  4. VIS-2 JS Error in Widget ovarius. Keine Optionen an select
6 Beiträge 3 Kommentatoren 514 Aufrufe 3 Beobachtet
    trojanhector
    ich habe eine View erstellt, in der ein Widget (Vis-2 widget ovarious v0.1.9) u. a. 35 html select tags enthält. Diese selects sollen alle die gleichen Optionen enthalten. Und hier laufe ich in Javascript auf einen Fehler:
    Uncaught TypeError: select.add is not a function
    let selectid="cboRoom";
    let dp_roomsSelection = JSON.parse(dp["0_userdata.0.heatingControl.rooms"]);
    let dp_roomSelected = "0_userdata.0.heatingControl.Vis.SelectedRoom";
    let db_timeOptions = dp["0_userdata.0.heatingControl.Vis.OverrideHeatingTemperatur"];
    <script>
    let selectid="<%- selectid %>";
    let dp_roomSelected="<%- dp_roomSelected %>";
    window.writeDP<%- selectid %>=(el)=>{
        //debugger;
        if (el.selectedOptions[0].value) vis.setValue(dp_roomSelected,el.selectedOptions[0].value);
    </script>
    <select class="cbo cbo-10rem" id="<%- selectid %>" name="<%- selectid %>" size="1" onchange="javascript:writeDP<%- selectid %>(this)" >
    //debugger;
    for(let i = 0; i < dp_roomsSelection.length; i++){
    var el = dp_roomsSelection[i];
    <option value ="<%- el %>" <%- ((dp[dp_roomSelected] == el) ? "selected":"") %>><%- el %></option>
    </select>
    <%- dp["0_userdata.0.heatingControl.Vis.Profil"]; %>
    <script>
    db_timeOptions = <%- db_timeOptions %>;
    let options = db_timeOptions.map(function(val, ind){
    return $("<option></option>").val(val.id).html(val.name);
    //$('#0_userdata__0__heatingControl__Profile__1__Bad__1_Montag__1__Temperatur').append(options);
    console.log(options);
    var selects = document.getElementsByClassName('hc-vis-pr-temp');
    debugger;
    for( var i = 0; i < selects.length; i++ ) {
        db_timeOptions.forEach((element) => {
            let option = new Option(element.name, element.id)
            let select = selects[i];
            select.add(option, undefined);
    </script>
    Hat jemand eine Idee, was ich falsch mache, oder wie es anders geht?
    Node.js:v20.18.1
    NPM:10.8.2
    Javascript 8.8.3
    js-controller:7.0.6
    vis2 2.9.64
    JSON Widget 0.1.9
    mcm1957M OliverIOO 2 Antworten Letzte Antwort
    • T trojanhector
      <script>
          //debugger;
      </script>
      //debugger;
      </select>
      <script>
      debugger;
      </script>
      Node.js:v20.18.1
      NPM:10.8.2
      Javascript 8.8.3
      js-controller:7.0.6
      vis2 2.9.64
      JSON Widget 0.1.9
      mcm1957M Offline
      mcm1957M Offline
      mcm1957
      --- deleted ---
      Der Beitrag war inhaltlich falsch.
      SORRY
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        --- deleted ---
        SORRY
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @mcm1957
        das ist leider nur teilweise korrekt.
        für ovarious stimmt das,
        aber nicht für vis2-widgets-ovarious
        Meine Adapter und Widgets
        Links im Profil
        • T trojanhector
          <script>
              //debugger;
          </script>
          //debugger;
          </select>
          <script>
          debugger;
          </script>
          Node.js:v20.18.1
          NPM:10.8.2
          Javascript 8.8.3
          js-controller:7.0.6
          vis2 2.9.64
          JSON Widget 0.1.9
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @trojanhector
          wie entstehen den die elemente mit der css-klasse hc-vis-pr-temp ?
          existieren die zum zeitpunkt, wenn das javascript von JSONTemplate läuft dann schon?
          Aufgrund der Fehlermeldung würde ich vermuten, das das was da selektiert wurde kein Objekt vom Typ https://developer.mozilla.org/en-US/docs/Web/API/HTMLSelectElement/add ist
          Links im Profil
          • OliverIOO OliverIO
            @trojanhector
            trojanhector
            @oliverio
            Die lasse ich mir im Blockly zusammenbauen. Je nach ausgewähltem Raum vom einzelnen Select in der View ändern sich die IDs.
            • T trojanhector
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @trojanhector hab gerade mein post erweitert
              gut wäre es das komplette konstrukt in einem erstellen zu lassen.
              für sowas ist die template engine des widgets prädestiniert
              Links im Profil
