  4. [gelöst]SONOFF ZigBee 3.0 wird n. in Zigbee eingebunden
    6.7k
11 Beiträge 4 Kommentatoren 985 Aufrufe 4 Beobachtet
  • H Offline
    Högi
    schrieb am zuletzt editiert von Högi
    *** BASE SYSTEM ***
     Static hostname: raspberrypi64bitbookworm
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:35:21 up 59 min,  2 users,  load average: 0.23, 0.20, 0.27
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-05-22 20:35:21 CEST
               Universal time: Thu 2025-05-22 18:35:21 UTC
                     RTC time: Thu 2025-05-22 18:35:21
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    josef
    HOME=/home/josef
    GROUPS=josef adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        2.2G        1.3G        6.3M        554M        1.8G
    Swap:           536M          0B        536M
    Total:          4.5G        2.2G        1.8G
    Active iob-Instances:   23
             3791 M total memory
             2097 M used memory
             2147 M active memory
              256 M inactive memory
             1243 M free memory
               50 M buffer memory
              478 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 20:35:22 up 59 min,  2 users,  load average: 0.23, 0.20, 0.27
    Tasks: 235 total,   1 running, 234 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.4 total,   1243.5 free,   2097.5 used,    529.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1694.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  6.0M  374M   2% /run
    /dev/mmcblk0p2 ext4       59G  7.1G   49G  13% /
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   57M  454M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Thu May 22 19:35:30 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:1C:58:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=3907a7b3-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu May 22 19:35:31 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
    [Thu May 22 19:35:33 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    861M    /var/lib
    684M    /var/lib/piVCCU3
    617M    /var/lib/piVCCU3/rootfs
    288M    /var/lib/piVCCU3/rootfs/opt
    Archived and active journals take up 4.7M in the file system.
    /opt/iobroker/backups:
    1.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    924M    /opt/iobroker/iobroker-data/
    836M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.2
    /usr/bin/node           v20.19.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.19.2-1nodesource1
      Version table:
     *** 20.19.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
         18.19.0+dfsg-6~deb12u1 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi64bitbookworm raspberrypi64bitbookworm (version: 7.0.6, hostname: raspberrypi64bitbookworm, alive, uptime: 3591)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi64bitbookworm                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
    + system.adapter.iot.0                    : iot                   : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi64bitbookworm                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi64bitbookworm                 -  enabled, port: 8087, bind: 192.168.178.150, run as: admin
    + system.adapter.sureflap.0               : sureflap              : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.telegram.0               : telegram              : raspberrypi64bitbookworm                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi64bitbookworm                 -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi64bitbookworm                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspberrypi64bitbookworm                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sureflap"     : 3.1.1    , installed 3.1.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        13034
    States:         10197
    Hit:2 http://phoscon.de/apt/deconz generic InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          6464       912/dnsmasq
    tcp        0      0 192.168.178.21:8701     0.0.0.0:*               LISTEN      1001       9054       2223/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7782       1800/io.shelly.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6228       637/sshd: /usr/sbin
    tcp        0      0 192.168.178.21:2010     0.0.0.0:*               LISTEN      1001       10540      2287/io.hm-rpc.2
    tcp        0      0 192.168.178.21:42001    0.0.0.0:*               LISTEN      1001       9439       2202/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5437       625/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6247       625/iobroker.js-con
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6124       2010/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6307       687/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6230       637/sshd: /usr/sbin
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          6463       912/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          6460       912/dnsmasq
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       7786       1679/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       7787       1679/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       8263       960/io.broadlink2.0
    udp        0      0 0.0.0.0:33798           0.0.0.0:*                           104        6174       503/avahi-daemon: r
    udp        0      0 0.0.0.0:46187           0.0.0.0:*                           1001       8287       960/io.broadlink2.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6172       503/avahi-daemon: r
    udp        0      0 0.0.0.0:44317           0.0.0.0:*                           1001       7465       960/io.broadlink2.0
    udp6       0      0 :::40622                :::*                                104        6175       503/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6173       503/avahi-daemon: r
    2025-05-22 20:18:28.783  - info: zigbee.0 (5204) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
    2025-05-22 20:18:28.785  - info: zigbee.0 (5204) Starting Zigbee-Herdsman
    2025-05-22 20:18:55.193  - info: zigbee.0 (5204) Unable to obtain herdsman settings
    2025-05-22 20:18:55.345  - error: zigbee.0 (5204) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    2025-05-22 20:18:55.347  - error: zigbee.0 (5204) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-05-22 20:18:55.348  - error: zigbee.0 (5204) unhandled promise rejection: undefined
    2025-05-22 20:18:55.349  - error: zigbee.0 (5204) undefined
    2025-05-22 20:18:55.403  - info: zigbee.0 (5204) cleaned everything up...
    2025-05-22 20:18:55.405  - info: zigbee.0 (5204) local config saved
    2025-05-22 20:18:55.408  - info: zigbee.0 (5204) Saved local configuration data
    2025-05-22 20:18:55.409  - info: zigbee.0 (5204) terminating
    2025-05-22 20:18:55.412  - warn: zigbee.0 (5204) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-05-22 20:18:55.423  - error: zigbee.0 (5204) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
        at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35)
        at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33)
        at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24)
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
    2025-05-22 20:18:55.427  - info: zigbee.0 (5204) terminating
    2025-05-22 20:18:55.914  - info: zigbee.0 (5204) terminating
    2025-05-22 20:18:56.099  - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-05-22 20:18:56.100  - error: host.raspberrypi64bitbookworm Caught by controller[0]: Error herdsman start
    2025-05-22 20:18:56.100  - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-05-22 20:18:56.100  - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
    2025-05-22 20:18:56.100  - warn: host.raspberrypi64bitbookworm Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    vorab bitte ich um ein etwas Nachsicht, da ich auf die 70 zugehe und was
    Linux angeht einfach copy und paste Laie bin.
    Ich betreibe meine Hausautomation mit Iobroker und PVICCU3.
    Ich habe mein System neu aufsetzen müssen (10 Jahre lief alles sehr gut auch mit root rechten) und habe soweit alles wieder am laufen. Bin auf einen PI 4 umgezogen.
    Einzig am verzweifeln bin ich an der Einbindung von meines neuen SONOFF ZigBee 3.0 USB DONGLE PLUS in den Adapter zigbee.
    Nach der Eingabe (siehe Bild)
    bleibt der Adapter auf gelb und die Fehlermeldungen (siehe iob diag) erscheinen.
    Habe schon im Netz alles an Vorschlägen etc. probiert aber ich komme nicht weiter.
    Habe es auch mit einem Conbee2 versucht aber auch das ging nicht.
    Vielleicht liest ja Thomas Braun mit, von dem ich dank seiner Expertise viel gelernt habe 👍
    Ich glaube das Problem hängt mit der Installation von PVICCU3 zusammen.
    Auf github (https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md)
    musste ich bei der Installation Raspbarry PI unter Punkt 8 die alte Methode zur Netzwerkkonfiguration ändern mit folgenden Befehlen:
    sudo nmcli connection show --active
    sudo apt install bridge-utils
    sudo nmcli connection add ifname br0 type bridge con-name br0
    sudo nmcli connection add type bridge-slave ifname eth0 master br0
    Vielleicht wird hier etwas geblockt.
    Ich hoffe Ihr könnt mir helfen.
    Danke im Voraus
    Jupp
    P.S
    Da meine Frau nicht mehr so fit ist, muss ich sagen, das der Alltag mit Alexa und Sprachsteuerung uns das Leben viel einfacher macht.
    Und das ist auch vielleicht mal ein Thema. Wenn mir z.b. mal was passiert und das System
    stürzt ab und nichts geht mehr was dann?
    Ich habe eine Dokumentation mit allen Passwörtern meiner Frau übergeben,
    und einen mir bekannten Ansprechpartner, der sich auskennt, der dann aushelfen muss.
    Das mal zum Nachdenken für die jüngere Generation.
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @högi
      • du musst unbedingt die panID anpassen - die ist so nicht gut. (16 stellige zahl, nicht 16 mal D
      • mach bitte folgendes:
        — zigbee Adapter anhalten
        — iobroker log löschen
        — zigbee Adapter starten
        — 120 Sekunden (plus/minus ein paar Sekunden ) warten.
        — log herunter laden
        — das herunter geladene log hier in code-tags posten.
      A.
      H 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        @högi
        A.
        Högi
        @asgothian
        hier die Ausgabe vom log.
        2025-05-22 22:05:30.312 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 13269
        2025-05-22 22:05:34.282 - info: zigbee.0 (13269) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        2025-05-22 22:05:34.312 - info: zigbee.0 (13269) init localConfig
        2025-05-22 22:05:34.323 - info: zigbee.0 (13269) --> transmitPower : normal
        2025-05-22 22:05:34.339 - info: zigbee.0 (13269) delete old Backup files. keep only last 10
        2025-05-22 22:05:34.344 - info: zigbee.0 (13269) --- creating device debug ---
        2025-05-22 22:05:34.346 - info: zigbee.0 (13269) Starting Adapter npm ...
        2025-05-22 22:05:34.404 - info: zigbee.0 (13269) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        2025-05-22 22:05:34.406 - info: zigbee.0 (13269) Starting Zigbee-Herdsman
        2025-05-22 22:05:48.281 - info: host.raspberrypi64bitbookworm "system.adapter.zigbee.0" disabled
        2025-05-22 22:05:48.286 - info: host.raspberrypi64bitbookworm stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2025-05-22 22:05:48.294 - info: zigbee.0 (13269) Got terminate signal TERMINATE_YOURSELF
        2025-05-22 22:05:48.298 - info: zigbee.0 (13269) cleaned everything up...
        2025-05-22 22:05:48.299 - info: zigbee.0 (13269) local config saved
        2025-05-22 22:05:48.301 - info: zigbee.0 (13269) Saved local configuration data
        2025-05-22 22:05:48.302 - info: zigbee.0 (13269) terminating
        2025-05-22 22:05:48.304 - info: zigbee.0 (13269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-05-22 22:05:48.405 - error: zigbee.0 (13269) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
        2025-05-22 22:05:48.416 - info: zigbee.0 (13269) terminating
        2025-05-22 22:05:48.452 - info: host.raspberrypi64bitbookworm stopInstance system.adapter.zigbee.0 send kill signal
        2025-05-22 22:05:48.806 - info: zigbee.0 (13269) terminating
        2025-05-22 22:05:48.982 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-05-22 22:12:25.154 - info: admin.0 (687) ==> Connected system.user.admin from ::ffff:192.168.178.102
        2025-05-22 22:17:25.242 - info: admin.0 (687) <== Disconnect system.user.admin from ::ffff:192.168.178.102
        2025-05-22 22:18:55.896 - info: host.raspberrypi64bitbookworm "system.adapter.zigbee.0" enabled
        2025-05-22 22:18:57.325 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14090
        2025-05-22 22:19:01.371 - info: zigbee.0 (14090) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        2025-05-22 22:19:01.402 - info: zigbee.0 (14090) init localConfig
        2025-05-22 22:19:01.412 - info: zigbee.0 (14090) --> transmitPower : normal
        2025-05-22 22:19:01.429 - info: zigbee.0 (14090) delete old Backup files. keep only last 10
        2025-05-22 22:19:01.433 - info: zigbee.0 (14090) --- creating device debug ---
        2025-05-22 22:19:01.436 - info: zigbee.0 (14090) Starting Adapter npm ...
        2025-05-22 22:19:01.492 - info: zigbee.0 (14090) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        2025-05-22 22:19:01.494 - info: zigbee.0 (14090) Starting Zigbee-Herdsman
        2025-05-22 22:19:24.177 - info: admin.0 (687) ==> Connected system.user.admin from ::ffff:192.168.178.102
        2025-05-22 22:19:24.473 - error: zigbee.0 (14090) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-05-22 22:19:24.475 - error: zigbee.0 (14090) unhandled promise rejection: Cannot read properties of undefined (reading 'CleanupRequired')
        2025-05-22 22:19:24.804 - error: zigbee.0 (14090) TypeError: Cannot read properties of undefined (reading 'CleanupRequired')
        at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97)
        at Zigbee. (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48)
        at Zigbee.emit (node:events:536:35)
        at Zigbee.emit (node:domain:489:12)
        at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34)
        at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37)
        at processImmediate (node:internal/timers:483:21)
        2025-05-22 22:19:24.805 - error: zigbee.0 (14090) Cannot read properties of undefined (reading 'CleanupRequired')
        2025-05-22 22:19:24.865 - info: zigbee.0 (14090) cleaned everything up...
        2025-05-22 22:19:24.866 - info: zigbee.0 (14090) local config saved
        2025-05-22 22:19:24.868 - info: zigbee.0 (14090) Saved local configuration data
        2025-05-22 22:19:24.869 - info: zigbee.0 (14090) terminating
        2025-05-22 22:19:24.873 - warn: zigbee.0 (14090) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-05-22 22:19:24.920 - error: zigbee.0 (14090) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
        2025-05-22 22:19:24.927 - info: zigbee.0 (14090) terminating
        2025-05-22 22:19:25.007 - info: zigbee.0 (14090) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"2e3882639474ef11b58fd08c8fcc3fa0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"}]
        2025-05-22 22:19:25.382 - info: zigbee.0 (14090) terminating
        2025-05-22 22:19:25.562 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'CleanupRequired')
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97)
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee. (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48)
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee.emit (node:events:536:35)
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee.emit (node:domain:489:12)
        2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34)
        2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37)
        2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at processImmediate (node:internal/timers:483:21)
        2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-05-22 22:19:25.564 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
        2025-05-22 22:19:56.435 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14168
        2025-05-22 22:20:00.397 - info: zigbee.0 (14168) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        2025-05-22 22:20:00.428 - info: zigbee.0 (14168) init localConfig
        2025-05-22 22:20:00.441 - info: zigbee.0 (14168) --> transmitPower : normal
        2025-05-22 22:20:00.460 - info: zigbee.0 (14168) delete old Backup files. keep only last 10
        2025-05-22 22:20:00.465 - info: zigbee.0 (14168) --- creating device debug ---
        2025-05-22 22:20:00.467 - info: zigbee.0 (14168) Starting Adapter npm ...
        2025-05-22 22:20:00.542 - info: zigbee.0 (14168) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        2025-05-22 22:20:00.544 - info: zigbee.0 (14168) Starting Zigbee-Herdsman
        2025-05-22 22:20:26.959 - info: zigbee.0 (14168) Unable to obtain herdsman settings
        2025-05-22 22:20:27.179 - error: zigbee.0 (14168) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
        2025-05-22 22:20:27.181 - error: zigbee.0 (14168) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-05-22 22:20:27.182 - error: zigbee.0 (14168) unhandled promise rejection: undefined
        2025-05-22 22:20:27.183 - error: zigbee.0 (14168) undefined
        2025-05-22 22:20:27.240 - info: zigbee.0 (14168) cleaned everything up...
        2025-05-22 22:20:27.241 - info: zigbee.0 (14168) local config saved
        2025-05-22 22:20:27.243 - info: zigbee.0 (14168) Saved local configuration data
        2025-05-22 22:20:27.244 - info: zigbee.0 (14168) terminating
        2025-05-22 22:20:27.247 - warn: zigbee.0 (14168) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-05-22 22:20:27.256 - error: zigbee.0 (14168) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
        2025-05-22 22:20:27.263 - info: zigbee.0 (14168) terminating
        2025-05-22 22:20:27.749 - info: zigbee.0 (14168) terminating
        2025-05-22 22:20:27.965 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2025-05-22 22:20:27.966 - error: host.raspberrypi64bitbookworm Caught by controller[1]: Error herdsman start
        2025-05-22 22:20:27.967 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-05-22 22:20:27.967 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
        2025-05-22 22:20:58.998 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14246
        2025-05-22 22:20:59.706 - info: admin.0 (687) <== Disconnect system.user.admin from ::ffff:192.168.178.102
        2025-05-22 22:21:03.058 - info: zigbee.0 (14246) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        2025-05-22 22:21:03.090 - info: zigbee.0 (14246) init localConfig
        2025-05-22 22:21:03.100 - info: zigbee.0 (14246) --> transmitPower : normal
        2025-05-22 22:21:03.116 - info: zigbee.0 (14246) delete old Backup files. keep only last 10
        2025-05-22 22:21:03.122 - info: zigbee.0 (14246) --- creating device debug ---
        2025-05-22 22:21:03.123 - info: zigbee.0 (14246) Starting Adapter npm ...
        2025-05-22 22:21:03.181 - info: zigbee.0 (14246) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        2025-05-22 22:21:03.184 - info: zigbee.0 (14246) Starting Zigbee-Herdsman
        2025-05-22 22:21:29.603 - info: zigbee.0 (14246) Unable to obtain herdsman settings
        2025-05-22 22:21:29.785 - error: zigbee.0 (14246) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
        2025-05-22 22:21:29.788 - error: zigbee.0 (14246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-05-22 22:21:29.789 - error: zigbee.0 (14246) unhandled promise rejection: undefined
        2025-05-22 22:21:29.790 - error: zigbee.0 (14246) undefined
        2025-05-22 22:21:29.852 - info: zigbee.0 (14246) cleaned everything up...
        2025-05-22 22:21:29.854 - info: zigbee.0 (14246) local config saved
        2025-05-22 22:21:29.856 - info: zigbee.0 (14246) Saved local configuration data
        2025-05-22 22:21:29.857 - info: zigbee.0 (14246) terminating
        2025-05-22 22:21:29.859 - warn: zigbee.0 (14246) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-05-22 22:21:29.867 - error: zigbee.0 (14246) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
        2025-05-22 22:21:29.875 - info: zigbee.0 (14246) terminating
        2025-05-22 22:21:30.363 - info: zigbee.0 (14246) terminating
        2025-05-22 22:21:30.561 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2025-05-22 22:21:30.562 - error: host.raspberrypi64bitbookworm Caught by controller[0]: Error herdsman start
        2025-05-22 22:21:30.563 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-05-22 22:21:30.563 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
        2025-05-22 22:21:30.563 - warn: host.raspberrypi64bitbookworm Do not restart adapter system.adapter.zigbee.0 because restart loop detected
        Die pan id habe ich geändert: 1437834385923494
        @högi So ich habe jetzt noch folgendes probiert.
        1.) aktuelle Firmware auf den Sonoff coordinator aufgespielt.
        2.) Kpl neu raspberry pi os lite (64bit) Debian Bookworm aufgesetzt und
        Iobroker mit : curl -sSLf https://iobroker.net/install.sh | bash -
        installiert.
        3.) Zigbee Adapter 2.0.5 installiert.
        4.) Coordinator wird unter /dev/serial/by-id angezeigt:
        5.)Pan ID 16 stellig vergeben.
        6.) Zigbee Adapter Version 2.0.4 probiert.
        7.) USB 0,5 m Verlängerung benutzt
        8.)Raspberry USB 2.0 und USB 3.0 benutzt.
        Alles hat nichts geholfen. Instanz bleibt rot.
        Bin mit meinem Latein am Ende.😧
        • H Högi
          @asgothian
          installiert.
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @högi du musst schon systematisch vorgehen. Bei dem geposteten Log ist dieser Eintrag entscheidend:
          Dieses bedeutet das
          • die serielle Schnittstelle geöffnet wurde (erfolgreich)
          • keine Kommunikation zur Firmware entsteht.
          Genau das musst du dir bei den einzelnen Versuchen anschauen.
          Bevor du da aber loslegst, bitte noch einmal verifizieren :
          Bitte noch einmal verifizieren - hast du einen Sonoff Dongle P oder Dongle E (steht auf dem Gerät selber drauf.
          A.
            Dieses bedeutet das
            A.
            Högi
            @asgothian Ich habe den Sonoff Dongle P
            • H Högi
              arteckA Offline
              arteckA Offline
              arteck
              @högi sagte in SONOFF ZigBee 3.0 wird nicht in Iobroker Zigbee eingebunden:
              und welche Firmware hast du da aufgespielt.. zeigmal den link
              • arteckA arteck
                Högi
                @arteck
                Über diesen link:https://github.com/Koenkk/Z-Stack-firmware/blob/master/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20240710.zip
                Und nach dieser Anleitung die Firmware aufgespielt:
                https://haus-automatisierung.com/hardware/sonoff/2022/01/11/sonoff-zigbee-usb-dongle-plus.html
                • W Offline
                  W Offline
                  Walter Weiss
                  @Högi
                  das der Zigbee-Stick in Verbindung mit der pivccu3 nicht gefunden wurde, hat ich auch schon.
                  Bei mir hat der CUx-Daemon von der pivccu3 die USB-Schnittstelle für den Zigbee-Stick blockiert.
                  Dies kann man verhindern, wenn man in der Pivccu3-Oberfläche in der Systemsteuerung unter CUx-Daemon das Setup anwählt und dort am Ende folgenden Eintrag ergänzt:
                  TTYASSIGN=ttyACM0:NC
                  und das Setup dann speichert.
                  Danach alles neu starten.
                  Ich hoffe es hilft.
                  • W Walter Weiss
                    @Högi
                    Ich hoffe es hilft.
                    Högi
                    @walter-weiss Ich habe das auch probiert und es hat sich nichts geändert.
                    Hatte ja mal testweise System nur mit Iobroker aufgesetzt und der Stick ließ sich
                    auch nicht einbinden.
                    Ich habe den Stick über Amazon gekauft und in den Rezessionen gelesen, das
                    auch defekte Sticks auch ausgeliefert wurden.
                    Bekomme Montag einen neuen Stick.
                    Dann bin ich gespannt.
                    • H Högi
                      Högi
                      @högi
                      So Problem gelöst und danke an Walter Weiss.
                      Das mit dem CUx-Daemon von der pivccu3 hat mich zur Lösung geführt.
                      Aber zuvor, der erste Sonoff coordinator war wirklich kaputt.
                      Nach dem ich den neuen Sonoff Stick in die Zigbee Instanz einbinden wollte war die Enttäuschung groß und ich wollte schon allen hinschmeißen.
                      Als ich aber den CUx-Daemon von der pivccu3 gestoppt habe, siehe da
                      den Zigbee Adapter wurde grün.
                      Danach habe ich TTYASSIGN=ttyACM0:NC im CUx-Daemon eingetragen
                      aber das hat auch nicht funktioniert.
                      Danach TTYASSIGN=ttyttyUSB0 :NC eingetragen und alles läuft reibungslos.
                      Mein Gott schwere Geburt
                      Danke an Alle
                      W 1 Antwort Letzte Antwort
                      • H Högi
                        @högi
                        Danke an Alle
                        W Offline
                        W Offline
                        Walter Weiss
                        @högi
                        Entschuldigung, ich hätte noch darauf hinweisen sollen, dass auf unterschiedlichen Systemen die USB-Schnittstellen unterschiedlich benannt werden. ich poste nicht so oft. Aber wieder was dazugelernt. Aber schön dass es geklappt hat.
