  4. [Vorlage] Spotify Skript
    6.7k
javascript
745 Beiträge 95 Kommentatoren 342.1k Aufrufe 41 Beobachtet
    mikiline
    #301
    Bis das Problem behoben ist, kann man sich so aushelfen
    ein javascript.0.Spotify.ReglerLautstaerke und ein zugehöriges Blockly das bei Änderung eben den Wert an spotify-premium.0.Player.Volume übergibt.
    Dann behalten auch die "Regler" ihren Wert
    • X Offline
      X Offline
      xmace
      #302
      Ok gute idee. Danke :)
      • X Offline
        X Offline
        xmace
        #303
        Hi zusammen,
        Adapter läuft super bis auf folgende sporadische Log Einträge:
        spotify-premium.0	2018-03-17 12:24:26.445	error	erron in Request
        spotify-premium.0	2018-03-17 10:37:27.637	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:37:22.521	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:37:17.358	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:37:12.205	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:46.325	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:41.161	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:36.019	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:30.861	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:25.699	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:20.483	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:15.303	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:09.638	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:36:04.428	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:59.247	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:54.064	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:48.825	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:43.636	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:38.480	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:33.308	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:28.144	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:22.973	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:17.767	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:12.592	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:07.418	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:35:02.269	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:57.102	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:51.952	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:46.815	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:41.671	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:36.063	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:30.908	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:25.764	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:20.620	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:15.471	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:10.340	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:05.176	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:34:00.031	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:54.846	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:49.699	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:44.550	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:39.422	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:34.244	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:29.082	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:23.948	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:18.820	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:13.659	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:33:03.491	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:32:58.333	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:32:53.190	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:32:48.040	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:32:42.881	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        spotify-premium.0	2018-03-17 10:32:37.726	warn	Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable
        Danke und Grüße ;)
        • O Offline
          O Offline
          ossilampe
          #304
          Servus Mikiline
          kannst du das noch etwas erklären, ich versuche mich gerade an spotify per iobroker, klappt auch bis jetzt. nur mit der Visualisierung ist noch etwas schwer.
          dein script mit der Playlist versuche ich gerade zu verwenden, Bitte erkläre doch etwas genauer was du mit " erstelle 4 neue States" meinst und wo und wie,
          gruss und Danke
          @mikiline:
          Hallo nochmals,
          Hab zwar schon das ein oder andere gefunden, jedoch war mir das zu "unflexibel". Bei den meisten Skripten muss man die Liste selbst pflegen oder Eintragungen vornehmen.
          Deshalb hab ich mir mittlerweile ein Skript gebastelt, das die aktuelle Playlist, die gespielt wird in eine Value List einliest, den ich dann im Widget ValueList String anzeigen und auswählen kann.
          Die Liste wird bei jedem Wechsel der Playlist automatisch eingelesen!
          Kurz und knapp:
          • Erstellung 4 neuer States unter Javascript.0.Spotify
          • der State "javascript.0.Spotify.PlayList.PlayList" wird im Skript nicht direkt verwendet (sollte sein um zu verhindern das nach Track-Auswahl der Player aufhört die Playlist zu spielen (klappt aber momentan nicht)
          Bitte schön
          `createState("javascript.0.Spotify.PlayList.TrackList", function () {
          createState("javascript.0.Spotify.PlayList.TrackTitle", function () {
          createState("javascript.0.Spotify.PlayList.TrackID", function () {
          createState("javascript.0.Spotify.PlayList.PlayThis", function () {
          createState("javascript.0.Spotify.PlayList.PlayList", function () {
          ! on({id: 'spotify-premium.0.PlaybackInfo.Playlist', change: "ne"}, function (obj) {
          ! var AktuellePlaylist = getState('spotify-premium.0.PlaybackInfo.Playlist').val;
          setState("javascript.0.Spotify.PlayList.PlayList"/javascript.0.Spotify.PlayList.TrackID/, AktuellePlaylist);
          str_AktuellePlaylist = AktuellePlaylist.replace(/ /g, '');
          ! str_AktuellePlaylist = 'spotify-premium.0.Playlists.' + str_AktuellePlaylist + '.Track_List'
          setState("javascript.0.Spotify.PlayList.TrackList"/javascript.0.Spotify.PlayList.TrackID/, str_AktuellePlaylist);
          ! var json = JSON.parse(JSON.stringify(getState(str_AktuellePlaylist).val));
          ! var PlayListid ;
          var PlayListTitle ;
          ! for(var i = 0; i < json.length; i++) {
          PlayListid += json[i].id  + ';';
          PlayListTitle += json[i].title + ';';
          PlayListid = PlayListid.slice(9,-1);
          PlayListTitle = PlayListTitle.slice(9,-1);
          ! setState("javascript.0.Spotify.PlayList.TrackID"/javascript.0.Spotify.PlayList.TrackID/, PlayListid);
          setState("javascript.0.Spotify.PlayList.TrackTitle"/javascript.0.Spotify.PlayList.TrackID/, PlayListTitle);
          ! on({id: 'javascript.0.Spotify.PlayList.PlayThis', change: "ne"}, function (obj) {
          setState("spotify-premium.0.Player.TrackId"/track idto play/, getState("javascript.0.Spotify.PlayList.PlayThis").val);
          }); ! Falls der ein oder andere scripcrack noch einen Fehler findet oder eine Verbesserung des Codes liefern kann, gerne her damit. ! Hier noch mein Widget zur Auswahl der Tracks aus der Liste ! >! ~~[spoiler]~~[code][{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.Spotify.PlayList.PlayThis","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":"","visibility-groups-action":"hide","values":"{javascript.0.Spotify.PlayList.TrackID}","texts":"{javascript.0.Spotify.PlayList.TrackTitle}","height":"120","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-oid":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":true,"open":false},"style":{"left":"264px","top":"376px","width":"258px","height":"247px"},"widgetSet":"jqui"}][/code][/spoiler] ! viel Spass damit ! @twonky ! es wäre wie gest schön, wenn die aktuelle Playlist (Track_List) unter PlaybackInfo zu finden wäre, so erspart man sich das Suchen. ! Es ist mir noch aufgefallen, jetzt wenn ich ein Lied auswähle ändert sich der Wert Device.type von playlist in Track. ! Wähle ich jedoch in der Spotify App einen Track aus der aktuellen Playliste, bleibt "playlist" erhalten. ! Die Wiedergabe stoppt natürlich wenn auf "track" geändert wird, was unschön ist. ! Vielleicht wird das ja dann verhindert, wenn die aktuelle playlist auch unter den PlaybackInfo zu finden ist, dann weiss Spotify das ich "nur" einen anderen Track aus der bereits vorhandenen Playlist auswähle und führt mit dem nächsten Track fort.[/i][/i] ```
            mikiline
            #305
            Das Skript selbst erstellt 4 neue States unter javascript.0.spotify
            Dann liest es die aktuell gespielte Playlist ein und gibt die Ausgabe in den erstellten States wieder.
            Dann kann man damit weiter arbeiten…...hoffe ich habe geholfen
            • O Offline
              O Offline
              ossilampe
              #306
              habe es verstanden dank dir…
                dYna
                #307
                Vielen Dank!
                Funktioniert super :-)
                • K Offline
                  Knorki
                  #308
                  @xmace:
                  Wird nämlich jetzt dann nicht schön im Widget angezeit, …..
                  ![](</s><URL url=)<link_text text="https://www.forum.iobroker.net/download ... &mode=view">https://www.forum.iobroker.net/download/file.php?id=23240&mode=view</link_text>" /> ` ~~Hey xmace, der view für Spotify gefällt mir. Könntest Du den mit mir teilen?
                  Stefan~~
                    dYna
                    #309
                    @xmace:
                    Hi zusammen,
                    Danke und Grüße ;) `
                    Gibt es eine Möglichkeit, diese Log Einträge zu deaktivieren?
                    • 0 Offline
                      0 Offline
                      0018
                      #310
                      bekomme vom Adapter keine Werte mehr und im Log ist nur
                      "Unexpected api response http 202; continue polling; You will see a 202 response the first time a user connects to the Spotify Connect API or when the device is temporarily unavailable"
                      zu sehen. Woran kann das liegen?
                      Mfg
                      0018
                      • K Offline
                        Knorki
                        #311
                        gleiches Problem bei mir.
                        Stefan
                          rnbprofi
                          #312
                          Moin!
                          Ich erhalten leider ein "null" als Werte Ausgabe bei der "PlayList" Object Anzeige.
                          Kannst evtl. sagen, woran es liegt?
                          Vielen Dank im voraus.
                          @mikiline:
                          Hallo nochmals,
                          Kurz und knapp:
                          Bitte schön
                          ! var PlayListid ;
                          var PlayListTitle ;
                          }); ! Falls der ein oder andere scripcrack noch einen Fehler findet oder eine Verbesserung des Codes liefern kann, gerne her damit. ! Hier noch mein Widget zur Auswahl der Tracks aus der Liste ! >! ~~[spoiler]~~[code][{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.Spotify.PlayList.PlayThis","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":"","visibility-groups-action":"hide","values":"{javascript.0.Spotify.PlayList.TrackID}","texts":"{javascript.0.Spotify.PlayList.TrackTitle}","height":"120","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-oid":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":true,"open":false},"style":{"left":"264px","top":"376px","width":"258px","height":"247px"},"widgetSet":"jqui"}][/code][/spoiler] ! viel Spass damit ! @twonky ! es wäre wie gest schön, wenn die aktuelle Playlist (Track_List) unter PlaybackInfo zu finden wäre, so erspart man sich das Suchen. ! Es ist mir noch aufgefallen, jetzt wenn ich ein Lied auswähle ändert sich der Wert Device.type von playlist in Track. ! Wähle ich jedoch in der Spotify App einen Track aus der aktuellen Playliste, bleibt "playlist" erhalten. ! Die Wiedergabe stoppt natürlich wenn auf "track" geändert wird, was unschön ist. ! Vielleicht wird das ja dann verhindert, wenn die aktuelle playlist auch unter den PlaybackInfo zu finden ist, dann weiss Spotify das ich "nur" einen anderen Track aus der bereits vorhandenen Playlist auswähle und führt mit dem nächsten Track fort. [/i][/i] ```
                            mikiline
                            #313
                            • Die Playlist muss Laufen
                            • Die Playlist muss im Spotify-Adapter bekannt sein
                            Ansonsten kann ich Dir ohne Weitere Infos keine Angaben machen.
                              rnbprofi
                              #314
                              @mikiline:
                              Ansonsten kann ich Dir ohne Weitere Infos keine Angaben machen. `
                              Habe ich geprüft. Jetzt zeigt er mehr an, aber nicht die Liste. Folgend mein Script.
                              ! createState("javascript.2.Spotify.PlayList.TrackList", function () {
                              ! createState("javascript.2.Spotify.PlayList.TrackTitle", function () {
                              ! createState("javascript.2.Spotify.PlayList.TrackID", function () {
                              ! createState("javascript.2.Spotify.PlayList.PlayThis", function () {
                              ! createState("javascript.2.Spotify.PlayList.PlayList", function () {
                              ! on({id: 'javascript.2.Spotify.PlaybackInfo.Playlist', change: "ne"}, function (obj) {
                              ! var AktuellePlaylist = getState('javascript.2.Spotify.PlaybackInfo.Playlist').val;
                              ! setState("javascript.2.Spotify.PlayList.PlayList"/javascript.2.Spotify.PlayList.TrackID/, AktuellePlaylist);
                              ! str_AktuellePlaylist = AktuellePlaylist.replace(/ /g, '');
                              ! str_AktuellePlaylist = 'javascript.2.Spotify.Playlists.' + str_AktuellePlaylist + '.Track_List';
                              ! setState("javascript.2.Spotify.PlayList.TrackList"/javascript.2.Spotify.PlayList.TrackID/, str_AktuellePlaylist);
                              ! var PlayListid ;
                              ! var PlayListTitle ;
                              ! PlayListid += json__.id + ';';
                              ! PlayListTitle += json__.title + ';';
                              ! PlayListid = PlayListid.slice(9,-1);
                              ! PlayListTitle = PlayListTitle.slice(9,-1);
                              ! setState("javascript.2.Spotify.PlayList.TrackID"/javascript.2.Spotify.PlayList.TrackID/, PlayListid);
                              ! setState("javascript.2.Spotify.PlayList.TrackTitle"/javascript.2.Spotify.PlayList.TrackID/, PlayListTitle);
                              ! on({id: 'javascript.2.Spotify.PlayList.PlayThis', change: "ne"}, function (obj) {
                              ! setState("javascript.2.Spotify.Player.TrackId"/track idto play/, getState("javascript.2.Spotify.PlayList.PlayThis").val);
                              ! });____ __ 5211_screenshot_2018-04-07_07.58.42_preview.png __
                                mikiline
                                #315
                                die Variablen aus meinem Skript "spotify-premium.0." darfst du nicht ändern…..denn das ist der Spotify Adapter aus dem die Werte für das Skript geholt werden
                                Du darfst wenn schon nur die "javascript.0." in Deine ändern.
                                Wenn du mein Skript 1:1 übernimmst sollte es gehen.....denk du hast auch einen Javascript.0 Object
                                  rnbprofi
                                  #316
                                  @mikiline:
                                  Wenn du mein Skript 1:1 übernimmst sollte es gehen.....denk du hast auch einen Javascript.0 Object `
                                  Verstanden. Habe tatsächlich .2. da sich die erste Instanz verabschiedet hat… wenn ich neu installiere, da erstellt er automatisch die nächste Instanz...
                                  Muss ich dann auch "spotify-premium.0." auch auf "spotify-premium.2." ändern?
                                    mikiline
                                    #317
                                    das änderst du in die instanz in der spotify-adapter läuft…....
                                    • twonkyT Offline
                                      twonkyT Offline
                                      twonky
                                      #318
                                      Nach einem Monat gibt es mal wieder eine neue Version vom Adapter: https://github.com/twonky4/ioBroker.spotify-premium
                                      Changelog:
                                      • automatisches Aktualisieren der Geräte und Playlisten (im Adapter konfigurierbar)
                                      • neuer State Devices.GERÄTNAME.is_available zeigt an ob ein Gerät verfügbar ist
                                      • zeigt Warnmeldung http 202 nur noch als debug und nur noch einmal an
                                      • die States Player.Shuffle, Player.Playlist_ID, Player.TrackId und Player.Volume zeigen ebenfalls den aktuellen Wert an
                                      • neue States Playlists.PLAYLISTNAME.image_url, PlaybackInfo.Playlist_image_url, PlaybackInfo.Album_image_url
                                      • den State PlaybackInfo.image_url als deprecated markiert. Wird bei Neuinstallation nicht mehr mit angelegt und in zukünftigen Versionen nicht mehr aktualisiert
                                      • das Ändern des State Playlists.PLAYLISTNAME.Track_List funktioniert nun wie in Luckys Skript. Man kann direkt einen Titel aus einer Playlist abspielen, wenn der State mit dessen Positionsnummer befüllt wird.
                                        mikiline
                                        #319
                                        Super und herzlichen Dank für die Mühe!
                                        Der State "Playlists.PLAYLISTNAME.Track_ID" wird bei mir nicht erstellt…...muss ich etwas zusätzliches tun?
                                        Löschen und neu Anlegen oder sowas?
                                          mikiline
                                          #320
                                          So….hab mal alle Playlists gelöscht und neu einlesen lassen.
                                          nur werden die States image_url erstellt, jedoch der State Track_ID immer noch nicht. Des Weiteren ist mir aufgefallen, das unter der Track_List nur noch ein Liedname steht. Das war vorher anders, oder ? stand da nicht [Object][object] ?
                                          Anbei noch ein Bild der Objecte einer Playlist nach dem Adapter Update (über Github, keine Neuinstallation)
