  4. Geekworm X1202 USV Variable in IObroker übernehmen
45 Beiträge 5 Kommentatoren 5.7k Aufrufe 3 Beobachtet
  • L Lieggie
    @oliverio
    Variable erstellt
    Minutliche ausführung
    nu komme ich nicht weiter weil mein merged.py so aussieht.
    wo soll ich deine Zeilen einfügen.
    #!/usr/bin/python3
    import os
    import struct
    import smbus
    import time
    import logging
    import subprocess
    import gpiod
    from subprocess import call
    # User-configurable variables
    SHUTDOWN_THRESHOLD = 3  # Number of consecutive failures required for shutdown
    SLEEP_TIME = 60  # Time in seconds to wait between failure checks
    Loop =  False
    def readVoltage(bus):
        read = bus.read_word_data(address, 2)
        swapped = struct.unpack("<H", struct.pack(">H", read))[0]
        voltage = swapped * 1.25 / 1000 / 16
        return voltage
    def readCapacity(bus):
        read = bus.read_word_data(address, 4)
        capacity = swapped / 256
        return capacity
    def get_battery_status(voltage):
        if 3.87 <= voltage <= 4.2:
            return "Full"
        elif 3.7 <= voltage < 3.87:
            return "High"
        elif 3.55 <= voltage < 3.7:
            return "Medium"
        elif 3.4 <= voltage < 3.55:
            return "Low"
        elif voltage < 3.4:
            return "Critical"
        else:
            return "Unknown"
    # Ensure only one instance of the script is running
    pid = str(os.getpid())
    pidfile = "/run/X1200.pid"
    if os.path.isfile(pidfile):
        print("Script already running")
        exit(1)
    else:
        with open(pidfile, 'w') as f:
            f.write(pid)
    try:
        bus = smbus.SMBus(1)
        address = 0x36
        PLD_PIN = 6
        chip = gpiod.Chip('gpiochip4')
        pld_line = chip.get_line(PLD_PIN)
        pld_line.request(consumer="PLD", type=gpiod.LINE_REQ_DIR_IN)
        while True:
            failure_counter = 0
            for _ in range(SHUTDOWN_THRESHOLD):
                ac_power_state = pld_line.get_value()
                voltage = readVoltage(bus)
                battery_status = get_battery_status(voltage)
                capacity = readCapacity(bus)
                print(f"Capacity: {capacity:.2f}% ({battery_status}), AC Power State: {'Plugged in' if ac_power_state == 1 else 'Unplugged'}, Voltage: {voltage:.2f}V")
                if capacity < 20:
                    print("Battery level critical.")
                    failure_counter += 1
                elif voltage < 3.20:
                    print("Battery voltage critical.")
                elif ac_power_state == 0:
                    print("UPS is unplugged or AC power loss detected.")
                else:
                    failure_counter = 0
                    break
                if failure_counter < SHUTDOWN_THRESHOLD:
                    time.sleep(SLEEP_TIME)
            if failure_counter >= SHUTDOWN_THRESHOLD:
                shutdown_reason = ""
                if capacity < 20:
                    shutdown_reason = "due to critical battery level."
                    shutdown_reason = "due to critical battery voltage."
                    shutdown_reason = "due to AC power loss or UPS unplugged."
                shutdown_message = f"Critical condition met {shutdown_reason} Initiating shutdown."
                print(shutdown_message)
                call("sudo nohup shutdown -h now", shell=True)
            else:
                #print("System operating within normal parameters. No action required.")
                if Loop:
                else:
                    exit(0)
    finally:
            os.unlink(pidfile)
        exit(0)
    #41
    @lieggie sagte: wo soll ich deine Zeilen einfügen.
    Damit es ohne sudo laufen kann, kommentiere die Zeilen 44 bis 51 und 106, 107 aus und teste es erst einmal auf der Konsole (ohne sudo).
    python3 /opt/iobroker/merged.py
    L 1 Antwort Letzte Antwort
      Lieggie
      #42
      @paul53 said in Geekworm X1202 USV Variable in IObroker übernehmen:
      Ich bekomme nun den String angezeigt
      nun kann ich mich an das zerlegen machen . Vielen Dank.
      Magst du mir erklären was wir dort nun genau rausgenommen haben ?
      • L Lieggie
        #43
        @lieggie sagte: Magst du mir erklären was wir dort nun genau rausgenommen haben ?
        Die Prüfung über eine pid-Datei, ob das Skript schon läuft, wurde raus genommen. Das Skript wird nur jede Minute gestartet und sollte sich vorher selbst beenden mit
        Loop = False
          Loop = False
          Lieggie
          schrieb am zuletzt editiert von Lieggie
          #44
          @paul53 danke an alle die geholfen haben, nun läuft alles
          anbei noch mal das Blockly
          und das merged Skript ohne die Zeilen 44 bis 51 und 106, 107
          co#!/usr/bin/python3
          import os
          import struct
          import smbus
          import time
          import logging
          import subprocess
          import gpiod
          from subprocess
          import call
          Loop =  False
              return voltage
              return capacity
                  return "Full"
                  return "High"
                  return "Medium"
                  return "Low"
              elif voltage < 3.4:
                  return "Critical"
              else:
                  return "Unknown"
          try:
              address = 0x36
              PLD_PIN = 6
              while True:
                  failure_counter = 0
                      if capacity < 20:
                      else:
                          failure_counter = 0
                          break
                      if capacity < 20:
                  else:
                      if Loop:
                      else:
                          exit(0)
          finally:
              exit(0)de_text
          • L Lieggie
            @oliverio
            ich versuche grad 2 gleisig zu fahren....ich komme weder mit blockly noch mit deinem Script weiter.
            Aus deine script bekomme ich diesen fehler
            javascript.0	14:59:52.402	info	Start JavaScript script.js.USV (Javascript/js)
            javascript.0	14:59:52.417	error	script.js.USV: Error: EINVAL: invalid argument, write
            javascript.0	14:59:52.417	error	at script.js.USV:26:18
            javascript.0	14:59:52.417	error	at script.js.USV:169:3
            komme damit auch nicht weiter
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #45
            @lieggie sagte in Geekworm X1202 USV Variable in IObroker übernehmen:
            hier mal noch was ich dir per PM geantwortet habe für alle
            wahrscheinlich das was thomas geschrieben hat, das seit der letzten betriebssystem version die bisherige methode zur kommunikation mit gpio nicht mehr funktioniert. man müsste dann opengpio nehmen, das berücksichtigt die neuesten änderungen. wahrscheinlich wäre es einfach, aber es kann auch ein wenig testen und rumprobieren bedeuten.
            da du geschrieben hast, das das mit skript nix für dich ist, verfolge erst einmal mit den anderen den python weg.
            wenn da wirklich gar nix geht, dann können wir mal schauen. für doppelt-entwicklung ist die zeit aktuell nicht da
            so wie es aussieht habt ihr ja den python weg auch hinbekommen
            Meine Adapter und Widgets
            Links im Profil
