  4. Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht
    1.0k
    6.1k
8 Beiträge 4 Kommentatoren 460 Aufrufe 3 Beobachtet
  • E Offline
    EndofPi
    Hallo, ich bin der Neue!
    Ich habe versucht den Node-Red Adapter über die Admin-GUI zu aktualisieren und
    leider keine Idee, was hier das Problem lösen könnte.
    • Adaptername: node-red
    • Link zu Adapterrepository: http://download.iobroker.net/sources-dist.json
    • Adapterversion: 4.0.3 -> 5.2.1
    • js-controller Version: 7.0.6
    • Admin Version: 7.4.10
    • Hardwaresystem: Pi3
    • Arbeitsspeicher: 8 GB
    • Festplattenart: SD-Karte
    • Betriebssystem: Raspbian GNU/Linux 11 (bullseye)
    • Nodejs-Version: 20.18.1
    • NPM-Version: 10.8.2
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: ...
    $ iobroker upgrade node-red@5.2.1 --debug
    Update node-red from @4.0.3 to @5.2.1
    NPM version: 10.8.2Installing iobroker.node-red@5.2.1... (System call)
    > bcrypt@5.1.1 install> node-pre-gyp install --fallback-to-build
    node-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@18.20.5 | linux | arm
    node-pre-gyp info check checked for "/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" (not found)
    node-pre-gyp http GET https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
    node-pre-gyp WARN Pre-built binaries not installable for bcrypt@5.1.1 and node@18.20.5 (node-v108 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
    gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@18.20.5 | linux | arm
    gyp info ok
    gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
    gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/bcrypt/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.5/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.5',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.5/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bcrypt',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
    gyp info ok
    gyp info spawn make
    gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    make: Verzeichnis „/opt/iobroker/node_modules/bcrypt/build“ wird betreten
    CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
    make: cc: Keine Berechtigung
    make: *** [../node-addon-api/nothing.target.mk:107: Release/obj.target/nothing/../node-addon-api/nothing.o] Fehler 127make: Verzeichnis „/opt/iobroker/node_modules/bcrypt/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
    gyp ERR! System Linux 6.1.21-v8+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=3" "--node_napi_label=napi-v3"gyp ERR! cwd /opt/iobroker/node_modules/bcryptgyp ERR! node -v v18.20.5gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3 --napi_version=9 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:517:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1098:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:303:5)
    node-pre-gyp ERR! System Linux 6.1.21-v8+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/bcryptnode-pre-gyp ERR! node -v v18.20.5node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3 --napi_version=9 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)
    npm error code 1
    npm error path /opt/iobroker/node_modules/bcryptnpm error command failednpm error command sh -c node-pre-gyp install --fallback-to-build
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-18T09_32_23_658Z-debug-0.log
    Updating objects from io-package.json for adapter "node-red" with version "4.0.3"
    upload [15] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/j
    son
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    Process exited with code 0
    HomoranH mickymM 2 Antworten Letzte Antwort
    • E EndofPi
      gyp info ok
      gyp info ok
      gyp info spawn make
      npm error code 1
      son
      @endofpi ob das ein Bug ist werden wir sehen.
      Auf jeden Fall passt schon mal
      @endofpi sagte in Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht:
      nicht zu
      bitte iob diag in der Langfassung posten
      EDIT:
      Da du einen Raspi verwendest bitte dafür diese drei Befehle nutzen
      curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
      chmod 744 iob_diag.sh
      ./iob_diag.sh
      • E Offline
        EndofPi
        Hallo Homoran,
        die manuell eingetragene Versionsinfo zu Nodejs-Version hatte ich aus dem hosts-Reiter von iobroker abgeschrieben, der Unterschied zum Update-Script ist mir aber nicht aufgefallen.
        Nachfolgend die Zusammenfassung aus dem Shellscript:
        			v.2024-12-09 Raspbian+zigbee diag+masking
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		32 bit
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        Display-Server: 	false
        Boot Target: 		multi-user.target
        Pending OS-Updates: 	0
        Pending iob updates: 	1
        Nodejs-Installation:
        /usr/bin/nodejs 	v20.18.1
        /usr/bin/node 		v20.18.1
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.29.4
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            7.8G        520M        3.1G        1.0M        4.2G        7.2G
        Swap:            99M          0B         99M
        Total:          7.9G        520M        3.2G
        Active iob-Instances: 	8
        Upgrade policy: none
        ioBroker Core: 		js-controller 		7.0.6
        			admin 			7.4.10
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.44 (SSL), run as: admin
          system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 192.168.178.44, run as: admin
        Objects: 		2169
        States: 		1710
        Size of iob-Database:
        12M	/opt/iobroker/iobroker-data/objects.jsonl
        9.8M	/opt/iobroker/iobroker-data/states.jsonl
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          @endofpi
          Komisch ist dass er offensichtlich nicht auf den cc Kompiler zugreifen kann:
          (in Zeile 20)
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • mcm1957M mcm1957
            @endofpi
            (in Zeile 20)
            @mcm1957 sagte in Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht:
            ist nicht meine Kragenweite, hab ich geflissentlich ignoriert.
            Da mehrfach node v18 im log erwähnt wird, ist sowieso anscheinend einiges schief.
            Bestenfalls zwei node Installationen parallel
            • E Offline
              EndofPi
              18.20.5 dürfte die default-version aus Raspbian sein.
              Auf Grund des Fehlers mit Node-Red habe ich versucht durch ein manuelles Upgrade mittels
              iob nodejs-update
              das Problem zu lösen. Das Problem mit dem Adapter bestand aber auch vorher.
              • E EndofPi
                iob nodejs-update
                Raspbian sollte kein eigenes nodejs mitbringen!
                d.h. wir bekommen keine Langfassung von iob diag mehr, die den Zeitpunkt des logs widerspiegelt?
                bitte lesen:
                • E EndofPi
                  gyp info ok
                  gyp info ok
                  gyp info spawn make
                  npm error code 1
                  son
                  mickymM Offline
                  mickymM Offline
                  mickym
                  upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript Process exited with code 0
                  Mal blöd gefragt - bist Du Dir denn sicher, dass das nicht funktioniert hat. - Vielleicht nur ein Browserrefresh. Der Prozess endet mit RC = 0 und das heißt, dass alles geklappt hat.
