  3. Off Topic
  4. Pflege des Betriebssystems
  5. RPI5 apt-get upgrade schlägt Fehlermeldung
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
28 Beiträge 5 Kommentatoren 6.0k Aufrufe 4 Beobachtet
  • K knopers1
    pi@VISundGrafana:~ $ sudo apt-get update
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Reading package lists... Done
    pi@VISundGrafana:~ $ sudo apt-get upgrade
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra
      edid-decode libqt5qmlworkerscript5 libqt5quickcontrols2-5
      libqt5quicktemplates2-5 libwlroots12 linux-headers-6.6.31+rpt-common-rpi
      linux-kbuild-6.6.31+rpt python3-gi-cairo qml-module-qtgraphicaleffects
      qml-module-qtquick-controls2 qml-module-qtquick-layouts
      qml-module-qtquick-templates2 qml-module-qtquick-window2 qml-module-qtquick2
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    @knopers1 sagte in RPI5 apt-get upgrade schlägt Fehlermeldung:
    immer noch!
    • K knopers1
      @knopers1
      Ja, autoremove.
      Aber der ganze Desktop -Kladderadatsch rumpelt immer noch mit.
      Und macht Updates dadurch komplexer als notwendig. Neben anderen Nachteilen.
      K 2 Antworten Letzte Antwort
        @knopers1
        Ja, autoremove.
        knopers1
        pi@VISundGrafana:~ $ sudo apt autoremove chromium-browser
        The following packages will be REMOVED:
        0 upgraded, 0 newly installed, 17 to remove and 0 not upgraded.
        After this operation, 65.6 MB disk space will be freed.
        Do you want to continue? [Y/n] y
        (Reading database ... 166892 files and directories currently installed.)
        Removing chromium-browser (1:130.0.6723.116-1~deb12u1+rpt1) ...
        Removing chromium-browser-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
        Removing chromium-codecs-ffmpeg-extra (126.0.6478.164-rpt1) ...
        Removing edid-decode (0.1~git20241119.5332a3b-1) ...
        Removing qml-module-qtgraphicaleffects:arm64 (5.15.8-2) ...
        Removing qml-module-qtquick2:arm64 (5.15.8+dfsg-3) ...
        Removing libqt5qmlworkerscript5:arm64 (5.15.8+dfsg-3) ...
        Removing qml-module-qtquick-controls2:arm64 (5.15.8+dfsg-2) ...
        Removing libqt5quickcontrols2-5:arm64 (5.15.8+dfsg-2) ...
        Removing qml-module-qtquick-templates2:arm64 (5.15.8+dfsg-2) ...
        Removing libqt5quicktemplates2-5:arm64 (5.15.8+dfsg-2) ...
        Removing libwlroots12:arm64 (0.17.4-1+rpt1) ...
        Removing linux-headers-6.6.31+rpt-common-rpi (1:6.6.31-1+rpt1) ...
        Removing linux-kbuild-6.6.31+rpt (1:6.6.31-1+rpt1) ...
        Removing python3-gi-cairo (3.42.2-3+b1) ...
        Removing qml-module-qtquick-layouts:arm64 (5.15.8+dfsg-3) ...
        Removing qml-module-qtquick-window2:arm64 (5.15.8+dfsg-3) ...
        Processing triggers for man-db (2.11.2-2) ...
        Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
          @knopers1
          Ja, autoremove.
          knopers1
          schrieb am zuletzt editiert von knopers1
          @thomas-braun said in RPI5 apt-get upgrade schlägt Fehlermeldung:
          @knopers1
          Ja, autoremove.
          ja, habe leider die letzte Zeit keine Updates gemacht.... Kann ich irgendwie noch was verbessern?
          Ich hatte vor einigen Monaten das System auf RPI5 vom RPI4 umgezogen und danach praktisch kaum etwas gemacht... Sonst sieht es jetzt wieder gut aus! Besten Dank! @Homoran - Dir ebenso riesen Dank für die Interesse!
          • K knopers1
            @knopers1
            Ja, autoremove.
            Kann ich dir sagen, wenn ich die Langfassung von
            iob diag
            sehe.
            K 1 Antwort Letzte Antwort
              iob diag
              sehe.
              knopers1
              @thomas-braun gerne doch....
              ```bash
              Script v.2024-10-19
              *** BASE SYSTEM ***
               Static hostname: VISundGrafana
                     Icon name: computer
                        Kernel: Linux 6.6.62+rpt-rpi-2712
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               18:21:20 up 36 min,  4 users,  load average: 2.15, 0.99, 0.50
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Mon 2025-01-06 18:21:20 CET
                         Universal time: Mon 2025-01-06 17:21:20 UTC
                               RTC time: Mon 2025-01-06 17:21:20
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Server: true
              Desktop:
              Terminal:       tty
              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
              *** MEMORY ***
              Mem:            8.4G        2.5G        4.6G         24M        1.4G        5.9G
              Swap:           209M          0B        209M
              Total:          8.7G        2.5G        4.8G
              Active iob-Instances:   29
                       8052 M total memory
                       2429 M used memory
                       2413 M active memory
                        768 M inactive memory
                       4389 M free memory
                        149 M buffer memory
                       1204 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 18:21:20 up 36 min,  4 users,  load average: 2.15, 0.99, 0.50
              Tasks: 237 total,   2 running, 235 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8052.2 total,   4388.5 free,   2429.9 used,   1354.3 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5622.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  3.9G     0  3.9G   0% /dev
              tmpfs          tmpfs     806M  6.0M  800M   1% /run
              /dev/sda2      ext4      235G  9.3G  214G   5% /
              tmpfs          tmpfs     4.0G  288K  4.0G   1% /dev/shm
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/sda1      vfat      510M   76M  435M  15% /boot/firmware
              tmpfs          tmpfs     806M  192K  806M   1% /run/user/1000
              [Mon Jan  6 17:44:37 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:3C:5E:BB vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=11c29a44-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Mon Jan  6 17:44:38 2025] EXT4-fs (sda2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
              [Mon Jan  6 17:44:39 2025] EXT4-fs (sda2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET               SOURCE    FSTYPE      OPTIONS
              /                    /dev/sda2 ext4        rw,noatime
              |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot/firmware     /dev/sda1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              1.1G    /var/
              403M    /var/cache
              391M    /var/cache/apt
              302M    /var/log/journal/1671f0a4980a454dbb2a7d3bf10bcd54
              Archived and active journals take up 301.0M in the file system.
              /opt/iobroker/backups:
              122M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.2G    /opt/iobroker/iobroker-data/
              972M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
              19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.1
              /usr/bin/node           v20.18.1
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.29.4
              nodejs:
                Installed: 20.18.1-1nodesource1
                Candidate: 20.18.1-1nodesource1
                Version table:
               *** 20.18.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              VISundGrafana       VISundGrafana (version: 7.0.6, hostname: VISundGrafana , alive, uptime: 121)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.1.5
              javascript:     8.8.3
              nodejs modules from github:     2
              | | +-- browser-serialport@2.0.3 (git+ssh://git@github.com/noopkat/browser-serialport.git#c8628c41c11890d3058875994c15f83f2df8185b)
              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
              Adapter State
              + system.adapter.admin.0                  : admin                 : VISundGrafana                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : VISundGrafana                            -  enabled
              + system.adapter.backitup.0               : backitup              : VISundGrafana                            -  enabled
              + system.adapter.cloud.0                  : cloud                 : VISundGrafana                            -  enabled
              + system.adapter.discovery.0              : discovery             : VISundGrafana                            -  enabled
              + system.adapter.email.1                  : email                 : VISundGrafana                            -  enabled
              + system.adapter.ems-esp.0                : ems-esp               : VISundGrafana                            -  enabled
                system.adapter.energiefluss.0           : energiefluss          : VISundGrafana                            - disabled
              + system.adapter.enigma2.0                : enigma2               : VISundGrafana                            -  enabled
                system.adapter.flot.0                   : flot                  : VISundGrafana                            - disabled
              + system.adapter.fritzbox.0               : fritzbox              : VISundGrafana                            -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : VISundGrafana                            -  enabled
              + system.adapter.history.0                : history               : VISundGrafana                            -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : VISundGrafana                            -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : VISundGrafana                            -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : VISundGrafana                            -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : VISundGrafana                            -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: VISundGrafana                            - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : VISundGrafana                            - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : VISundGrafana                            - disabled
                system.adapter.influxdb.0               : influxdb              : VISundGrafana                            - disabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : VISundGrafana                            -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : VISundGrafana                            -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : VISundGrafana                            -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : VISundGrafana                            -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.opendtu.0                : opendtu               : VISundGrafana                            -  enabled
              + system.adapter.opendtu.1                : opendtu               : VISundGrafana                            -  enabled
              + system.adapter.ping.0                   : ping                  : VISundGrafana                            -  enabled
              + system.adapter.rflink.0                 : rflink                : VISundGrafana                            -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : VISundGrafana                            -  enabled
                system.adapter.samsung.0                : samsung               : VISundGrafana                            - disabled
              + system.adapter.shelly.0                 : shelly                : VISundGrafana                            -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.sonoff.0                 : sonoff                : VISundGrafana                            -  enabled, port: 1500, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : VISundGrafana                            -  enabled
                system.adapter.tankerkoenig.0           : tankerkoenig          : VISundGrafana                            -  enabled
                system.adapter.terminal.0               : terminal              : VISundGrafana                            -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
              + system.adapter.tr-064.0                 : tr-064                : VISundGrafana                            -  enabled
                system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : VISundGrafana                            - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : VISundGrafana                            - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : VISundGrafana                            - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : VISundGrafana                            - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : VISundGrafana                            - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : VISundGrafana                            - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : VISundGrafana                            - disabled
                system.adapter.vis-keyboard.0           : vis-keyboard          : VISundGrafana                            - disabled
                system.adapter.vis-metro.0              : vis-metro             : VISundGrafana                            - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : VISundGrafana                            - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : VISundGrafana                            - disabled
                system.adapter.vis-weather.0            : vis-weather           : VISundGrafana                            - disabled
                system.adapter.vis.0                    : vis                   : VISundGrafana                            -  enabled
              + system.adapter.web.0                    : web                   : VISundGrafana                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name      │ url        │ auto upgrade │
              │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
              │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
              │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
              │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.1.5    , installed 7.1.5
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.25   , installed 3.0.25
              Adapter    "cloud"        : 5.0.1    , installed 5.0.1
              Adapter    "email"        : 1.3.1    , installed 1.3.1
              Adapter    "ems-esp"      : 5.0.6    , installed 5.0.6
              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
              Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
              Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "ical"         : 1.16.1   , installed 1.16.1
              Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
              Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
              Adapter    "rflink"       : 2.1.12   , installed 2.1.12
              Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
              Adapter    "samsung"      : 0.6.1    , installed 0.6.1
              Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
              Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
              Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
              Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
              Adapter    "web"          : 6.2.5    , installed 6.2.6
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Objects and States
              Objects:        8688
              States:         7367
              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.1.100:2001      0.0.0.0:*               LISTEN      1001       60989      8442/io.hm-rpc.0
              tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1001       62975      9385/io.sonoff.0
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       63828      9366/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       61228      8521/io.mqtt.0
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       58758      7874/node-red
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4949       854/sshd: /usr/sbin
              tcp        0      0 192.168.1.100:8701      0.0.0.0:*               LISTEN      1001       61745      8457/io.hm-rpc.1
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       59480      7774/iobroker.js-co
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       59475      7774/iobroker.js-co
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7007       841/cupsd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7006       841/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          4951       854/sshd: /usr/sbin
              tcp6       0      0 :::80                   :::*                    LISTEN      1001       58759      7874/node-red
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63321      9675/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57834      7792/io.admin.0
              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       66381      9845/io.terminal.0
              udp        0      0 192.168.1.100:5353      0.0.0.0:*                           1001       63954      9436/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7721       656/avahi-daemon: r
              udp        0      0 0.0.0.0:59726           0.0.0.0:*                           104        7723       656/avahi-daemon: r
              udp6       0      0 fe80::c3f8:2347:667:546 :::*                                0          8371       806/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        7722       656/avahi-daemon: r
              udp6       0      0 :::43675                :::*                                104        7724       656/avahi-daemon: r
              2025-01-06 18:21:14.182  - info: tankerkoenig.0 (9816) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.18.1, js-controller: 7.0.6
              2025-01-06 18:21:14.201  - info: tankerkoenig.0 (9816) Adapter is already in daemon mode
              2025-01-06 18:21:14.202  - warn: tankerkoenig.0 (9816) Sync time was too short (5). New sync time is 10 min
              2025-01-06 18:21:14.202  - info: tankerkoenig.0 (9816) Sync time set to 10 minutes or 600000 ms
              2025-01-06 18:21:14.629  - info: shelly.0 (9366) [MQTT] Device with client id "shellyplus1pm-48551999ccc0" connected!
              2025-01-06 18:21:15.797  - info: ems-esp.0 (8088) KM200 recordings: polling every hour
              2025-01-06 18:21:15.933  - info: sourceanalytix.0 (9778) Updating SourceAnalytix configuration for : shelly.0.shellyplus1pm#48551999ccc0#1.Relay0.Energy
              2025-01-06 18:21:17.220  - info: host.VISundGrafana instance system.adapter.terminal.0 in version "1.0.0" started with pid 9845
              2025-01-06 18:21:17.366  - debug: rflink.0 (9713) Serial data received: 20;02;Aster;ID=0dcc;SWITCH=01;CMD=ON;
              2025-01-06 18:21:17.367  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
              2025-01-06 18:21:18.815  - info: terminal.0 (9845) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v20.18.1, js-controller: 7.0.6
              2025-01-06 18:21:18.838  - info: terminal.0 (9845) http server listening on port 8088
              2025-01-06 18:21:19.255  - info: tankerkoenig.0 (9816) Start first request
              2025-01-06 18:21:22.031  - info: vis.0 (10027) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
              2025-01-06 18:21:22.422  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
              2025-01-06 18:21:22.436  - info: web.0 (9675) <== Disconnect system.user.admin from ::ffff:192.168.1.174
              2025-01-06 18:21:22.444  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
              2025-01-06 18:21:22.459  - info: web.0 (9675) <== Disconnect system.user.admin from ::ffff:192.168.1.174
              2025-01-06 18:21:22.750  - info: vis.0 (10027) Terminated (NO_ERROR): Without reason
              2025-01-06 18:21:23.299  - info: host.VISundGrafana instance system.adapter.vis.0 terminated while should be started once
              2025-01-06 18:21:23.643  - info: web.0 (9675) ==> Connected system.user.admin from ::ffff:192.168.1.174
              2025-01-06 18:21:40.436  - debug: rflink.0 (9713) Serial data received: 20;03;Aster;ID=0ff8;SWITCH=01;CMD=ON;
              2025-01-06 18:21:40.437  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
              2025-01-06 18:21:43.944  - debug: rflink.0 (9713) Serial data received: 20;04;Aster;ID=0e7c;SWITCH=01;CMD=OFF;
              2025-01-06 18:21:43.944  - debug: rflink.0 (9713) Device "Aster not included, because inclusion mode disabled
              iob diag has finished.
              Copy text starting here:
                                      v.2024-10-19
                     Icon name: computer
                  Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CET, +0100)
              User-ID:                1000
              Pending OS-Updates:     0
              Pending iob updates:    1
              Nodejs-Installation:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              Recommended versions are nodejs 20.18.1 and npm 10.8.2
              nodeJS installation is correct
              MEMORY:
              Mem:            8.4G        2.4G        4.8G         24M        1.4G        6.0G
              Swap:           209M          0B        209M
              Total:          8.7G        2.4G        5.0G
              Active iob-Instances:   31
              ioBroker Core:          js-controller           7.0.6
                                      admin                   7.1.5
              Objects type: jsonl
              States  type: jsonl
              Objects:                8688
              States:                 7359
              Size of iob-Database:
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              2.6M    /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
              • K knopers1
                ```bash
                Script v.2024-10-19
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           209M          0B        209M
                         8052 M total memory
                         2429 M used memory
                         4389 M free memory
                          149 M buffer memory
                         1204 M swap cache
                          199 M total swap
                            0 M used swap
                          199 M free swap
                *** FILESYSTEM ***
                /var:
                1.1G    /var/
                403M    /var/cache
                391M    /var/cache/apt
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.1.5
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        8688
                States:         7367
                Pending Updates: 0
                                        v.2024-10-19
                       Icon name: computer
                    Architecture: arm64
                Kernel:                 aarch64
                Userland:               64 bit
                User-ID:                1000
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                MEMORY:
                Swap:           209M          0B        209M
                                        admin                   7.1.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                8688
                States:                 7359
                Ausschalten...
                Updaten.
                  Ausschalten...
                  Updaten.
                  knopers1
                  besten Dank Thomas 👍
