  4. Growatt Noah 2000 - Nulleinspeisung
    2.8k
    4.9k
    4.1k
growattnoahnulleinspeisung
77 Beiträge 8 Kommentatoren 32.3k Aufrufe 9 Beobachtet
  • R Ravermichl
    @liv-in-sky
    Interessant. Quasi selbst erstellt dann oder wie?
    Aber erspart das den Weg über die Cloud? Wohl nicht, wenn man Username und PW eingeben muss oder? Dann kann ich gleich den Growatt-Adapter benutzen 🤷
    liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    @ravermichl
    jetzt bin ich aber erstaunt:
    sieh dir mal die log zeiten an - das ist schnell
    javascript.0	09:05:40.564	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":0,"solar_w":30,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    javascript.0	09:06:10.628	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":0,"solar_w":31,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    javascript.0	09:06:40.695	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":0,"solar_w":32,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    javascript.0	09:06:50.716	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":26,"solar_w":32,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    javascript.0	09:07:00.740	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":0,"solar_w":32,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    javascript.0	09:07:10.761	info	script.js.MYSTUFF.STROM-PHOLTAIK.noah2mqtt: {"output_w":0,"solar_w":33,"soc":10,"charge_w":0,"discharge_w":0,"battery_num":1,"generation_total_kwh":240.4,"generation_today_kwh":0,"work_mode":"battery_first","status":"online"}
    R 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      @ravermichl
      Ravermichl
      @liv-in-sky
      Ja, durchaus. Man kann ja auch in der App selbst laufend aktualisieren. Also werden die Daten wohl auch dauernd in die Cloud geschickt und nicht nur alle fünf Minuten. Warum dann aber der Growattadapter nur alle fünf Minuten gefüttert wird, verstehe ich nicht.
        Ravermichl
        @liv-in-sky
        Konntest du testen, ob man auch Datenpunkte setzen kann und nicht nur lesen?
        liv-in-skyL 3 Antworten Letzte Antwort
        • R Ravermichl
          @liv-in-sky
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          @ravermichl
          Ich muss eigentlich nix mehr setzen am Noah
          Aber ich kann das Mal testen
          Bei mir war heute Null Sonne - der schläft schon wieder
          • R Ravermichl
            @liv-in-sky
            liv-in-skyL Offline
            liv-in-skyL Offline
            liv-in-sky
            @ravermichl du meinst die Default Power
            • R Ravermichl
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              @ravermichl
              habe den akku noch ein wenig entladen und getestet
              konnte die default power des noah setzen :-)
              R D 2 Antworten Letzte Antwort
                @ravermichl
                Ravermichl
                @liv-in-sky
                Oha.! Danke fürs Testen. Klingt gut. Jetzt würde ich nur noch gern verstehen, wie genau dieser Adapter seine Daten bekommt und wozu dieses "Go" dient. Möchte ungern was auf meinem iobroker installieren, was ich nicht kapiere 😭
                Und bringen würde es mir ohnehin nur was, wenn man sich damit den Growattserver Login spart. Ist das denn so?
                • R Ravermichl
                  @liv-in-sky
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  liv-in-sky
                  @ravermichl
                  ehrlich - ich weiß es nicht - beim setzen denke ich, er wird es brauchen - ich frag nochmal in dem anderen forum nach
                    @ravermichl
                    Ravermichl
                    @liv-in-sky
                    Akkudoktor? 😉 Eines der wenigen Foren, wo ich mich jetzt nicht auch noch extra registrieren wollte 😂
                    • R Ravermichl
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      liv-in-sky
                      @ravermichl
                      noah-mqtt simuliert wohl die shine app - so wie der alexa adapter die alexa app
                        @ravermichl
                        Ravermichl
                        @liv-in-sky
                        Mhm also ist das schon sone Art lokaler Zugriff. Denn die Daten in der App selbst kommen auch nicht aus der Cloud, sondern schon lokal, weil dort ist die Aktualisierung auch schneller als 5 Minuten. Nur die Daten aus der Cloud selbst kann man anscheinend nur alle 5 Minuten abrufen. Die Frage ist nur, ob es sich dieses Tool dann auch jedes mal bei einer Änderung am Noah einloggt oder ob es den Login offen hält (ähnlich wie der Alexa Adapter). Dann wäre es schon eine bessere Lösung, weil die Daten schneller kommen und die Logins reduziert würden 🤷 Noch besser wäre es, wenn man auf den Login bei Umstellung komplett verzichten könnte. Wer kann einem das sagen?
                        • R Ravermichl
                          @liv-in-sky
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          liv-in-sky
                          @ravermichl
                          ich glaube der trick ist, das es sich nur einmal einloggt - ähnlich, wie der adapter - bei den häufigen aktualisierungen würde man sofort geblockt - anders wie bei unserem python-tool
                          auf das login wirst du nie verzichten können - du kannst die app ja auch nicht ohne logging nutzen
                            @ravermichl
                            Ravermichl
                            @liv-in-sky said in Growatt Noah 2000 - Nulleinspeisung:
                            @ravermichl
                            Ja, könnte sein. Werd ich mal im Hinterkopf behalten, falls ich mit aktuelleren Daten von Noah arbeiten will oder ausgesperrt werde wg zu häufigem Login bei der Python-Methode. Bis jetzt lief es problemlos.
                            Trotzdem wäre eine vollständig lokale Steuerung schon sinnvoll. Vllt findet noch jemand raus, wie das geht oder growatt baut was ein.. Oder sagt uns, wie es geht 😁
                            • R Ravermichl
                              Nachfolgend "kurze" Projektvorstellung der Möglichkeit mit einem NOAH 2000 Speicher von Growatt und iobroker sowie python3 eine annähernde Nulleinspeisung zu generieren, auch wenn man keinen steuerbaren Wechselrichter hat. Es funktioniert bei mir seit ein paar Tagen sehr gut.
                              Lediglich wenn der Speicher voll ist und im Haus weniger verbraucht wird, als gerade vom Dach kommt, geht noch etwas ins Netz.
                              Ausgangslage:
                              Hardware:
                              Modulgesamtleistung: 1540wp
                              Speicher: Growatt Noah 2000
                              Wechselrichter: APSystems DS3-S, der von APSystems auf einen DS3-L (maximale Ausgangsleistung ca. 730Watt - Eingangsleistung: ca. 770Watt) gepimpt wurde.
                              Digitaler Stromzähler, der die einzelnen Leitungen saldiert.
                              IR-Lesekopf für Stromzähler
                              Am Noah dürfen keine Zeitpläne eingestellt sein
                              Adapter:
                              • "Smartmeter" für das auslesen des Stromzählers (alle 5 Sekunden) und abgreifen des saldierten Stromverbrauchs (im Blockly als Datenpunkt 1-0:16 dargestellt).
                              • "Growatt" für die Einbindung von Datenpunkten des NOAH (ist einfacher als auch diese mittels python3 auszulesen)
                              • "javascript" für Blockly
                              • "Solar - Wetter" für Ertragsprognose
                              Vorgehen:
                              1. Es ist ein Skript außerhalb iobroker notwendig.
                                a. Hierfür muss python3 mit package "growattServer" (Github: "PyPi_Growattserver") und aktuellster init.py dieses Pakets, da das Paket (Stand Version 1.5.1) die Variablen für den NOAH nocht nicht enthält.
                                Es muss zur Anpassung im entsprechenden Verzeichnis im iobroker ( überSSH) "[...]site-packages/growattServer" die enthaltene init.py durch die auf github enthaltene ersetzt werden.
                                b. Der Benutzer iobroker muss berechtigt sein das entsprechend zu erstellende python3 script auszuführen. Ich musste python3 hierfür nochmals explizit für den Nutzer "iobroker" installieren. Das "site-package" Verzeichnis befand sich dann bei mir unter /home/iobroker/.local/lib/python3.x/site-packages/growattServer
                              Das mit "nano" problemlos zu erstellende Skript für die Steuerung des Outputs des NOAH sieht bei mir aktuell wie folgt aus und ist auf dem iobroker unter dem Namen noahxw.py gespeichert:
                              import growattServer
                              import datetime
                              import getpass
                              import sys
                              Skript passt default_output noah auf bestimmten Wert an. Bspw.: Befehl: "python3 noahxw.py 150" passt Wert auf 150 Watt an
                              api = growattServer.GrowattApi(False, "Chrome")
                              login_response = api.login('Benutzername Growattlogin', 'Passwort Growattlogin')
                              response = api.update_noah_settings('SeriennummerNOAH', 'default_power', [int(sys.argv[1])])
                              print(response)
                              Mehr dazu u. a. in der Diskussion hier: github.com/indykoning/PyPi_GrowattServer/issues/88
                              1. Soviel zu den Vorbereitungen. Nun zum eigentlichen Blockly bzw. den Blocklys zur Steuerung des Output.
                              a. Mit folgendem Blockly wird die Aktivierung des Skripts zur Nulleinspeisung gesteuert. Hintergrund ist, dass ich die Server von Growatt möglichst wenig belasten will (bei jeder Änderung wird sich ja neu eingeloggt).
                              Somit ist ein Login an solchen Tagen nicht nötig, wo entweder die PV Leistung ohnehin so niedrig ist, dass gerade mal der Speicher voll wird, also schon meine Grundlast (ca. 190 W pro Stunde) diese verbraucht.
                              Daher lasse ich das Nulleinspeisungskript nur laufen, wenn die erwartete PV Leistung am Tag größer als 2.4 kwh ist. Diesen Wert habe ich für mich als sicher zu verbrauchenden Wert, auch wenn der Speicher sehr schnell voll werden sollte, errechnet.
                              Ist bewusst niedrig gewählt und absolut optional. Die Daten werden über den Adapter Solar-Wetter bereit gestellt.
                              Außerdem wird das Skript nur gestartet, wenn wir uns zwischen Sonnenaufgang und Sonnenuntergang befinden sowie erst dann, wenn der SoC bei mindestens 20% liegt.
                              Unter 15% wird es wieder beendet; ebenfalls nach Sonnenuntergang oder wenn die prognostizierte PV Leistung am Tag wieder unter 2.4 kwh fällt (optional).
                              Zw. 15 und 20 Prozent deshalb, weil der Growattadapter nur alle 5 Minuten aktualisiert und wenn ich 10% (untere Entladungsgrenze meines Noah genommen habe, wurde es tagsüber nur zufällig beendet und lief dann auch teilweise bei 11, weil die 10% nicht registriert wurden.
                              Die eingebauten Meldungen an Telegram sind optional; ebenso die Debug Ausgaben. Haben mir aber beim Testen sehr geholfen.
                              Außerdem stellt das Skript bei Start und Stop Werte sowohl für die Output-Variable (NOAH_Output - siehe dazu unten) und auch direkt am Noah den Outputwert (default power) ein (190 Watt entspricht ca. meiner Grundlast).
                              Noch ein paar Erläuterungen zum Skript:
                              • Variable Prognose Ertrag errechnet sich bei mir in dem ich den Mittelwert der beiden Werte, die der Adapter Solar-Watt liefert für meine Region bilde ((Max + Min) / 2) und diesen mit meinem Ertragswert (86%) der Anlagenausrichtung (Ost/West ca. 20% Neigung) multipliziere.
                              • Rest sollte selbsterklärend sein.
                              Skript ist m. E. optional, aber dient eben der Verringerung der Serverbelastung in Zeiten, wo es eh nicht gebraucht wird.
                              Screenshot vom Script auf Anfrage per PN erhältlich aufgrund schlechter Erfahrungen mit freier Verfügbarkeit...
                              b. Nachfolgendes Blockly steuert nach Aktivierung durch vorhergehendes die Nulleinspeisung:
                              Ausgangslage ist auch hier wieder eine möglichst geringe Serverbelastung und zudem eine möglichst geringe Einspeisung ins Netz. Daher orientiere ich mich bei der Wahl, welcher Wert eingestellt werden soll immer am geringsten übermittelten Stromsaldowert meines Zählers und nicht am größten. Mir ist es lieber ich beziehe kurz ein bisschen Strom, als das ich einen verschenke.
                              Zudem wurde es so konzipiert, dass eine Anpassung nur dann erfolgt, wenn die Abweichung zur 0 (Stromsaldo) kleiner als -10 oder größer als 20 Watt ist. Diese Werte sind beliebig anpassbar.
                              Weiterhin werden zwei Durchläufe (siehe dazu unten in den Erläuterungen) der Stromsaldomessungen miteinander verglichen und nur wenn die Werte innerhalb einer gewissen Toleranz (bei mir zw. - 20 und + 20) liegen, wird eine Änderung gesendet.
                              Das verhindert wirksam, dass bspw. wenn ein großer Verbraucher an ist und gerade Volleinspeisung erfolgt, aber dieser sich zwischendurch nur kurz abschaltet (passiert bspw. bei der Mikrowelle), sofort eine Anpassung nach unten (da ich ja immer auf den kleinsten Wert nahe 0 abstelle) erfolgt, nur um dann gleich wieder auf Volleinspeisung anzupassen.
                              Nachfolgend das Skript (m. E. sehr verschachtelt; mglw. kann es noch vereinfacht werden; mir fehlen dazu aber die Blockly Kenntnisse. Bspw. habe ich es nicht hingebracht, dass aus der Liste der Wert genommen wird der am nähesten an der 0 ist (weil das ja der kleinste Verbraucher ist). Somit konnte ich nur zwei Werte nutzen (was aber m. E. ausreicht) und musste mir mit dem "aus der Liste nimm Minimalwert und Maximalwert Abfragen behelfen, damit als kleinster Wert bspw. bei einer Liste mit [-49 und 5] nicht -49, sondern eben 5 (da näher an 0) genommen wird.
                              Erläuterungen in Worten:
                              Skript macht Folgendes:
                              Im ersten Abschnitt wird eine leere Liste erzeugt, in die bei jeder Aktualisierung der Stromsaldos meines Zählers der entsprechende Wert geschrieben wird (dieser Wert besteht also aus den Verbräuchen über meine drei Phasen und beinhaltet auch bereits eine eventuelle Einspeisungsleistung).
                              Die Pause vorab greift dann, wenn gerade die Leistung erst angepasst wurde, damit diese sich einpendeln kann, bevor wieder ein Stromsaldowert abgefragt wird (aktuell ist diese bei mir bei 13 Sekunden eingestellt - Variable ist also falsch benannt ;) )
                              Ist die Liste mit zwei Werten "voll", dann wird eine vorab eigens erstellter Datenpunkt "Kleinster_Verbrauch") mit dem Minimalwert der Liste beschrieben; das nachfolgende "falls" prüft, ob der Minimalwert kleiner als -10 ist und es eventuell einen "Maximalwert" zw. -10 und 20 gibt und passt in diesem Fall den "Kleinster_Verbrauch" auf den Maximalwert an, da dies derjenige am nächsten an der Null und innerhalb des von mir vorgegebenen Toleranzbereichs ist.
                              Elegantere Lösung wäre "Kleinster_Verbrauch" gleich auf den Wert in der Liste, der am nähesten an der 0 ist, zu setzen; wie oben geschrieben weiß ich allerdings nicht, wie das geht.
                              In den weiteren Variablen wird ein Vergleichswert "Kleinster_Verbraucher_Vergleich" zwischen zwei aufeinanderfolgenden Durchläufen des Listenabschnittes generiert. Wozu dies dient, steht oben.
                              Damit ist der Listenabschnitt abgeschlossen.
                              Im nächsten "Falls Trigger" wird nun bei Änderung des "Kleinster_Verbraucher" zunächst geprüft, ob die Toleranzen passen (Wertevergleich zweier aufeinanderfolgender Listenzyklen über "Kleinster_Verbraucher_Vergleich" und Prüfung, ob "Kleinster_Verbraucher" außerhalb Toleranzbereich liegt.
                              Falls zutreffend wird die Variable "Noah_Output" der spätestens nach zwei Durchläufem dem tatsächlichem default_output-Wert des Noahs entsprechen sollte, wie folgt aktualisiert:
                              Der eingestellte Output Wert des Datenpunkte "Noah Output" wird addiert um den Wert des kleinsten Verbrauchers multipliziert mit 1.1 (Formle: Noah_Output + (Kleinster_Verbraucher x 1.1); 1.1 deshalb, weil der Wert des "Kleinster_Verbraucher" ein realer Stromverbrauchswert ist und wenn ich diesen ausgleichen will, muss der Output des Noah in etwa 10% höher sein (bei mir funktioniert das tadellos).
                              Außerdem wird der Wert gerundet und zw. 0 und 800 begrenzt, da der Noah eh nicht mehr ausgeben kann.
                              Die anschließende Vairable 800over dient nur einer Kontrolle und gibt den tatsächlichen Wert aus, der eigentlich gesetzt werden müsste, also über 800.
                              Der nächste "falls" Abschnitt überprüft, ob der Wert bereits auf 800 gesetzt wurde und auf 800 bleiben soll, dann wird kein Befehl an den Noah gesendet; sonst schon.
                              Die Befehle sind ersichtlich; es wird das python-script ausgeführt und geprüft, ob ein Fehler kommt, dann erfolgt eine Nachricht an Telegramm (optional).
                              Anschließend werden 13 Sekunden Pause getriggert, um den Noah sich anpassen zu lassen.
                              Der falls Abschnitt darunter gehört noch zur Prüfung, ob schon über 800 Watt eingestellt wurden oder nicht.
                              Alle Debug und Telegramm Einschübe dienen der Kontrolle und waren bei Erstellung des Skriptes (hat mich über eine Woche gekostet) sehr hilfreich.
                              Ich hoffe diese zugegebenermaßen viel zu ausführliche Anleitung ist hilfreich für euch.
                              Für jede Skriptverbesserung bzw. Verkürzung bin ich dankbar!
                              VasflipaoV Offline
                              VasflipaoV Offline
                              Vasflipao
                              Hallo @ravermichl,
                              kein Interesse?!?! das gegenteil, der Interesse ist groß, zumindest von mir ;-), geile Sache was du da gebaut hast. Ich habe bei mir endlich alle Adapters installiert die man braucht und sogar die Noah-MQTT läuft jetzt auch bei mir. Es war eine größe Hürde die Ausführung von Python Skrypts, weil ich die Rückmeldungen nicht gesehen haben und dachte es klappt ja nicht, aber es hat die ganze Zeit funktioniert.
                              Naja Hacken dran. Jetzt kann ich mit den Einbau von den Skrypt für die Null-Einspeinsung beginnen. Könntest du es mir per "Export" im Blocky den Zukommen lassen, wenn es geht, wenn auf "Sicherheits-Gründen" nicht geht, werde ich mich mit Screenshots zurecht kommen,;-)
                              Mit der Implementierung von Schelly und Noah hat sich die Sache ein bisschen entschärft, klappt das mehr oder weniger gut, aber...., der ist zu langsam beim aktualisieren und geht viel Energie verloren. Das wird bestimmt viel besser mit den Skript, weil die Daten viel schneller auslesen kann und die Werte anpassen kann.
                              Wenn ich den Skript am Laufen habe, möchte ist es noch optimieren mit Dynamischen Tarife, in drei Monate bekomme ich Strom von Tibber :-).
                              Mein Equipment: 2xNoah, 2400 kwp (6xSolarmodulen), NEO 800, Shelly 3 Pro und Raspi 5.
                              Vielen Dank für die muhe und das Teilen
                              VG
                              P.S. Sorry für mein Deutsch, komme aus der Land der Sonne (Spanien) und arbeite ich noch dran.
                              • VasflipaoV Vasflipao
                                Hallo @ravermichl,
                                VG
                                Ravermichl
                                @vasflipao
                                Dein Deutsch ist immerhin besser als mein Spanisch 😂
                                Hast ne Nachricht im privat Chat.
                                  Andreas 1
                                  Guten Abend,
                                  ich habe seit einigen Tagen jetzt auch einen NOAH 2000 ( der Preis war gerade gut und bei dem Tibber Strompreis wg. der Dunkelflaute gab es keine Einwände seitens der Regierung).
                                  Die Möglichkeit am Speicher die Ausgangsleistung einzustellen ist eleganter als über openDtu am Hoymiles Wechselrichter, jedoch möchte ich nicht noch einen shelly im Schaltschrank verbauen lassen, da ist schon der tibber-pluse auf dem Zähler für den Haushaltsstrom und ein hitchi für die Wärmepumpe, Infos zum Strombedarf habe ich also ausreichend.
                                  Wenn also aus dem iobroker der gewünschte Wert ohne cloud dem NOAH übermittelt werden könnte wäre es die top Lösung.
                                  Jetzt im Herbst/Winter versuche ich den Speicher mit einem Ladegerät zu günstigen Zeiten aufzuladen und dann möglichst clever zu steuern. Mal sehen wie sich das so verhält.
                                  Wenn es sich einigermaßen bedienen lässt wird es nicht der letzte NOAH gewesen sein.
                                  • A Andreas 1
                                    Guten Abend,
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    liv-in-sky
                                    @andreas-1
                                    @andreas-1 sagte in Growatt Noah 2000 - Nulleinspeisung:
                                    da bin ich mir nicht so sicher. der WR wird ja auf eine leistungsabgabe eingestellt - der noah reagiert darauf. letztlich sagt der WR, was eingespeist werden soll !
                                    ich habe festgestellt, dass mir das verhalten bei z.b. wenig sonne (wie im moment) des noah's nicht gefällt - zb. sind im moment unter 180W an den modulen - d.h. der noah lädt sich bis zu seiner minmalgrenze und etwas darüber - dann aber entlädt er sich, wenn der WE etwas höher eingestellt ist . das geht dann den ganzen tag so. ich schalte bei diesem wetter den WE aus und lass den noah den ganzen tag laden - ab 17:00 wird dann der standard verbrauch abgegeben - find ich besser :-)
                                    wenn du regeln willst kommst du um den noah-mqtt nicht herum - der adapter ist zu langsam bei der datenaktualität https://github.com/mtrossbach/noah-mqtt/tree/main
                                    dieses tool ist wie die app und reagiert ziemlich flot - in beide richtungen - in iob brauchst du nur noch eine mqtt-instanz
                                      @andreas-1
                                      Ravermichl
                                      @liv-in-sky
                                      Also ich regle ohne noah-mqtt, da meine Regelungen keine Topaktuellen Daten vom Noah braucht.
                                      • R Ravermichl
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        liv-in-sky
                                        @ravermichl
                                        ja - der unterschied, glaube ich, ist, dass du nicht auf den akku achtest - ich will keine dauerndes laden und entladen - oder liege ich da falsch
                                          @ravermichl
                                          Ravermichl
                                          @liv-in-sky
                                          Da liegst du richtig, das mache ich manuell. Aber um auf den Akku zu achten, würde mir auch die 5min Verzögerung vom Adapter reichen
