabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
            + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
             system.adapter.labcom.0                 : labcom                : ioBroker                                 -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
            + system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 -  enabled
            + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
            + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
            + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
            + system.adapter.nut.1                    : nut                   : ioBroker                                 -  enabled
             system.adapter.nut.2                    : nut                   : ioBroker                                 - disabled
            + system.adapter.nut.3                    : nut                   : ioBroker                                 -  enabled
             system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
            + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
            + system.adapter.pollenflug.1             : pollenflug            : ioBroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
            + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: rest
             system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
             system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5000
            + system.adapter.synology.1               : synology              : ioBroker                                 -  enabled, port: 5000
             system.adapter.synology.2               : synology              : ioBroker                                 - disabled, port: 5000
             system.adapter.tagesschau.0             : tagesschau            : ioBroker                                 - disabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
             system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 - disabled, port: 443
            + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
             system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 -  enabled
             system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
             system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
             system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
             system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
             system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
             system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
             system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
             system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
             system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
             system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
             system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
             system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
             system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
             system.adapter.vis-owl.0                : vis-owl               : ioBroker                                 -  enabled
             system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
             system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
             system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
            + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
             system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
             system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
            + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
            + instance is alive
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            │ 2       │ 'stable-live'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
            │ 3       │ 'latest-live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
            Adapter    "admin"        : 7.7.19   , installed 7.7.2  [Updatable]
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
            Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
            Adapter    "brightsky"    : 0.6.6    , installed 0.6.6
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
            Adapter    "email"        : 2.0.4    , installed 2.0.4
            Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.8
            Adapter    "ical"         : 1.17.0   , installed 1.17.0
            Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
            Adapter    "icons-material-png": 0.1.0, installed 0.1.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
            Adapter    "iot"          : 5.0.5    , installed 5.0.5
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "logparser"    : 2.4.0    , installed 2.4.0
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "ping"         : 1.6.2    , installed 1.7.9
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
            Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
            Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
            Adapter    "shelly"       : 10.2.0   , installed 10.2.0
            Adapter    "snmp"         : 3.3.0    , installed 3.3.0
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tagesschau"   : 0.6.0    , installed 0.6.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "unifi-network": 1.1.6    , installed 1.1.6
            Adapter    "upnp"         : 1.1.0    , installed 1.1.0
            Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
            Adapter    "vis-2-widgets-icontwo": 1.16.0, installed 1.16.0
            Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.3.6
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
            Adapter    "weather-warnings": 0.8.0 , installed 0.9.0
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "zigbee"       : 3.1.5    , installed 3.2.2
            Objects and States
            Objects:        45184
            States:         40081
            W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/nodesource.list:1 and /etc/apt/sources.list.d/nodesource.sources:1
            W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/nodesource.list:1 and /etc/apt/sources.list.d/nodesource.sources:1
            W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/nodesource.list:1 and /etc/apt/sources.list.d/nodesource.sources:1
            Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:2 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
            Hit:3 http://security.debian.org trixie-security InRelease
            Hit:4 http://deb.debian.org/debian trixie InRelease
            Hit:5 http://deb.debian.org/debian trixie-updates InRelease
            Reading package lists... Done
            Pending Updates: 0
            tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       46969935   125426/io.web.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          44760423   310/master
            tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       49832200   299066/nc
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46957784   124695/io.shelly.1
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          44755966   1/init
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       46944731   123304/iobroker.js-
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       46944054   123304/iobroker.js-
            tcp6       0      0 :::8093                 :::*                    LISTEN      1001       46965838   125285/io.rest-api.
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46945409   123322/io.admin.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       46965961   125316/io.simple-ap
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       46970148   125453/io.ws.0
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          44760424   310/master
            tcp6       0      0 :::22                   :::*                    LISTEN      0          44759288   1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          44755968   1/init
            udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       46955656   124199/io.tr-064.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       46951106   124122/io.shelly.0
            udp        0      0 0.0.0.0:55495           0.0.0.0:*                           1001       46950385   124137/io.snmp.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46953927   124520/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46953928   124520/io.tuya.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          44755967   1/init
            udp        0      0 0.0.0.0:58143           0.0.0.0:*                           1001       46966989   125380/io.upnp.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       46969243   125380/io.upnp.0
            udp        0      0 0.0.0.0:59313           0.0.0.0:*                           1001       46950386   124137/io.snmp.0
            udp6       0      0 :::111                  :::*                                0          44760065   1/init
            2025-11-01 18:13:14.996  - info: daswetter.1 (296101) still wrong data structure from server received! repaired...
            2025-11-01 18:13:16.467  - info: daswetter.1 (296101) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-11-01 18:13:16.971  - info: daswetter.1 (296101) cleaned everything up...
            2025-11-01 18:13:16.980  - info: host.ioBroker instance system.adapter.daswetter.1 having pid 296101 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-11-01 18:13:16.981  - info: javascript.0 (123439) script.js.Wetter.Statistik-md-gitti: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.1.alive'
            2025-11-01 18:13:33.021  - info: javascript.0 (123439) script.js.Ereignisse.Schlafheizung: Warm Heizung-Schlaf ist aus
            2025-11-01 18:13:43.580  - info: javascript.0 (123439) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
            2025-11-01 18:14:50.149  - info: javascript.0 (123439) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
            2025-11-01 18:15:00.026  - info: javascript.0 (123439) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 1
            2025-11-01 18:15:00.033  - info: javascript.0 (123439) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
            2025-11-01 18:15:13.045  - info: linux-control.0 (125200) getting data from Proxmox (192.168.1.13:22)
            2025-11-01 18:15:13.345  - info: linux-control.0 (125200) successful received data from Proxmox (192.168.1.13:22)
            2025-11-01 18:15:13.634  - info: linux-control.0 (125200) getting data from ioBroker (192.168.1.14:22)
            2025-11-01 18:15:13.994  - info: linux-control.0 (125200) successful received data from ioBroker (192.168.1.14:22)
            2025-11-01 18:15:17.853  - info: javascript.0 (123439) script.js.Ereignisse.Kuechenlicht: #### Küchenlicht eingeschaltet
            2025-11-01 18:15:51.600  - info: javascript.0 (123439) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
            2025-11-01 18:16:00.225  - info: javascript.0 (123439) script.js.Netzwerk.IP-Adresse2: IP-Adresse (ausgelesen von http://ipecho.net/plain): 94.31.111.160
            2025-11-01 18:16:58.598  - info: javascript.0 (123439) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
            2025-11-01 18:17:00.603  - info: host.ioBroker instance system.adapter.pollenflug.1 scheduled normal terminated and will be restarted on schedule.
            2025-11-01 18:17:00.603  - info: host.ioBroker Restart adapter system.adapter.pollenflug.1 because enabled
            2025-11-01 18:17:02.084  - info: host.ioBroker instance system.adapter.pollenflug.1 in version "2.0.0" started with pid 298613
            2025-11-01 18:17:05.205  - info: javascript.0 (123439) script.js.Ereignisse.Flurlicht: #### Flurlicht eingeschaltet
            2025-11-01 18:18:02.608  - info: javascript.0 (123439) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
            2025-11-01 18:18:29.967  - info: javascript.0 (123439) script.js.Ereignisse.Werkstattheizung: Warm Heizung-Werkstatt ist aus
            2025-11-01 18:18:41.162  - info: javascript.0 (123439) script.js.Ereignisse.Flurheizung: Warm Heizung-Treppe ist aus
            Gruß Ralf
            Mir egal, wer Dein Vater ist! Wenn ich hier angel, wird nicht übers Wasser gelaufen!!
            • NashraN Nashra
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
               Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
                              RTC time: n/a
                       RTC in local TZ: no
              jack
              HOME=/home/jack
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Swap:             0B          0B          0B
                      4554 M used memory
                      6078 M free memory
                         0 M buffer memory
                      1657 M swap cache
                         0 M total swap
                         0 M used swap
                         0 M free swap
              *** FILESYSTEM ***
              /var:
              2.5G    /var/
              2.2G    /var/log
              206M    /var/cache
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
               Version table:
                  20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        45184
              States:         40081
              Pending Updates: 0
              #66
              @nashra sagte in Update von Debian 12 auf 13 möglich?:
              Liegt an:
              Virtualization: lxc
              Ich glaube in der Dokumentation zu LXCs steht auch wie man das wegbekommen kann.
              NashraN 1 Antwort Letzte Antwort
              • NashraN Nashra
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                 Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 4
                                RTC time: n/a
                         RTC in local TZ: no
                jack
                HOME=/home/jack
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:
                *** MEMORY ***
                Swap:             0B          0B          0B
                        4554 M used memory
                        6078 M free memory
                           0 M buffer memory
                        1657 M swap cache
                           0 M total swap
                           0 M used swap
                           0 M free swap
                *** FILESYSTEM ***
                /var:
                2.5G    /var/
                2.2G    /var/log
                206M    /var/cache
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.4
                /usr/bin/npx            10.9.4
                nodejs:
                 Version table:
                    20.19.2+dfsg-1 500
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.2
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        45184
                States:         40081
                Pending Updates: 0
                #67
                Da solltest du dich entscheiden. Entweder nodesource.sources oder nodesource.list verwenden.
                Beides gleichzeitig ist Mist.
                Siggi0904S NashraN 2 Antworten Letzte Antwort
                  Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  #68
                  @thomas-braun geht nur nodesource.list da der iob-nodejs-update immer die list installiert, oder?
                  • Siggi0904S Siggi0904
                    #69
                    @siggi0904
                    Ich würde in die nodesource.sources einfach eintragen:
                    Enabled: no
                    Types: deb
                    URIs: https://deb.nodesource.com/node_22.x/
                    Suites: nodistro
                    Components: main
                    Architectures: arm64
                    Signed-By: /etc/apt/keyrings/nodesource.gpg
                    Siggi0904S 1 Antwort Letzte Antwort
                      @siggi0904
                      Enabled: no
                      Types: deb
                      Suites: nodistro
                      Components: main
                      Siggi0904S Offline
                      Siggi0904S Offline
                      Siggi0904
                      #70
                      @thomas-braun ui, das geht? Ich dachte, die list kommt immer wieder.
                        #71
                        @siggi0904
                        Der Eintrag
                        Enabled: no
                        deaktiviert die nodesource.sources und die nodesource.list greift dann wieder exklusiv.
                        Dann haste die .sources aber schon parat und kannst die leicht aktivieren, indem du Enabled auf yes setzt.
                          @siggi0904
                          Der Eintrag
                          Enabled: no
                          Siggi0904S Offline
                          Siggi0904S Offline
                          Siggi0904
                          #72
                          @thomas-braun Das Enabled natürlich überlesen. Danke.
                            NashraN Offline
                            NashraN Offline
                            Nashra
                            #73
                            Ah, dieser Fehler hatte ich nie deswegen war ich verwundert wo der herkommt.
                            Ok die nodesource.sources mit Enable: no versehen und Fehler bleibt.
                            Ich gehe davon aus das ich komplett neu starten muß damit der Eintrag greift.
                            Gruß Ralf
                            • NashraN Nashra
                              #74
                              Nein, der greift sofort.
                              Denn ein
                              sudo apt update
                              liest die config jeweils sofort frisch ein.
                              Und welcher 'Fehler'??
                              Das ist kein "Fehler" (es sein denn, ein Fehler des Administrators der Kiste), sondern nur ein HINWEIS auf eine seltsame und unnötige Einstellung.
                                Denn ein
                                sudo apt update
                                NashraN Offline
                                NashraN Offline
                                Nashra
                                #75
                                Denn ein
                                sudo apt update
                                Warnung weiterhin vorhanden, oder es hängt mit der aktuellen Version 9.0.11 von Proxmox zusammen.
                                Ich suche mal...
                                Gruß Ralf
                                  Liegt an:
                                  Virtualization: lxc
                                  NashraN Offline
                                  NashraN Offline
                                  Nashra
                                  #76
                                  Liegt an:
                                  Virtualization: lxc
                                  Bei Proxmox oder ioBroker?
                                  Gruß Ralf
                                  • NashraN Nashra
                                    Denn ein
                                    sudo apt update
                                    Ich suche mal...
                                    #77
                                    @nashra
                                    Dann zeig man die komplette Ausgabe...
                                    Die Doubletten sind ja da genannt. Sogar mit Zeilennummer.
                                      @nashra
                                      NashraN Offline
                                      NashraN Offline
                                      Nashra
                                      #78
                                      @nashra
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       19:02:57 up 9 min,  0 users,  load average: 0.80, 1.10, 1.01
                                      CPU threads: 4
                                                     Local time: Sat 2025-11-01 19:02:57 CET
                                                 Universal time: Sat 2025-11-01 18:02:57 UTC
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      jack
                                      HOME=/home/jack
                                      iobroker
                                      [sudo] password for jack:
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:
                                      *** MEMORY ***
                                      Mem:             12G        4.3G        7.5G        3.4M        1.1G        8.6G
                                      Swap:             0B          0B          0B
                                      Total:           12G        4.3G        7.5G
                                               4092 M used memory
                                               4183 M active memory
                                                728 M inactive memory
                                               7181 M free memory
                                                  0 M buffer memory
                                               1016 M swap cache
                                                  0 M total swap
                                                  0 M used swap
                                                  0 M free swap
                                      top - 19:03:02 up 9 min,  0 users,  load average: 0.82, 1.10, 1.01
                                      %Cpu(s):  2.4 us,  0.0 sy,  0.0 ni, 95.2 id,  0.0 wa,  0.0 hi,  2.4 si,  0.0 st
                                      MiB Mem :  12288.0 total,   7179.8 free,   4094.1 used,   1017.2 buff/cache
                                      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8193.9 avail Mem
                                      *** FILESYSTEM ***
                                      /dev/mapper/pve-vm--100--disk--0 ext4       21G   17G  2.6G  88% /
                                      tmpfs                            tmpfs     7.8G  3.2M  7.8G   1% /tmp
                                      /var:
                                      2.5G    /var/
                                      2.2G    /var/log
                                      206M    /var/cache
                                      85M     /opt/iobroker/iobroker-data/objects.jsonl
                                      81M     /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      HINT:
                                      /dev/ttyUSB0
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.9.4
                                      /usr/bin/npx            10.9.4
                                      nodejs:
                                        Version table:
                                           20.19.2+dfsg-1 500
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 544)
                                      admin:          7.7.19
                                      javascript:     8.9.2
                                      Adapter State
                                      + instance is alive
                                      Adapter    "admin"        : 7.7.19   , installed 7.7.19
                                      Objects and States
                                      Objects:        45184
                                      States:         40170
                                      Hit:2 http://security.debian.org trixie-security InRelease
                                      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
                                      Pending Updates: 0
                                      tcp        0      0 192.168.1.14:8082       0.0.0.0:*               LISTEN      1001       50184097   1831/io.web.0
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          50157877   1/init
                                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       50159470   156/iobroker.js-con
                                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       50160340   156/iobroker.js-con
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          50160094   310/master
                                      tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       50232770   4526/nc
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       50174456   1213/io.shelly.1
                                      tcp6       0      0 :::8093                 :::*                    LISTEN      1001       50180846   1548/io.rest-api.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50161216   371/io.admin.0
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       50181681   1580/io.simple-api.
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       50184130   2096/io.ws.0
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          50160095   310/master
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          50158082   1/init
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          50157879   1/init
                                      udp        0      0 0.0.0.0:45679           0.0.0.0:*                           1001       50168633   925/io.snmp.0
                                      udp        0      0 0.0.0.0:54318           0.0.0.0:*                           1001       50170950   925/io.snmp.0
                                      udp        0      0 192.168.1.14:5353       0.0.0.0:*                           1001       50171514   992/io.tr-064.0
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       50168515   910/io.shelly.0
                                      udp        0      0 0.0.0.0:39373           0.0.0.0:*                           1001       50185376   1643/io.upnp.0
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       50169552   1017/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       50169553   1017/io.tuya.0
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          50157878   1/init
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       50186409   1643/io.upnp.0
                                      udp6       0      0 :::111                  :::*                                0          50157880   1/init
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Waeschezimmer] Fixed Calculation: RH_in=79%, Threshold=70 -> Empfehlung Lüften: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Waeschezimmer] Absolute Humidity Calculation: AH_in=12.41 g/m³, AH_out=8.99 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Flur gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Flur: 15.34 g/m³
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Taupunkt in Flur gespeichert in 0_userdata.0.Raumklima.Taupunkt.Flur: 21.08 °C
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Flur] Fixed Calculation: RH_in=85%, Threshold=70 -> Empfehlung Lüften: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Flur] Absolute Humidity Calculation: AH_in=15.34 g/m³, AH_out=8.99 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Schlafzimmer: 14.01 g/m³
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Taupunkt in Schlafzimmer gespeichert in 0_userdata.0.Raumklima.Taupunkt.Schlafzimmer: 19.61 °C
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Schlafzimmer] Fixed Calculation: RH_in=77%, Threshold=70 -> Empfehlung Lüften: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Schlafzimmer] Absolute Humidity Calculation: AH_in=14.01 g/m³, AH_out=8.99 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Absolute Luftfeuchte in Werkstatt gespeichert in 0_userdata.0.Raumklima.Lueftungsempfehlung.AbsoluteLuftfeuchtigkeit.Werkstatt: 10.53 g/m³
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: Taupunkt in Werkstatt gespeichert in 0_userdata.0.Raumklima.Taupunkt.Werkstatt: 15.14 °C
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Werkstatt] Fixed Calculation: RH_in=53.5%, Threshold=70 -> Empfehlung Lüften: false
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: [Werkstatt] Absolute Humidity Calculation: AH_in=10.53 g/m³, AH_out=8.99 g/m³, Offset=0 -> Lüften senkt Luftfeuchte: true
                                      2025-11-01 19:00:00.043  - info: javascript.0 (491) script.js.Heizungen.Raumklima: runCalculation ausgelöst (10-Minuten-Intervall)
                                      2025-11-01 19:00:00.051  - info: javascript.0 (491) script.js.Allerlei.Astro-KSB: Astro: Gültige Zeiten: [aktueller Tag: 2] | [nächster Tag: 12] | [Aktualisiert: 0] | Aktuelle Tageszeit: Abenddämmerung | Kommende Tageszeit: später Abend
                                      2025-11-01 19:00:00.071  - info: javascript.0 (491) script.js.Allerlei.Shelly-Verbrauch-MQTT: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 1
                                      2025-11-01 19:00:00.098  - info: javascript.0 (491) script.js.Allerlei.Shelly-Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 2
                                      2025-11-01 19:00:01.510  - info: javascript.0 (491) script.js.Kalender.ICal-farben-Kalender: <table style='font-size:0.9em;'><tbody><tr><td style='font-size:1.1em; padding-left:3px;color:#01DF01'>Heute</td><td style='font-size:1.1em; padding-left:5px;color:#01DF01'>Allerheiligen (regionaler Feiertag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:yellow'>Übermorgen</td><td style='font-size:1.1em; padding-left:5px;color:yellow'>Sandra Geburtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:yellow'>Übermorgen</td><td style='font-size:1.1em; padding-left:5px;color:yellow'>09:00 Zählertausch</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>11.11.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>St. Martin</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>11.11.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>08:50 Blutabnahme</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>14.11.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Ralf Geburtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>16.11.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Volkstrauertag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>19.11.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Buß- und Bettag (Sachsen)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>23.11.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Totensonntag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>30.11.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>01.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Abba</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Hochzeitstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Nikolaustag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>07.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>09.12.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>8:30 Blutabnahme</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>14.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Dritter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>21.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Vierter Advent</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#0080c0'>22.12.</td><td style='font-size:1.1em; padding-left:5px;color:#0080c0'>Weihnachtsferien 2025 Nordrhein-Westfalen</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heiligabend (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>24.12.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Jack</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>25.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Erster Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>26.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Zweiter Weihnachtstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>31.12.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Silvester (halber Tag)</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>01.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Neujahrstag</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#ffff00'>05.01.</td><td style='font-size:1.1em; padding-left:5px;color:#ffff00'>Michael</td></tr><tr><td style='font-size:1.1em; padding-left:3px;color:#fff'>06.01.</td><td style='font-size:1.1em; padding-left:5px;color:#fff'>Heilige Drei Könige (regionaler Feiertag)</td></tr></body></table>
                                      2025-11-01 19:00:07.041  - info: host.ioBroker instance system.adapter.ical.0 having pid 3095 terminated with code 0 (NO_ERROR)
                                      2025-11-01 19:00:30.066  - error: javascript.0 (491) script.js.Wetter.Luftdaten: httpGet(url=https://air.plumelabs.com/air-quality-in-wankum-aw-986728?utm_source=accuweather&utm_medium=current_aq_widget&utm_campaign=#ae16, error=timeout of 30000ms exceeded)
                                      2025-11-01 19:00:30.066  - error: javascript.0 (491) script.js.Wetter.Luftdaten: LuftMessDaten: null
                                      2025-11-01 19:00:36.531  - info: javascript.0 (491) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                      2025-11-01 19:01:37.599  - info: javascript.0 (491) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                      2025-11-01 19:02:50.497  - info: javascript.0 (491) script.js.Wetter.Statistik-md: Material Design Widgets: Wetter Skript triggered by '0_userdata.0.Wetterstation.Aussentemperatur'
                                      Gruß Ralf
                                      • NashraN Nashra
                                        Liegt an:
                                        Virtualization: lxc
                                        #79
                                        @nashra
                                        Da stehts dabei:
                                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                                        • NashraN Nashra
                                          Denn ein
                                          sudo apt update
                                          Ich suche mal...
                                          #80
                                          Nein, die Hinweise sind weg. Jedenfalls die auf doppelte Einträge in den Quellen.
