  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 119.7k Aufrufe
  • H
    H
    Haus
    #181
    @kto:
    @Bluefox:
    http://forum.iobroker.net/viewtopic.php … =20#p10299
    apt-get update && apt-get upgrade
    apt-get install unzip
    apt-get install libudev-dev
    Так, unzip был установлен, libudev-dev установился.
    Это повлияло в лучшую сторону, но полного успеха всё ещё нет.
    При попытке установить через ioBroker:
    $ ./iobroker add zwave
    npm install iobroker.zwave --production --prefix "/opt/iobroker" (System call)
    In file included from ../src/openzwave.hpp:27:0, from ../src/callbacks.cc:18:
    /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/node_modules/nan/nan.h:328:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
    static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
    ! make: *** [Release/obj.target/openzwave_shared/src/callbacks.o] Error 1
    gyp
    ERR! build error
    gyp
    ERR! stack Error: make failed with exit code: 2gyp ERR!
    stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
    gyp ERR! stack at ChildProcess.emit (events.js:98:17)gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
    gyp ERR! System Linux 4.1.17-v7+
    gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared
    gyp ERR!
    node -v v0.10.29gyp ERR! node-gyp -v v0.12.2
    gyp ERR! not ok
    ! npm
    WARN This failure might be due to the use of legacy binary "node"npm WARN For further explanations, please read
    /usr/share/doc/nodejs/README.Debian
    ! npm
    ERR! openzwave-shared@1.1.7 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR! npm ERR! Failed at the openzwave-shared@1.1.7 install script.
    npm ERR! This is most likely a problem with the openzwave-shared package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get their info via:
    ! npm
    ERR! npm owner ls openzwave-sharednpm ERR! There is likely additional logging output above.
    ! npm ERR! System Linux 4.1.17-v7+
    npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--production" "--prefix" "/opt/iobroker"
    npm ERR! cwd /
    npm ERR! node -v v0.10.29
    npm ERR! npm -v 1.4.21
    npm ERR! code ELIFECYCLE
    ! npm
    ERR! Error: EACCES, open 'npm-debug.log'npm ERR! { [Error: EACCES, open 'npm-debug.log'] errno: 3, code: 'EACCES', path: 'npm-debug.log' }
    npm ERR!
    npm ERR! Please try running this command again as root/Administrator.
    ! npm
    npm ERR! cwd /npm ERR! node -v v0.10.29
    npm ERR! path npm-debug.log
    npm ERR! code EACCES
    npm ERR! errno 3
    npm ERR! stack Error: EACCES, open 'npm-debug.log'
    ! npm ERR! npm ERR! Additional logging details can be found in:
    npm ERR! /npm-debug.log
    npm ERR! not ok code 0
    ! ERROR: host.raspberrypi Cannot install iobroker.zwave: 1
    Та же ошибка и при установке через консоль:
    -----бла---бла---бла--------
      inflating: open-zwave-master/openzwave.dsc
      inflating: open-zwave-master/openzwave.spec
    >! stderr:
    ---> cd open-zwave-master && make
    stdout: CPPFLAGS= make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build/ -
    make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build'
    Building OpenZWave Version 1.4.-1
    Building tinystr.o
    Building tinyxmlerror.o
    Building tinyxml.o
    Building vers.o
    Linking Static Library
    Linking Shared Library
    Making ozw_config file
    make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build'
    CPPFLAGS= make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW/ -
    make[1]: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW'
    Building Main.o
    Linking /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/MinOZW
    g++   -o /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/MinOZW /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/.lib/Main.o /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/libopenzwave.so -pthread
    Creating Temporary Shell Launch Script
    make[1]: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW'
    >! stderr:
    ---> cd open-zwave-master && sudo make install
    stdout: make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/build/ - install
    Making libopenzwave pkg-config file
    Installing Shared Library
    Installing Headers
    Installing Config Database
    Installing Documentation
    Installing Pkg-config Files
    make -C /opt/iobroker/node_modules/iobroker.zwave/open-zwave-master/cpp/examples/MinOZW/ - install
    Installing into Prefix: /usr/local
    >! stderr: Makefile:193: Documentation not being built
    > openzwave-shared@1.1.7 preinstall /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared
    > node lib/install-ozw.js
    > openzwave-shared@1.1.7 install /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared
    > node-gyp rebuild
    >! make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
      CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    openzwave_shared.target.mk:105: recipe for target 'Release/obj.target/openzwave_shared/src/callbacks.o' failed
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
    gyp ERR! node -v v0.10.29
    gyp ERR! not ok
    npm WARN This failure might be due to the use of legacy binary "node"
    npm ERR! openzwave-shared@1.1.7 install: `node-gyp rebuild`
    npm ERR!
    npm ERR!     npm owner ls openzwave-shared
    npm ERR! cwd /opt/iobroker
    npm ERR!
    npm ERR!     /opt/iobroker/npm-debug.log
    Насколько я понял - это вызвано проблемами с версией nodejs.
    У меня стоит v0.10.29, в google борются с этой ошибкой другой версией nodejs.
    В частности https://github.com/nodesource/distributions .
    Насколько это правильный подход? Стоит ему последовать или будут другие рекомендации?
    На всякий случай напомню, что ставлю это всё на raspbian, который крутиться на raspberry pi 2B. `
    А эта инструкция не ваш случай?
    Installation
    First of all, Implemenation is tested only on ARM Linux (e.g. Raspberry Pi (2)).
    You need a fully Development Environment (gcc, make,...)
    npm install iobroker.zwave does following Steps for you:
    Download and install latest openzwave from github
    # cd /opt
    # curl -L -O https://github.com/OpenZWave/open-zwave/archive/master.zip
    # unzip master.zip
    # cd open-zwave-master
    # make
    # sudo make install
    After that you have to do the following Steps:
    Put your USB Stick into your Server
    Check whether the system has recognized the USB stick
    # lsusb
    # ls -al /dev/ttyA*
    Go into iobroker Website and add the Zwave Adapter
    Configure zwave Adapter as described
    Start the new zwave Adapter instance
    wait
    -- until the Message "zwave.0 Scan completed" is found in iobroker.log
    -- the Object zwave.0.completed has State "true"
    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
    admin: 3.6.0
    javascript: 4.1.10
    web: 2.4.1 vis: 1.1.10
    cloud: 2.6.2
    Server: DELL FX170 / linux: Debian 9.5 Stretch
    Adapter: MegaD-2561, Mega-ES…
    • K
      K
      kto
      #182
      @spectrekr:
      Отмучал!
      Выполняем все под рутом.
      /etc/init.d/iobroker stop
      apt-get update && apt-get -y upgrade && apt-get -y remove nodejs npm && apt-get -y autoremove
      wget http://node-arm.herokuapp.com/node_latest_armhf.deb && dpkg -i node_latest_armhf.deb
      sed -i 's/^NODECMD=\/usr\/bin\/node/NODECMD=\/usr\/local\/bin\/node/g' /etc/init.d/iobroker.sh
      init 6
      После того как малинка загрузится, можно ставить ZWave драйвер. `
      Огромное человеческое спасибище)
      Прямо сейчас мучаю Малинку)
      Установилось!) Спасибо) Завтра буду пробовать подключить адаптер и проверить работу в целом.
      Для справки - теперь версия node - 4.2.1, а npm - 2.14.7.
      @Haus:
      Installation
      ! First of all, Implemenation is tested only on ARM Linux (e.g. Raspberry Pi (2)).
      ! npm install iobroker.zwave does following Steps for you:
      ! Download and install latest openzwave from github
      cd /opt
      unzip master.zip
      make
      sudo make install
      ! Put your USB Stick into your Server
      lsusb
      ls -al /dev/ttyA*
      ! Go into iobroker Website and add the Zwave Adapter
      ! Configure zwave Adapter as described
      wait
      Похоже, я перед тем, как ставить по инструкции Haus'a сделал бекап. Нужно будет проверить и этот метод.
      Меня единственное что смущает - так это````
      make install
      Что скажите?
      • S
        S
        spectrekr
        #183
        Нормальная и правильная практика, только не надо удалять исходники после установки.
        Когда надо обновить пакет или удалить, делаем
        make remove
        В папке с иходниками и он удалит все поставленные компоненты.
        • K
          K
          kto
          #184
          @spectrekr:
          make remove
          В папке с иходниками и он удалит все поставленные компоненты. `
          Понял, спасибо.
          Сегодня с работы пытался завести Zwave. Получилось, хоть и не с первого раза.
          При запуске драйвера в лог выпадает такое:
          host-raspberrypi 2016-02-18 12:50:33 error instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
          Error: 2016-02-18 12:50:33 error at Module.load (module.js:356:32)
          Error: 2016-02-18 12:50:33 error at Object.Module._extensions..js (module.js:442:10)
          Error: 2016-02-18 12:50:33 error at Module._compile (module.js:435:26)
          Error: 2016-02-18 12:50:33 error at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
          Error: 2016-02-18 12:50:33 error at require (module.js:385:17)
          Error: 2016-02-18 12:50:33 error at Module.require (module.js:366:17)
          Error: 2016-02-18 12:50:33 error at Function.Module._load (module.js:311:12)
          Error: 2016-02-18 12:50:33 error at Object.Module._extensions..node (module.js:460:18)
          Error: 2016-02-18 12:50:33 error at Error (native)
          Error: 2016-02-18 12:50:33 error libopenzwave.so.1.4: cannot open shared object file: No such file or directory
          uncaught 2016-02-18 12:50:33 error exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
          Помог совет из гугла.
          Выполнить на Raspberry
          sudo ldconfig
          После этого стартовал нормально.
          Разве что ошибка в логе:
          zwave-0 2016-02-18 12:50:51 error ##### Value added: zwave.0.NODE1.BASIC.Basic = 0 index = 0 comclass = 32 instance = 1
          Пока не знаю, насколько критично, так как судя по логу, USB свисток оно подтянуло.
          zwave-0 2016-02-18 12:50:51 info Scan completed
          zwave-0 2016-02-18 12:50:51 info node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
          zwave-0 2016-02-18 12:50:51 info nodeid 1 is now available, but maybe not ready
          zwave-0 2016-02-18 12:50:51 info driver ready: homeid = 3607400198
          zwave-0 2016-02-18 12:50:51 info scanning homeid=0xd7048f06...
          zwave-0 2016-02-18 12:50:51 info connected: homeid = 1.4.0
          zwave-0 2016-02-18 12:50:50 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.zwave
          host-raspberrypi 2016-02-18 12:50:48 info instance system.adapter.zwave.0 started with pid 2361
          host-raspberrypi 2016-02-18 12:50:47 info object change system.adapter.zwave.0
          host-raspberrypi 2016-02-18 12:50:33 info Restart adapter system.adapter.zwave.0 because enabled
          • K
            K
            kto
            #185
            К сожалению не получается воспользоваться Zwave адаптером.
            При подключении устройства (Fibaro Switch) получаю целую простыню ошибок:
            ! ` > zwave-0 2016-02-18 22:33:50 info Scan completed
            zwave-0 2016-02-18 22:33:50 info node ready nodeid:11 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGS222 Double Relay Switch 2x1.5kW","producttype":"0x0202","productid":"0x1002","type":"Binary Power
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.SWITCH_BINARY.Switch_2 = false index = 0 comclass = 37 instance = 2
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.SWITCH_BINARY.Switch_1 = false index = 0 comclass = 37 instance = 1
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Timeout = 0 index = 1 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Powerlevel = Normal index = 0 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.SWITCH_ALL.Switch All = On and Off Enabled index = 0 comclass = 39 instance = 1
            zwave-0 2016-02-18 22:33:50 info controller command feedback: state:The command has completed successfully #### error:No error #### helpmsg:ControllerCommand - Completed #### currently not implemented
            zwave-0 2016-02-18 22:33:50 info controller command feedback: state:The controller is communicating with the other device to carry out the command #### error:No error #### helpmsg:ControllerCommand - InProgress #### currently not im
            zwave-0 2016-02-18 22:33:50 info controller command feedback: state:The command is starting #### error:No error #### helpmsg:ControllerComand - Starting #### currently not implemented
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.VERSION.Application Version = 2.02 index = 2 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.VERSION.Protocol Version = 3.52 index = 1 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:50 error ##### Value added: zwave.0.NODE11.VERSION.Library Version = 3 index = 0 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 2: Response to Temperature Alarm = ALARM RELAY ON - relay will turn ON upon receipt of alarm frame index = 43 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 2: Response to Smoke, CO, CO2 Alarm = ALARM FLASHING - relay will turn ON and OFF periodically (see param.39) index = 42 comclass = 112 instance
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 2: Response to Water Flood Alarm = ALARM RELAY OFF - relay will turn OFF upon receipt of alarm frame index = 41 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 2: Response to General Alarm = ALARM FLASHING - relay will turn ON and OFF periodically (see param.39) index = 40 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.ALARM FLASHING alarm time = 88 index = 39 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 1: Response to Temperature Alarm = ALARM RELAY ON - relay will turn ON upon receipt of alarm frame index = 33 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 1: Response to Smoke, CO, CO2 Alarm = ALARM FLASHING - relay will turn ON and OFF periodically (see param.39) index = 32 comclass = 112 instance
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 1: Response to Water Flood Alarm = ALARM RELAY OFF - relay will turn OFF upon receipt of alarm frame index = 31 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Relay 1: Response to General Alarm = ALARM FLASHING - relay will turn ON and OFF periodically (see param.39) index = 30 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Saving state before power faillure = State saved at power failure, all outputs are set to previous state upon power restore index = 16 comclass = 112 i
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Dimmer/Roller shutter control = Disable Dimmer/Roller shutter control index = 15 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Inputs Button/Switch configuration = Bi-stable input (switch) index = 14 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Inputs behaviour = Toggle index = 13 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Control key #2 behaviour = Device status is checked index = 7 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Separation of association sending (key 1) = Map status to all devices in group 1 (default) index = 6 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Auto off for relay 2 = 0 index = 5 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Auto off for relay 1 = 0 index = 4 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Auto off relay after specified time = Manual override disabled index = 3 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.CONFIGURATION.Enable/Disable ALL ON/OFF = ALL ON active / ALL OFF active index = 1 comclass = 112 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Acked Frames = 0 index = 9 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Test Status = Failed index = 8 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Report = undefined index = 7 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Test = undefined index = 6 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Frame Count = 0 index = 5 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Test Powerlevel = Normal index = 4 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Test Node = 0 index = 3 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Set Powerlevel = undefined index = 2 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Timeout = 0 index = 1 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.POWERLEVEL.Powerlevel = Normal index = 0 comclass = 115 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.VERSION.Application Version = Unknown index = 2 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.VERSION.Protocol Version = Unknown index = 1 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.VERSION.Library Version = Unknown index = 0 comclass = 134 instance = 1
            zwave-0 2016-02-18 22:33:49 info node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
            zwave-0 2016-02-18 22:33:49 info node11: nop, currently not implemented
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.SWITCH_ALL.Switch All = Disabled index = 0 comclass = 39 instance = 1
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE11.SWITCH_BINARY.Switch_1 = false index = 0 comclass = 37 instance = 1
            zwave-0 2016-02-18 22:33:49 info nodeid 1 is now available, but maybe not ready
            zwave-0 2016-02-18 22:33:49 error ##### Value added: zwave.0.NODE1.BASIC.Basic = 0 index = 0 comclass = 32 instance = 1
            zwave-0 2016-02-18 22:33:49 info driver ready: homeid = 3607400198 `
            К величайшему моему сожалению, пока не нахожу, как с этим справиться.
            Метод установки от Haus'а так же не помог - не работает без смены версии nodejs.
            А даже сменив - получаем всё те-же ошибки.
            • F
              F
              fotya
              #186
              Привет.
              Не могу установить iobroker на bananapi BPI-M1+.
              Перепробовал все или почти все, ну просто не хочет работать . На Raspberry установилась с первого раза.
              Может кто подскажет как на это китайское чудо установить? А то уже появилось желание ,упаковать аккуратно в коробочку и выкинуть.
              • BluefoxB
                #187
                @fotya:
                Привет.
                Может кто подскажет как на это китайское чудо установить? А то уже появилось желание ,упаковать аккуратно в коробочку и выкинуть. `
                Что пишет то?
                пробовал мануально установить (по пакетам)?
                • F
                  F
                  fotya
                  #188
                  Пробовал, не хочет.
                  В линуксе я слабоват и может что-то не понимаю.
                  Делал так -
                  Смонтировал образ Bananian Linux ,сделал настройки ,а дальше все мои манипуляции ни к чему не привели.
                  Как это по шагам сделать?
                  • K
                    K
                    kontakter
                    #189
                    Подскажите пароль для root. Образ для bananapi http://www.iobroker.net/?download=2895 .Armbian для BananaPi на сайте своем пишет 1234. Доступа нет.
                    • BluefoxB
                      #190
                      @kontakter:
                      Подскажите пароль для root. Образ для bananapi http://www.iobroker.net/?download=2895 .Armbian для BananaPi на сайте своем пишет 1234. Доступа нет. `
                      Name: bananapi Passwort: bananapi
                      if Bananian OS
                      Name: root Passwort: pi
                      • BluefoxB
                        #191
                        @fotya:
                        Пробовал, не хочет.
                        Делал так -
                        Как это по шагам сделать? `
                        К чему они то привели? Где застрял то? Залогиниться смог? Итд?
                        • F
                          F
                          fotya
                          #192
                          Захожу под "root"
                          root@bananapi ~ # apt-get update
                          root@bananapi ~ # apt-get upgrade
                          устанавливаю "npm" и "nodejs"
                          root@bananapi ~ # apt-get install curl
                          root@bananapi ~ # curl -sL https://deb.nodesource.com/setup_5.x | bash -
                          root@bananapi ~ # apt-get install  nodejs
                          получается так -````
                          root@pi ~ # nodejs -v
                          v5.7.1
                          root@pi ~ # npm -v
                          3.6.0
                          дальше -````
                          $ cd /opt
                          $ mkdir iobroker
                          $ cd iobroker
                          $ npm install iobroker
                          получается вот-так -
                          ! npm WARN lifecycle iobroker@0.6.0~install: cannot run in wd %s %s (wd=%s) iobrok er@0.6.0 node lib/setup.js /opt/iobroker/node_modules/iobroker
                          ! /opt/iobroker
                          ! └─┬ iobroker@0.6.0
                          ! └─┬ yargs@4.2.0
                          ! ├── camelcase@2.1.0
                          ! ├─┬ cliui@3.1.0
                          ! │ ├─┬ strip-ansi@3.0.1
                          ! │ │ └── ansi-regex@2.0.0
                          ! │ └── wrap-ansi@1.0.0
                          ! ├── decamelize@1.2.0
                          ! ├─┬ lodash.assign@4.0.6
                          ! │ ├── lodash.keys@4.0.5
                          ! │ └── lodash.rest@4.0.1
                          ! ├─┬ os-locale@1.4.0
                          ! │ └─┬ lcid@1.0.0
                          ! │ └── invert-kv@1.0.0
                          ! ├─┬ pkg-conf@1.1.1
                          ! │ ├─┬ find-up@1.1.2
                          ! │ │ ├── path-exists@2.1.0
                          ! │ │ └─┬ pinkie-promise@2.0.0
                          ! │ │ └── pinkie@2.0.4
                          ! │ ├── object-assign@4.0.1
                          ! │ ├─┬ read-pkg@1.1.0
                          ! │ │ ├─┬ load-json-file@1.1.0
                          ! │ │ │ ├── graceful-fs@4.1.3
                          ! │ │ │ ├─┬ parse-json@2.2.0
                          ! │ │ │ │ └─┬ error-ex@1.3.0
                          ! │ │ │ │ └── is-arrayish@0.2.1
                          ! │ │ │ ├── pify@2.3.0
                          ! │ │ │ └─┬ strip-bom@2.0.0
                          ! │ │ │ └── is-utf8@0.2.1
                          ! │ │ ├─┬ normalize-package-data@2.3.5
                          ! │ │ │ ├── hosted-git-info@2.1.4
                          ! │ │ │ ├─┬ is-builtin-module@1.0.0
                          ! │ │ │ │ └── builtin-modules@1.1.1
                          ! │ │ │ ├── semver@5.1.0
                          ! │ │ │ └─┬ validate-npm-package-license@3.0.1
                          ! │ │ │ ├─┬ spdx-correct@1.0.2
                          ! │ │ │ │ └── spdx-license-ids@1.2.0
                          ! │ │ │ └─┬ spdx-expression-parse@1.0.2
                          ! │ │ │ └── spdx-exceptions@1.0.4
                          ! │ │ └── path-type@1.1.0
                          ! │ └── symbol@0.2.1
                          ! ├── read-pkg-up@1.0.1
                          ! ├── require-main-filename@1.0.1
                          ! ├─┬ string-width@1.0.1
                          ! │ ├─┬ code-point-at@1.0.0
                          ! │ │ └── number-is-nan@1.0.0
                          ! │ └── is-fullwidth-code-point@1.0.0
                          ! ├── window-size@0.2.0
                          ! ├── y18n@3.2.0
                          ! └── yargs-parser@2.1.1
                          ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.j son'
                          ! npm WARN iobroker No description
                          ! npm WARN iobroker No repository field.
                          ! npm WARN iobroker No README data
                          ! npm WARN iobroker No license field.
                          ! npm install iobroker 30.53s user 2.83s system 82% cpu 40.216 total
                          И не работает.
                          • K
                            K
                            kontakter
                            #193
                            Методом перебора, за час выяснил : пользователь pi, пароль raspberry. Это для образа http://www.iobroker.net/?download=2895 . Для других не знаю.
                            • BluefoxB
                              #194
                              @fotya:
                              Захожу под "root"
                              v5.7.1
                              root@pi ~ # npm -v
                              3.6.0
                              дальше -````
                              $ cd /opt
                              $ mkdir iobroker
                              $ cd iobroker
                              ! /opt/iobroker
                              ! └─┬ yargs@4.2.0
                              ! ├─┬ cliui@3.1.0
                              ! │ └─┬ lcid@1.0.0
                              ! ├── y18n@3.2.0
                              И не работает. `
                              node 5 не работает. Надо 4 ставить
                              • BluefoxB
                                #195
                                @fotya:
                                Захожу под "root"
                                v5.7.1
                                root@pi ~ # npm -v
                                3.6.0
                                дальше -````
                                $ cd /opt
                                $ mkdir iobroker
                                $ cd iobroker
                                ! /opt/iobroker
                                ! └─┬ yargs@4.2.0
                                ! ├─┬ cliui@3.1.0
                                ! │ └─┬ lcid@1.0.0
                                ! ├── y18n@3.2.0
                                И не работает. `
                                http://stackoverflow.com/questions/1813 … -run-in-wd
                                If npm was invoked with root privileges, then it will change the uid to the user account or uid specified by the user config, which defaults to nobody. Set the unsafe-perm flag to run scripts with root privileges.
                                [sudo] npm install --unsafe-perm
                                • F
                                  F
                                  fotya
                                  #196
                                  Ура заработало!
                                  Изменил строку:
                                  curl -sL https://deb.nodesource.com/setup_5.x | sudo -E bash -
                                  ````на
                                  curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
                                  и установка так :
                                  npm install iobroker --unsafe-perm
                                  и заработало ,но нет автозапуска. Только через - iobroker start
                                  • H
                                    H
                                    Haus
                                    #197
                                    @fotya:
                                    Ура заработало!
                                    Изменил строку:
                                    ````на
                                    и установка так :
                                    и заработало ,но нет автозапуска. Только через - iobroker start `
                                    Сделай /etc/init.d/iobroker.sh start
                                    admin: 3.6.0
                                    javascript: 4.1.10
                                    cloud: 2.6.2
                                    • F
                                      F
                                      fotya
                                      #198
                                      zsh: Отказано в доступе: /etc/init.d/iobroker.sh
                                      вот так.
                                      • BluefoxB
                                        #199
                                        @fotya:
                                        вот так. `
                                        sudo /etc/init.d/iobroker.sh start
                                        • F
                                          F
                                          fotya
                                          #200
                                          Теперь вот такое выдает.
                                          root@pi ~ # sudo /etc/init.d/iobroker.sh start
                                          sudo will not execute and completion _sudo exists.
                                          Может куда принудительно строку добавить?
