  4. [HOW-TO] backitup Konfiguration mit nfs
backitup nasiob nfs bookworm
61 Beiträge 3 Kommentatoren 7.5k Aufrufe 3 Beobachtet
    @norbert999
    iobroker start
    sowie
    systemctl status iobroker
    sagen?
    N Offline
    N Offline
    norbert999
    @thomas-braun said in [HOW-TO] backitup Konfiguration mit nfs:
    pi@raspi5:~ $ iobroker start
    -bash: iobroker: command not found
    pi@raspi5:~ $ systemctl status iobroker
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
         Active: active (running) since Tue 2025-01-14 17:05:13 CET; 15h ago
           Docs: http://iobroker.net
       Main PID: 1220 (iobroker.js-con)
          Tasks: 220 (limit: 9564)
            CPU: 1h 27min 5.187s
         CGroup: /system.slice/iobroker.service
                 ├─1220 iobroker.js-controller
                 ├─1698 io.admin.0
                 ├─1739 io.javascript.0
                 ├─2336 io.nut.0
                 ├─2397 io.snmp.0
                 ├─2415 io.snmp.1
                 ├─2433 io.tr-064.0
                 ├─2452 io.backitup.0
                 ├─2467 io.hm-rpc.0
                 ├─2474 io.hm-rega.0
                 ├─2492 io.hm-rpc.1
                 ├─2515 io.discovery.0
                 ├─2526 io.web.0
                 ├─2541 io.fronius-solarweb.0
                 ├─2552 io.trashschedule.0
                 ├─2559 io.pi-hole.0
                 ├─2569 io.energiefluss-erweitert.0
                 ├─2664 io.vis-2.0
                 ├─3519 io.pushover.0
                 └─3546 io.fronius-wattpilot.0
    Jan 15 07:12:13 raspi5 sudo[22204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Jan 15 07:12:13 raspi5 sudo[22204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Jan 15 07:12:14 raspi5 sudo[22204]: pam_unix(sudo:session): session closed for user root
    Jan 15 08:17:14 raspi5 bash[1220]: Send diag info: {"uuid":"6314d3b3-71c3-1ccc-c873-938803957853","language":"de","country":"Germany","hosts":[{"version":"7.0.6","platform":"Javascript/Nod>
    Jan 15 08:17:14 raspi5 sudo[29199]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
    Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Jan 15 08:17:14 raspi5 sudo[29199]: pam_unix(sudo:session): session closed for user root
    Jan 15 08:17:14 raspi5 sudo[29204]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
    Jan 15 08:17:14 raspi5 sudo[29204]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Jan 15 08:17:15 raspi5 sudo[29204]: pam_unix(sudo:session): session closed for user root
    • N norbert999
                   ├─1698 io.admin.0
                   ├─2336 io.nut.0
                   ├─2397 io.snmp.0
                   ├─2415 io.snmp.1
                   ├─2433 io.tr-064.0
                   ├─2467 io.hm-rpc.0
                   ├─2474 io.hm-rega.0
                   ├─2492 io.hm-rpc.1
                   ├─2526 io.web.0
                   ├─2559 io.pi-hole.0
                   ├─2664 io.vis-2.0
      @norbert999
      Jag den Fixer mal über das System. Musst du aber wohl dann direkt aus dem Netz ziehen, wenn 'iobroker' und 'iob' nicht direkt aufrufbar sind.
      Ich meine @Homoran hat den Befehl dazu in der Signatur.
      HomoranH N 2 Antworten Letzte Antwort
        @norbert999
        @thomas-braun sagte in [HOW-TO] backitup Konfiguration mit nfs:
        hat er!
        wenn der noch passt
          @norbert999
          N Offline
          N Offline
          norbert999
          pi@raspi5:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
          Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
          library: loaded
          Library version=2024-10-22
          ioBroker or some processes are still running:
          1698 io.admin.0
          2336 io.nut.0
          2397 io.snmp.0
          2415 io.snmp.1
          2433 io.tr-064.0
          2452 io.backitup.0
          2467 io.hm-rpc.0
          2474 io.hm-rega.0
          2492 io.hm-rpc.1
          2515 io.discovery.0
          2526 io.web.0
          2559 io.pi-hole.0
          2664 io.vis-2.0
          3519 io.pushover.0
          Please stop them first and try again!
          pi@raspi5:~ $ ^C
          pi@raspi5:~ $
          Wie stoppe ich das alles? Alle iob Instanzen anhalten, oder wie?
          • N norbert999
            library: loaded
            1698 io.admin.0
            2336 io.nut.0
            2397 io.snmp.0
            2415 io.snmp.1
            2433 io.tr-064.0
            2452 io.backitup.0
            2467 io.hm-rpc.0
            2474 io.hm-rega.0
            2492 io.hm-rpc.1
            2515 io.discovery.0
            2526 io.web.0
            2559 io.pi-hole.0
            2664 io.vis-2.0
            3519 io.pushover.0
            pi@raspi5:~ $ ^C
            pi@raspi5:~ $
            @norbert999 sagte in [HOW-TO] backitup Konfiguration mit nfs:
            iob stop in der Konsole
            N 1 Antwort Letzte Antwort
              N Offline
              N Offline
              norbert999
              @homoran said in [HOW-TO] backitup Konfiguration mit nfs:
              pi@raspi5:~ $ sudo iob stop
              sudo: iob: command not found
              pi@raspi5:~ $
              Geht nicht.
              • N norbert999
                pi@raspi5:~ $
                Geht nicht.
                @norbert999 wer hat was von sudo gesagt?
                Niemals Befehle mit iob... mit sudo anfassen
                  N Offline
                  N Offline
                  norbert999
                  @homoran Verstanden. Aber auch ohne sudo dasgleiche Resultat.
                  • N norbert999
                    Dann ist da richtig was faul
                    was sagt iob status?
                      N Offline
                      N Offline
                      norbert999
                      pi@raspi5:~ $ iob status
                      -bash: iob: command not found
                      pi@raspi5:~ $
                      • N norbert999
                        pi@raspi5:~ $
                        @norbert999 du bist wirklich auf dem pi, auf dem iob installiert ist?
                          dann müsste dir @Thomas-Braun mal die richtige Syntax von sudo systemctl status iobroker sagen.
                          ich weiß nicht ob das so passt
                            N Offline
                            N Offline
                            norbert999
                            Ganz sicher!
                                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                                 Active: active (running) since Wed 2025-01-15 09:40:52 CET; 2min 14s ago
                               Main PID: 1261 (iobroker.js-con)
                                    CPU: 1min 2.054s
                                         ├─1261 iobroker.js-controller
                                         ├─1741 io.admin.0
                                         ├─2271 io.javascript.0
                                         ├─2411 io.nut.0
                                         ├─2432 io.snmp.0
                                         ├─2447 io.snmp.1
                                         ├─2462 io.tr-064.0
                                         ├─2469 io.backitup.0
                                         ├─2496 io.hm-rpc.0
                                         ├─2514 io.hm-rega.0
                                         ├─2529 io.hm-rpc.1
                                         ├─2544 io.discovery.0
                                         ├─2559 io.web.0
                                         ├─2566 io.fronius-solarweb.0
                                         ├─2585 io.trashschedule.0
                            lines 1-23
                            • N norbert999
                              Ganz sicher!
                                      CPU: 1min 2.054s
                                           ├─1741 io.admin.0
                                           ├─2411 io.nut.0
                                           ├─2432 io.snmp.0
                                           ├─2447 io.snmp.1
                                           ├─2462 io.tr-064.0
                                           ├─2496 io.hm-rpc.0
                                           ├─2514 io.hm-rega.0
                                           ├─2529 io.hm-rpc.1
                                           ├─2559 io.web.0
                              lines 1-23
                              @norbert999 wenn der staus klappt, dann mach sudo systemctl stop iobroker
                              • N norbert999
                                Ganz sicher!
                                        CPU: 1min 2.054s
                                             ├─1741 io.admin.0
                                             ├─2411 io.nut.0
                                             ├─2432 io.snmp.0
                                             ├─2447 io.snmp.1
                                             ├─2462 io.tr-064.0
                                             ├─2496 io.hm-rpc.0
                                             ├─2514 io.hm-rega.0
                                             ├─2529 io.hm-rpc.1
                                             ├─2559 io.web.0
                                lines 1-23
                                N Offline
                                N Offline
                                norbert999
                                @norbert999
                                Sorry, hatte nicht die vollständige Ausgabe kopiert. Jetzt richtig, untenstehen die Fehlermeldungen
                                     Active: active (running) since Wed 2025-01-15 09:40:52 CET; 3min 9s ago
                                        CPU: 1min 9.071s
                                             ├─1741 io.admin.0
                                             ├─2411 io.nut.0
                                             ├─2432 io.snmp.0
                                             ├─2447 io.snmp.1
                                             ├─2462 io.tr-064.0
                                             ├─2496 io.hm-rpc.0
                                             ├─2514 io.hm-rega.0
                                             ├─2529 io.hm-rpc.1
                                             ├─2559 io.web.0
                                             ├─2593 io.pi-hole.0
                                             ├─2608 io.energiefluss-erweitert.0
                                             ├─2628 io.vis-2.0
                                             ├─2672 io.pushover.0
                                             └─2692 io.fronius-wattpilot.0
                                Jan 15 09:41:26 raspi5 sudo[2402]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                Jan 15 09:41:26 raspi5 sudo[2402]: pam_unix(sudo:session): session closed for user root
                                Jan 15 09:41:26 raspi5 sudo[2407]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                                Jan 15 09:41:26 raspi5 sudo[2407]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                Jan 15 09:41:26 raspi5 sudo[2407]: pam_unix(sudo:session): session closed for user root
                                Jan 15 09:41:27 raspi5 su[2377]: FAILED SU (to root) iobroker on none
                                Jan 15 09:41:27 raspi5 su[2423]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
                                Jan 15 09:41:29 raspi5 su[2423]: FAILED SU (to pi) iobroker on none
                                Jan 15 09:41:30 raspi5 su[2439]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
                                Jan 15 09:41:32 raspi5 su[2439]: FAILED SU (to pi) iobroker on none
                                  N Offline
                                  N Offline
                                  norbert999
                                  Das hat funktioniert!
                                  aspi5:~ $ sudo systemctl stop iobroker
                                  library: loaded
                                      Welcome to the ioBroker installation fixer!
                                      Script version: 2024-10-22
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/5)
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:4 https://apt.grafana.com stable InRelease
                                  Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:6 https://repos.influxdata.com/debian stable InRelease
                                  Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Reading package lists... Done
                                      Checking ioBroker user and directory permissions (2/5)
                                  Created /etc/sudoers.d/iobroker
                                  chown: changing ownership of '/opt/iobroker/backups/@Recycle/desktop.ini': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/@Recycle': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/.@__thumb/sanlight-bt-dimmer-manual-2023-de.pdf.error': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/.@__thumb/sanlight-bt-dimmer-manual-2023-dexxxxxxxxxxxxxxxxxxxxxxxxx.pdf.error': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/.@__thumb': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_11-17_26_51_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/raspi5': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_11-17_26_58_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_11-17_44_54_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_11-17_45_00_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_12-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_12-02_48_16_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_13-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_13-02_48_16_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_14-02_48_10_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_14-02_48_17_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-02_48_11_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-02_48_18_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-07_16_49_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-07_16_55_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-07_21_52_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-07_21_59_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/iobroker_2025_01_15-08_18_25_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups/javascripts_2025_01_15-08_18_32_backupiobroker.tar.gz': Operation not permitted
                                  chown: changing ownership of '/opt/iobroker/backups': Operation not permitted
                                  This system does not support setting default permissions.
                                  Do not use npm to manually install adapters unless you know what you are doing!
                                      Check and cleanup npm temporary directories (3/5)
                                  Done.
                                      Database maintenance (4/5)
                                  Checking for uncompressed JSONL databases... This might take a while!
                                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                  Compressed 2 JSONL files. Done
                                      Checking autostart (5/5)
                                  Enabling autostart...
                                  Autostart enabled!
                                  pi@raspi5:~ $
                                  Und jetzt?
                                  • N norbert999
                                    library: loaded
                                    Done.
                                    Autostart enabled!
                                    pi@raspi5:~ $
                                    Und jetzt?
                                    Und jetzt?
                                      Und jetzt?
                                      N Offline
                                      N Offline
                                      norbert999
                                      Objects type: jsonl
                                      States  type: jsonl
                                      pi@raspi5:~ $
                                      Jetzt geht der iob status, der definitiv vorher nicht ging!
                                      • N norbert999
                                        Objects type: jsonl
                                        States  type: jsonl
                                        pi@raspi5:~ $
                                        da war ja auch alles massiv verbogen
                                        • N Offline
                                          N Offline
                                          norbert999
                                          Fixer habe ich erfolgreich ausgeführt. Danach nochmal iob diag:
                                          ```bash
                                          Script v.2024-10-19
                                          *** BASE SYSTEM ***
                                           Static hostname: raspi5
                                                 Icon name: computer
                                                    Kernel: Linux 6.6.62+rpt-rpi-2712
                                              Architecture: arm64
                                          OS is similar to:
                                          Model           : Raspberry Pi 5 Model B Rev 1.0
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           09:58:28 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
                                          CPU threads: 4
                                          *** LIFE CYCLE STATUS ***
                                          Operating System is the current Debian stable version codenamed 'bookworm'!
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          *** TIME AND TIMEZONES ***
                                                         Local time: Wed 2025-01-15 09:58:28 CET
                                                     Universal time: Wed 2025-01-15 08:58:28 UTC
                                                           RTC time: Wed 2025-01-15 08:58:29
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          *** DISPLAY-SERVER SETUP ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                          *** MEMORY ***
                                          Mem:            8.4G        1.9G        5.4G         39M        1.2G        6.5G
                                          Swap:           536M          0B        536M
                                          Total:          9.0G        1.9G        5.9G
                                          Active iob-Instances:   12
                                                   8052 M total memory
                                                   1854 M used memory
                                                   2143 M active memory
                                                    505 M inactive memory
                                                   5134 M free memory
                                                     59 M buffer memory
                                                   1132 M swap cache
                                                    511 M total swap
                                                      0 M used swap
                                                    511 M free swap
                                          top - 09:58:29 up 1 min,  4 users,  load average: 5.60, 2.02, 0.73
                                          Tasks: 248 total,   1 running, 247 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   8052.2 total,   5133.2 free,   1855.9 used,   1192.1 buff/cache
                                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6196.3 avail Mem
                                          *** FAILED SERVICES ***
                                            UNIT               LOAD   ACTIVE SUB    DESCRIPTION
                                          * nut-server.service loaded failed failed Network UPS Tools - power devices information server
                                          1 loaded units listed.
                                          *** DMESG CRITICAL ERRORS ***
                                          No critical errors detected
                                          *** FILESYSTEM ***
                                          Filesystem                            Type      Size  Used Avail Use% Mounted on
                                          udev                                  devtmpfs  3.9G     0  3.9G   0% /dev
                                          tmpfs                                 tmpfs     806M  6.2M  800M   1% /run
                                          /dev/sda2                             ext4       29G   10G   18G  37% /
                                          tmpfs                                 tmpfs     4.0G  3.3M  4.0G   1% /dev/shm
                                          tmpfs                                 tmpfs     5.0M   48K  5.0M   1% /run/lock
                                          /dev/sda1                             vfat      510M   67M  444M  14% /boot/firmware
                                          192.168.1.12:/share/backup_raspi5     nfs       5.4T  3.0T  2.4T  56% /opt/iobroker/backups
                                          192.168.1.12:/share/backup_raspberry5 nfs       5.4T  3.0T  2.4T  56% /backup
                                          tmpfs                                 tmpfs     806M  192K  806M   1% /run/user/1000
                                          [Wed Jan 15 09:56:40 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:8D:08:0B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1cf07110-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                          [Wed Jan 15 09:56:45 2025] EXT4-fs (sda2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
                                          [Wed Jan 15 09:56:46 2025] EXT4-fs (sda2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET                  SOURCE                                FSTYPE      OPTIONS
                                          /                       /dev/sda2                             ext4        rw,noatime
                                          |-/run/user/1000/doc    portal                                fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                          |-/boot/firmware        /dev/sda1                             vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          |-/opt/iobroker/backups 192.168.1.12:/share/backup_raspi5     nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
                                          `-/backup               192.168.1.12:/share/backup_raspberry5 nfs         rw,nosuid,nodev,noexec,relatime,sync,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.12,mountvers=3,mountport=32777,mountproto=udp,local_lock=all,addr=192.168.1.12
                                          /var:
                                          1.6G    /var/
                                          482M    /var/cache
                                          476M    /var/cache/apt
                                          361M    /var/cache/apt/archives
                                          354M    /var/log
                                          Archived and active journals take up 332.6M in the file system.
                                          /opt/iobroker/backups:
                                          64M     /opt/iobroker/backups/
                                          16K     /opt/iobroker/backups/.@__thumb
                                          12K     /opt/iobroker/backups/@Recycle
                                          8.0K    /opt/iobroker/backups/raspi5
                                          /opt/iobroker/iobroker-data:
                                          1.1G    /opt/iobroker/iobroker-data/
                                          1007M   /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                                          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                                          24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                                          15M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.18.1
                                          /usr/bin/node           v20.18.1
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.29.4
                                          nodejs:
                                            Installed: 20.18.1-1nodesource1
                                            Candidate: 20.18.1-1nodesource1
                                            Version table:
                                           *** 20.18.1-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                               20.18.0-1nodesource1 1001
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                          No problems detected
                                          Errors in npm tree: 0
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          raspi5              raspi5 (version: 7.0.6, hostname: raspi5        , alive, uptime: 72)
                                          Core adapters versions
                                          js-controller:  7.0.6
                                          admin:          7.4.10
                                          javascript:     8.8.3
                                          nodejs modules from github:     0
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
                                          + system.adapter.discovery.0              : discovery             : raspi5                                   -  enabled
                                            system.adapter.dwd.0                    : dwd                   : raspi5                                   -  enabled
                                            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspi5                                   -  enabled
                                            system.adapter.fronius-solarweb.0       : fronius-solarweb      : raspi5                                   -  enabled
                                            system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : raspi5                                   -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : raspi5                                   -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : raspi5                                   -  enabled, port: 0
                                            system.adapter.ical.0                   : ical                  : raspi5                                   -  enabled
                                          + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
                                          + system.adapter.nut.0                    : nut                   : raspi5                                   -  enabled
                                            system.adapter.pi-hole.0                : pi-hole               : raspi5                                   -  enabled
                                            system.adapter.pushover.0               : pushover              : raspi5                                   -  enabled
                                          + system.adapter.snmp.0                   : snmp                  : raspi5                                   -  enabled
                                          + system.adapter.snmp.1                   : snmp                  : raspi5                                   -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
                                            system.adapter.trashschedule.0          : trashschedule         : raspi5                                   -  enabled
                                            system.adapter.vis-2.0                  : vis-2                 : raspi5                                   -  enabled
                                            system.adapter.vis.0                    : vis                   : raspi5                                   -  enabled
                                            system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Upgrade policy: none
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 7.4.10   , installed 7.4.10
                                          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                                          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                          Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Controller "js-controller": 7.0.6    , installed 7.0.6
                                          Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                          Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                          Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                          Objects and States
                                          Objects:        7241
                                          States:         5787
                                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                                          Hit:5 https://apt.grafana.com stable InRelease
                                          Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        8348       921/pihole-FTL
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4884       822/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          8334       974/lighttpd
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5920       812/cupsd
                                          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        8354       921/pihole-FTL
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7816       1217/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9732       1217/iobroker.js-co
                                          tcp        0      0 127.0.0.1:5335          0.0.0.0:*               LISTEN      0          7090       824/unbound
                                          tcp        0      0 192.168.1.6:2001        0.0.0.0:*               LISTEN      1001       14578      2412/io.hm-rpc.0
                                          tcp        0      0 192.168.1.6:2010        0.0.0.0:*               LISTEN      1001       13581      2452/io.hm-rpc.1
                                          tcp6       0      0 :::53                   :::*                    LISTEN      999        8350       921/pihole-FTL
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          4886       822/sshd: /usr/sbin
                                          tcp6       0      0 :::80                   :::*                    LISTEN      0          8333       974/lighttpd
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13362      1584/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13700      2575/io.web.0
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      995        10517      897/influxd
                                          tcp6       0      0 ::1:4711                :::*                    LISTEN      999        8355       921/pihole-FTL
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5919       812/cupsd
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      113        9167       1216/grafana
                                          udp        0      0 0.0.0.0:55571           0.0.0.0:*                           1001       13679      2366/io.snmp.0
                                          udp        0      0 0.0.0.0:43935           0.0.0.0:*                           104        6932       561/avahi-daemon: r
                                          udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        8347       921/pihole-FTL
                                          udp        0      0 127.0.0.1:5335          0.0.0.0:*                           0          7089       824/unbound
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6930       561/avahi-daemon: r
                                          udp        0      0 0.0.0.0:50633           0.0.0.0:*                           1001       12860      2377/io.snmp.1
                                          udp6       0      0 :::44673                :::*                                104        6933       561/avahi-daemon: r
                                          udp6       0      0 :::53                   :::*                                999        8349       921/pihole-FTL
                                          udp6       0      0 fe80::f0ae:1c2a:23c:546 :::*                                0          6011       777/NetworkManager
                                          udp6       0      0 :::5353                 :::*                                104        6931       561/avahi-daemon: r
                                          2025-01-15 09:58:30.841  - info: pi-hole.0 (2784) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:33.986  - info: host.raspi5 instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 2885
                                          2025-01-15 09:58:34.908  - info: energiefluss-erweitert.0 (2885) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:34.927  - info: energiefluss-erweitert.0 (2885) Adapter started. Loading config!
                                          2025-01-15 09:58:35.312  - info: energiefluss-erweitert.0 (2885) Configuration loaded!
                                          2025-01-15 09:58:35.313  - info: energiefluss-erweitert.0 (2885) Requesting the following states: energiefluss-erweitert.0.configuration,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerPV.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerLoad.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerFeedIn.value,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.BattSOC.value,0_userdata.0.Photovoltaik.BattLoadState,fronius-solarweb.0.96605a5f-da06-4373-b8d5-b985faa71359.flowdata.PowerBattCharge.value,0_userdata.0.Photovoltaik.BattCapac,energiefluss-erweitert.0.calculation.battery.remaining,0_userdata.0.Photovoltaik.FlowSelfConsumption,0_userdata.0.Photovoltaik.PowerIntoGrid,0_userdata.0.Photovoltaik.BattMinDischarge,0_userdata.0.Photovoltaik.FlowBattCharge
                                          2025-01-15 09:58:35.941  - info: web.0 (2575) <== Disconnect system.user.admin from ::ffff:192.168.1.209
                                          2025-01-15 09:58:36.090  - info: web.0 (2575) ==> Connected system.user.admin from ::ffff:192.168.1.209
                                          2025-01-15 09:58:37.946  - info: host.raspi5 instance system.adapter.vis-2.0 in version "2.9.64" started with pid 2931
                                          2025-01-15 09:58:38.730  - info: vis-2.0 (2931) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:38.889  - info: vis-2.0 (2931) vis-2 license is OK.
                                          2025-01-15 09:58:42.004  - info: host.raspi5 instance scheduled system.adapter.dwd.0 */5 * * * *
                                          2025-01-15 09:58:42.007  - info: host.raspi5 instance system.adapter.dwd.0 in version "2.8.5" started with pid 2999
                                          2025-01-15 09:58:42.953  - info: dwd.0 (2999) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:43.273  - info: dwd.0 (2999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2025-01-15 09:58:43.799  - info: host.raspi5 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2025-01-15 09:58:48.496  - info: vis.0 (3014) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:50.064  - info: host.raspi5 instance system.adapter.pushover.0 in version "4.1.0" started with pid 3046
                                          2025-01-15 09:58:51.750  - info: pushover.0 (3046) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.pushover, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:52.051  - info: vis.0 (3014) Terminated (NO_ERROR): Without reason
                                          2025-01-15 09:58:52.588  - info: host.raspi5 instance system.adapter.vis.0 terminated while should be started once
                                          2025-01-15 09:58:53.946  - info: host.raspi5 instance system.adapter.fronius-wattpilot.0 in version "4.6.3" started with pid 3078
                                          2025-01-15 09:58:54.866  - info: fronius-wattpilot.0 (3078) starting. Version 4.6.3 in /opt/iobroker/node_modules/iobroker.fronius-wattpilot, node: v20.18.1, js-controller: 7.0.6
                                          2025-01-15 09:58:54.880  - info: fronius-wattpilot.0 (3078) Try to connect to: ws://192.168.1.132/ws
                                          2025-01-15 09:58:56.402  - info: fronius-wattpilot.0 (3078) Connected!
                                          Siehts jetzt besser aus?
