  4. twinkly Lichterkette keine verbindung
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 481 Aufrufe 2 Beobachtet
  • Horst BöttcherH Offline
    Horst Böttcher
    schrieb am zuletzt editiert von Horst Böttcher
    Hallo ich versuche gerde eine twinkly Lichterkette
    Iob läuft auf Proxmox in eim LXC Contäner ohnne Docker
    ich nutze die letzte Adapter version Release v1.0.14
    Im letzten Jahr ging es noch supper doch jetzt verbindet sich die kette nicht mehr mit dem adapter
    twinkly.0
    2024-12-20 18:02:16.361	info	Got terminate signal TERMINATE_YOURSELF
    twinkly.0
    2024-12-20 18:02:16.361	info	cleaned everything up...
    twinkly.0
    2024-12-20 18:02:16.862	info	terminating
    twinkly.0
    2024-12-20 18:02:16.862	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    twinkly.0
    2024-12-20 18:02:21.812	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v20.18.1, js-controller: 7.0.3
    twinkly.0
    2024-12-20 18:02:21.932	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    twinkly.0
    2024-12-20 18:02:21.934	info	Startup complete
    twinkly.0
    2024-12-20 18:03:21.937	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    twinkly.0
    2024-12-20 18:04:21.941	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    twinkly.0
    2024-12-20 18:05:21.945	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    twinkly.0
    2024-12-20 18:06:21.949	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    twinkly.0
    2024-12-20 18:07:21.953	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
    host.Iobroker
    2024-12-20 18:01:52.323	error	cannot call visUtils: Cannot convert undefined or null to object
    host.Iobroker
    2024-12-20 18:02:16.337	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
    host.Iobroker
    2024-12-20 18:02:16.404	info	stopInstance system.adapter.twinkly.0 send kill signal
    host.Iobroker
    2024-12-20 18:02:17.399	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:02:20.694	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4668
    host.Iobroker
    2024-12-20 18:05:48.010	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4689
    host.Iobroker
    2024-12-20 18:05:50.063	info	instance system.adapter.dwd.0 having pid 4689 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:10:48.009	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4709
    host.Iobroker
    2024-12-20 18:10:50.018	info	instance system.adapter.dwd.0 having pid 4709 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:15:38.955	error	cannot call visUtils: Cannot convert undefined or null to object
    host.Iobroker
    2024-12-20 18:15:47.010	info	instance system.adapter.daswetter.0 in version "3.1.16" started with pid 4744
    host.Iobroker
    2024-12-20 18:15:51.018	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4759
    host.Iobroker
    2024-12-20 18:15:53.168	info	instance system.adapter.dwd.0 having pid 4759 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:15:54.501	info	instance system.adapter.daswetter.0 having pid 4744 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:16:28.810	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
    host.Iobroker
    2024-12-20 18:16:28.886	info	stopInstance system.adapter.twinkly.0 send kill signal
    host.Iobroker
    2024-12-20 18:16:29.877	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:16:33.176	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4778
    host.Iobroker
    2024-12-20 18:17:22.789	info	"system.adapter.ping.0" enabled
    host.Iobroker
    2024-12-20 18:17:23.178	info	instance system.adapter.ping.0 in version "1.6.2" started with pid 4794
    host.Iobroker
    2024-12-20 18:17:28.804	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
    host.Iobroker
    2024-12-20 18:17:28.866	info	stopInstance system.adapter.twinkly.0 send kill signal
    host.Iobroker
    2024-12-20 18:17:29.861	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:17:33.168	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4809
    host.Iobroker
    2024-12-20 18:18:05.469	error	cannot call visUtils: Cannot convert undefined or null to object
    host.Iobroker
    2024-12-20 18:18:19.013	info	instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 4839
    host.Iobroker
    2024-12-20 18:18:32.876	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
    host.Iobroker
    2024-12-20 18:18:32.936	info	stopInstance system.adapter.twinkly.0 send kill signal
    host.Iobroker
    2024-12-20 18:18:33.934	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:18:35.313	info	instance system.adapter.openweathermap.0 having pid 4839 terminated with code 0 (NO_ERROR)
    host.Iobroker
    2024-12-20 18:18:37.215	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4854
    host.Iobroker
    2024-12-20 18:18:57.859	info	stopInstance system.adapter.ping.0 (force=false, process=true)
    host.Iobroker
    2024-12-20 18:18:57.933	info	stopInstance system.adapter.ping.0 send kill signal
    host.Iobroker
    2024-12-20 18:18:58.926	info	instance system.adapter.ping.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.Iobroker
    2024-12-20 18:19:02.236	info	instance system.adapter.ping.0 in version "1.6.2" started with pid 4870
    host.Iobroker
    2024-12-20 18:20:48.010	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4897
    host.Iobroker
    2024-12-20 18:20:50.046	info	instance system.adapter.dwd.0 having pid 4897 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      twinkly.0
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      host.Iobroker
      crunchipC Abwesend
      crunchipC Abwesend
      @horst-böttcher sagte in twinkly Lichterkette keine verbindung:
      in eim LXC Contäner
      https://github.com/patrickbs96/ioBroker.twinkly/issues/298
      Horst BöttcherH 1 Antwort Letzte Antwort
        in eim LXC Contäner
        Horst Böttcher
        @crunchip hab die lösung probiet hat aber nicht geholfen
        fürleicht setzte ich iob in einer VM um fürleicht geht es dann alles
          crunchipC Abwesend
          crunchipC Abwesend
          Weil, keine Meldung im LOG?
