  4. update Reihenfolge
    6.5k
update Reihenfolge
18 Beiträge 2 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • ubeckerU Online
    ubeckerU Online
    ubecker
    Hallo
    ich versuche meine systeme auf dem laufenden zu halten. Bei einem System geht das nicht immer da dieses etwas weiter von mir entfernt ist. Updates über VPN traue ich mich nicht immer. (wenn ich nicht genau weiß was ich da mache)
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.09.24 14:15:02 =~=~=~=~=~=~=~=~=~=~=~=
    login as: udo
    udo@udo's password:
    Linux borkum-pi5 6.12.34+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26) aarch64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Sat Jul 19 12:04:15 2025 from 192.168.178.205
    [?2004h]0;udo@borkum-pi5: ~udo@borkum-pi5:~ $ iob diag
    [?2004l
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: borkum-pi5
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:15:45 up 83 days, 28 min,  4 users,  load average: 0.00, 0.02, 0.00
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-09-24 14:15:45 CEST
               Universal time: Wed 2025-09-24 12:15:45 UTC
                     RTC time: Wed 2025-09-24 12:15:45
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    udo
    HOME=/home/udo
    GROUPS=udo adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	true
    Display-Manager: 	* lightdm.service - Light Display Manager
    Desktop:
    Session: 		tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.5G        1.8G        3.1G         25M        3.7G        6.7G
    Swap:           209M          0B        209M
    Total:          8.7G        1.8G        3.3G
    Active iob-Instances: 	12
             8063 M total memory
             1706 M used memory
             1710 M active memory
             2961 M inactive memory
             2983 M free memory
             1095 M buffer memory
             2390 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 14:15:45 up 83 days, 28 min,  4 users,  load average: 0.00, 0.02, 0.00
    Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.2 total,   2983.2 free,   1706.2 used,   3486.1 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6357.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  6.0M  801M   1% /run
    /dev/nvme0n1p2 ext4      234G  9.9G  212G   5% /
    tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      511M   78M  434M  16% /boot/firmware
    tmpfs          tmpfs     807M  176K  807M   1% /run/user/1000
    [Thu Jul  3 13:47:07 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:5C:5F:1B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=f7c452d0-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Jul  3 13:47:08 2025] EXT4-fs (nvme0n1p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
    [Thu Jul  3 13:47:08 2025] EXT4-fs (nvme0n1p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/nvme0n1p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G	/var/
    564M	/var/cache
    551M	/var/cache/apt
    437M	/var/cache/apt/archives
    400M	/var/log/journal/a230a4c05b2c4f298a07f98ebe72de3f
    Archived and active journals take up 399.1M in the file system.
    /opt/iobroker/backups:
    359M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1002M	/opt/iobroker/iobroker-data/
    753M	/opt/iobroker/iobroker-data/history
    183M	/opt/iobroker/iobroker-data/files
    53M	/opt/iobroker/iobroker-data/backup-objects
    47M	/opt/iobroker/iobroker-data/files/admin.admin
    24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.3M	/opt/iobroker/iobroker-data/objects.jsonl
    9.3M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.6M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    5.3M	/opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.3
    /usr/bin/node 		v20.19.3
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
         20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
     *** 20.19.3-1nodesource1 1001
            100 /var/lib/dpkg/status
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    borkum-pi5          borkum-pi5 (version: 7.0.6, hostname: borkum-pi5    , alive, uptime: 7172922)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : borkum-pi5                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : borkum-pi5                               -  enabled
    + system.adapter.email.0                  : email                 : borkum-pi5                               -  enabled
      system.adapter.flot.0                   : flot                  : borkum-pi5                               -  enabled
    + system.adapter.history.0                : history               : borkum-pi5                               -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : borkum-pi5                               -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : borkum-pi5                               -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : borkum-pi5                               -  enabled, port: 0
      system.adapter.icons-material-svg.0     : icons-material-svg    : borkum-pi5                               - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : borkum-pi5                               - disabled
    + system.adapter.javascript.0             : javascript            : borkum-pi5                               -  enabled
    + system.adapter.modbus.0                 : modbus                : borkum-pi5                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : borkum-pi5                               -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : borkum-pi5                               - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : borkum-pi5                               - disabled
      system.adapter.vis.0                    : vis                   : borkum-pi5                               -  enabled
    + system.adapter.web.0                    : web                   : borkum-pi5                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.6.17 [Updatable]
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Objects and States
    Objects: 	4823
    States: 	3716
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 187
    *** Listening Ports ***
    tcp        0      0 192.168.178.3:9292      0.0.0.0:*               LISTEN      1001       4143555    220016/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3046       867/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8922       867/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21376037   1133500/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8423       885/sshd: /usr/sbin
    tcp        0      0 192.168.178.3:2010      0.0.0.0:*               LISTEN      1001       4144420    220015/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7368100    388820/io.mqtt.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21376036   1133500/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8425       885/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9972       1811/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11325      1475/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7577       701/avahi-daemon: r
    udp        0      0 0.0.0.0:59777           0.0.0.0:*                           104        7579       701/avahi-daemon: r
    udp6       0      0 :::52687                :::*                                104        7580       701/avahi-daemon: r
    udp6       0      0 fe80::5504:b1f3:521:546 :::*                                0          9647       767/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        7578       701/avahi-daemon: r
    2025-09-24 07:21:36.154  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 23
    2025-09-24 07:37:55.268  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 74
    2025-09-24 07:52:08.864  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 75
    2025-09-24 07:54:33.123  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 76
    2025-09-24 08:29:16.148  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 86
    2025-09-24 08:35:38.356  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 89
    2025-09-24 08:38:21.626  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 90
    2025-09-24 08:44:57.643  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 91
    2025-09-24 08:59:54.512  - info: javascript.0 (1658) script.js.Heizungen.WWasser_von_Hz:  , WW = 0
    2025-09-24 09:00:54.564  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 62
    2025-09-24 09:01:38.466  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 80
    2025-09-24 09:11:38.795  - info: javascript.0 (1658) script.js.Heizungen.WWasser_von_Hz:  , WW = 1
    2025-09-24 09:13:59.047  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 111
    2025-09-24 09:14:33.972  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 142
    2025-09-24 09:25:59.880  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 140
    2025-09-24 09:33:57.131  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 138
    2025-09-24 10:24:54.528  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 129
    2025-09-24 11:19:21.225  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 117
    2025-09-24 11:21:01.016  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 102
    2025-09-24 11:33:04.047  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 49
    2025-09-24 11:41:01.868  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 95
    2025-09-24 11:42:57.662  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 49
    2025-09-24 12:03:53.131  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 94
    2025-09-24 12:14:04.817  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 92
    2025-09-24 12:16:18.057  - info: javascript.0 (1658) script.js.Heizungen.set_value_energieanforderung: 85
    Um dieses System geht es jetzt.
    ich weiß nicht was zuerst gemacht werden muss und Linux kommandos versuche ich zu vermeiden (bin mittlerweile auf klicken).
    Ich möchte das system auch direkt auf Trixie machen.
    Eine komplette Installation ist ok. Die mache ich auf einer SD Karte. Nur gibt es diese noch nicht bei PI Imager. zu Fuss mach ich nicht.
    Nächste Problem, ich hab die GUI drin, weiß ich, aber nur um anschließend die SD Karte auf die M.2 SSD zu kopieren. Direkt darauf installieren geht nicht weil es keine USB Platte ist. PCIe direkt verbunden.
    Bitte um kurze Hilfe. Was zuerst und wie ein Restore.
    Gruß Udo
    • ubeckerU ubecker
      Hallo
      login as: udo
      udo@udo's password:
      [?2004l
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      udo
      HOME=/home/udo
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session: 		tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               8063 M total memory
               1706 M used memory
               2983 M free memory
               2390 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      1.4G	/var/
      564M	/var/cache
      551M	/var/cache/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.6.17
      javascript: 	8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4823
      States: 	3716
      @ubecker sagte in update Reihenfolge:
      Über SSH aber schwierig...
      Schalt den Desktop-Krempel einfach aus. Das ganze System ist dann auch EINFACHER zu administrieren, weil der ganze GUI-Overhead da nicht mitgeschleppt werden muss.
      Da würde ich warten, bis das auch offizielle für RaspberryOS freigegeben ist.
      Konkret für was? Für die
      Regelmäßige Systempflege (ganz ohne KlickiBunti):
      iob stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Denn ioBroker per
      iob update
      iob upgrade
      Auch ohne Geklicke...
      Upgrade auf nodejs@(aktuelle_Empfehlung):
      iob nodejs-update
      Ebenfalls ohne Geklicke.
      Edit: Und weil wir gerade dabei sind, auch ganz klickfrei:
      https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
      ubeckerU 1 Antwort Letzte Antwort
        iob stop
        sudo apt update
        sudo reboot
        Denn ioBroker per
        iob update
        iob upgrade
        iob nodejs-update
        ubeckerU Online
        ubeckerU Online
        ubecker
        @thomas-braun erstmal danke. Da ich mit trixie noch warten soll ist der Rest fast klar, nur noch die Frage ist eine Update Reihenfolge erforderlich?
        *Schalt den Desktop-Krempel einfach aus. *
        Wie ich geschrieben habe benötige ich den Krempel nur wenn ich die SD Karte auf die m.2 kopieren muss da ich nicht weiß wie die m.2 dann bootfähig ist.
        Ich starte das System von SD wenn diese vorhanden ist. Sonst von der m.2
        Gruß Udo
        • ubeckerU ubecker
          Ich verstehe den Ansatz schon nicht. Was willst denn da kopieren, was dann bootfähig sein soll?
            ubeckerU Online
            ubeckerU Online
            ubecker
            @thomas-braun said in update Reihenfolge:
            ich habe in den PI5 keine USB Platte sondern eine an dem PCIe Interface. Diese kann ich nicht mit dem Raspberry Pi Imager beschreiben. Das brauche ich auch nur für eine neue Installation wenn ich auf Trixie updaten muss.
            Also denke ich (so habe ich auch das system bisher aufgesetzt)
            1. SD Karte mit dem Imager neu erstellen
            2. IOB installieren
            3. Restore vom alten system.
            4. Mit der GUI die SD nach der PCIe Platte kopieren so das diese auch bootet.
            5. SD Karte entnehmen und system neu starten.
            Alle meine Versuche das anders zu machen sind gescheitert. Die PCIe hat nie gebootet.
            Gruß Udo
            • ubeckerU ubecker
              2. IOB installieren
              @ubecker
              Macht man mit einem USB-Adapter. Geht so:
              Step 1: Hardware Setup
              Connect the PCIe adapter:
              Attach the PCIe adapter to the specific connection on the Raspberry Pi 5 board.
              Install the NVMe SSD:
              Insert your NVMe SSD into the M.2 slot on the adapter and secure it with the provided screw.
              Connect the ribbon cable:
              Insert the ribbon cable into the PCIe port on the Raspberry Pi 5, ensuring the contact points face inward.
              Step 2: Install Raspberry Pi Imager
              Download: On your main computer, download the Raspberry Pi Imager tool from the Raspberry Pi website.
              Install: Install the imager application.
              Step 3: Image the SSD
              Launch Imager: Open the Raspberry Pi Imager application.
              Select device: Choose your Raspberry Pi model from the list.
              Choose OS: Select the desired version of Raspberry Pi OS.
              Select storage: Connect your NVMe drive to your computer (using a USB-C adapter is a common way to do this) and select it as the storage device in the imager.
              Write the image: Start the imaging process to write the OS to the NVMe SSD.
              Step 4: Enable PCIe Booting
              Boot from SD card: Boot the Raspberry Pi 5 from a micro SD card to access the operating system.
              Edit the EEPROM configuration: Open a terminal on the Raspberry Pi and run sudo rpi-eeprom-config --edit.
              Change the boot order: Find the line BOOT_ORDER=0xf416 and add it, or change the existing one, to this value. This enables the Pi to attempt to boot from NVMe first.
              Save and exit: Save your changes (Ctrl+O, then Enter) and exit the editor (Ctrl+X).
              Reboot: Shut down the Raspberry Pi using sudo poweroff.
              Step 5: Boot from the NVMe SSD
              Remove the SD card: Remove the micro SD card from the Raspberry Pi.
              Power on: Power on the Raspberry Pi 5. It will now attempt to boot from the PCIe NVMe SSD.
              Ganz ohne GUI. Hier auch ohne GUI:
              https://www.raspifun.de/viewtopic.php?t=388
                @ubecker
                ubeckerU Online
                ubeckerU Online
                ubecker
                das war ein Problem. Habe keinen Adapter. Der Rest war klar. Deshalb der Weg über SD Karte und kopieren.
                Funktioniert ja, nur brauche ich dazu die GUI von Linux. Den Consolenbefehl dazu habe ich nicht hinbekommen. (ist mir auch sehr suspect)
                War aber nicht meine eigentliche Frage.
                Frage bezog sich auf die Reihenfolge wenn ich mein verhandenes System auf Trixie updaten muss. (hat sich ja erst mal erledigt)
                müssen vorher alle IOB Teile auf dem aktellen Stand sein. Davon ein Backup
                danach
                1. Trixie mit Imager auf SD Karte.
                2. IOB Grundinstallation
                3. Restore vom Backup
                oder ist die Reihenfolge beliebig. Können IOB update auch danach gemacht werden.
                Ich kenn immer noch nicht die Zusammenhänge zwischen JS-Controller NPM usw.
                Eigentlich möchte ich eine Funktion auf der Oberfäche von IOB. Knopf drücken und fertig. (Systemupdate)
                Macht alle notwendigen update fürs System. Die einzelnen Adapter ausgenommen.
                Auch das OS (Debian xy) ausgenommen.
                Noch eine Frage: Da ich mit dem neuen OS noch warten soll, wie lange kann man warten. Ich habe meistens nur einmal im Jahr die Möglichkeit das update zu machen.
                Gruß Udo
                Thomas BraunT 3 Antworten Letzte Antwort
                • ubeckerU ubecker
                  danach
                  iobroker und das OS sind nicht sehr eng miteinander verzahnt, die Reihenfolge ist also mehr oder weniger beliebig.
                  Ich gehe aber von 'unten nach oben' vor. Also erst schau ich was beim OS anliegt (das musst du deutlich regelmäßiger machen!) und dann schau ich was beim ioBroker anliegt.
                  Finde den Widerspruch. Was bezeichnest du denn als 'System', wenn beim ioBroker die Adapter und beim OS die Pakete ausgenommen sind?
                  Wie man eine regelmäßige Systempflege betreibt hab ich dir oben schon geschrieben.
                  Und da ich ein fauler Admin bin hab ich mir das in ein kleines Skript gegossen:
                  #!/usr/bin/bash
                  sudo apt-get update;
                  echo "";
                  sudo apt-get full-upgrade;
                  echo "------------------------------------------------------------------------";
                  iob update;
                  iob upgrade;
                  echo ""
                  if [ -f "/var/run/reboot-required" ]; then
                          echo "";
                          echo "This system needs to be REBOOTED!";
                          echo "";
                  fi
                  exit;
                  • ubeckerU ubecker
                    danach
                    Bis Raspberry OS 13 überhaupt mal veröffentlich wird? Bookworm/Debian 12 ist derzeitig das sog. 'oldstable release', das wird noch bis Sommer 2026 voll unterstützt. Bis dahin solltest du aber den Absprung geschafft haben.
                    • ubeckerU ubecker
                      danach
                      Die paar Euro würde ich ausgeben.
                      Die zweite Anleitung kommt übrigens auch ohne USB-Adapter aus. Dafür ist die was komplizierter umzusetzen.
                      Aber auch da ohne Desktop...
                        #!/usr/bin/bash
                        echo "";
                        iob update;
                        iob upgrade;
                        echo ""
                                echo "";
                                echo "";
                        fi
                        exit;
                        ubeckerU Online
                        ubeckerU Online
                        ubecker
                        Hast Recht. Jeder denkt hier anders.
                        Meine Denkweise wie ich das meinte:
                        Es gibt
                        OS Debian xy
                        IOB mit notwendigen Komponenten Host, Admin, NPM usw. ist für mich das IOB System
                        Adapter sind Anwenderbezogen.
                        iob update;
                        iob upgrade;
                        echo ""
                                echo "";
                                echo "";
                        fi
                        exit;
                        Das wäre dann mein Knopf Systemupdate.
                        Gruß Udo
                        • ubeckerU ubecker
                          Es gibt
                          OS Debian xy
                          iob update;
                          iob upgrade;
                          echo ""
                                  echo "";
                                  echo "";
                          fi
                          exit;
                          Den 'Knopf' rufst du in der Kommandozeile auf.
                            ubeckerU Online
                            ubeckerU Online
                            ubecker
                            das ist nicht das Problem. Habe ich erst festgestellt als ich alles zusammengebaut hatte. Dann habe ich das über copy gefunden.
                            Gruß Udo
                            • ubeckerU ubecker
                              @ubecker
                              Sei's wie es ist, aber Server IMMER ohne Desktop-Mumpitz. Spart dir auch diverse Updates, spart dir Ressourcen, ist sicherer und ist stabiler.
                              Den Mumpf kannste auch nachträglich noch ausknipsen, u. a. per
                              iob fix
                                ubeckerU Online
                                ubeckerU Online
                                ubecker
                                ich liebe den Docker auf meiner Synology
                                Gruß Udo
                                • ubeckerU ubecker
                                  Auch den musst du updaten. Ob mit 'Knopf' oder nicht.
                                    ubeckerU Online
                                    ubeckerU Online
                                    ubecker
                                    richtig, nur brauch ich um nichts kümmern. Ich bemomme eine Medung von der Synology dann starte ich dort das Update ohne Commandozeile.
                                    Gruß Udo
                                      @ubecker
                                      iob fix
                                      ubeckerU Online
                                      ubeckerU Online
                                      ubecker
                                      werde den IOB fix dann machen. Ich brauche die GUI ja nur für das eine mal.
                                      Gruß Udo
