  4. Samsung TV mittels Samsung Titzen Instanz nutzen
    apollon77A
28 Beiträge 3 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • NegaleinN Negalein
    @mico sagte in Samsung TV mittels Samsung Titzen Instanz nutzen:
    So grün ist die Instanz wie steuere ich denn nun z.B. Plex oder Disney usw.
    da fehlt einiges.
    was sagt das Log?
    M
    M
    Mico
    @negalein
    Da scheint er wohl kein Gerät zu Entdecken
    2025-07-11 19:22:52.752  - info: host.raspberrypi5 "system.adapter.smartthings.0" disabled
    2025-07-11 19:22:52.752  - info: host.raspberrypi5 stopInstance system.adapter.smartthings.0 (force=false, process=true)
    2025-07-11 19:22:52.755  - info: smartthings.0 (27065) Got terminate signal TERMINATE_YOURSELF
    2025-07-11 19:22:52.822  - info: host.raspberrypi5 stopInstance system.adapter.smartthings.0 send kill signal
    2025-07-11 19:22:52.875  - info: host.raspberrypi5 stopInstance system.adapter.smartthings.0 (force=false, process=true)
    2025-07-11 19:22:52.876  - info: smartthings.0 (27065) terminating
    2025-07-11 19:22:52.877  - info: smartthings.0 (27065) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-07-11 19:22:52.878  - info: smartthings.0 (27065) Got terminate signal TERMINATE_YOURSELF
    2025-07-11 19:22:52.917  - info: host.raspberrypi5 stopInstance system.adapter.smartthings.0 send kill signal
    2025-07-11 19:22:53.257  - info: smartthings.0 (27065) terminating
    2025-07-11 19:22:53.464  - info: host.raspberrypi5 instance system.adapter.smartthings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-07-11 19:22:53.878  - info: host.raspberrypi5 "system.adapter.smartthings.0" enabled
    2025-07-11 19:22:54.284  - info: host.raspberrypi5 instance system.adapter.smartthings.0 in version "0.2.2" (non-npm: TA2k/ioBroker.smartthings#b055221990231cf4c8b7fbfd6bee94ff59b0fd75) started with pid 27418
    2025-07-11 19:22:55.181  - info: smartthings.0 (27418) starting. Version 0.2.2 (non-npm: TA2k/ioBroker.smartthings#b055221990231cf4c8b7fbfd6bee94ff59b0fd75) in /opt/iobroker/node_modules/iobroker.smartthings, node: v20.19.3, js-controller: 7.0.6
    2025-07-11 19:22:55.201  - info: smartthings.0 (27418) Use existing session to login
    2025-07-11 19:22:55.602  - info: smartthings.0 (27418) 0 devices detected
    Mico
    • M Mico
      @negalein
      Mico
      M
      M
      Mico
      schrieb am zuletzt editiert von Mico
      Nochmals zur Überprüfung "Firefox Browser" ich habe den roten Link angeklickt mich mit meiner Mail Adresse eingelockt und die F12 Taste gedrückt.
      und dieses Kopiert
      • M Mico
        und dieses Kopiert
        NegaleinN
        NegaleinN
        Negalein
        das passt.
        Hast du die Smartthings-App am Handy? Siehst du dort deinen TV?
        ° Fixer ---> iob fix
          das passt.
          M
          M
          Mico
          @negalein
          Nein die habe ich nicht werde ich gleich versuchen zu installieren.
          D 2 Antworten Letzte Antwort
          • M Mico
            @negalein
            D
            D
            denjo
            @mico das ist ja auch die voraussetzen die app zu haben und den tv dort rein zu machen.
            • M Mico
              @negalein
              D
              D
              denjo
              @mico du solltest dir mal ein paar Videos zu iobroker bei Youtube rein ziehen, bissl grund wissen kann nicht schaden.
              • D denjo
                M
                M
                Mico
                @denjo
                Das hat geklappt der Fernseher wird mit Objekten im Iobroker angezeigt!
                Und wenn ich nun Plex oder Disney direkt einschalten möchte muß ich ein Blockly Script dafür nutzen? welches Objekt wäre denn zu schalten und wie?
                • M Mico
                  @denjo
                  D
                  D
                  denjo
                  @mico weiß ich ausn kopf nicht, ausprobieren am besten. Ist mit sicherheit ein nicht schreib geschütztes Objekt, da gibt es nicht als so viele.
                  84.0k
                  1.4m
