  4. [Fehler] Alexa Antwort in Sayit.0.tts verursacht Fehler
6 Beiträge 2 Kommentatoren 1.1k Aufrufe
    pix
    ich lasse Alexa Antworten in den Sayit-Adapter setzen. Das stellt man im cloud-Adapter unter "Schreibe Antowort ins …" ein.
    Es kommt aber ein Fehler:
    2017-09-26 21:17:49.859  - [32minfo[39m: sayit.0 saying: /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3
    2017-09-26 21:17:49.863  - [32minfo[39m: javascript.2 script.js.common.Alexa.Alexa_Szenen_schalten: TV durch Alexa-Kontrollschalter eingeschaltet
    2017-09-26 21:17:49.864  - [32minfo[39m: javascript.2 script.js.common.Alexa.Alexa_Szenen_schalten: TV-Licht eingeschaltet, da dunkel
    2017-09-26 21:17:49.882  - [32minfo[39m: javascript.0 script.js.common.VIS.VIS_View_Meldung: Meldung wird angesagt, Vis-View HOME wird angezeigt
    2017-09-26 21:17:50.870  - [32minfo[39m: sayit.0 saying: Fernseher ist <emphasis>eingeschaltet</emphasis>!
    2017-09-26 21:17:50.875  - [31merror[39m: sayit.0 uncaught exception: path is not defined
    2017-09-26 21:17:50.877  - [31merror[39m: sayit.0 ReferenceError: path is not defined
        at Text2Speech.sayItGetSpeech (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:479:31)
        at sayIt (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:398:21)
        at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:161:13)
        at Timer.listOnTimeout (timers.js:92:15)
    2017-09-26 21:17:50.878  - [32minfo[39m: sayit.0 stopping...
    2017-09-26 21:17:50.882  - [32minfo[39m: sayit.0 terminating
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[0]: [ReferenceError: path is not defined]
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[1]: 2017-09-26 21:17:50.875  -  sayit.0 uncaught exception: path is not defined
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[2]: 2017-09-26 21:17:50.877  -  sayit.0 ReferenceError: path is not defined
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[2]:     at Text2Speech.sayItGetSpeech (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:479:31)
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[2]:     at sayIt (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:398:21)
    2017-09-26 21:17:50.940  - [31merror[39m: Caught by controller[2]:     at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:161:13)
    2017-09-26 21:17:50.941  - [31merror[39m: Caught by controller[2]:     at Timer.listOnTimeout (timers.js:92:15)
    2017-09-26 21:17:50.941  - [31merror[39m: host.MacMini.local instance system.adapter.sayit.0 terminated with code 0 (OK)
    2017-09-26 21:17:50.941  - [32minfo[39m: host.MacMini.local Restart adapter system.adapter.sayit.0 because enabled
    Kann ich den PATH selbst einstellen?
    Pix
    • BluefoxB Offline
      BluefoxB Offline
      Probier mal die Version direkt vom git.
        pix
        Im Log keine Änderung.```
        2017-09-26 22:28:21.862 - [32minfo[39m: sayit.0 saying: /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3 2017-09-26 22:28:21.864 - [31merror[39m: sayit.0 Cannot play file "/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3": Error: ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3' 2017-09-26 22:28:21.870 - [32minfo[39m: sayit.0 saying: Kinderzimmer Licht ist <emphasis>ausgeschaltet</emphasis>! 2017-09-26 22:28:21.882 - [32minfo[39m: javascript.2 script.js.common.Alexa.Alexa_Szenen_schalten: Licht im Kinderzimmer durch Alexa-Kontrollschalter ausgeschaltet 2017-09-26 22:28:21.876 - [31merror[39m: sayit.0 uncaught exception: path is not defined 2017-09-26 22:28:21.884 - [31merror[39m: sayit.0 ReferenceError: path is not defined at Text2Speech.sayItGetSpeech (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:479:31) at sayIt (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:398:21) at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:161:13) at Timer.listOnTimeout (timers.js:92:15) 2017-09-26 22:28:21.885 - [32minfo[39m: sayit.0 stopping... 2017-09-26 22:28:21.891 - [32minfo[39m: sayit.0 terminating 2017-09-26 22:28:21.970 - [31merror[39m: Caught by controller[0]: 2017-09-26 22:28:21.864 - sayit.0 Cannot play file "/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3": Error: ENOENT: no such file or directory, open '/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3' 2017-09-26 22:28:21.971 - [31merror[39m: Caught by controller[1]: [ReferenceError: path is not defined] 2017-09-26 22:28:21.971 - [31merror[39m: Caught by controller[1]: 2017-09-26 22:28:21.876 - sayit.0 uncaught exception: path is not defined 2017-09-26 22:28:21.971 - [31merror[39m: Caught by controller[2]: 2017-09-26 22:28:21.884 - sayit.0 ReferenceError: path is not defined 2017-09-26 22:28:21.971 - [31merror[39m: Caught by controller[2]: at Text2Speech.sayItGetSpeech (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:479:31) 2017-09-26 22:28:21.971 - [31merror[39m: Caught by controller[2]: at sayIt (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:398:21) 2017-09-26 22:28:21.972 - [31merror[39m: Caught by controller[2]: at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:161:13) 2017-09-26 22:28:21.972 - [31merror[39m: Caught by controller[2]: at Timer.listOnTimeout (timers.js:92:15) 2017-09-26 22:28:21.972 - [31merror[39m: host.MacMini.local instance system.adapter.sayit.0 terminated with code 0 (OK) 2017-09-26 22:28:21.972 - [32minfo[39m: host.MacMini.local Restart adapter system.adapter.sayit.0 because enabled 2017-09-26 22:28:51.986 - [32minfo[39m: host.MacMini.local instance system.adapter.sayit.0 started with pid 72443[/code]
        Pix
          pix
          Hier der neue Fehler:
          [TypeError: that.sayItGetSpeechCloud is not a function]
          2017-09-27 14:45:59.050  - [32minfo[39m: sayit.0 saying: Ladegerät ist <emphasis>eingeschaltet</emphasis>!
          2017-09-27 14:45:59.070  - [31merror[39m: sayit.0 uncaught exception: that.sayItGetSpeechCloud is not a function
          2017-09-27 14:45:59.073  - [31merror[39m: sayit.0 TypeError: that.sayItGetSpeechCloud is not a function
              at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:337:22)
              at Socket.onack (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
              at Socket.onpacket (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
              at Manager. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
              at Manager.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              at Manager.ondecoded (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
              at Decoder. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
              at Decoder.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
              at Decoder.add (/Users/pix/Documents/iobroker/node_modules/socket.io-parser/index.js:246:12)
              at Manager.ondata (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
          2017-09-27 14:45:59.073  - [32minfo[39m: sayit.0 stopping...
          2017-09-27 14:45:59.076  - [32minfo[39m: sayit.0 terminating
          2017-09-27 14:45:59.130  - [31merror[39m: Caught by controller[0]: [TypeError: that.sayItGetSpeechCloud is not a function]
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[1]: 2017-09-27 14:45:59.070  -  sayit.0 uncaught exception: that.sayItGetSpeechCloud is not a function
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]: 2017-09-27 14:45:59.073  -  sayit.0 TypeError: that.sayItGetSpeechCloud is not a function
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/lib/text2speech.js:337:22)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Socket.onack (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Socket.onpacket (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Manager. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Manager.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Manager.ondecoded (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
          2017-09-27 14:45:59.131  - [31merror[39m: Caught by controller[2]:     at Decoder. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
          2017-09-27 14:45:59.132  - [31merror[39m: Caught by controller[2]:     at Decoder.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
          2017-09-27 14:45:59.132  - [31merror[39m: Caught by controller[2]:     at Decoder.add (/Users/pix/Documents/iobroker/node_modules/socket.io-parser/index.js:246:12)
          2017-09-27 14:45:59.132  - [31merror[39m: Caught by controller[2]:     at Manager.ondata (/Users/pix/Documents/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
          2017-09-27 14:45:59.132  - [31merror[39m: host.MacMini.local instance system.adapter.sayit.0 terminated with code 0 (OK)
          2017-09-27 14:45:59.132  - [32minfo[39m: host.MacMini.local Restart adapter system.adapter.sayit.0 because enabled
          2017-09-27 14:46:00.009  - [32minfo[39m: host.MacMini.local instance system.adapter.tankerkoenig.0 started with pid 78401</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
          Gruß,
          Pix
          • BluefoxB Offline
            BluefoxB Offline
            @pix:
            Gruß,
            Pix `
            Noch mal vom latest bitte probieren.
              pix
              Die "große" Fehlermeldung ist jetzt weg. Nur noch diese kleine:
              `2017-09-28 15:28:49.030  - [32minfo[39m: sayit.0 saying: Kinderzimmer Licht ist <emphasis>eingeschaltet</emphasis>!
              2017-09-28 15:28:49.129  - [31merror[39m: sayit.0 Answer in invalid format: {"error":"Unknown key"}
              2017-09-28 15:28:54.276  - [32minfo[39m: sayit.0 saying: Küchenlicht ist <emphasis>eingeschaltet</emphasis>!
              2017-09-28 15:28:54.381  - [31merror[39m: sayit.0 Answer in invalid format: {"error":"Unknown key"}[/code]`
              Vielleicht kann man die Strings <emphasis> und </emphasis> noch rausschneiden, bevor sie in sayit einlaufen. Oder sie werden von sayit ignoriert.
              Pix
