  4. Nach Update js-controller macht host.raspberrypi Fehler
37 Beiträge 5 Kommentatoren 5.7k Aufrufe 3 Beobachtet
  • spicerS Offline
    spicerS Offline
    spicer
    Nach Update des js-controller von @6.0.9 nach @6.0.11 macht host.raspberrypi folgende Fehler:
    host.raspberrypi
    	2024-08-28 22:44:01.596	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    	2024-08-28 22:44:01.595	error	Caught by controller[0]: Node.js v18.20.4
    host.raspberrypi
    	2024-08-28 22:44:01.595	error	Caught by controller[0]: }
    host.raspberrypi
    	2024-08-28 22:44:01.595	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
    host.raspberrypi
    	2024-08-28 22:44:01.595	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi
    	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
    host.raspberrypi
    	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.raspberrypi
    	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.raspberrypi
    	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.raspberrypi
    	2024-08-28 22:44:01.593	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.raspberrypi
    	2024-08-28 22:44:01.592	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
    host.raspberrypi
    	2024-08-28 22:44:01.592	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    host.raspberrypi
    	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.raspberrypi
    	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
    host.raspberrypi
    	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    host.raspberrypi
    	2024-08-28 22:44:01.591	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
    host.raspberrypi
    	2024-08-28 22:44:01.590	error	Caught by controller[0]: Require stack:
    host.raspberrypi
    	2024-08-28 22:44:01.590	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
    host.raspberrypi
    	2024-08-28 22:44:01.590	error	Caught by controller[0]: ^
    host.raspberrypi
    	2024-08-28 22:44:01.589	error	Caught by controller[0]: throw err;
    host.raspberrypi
    	2024-08-28 22:44:01.588	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
    Echarts läuft so auch nicht mehr.
    Hat jemand Rat?
    Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
    (Murphys Gesetz)
    • spicerS spicer
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      Hat jemand Rat?
      @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
      Node.js v18.20.4
      iob nodejs-update
      Danach die Langfassung von
      iob diag
      spicerS 1 Antwort Letzte Antwort
        Node.js v18.20.4
        iob nodejs-update
        iob diag
        spicerS Offline
        spicerS Offline
        spicer
        schrieb am zuletzt editiert von spicer
        ======== Start marking the full check here =========
        Skript v.2024-05-22
        *** BASE SYSTEM ***
        Static hostname: raspberrypi
        Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
        Kernel: Linux 6.1.21-v7+
        Architecture: arm
        Model : Raspberry Pi 3 Model B Rev 1.2
        Docker : false
        Virtualization : none
        Kernel : armv7l
        Userland : 32 bit
        Systemuptime and Load:
        23:15:39 up 1:10, 3 users, load average: 3.87, 3.05, 1.60
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
        Local time: Wed 2024-08-28 23:15:39 CEST
        Universal time: Wed 2024-08-28 21:15:39 UTC
        RTC time: Wed 2024-08-28 21:15:40
        Time zone: Europe/Zurich (CEST, +0200)
        NTP service: active
        RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal: tty
        Boot Target: graphical.target
        *** MEMORY ***
        total used free shared buff/cache available
        Mem: 921M 547M 147M 0.0K 227M 315M
        Swap: 2.0G 374M 1.7G
        Total: 3.0G 922M 1.8G
        Active iob-Instances: 10
              921 M total memory
              547 M used memory
              404 M active memory
              278 M inactive memory
              147 M free memory
               39 M buffer memory
              187 M swap cache
             2047 M total swap
              374 M used swap
             1673 M free swap
        *** top - Table Of Processes ***
        top - 23:15:40 up 1:10, 3 users, load average: 3.87, 3.05, 1.60
        Tasks: 196 total, 2 running, 194 sleeping, 0 stopped, 0 zombie
        %Cpu(s): 39.2 us, 5.1 sy, 0.0 ni, 55.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
        MiB Mem : 922.0 total, 146.0 free, 548.2 used, 227.7 buff/cache
        MiB Swap: 2048.0 total, 1673.2 free, 374.8 used. 314.1 avail Mem
        *** FAILED SERVICES ***
        • plymouth-start.service loaded failed failed Show Plymouth Boot Screen
        LOAD = Reflects whether the unit definition was properly loaded.
        SUB = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        /dev/root ext4 118G 12G 101G 11% /
        devtmpfs devtmpfs 333M 0 333M 0% /dev
        tmpfs tmpfs 461M 0 461M 0% /dev/shm
        tmpfs tmpfs 185M 1.1M 184M 1% /run
        tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
        /dev/sda1 vfat 255M 51M 205M 20% /boot
        tmpfs tmpfs 93M 24K 93M 1% /run/user/1000
        [Wed Aug 28 22:04:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=7a0c97b2-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Aug 28 22:04:53 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Aug 28 22:04:53 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Aug 28 22:04:56 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET SOURCE FSTYPE OPTIONS
        / /dev/sda2 ext4 rw,noatime
        |-/dev devtmpfs devtmpfs rw,relatime,size=340460k,nr_inodes=85115,mode=755
        | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev
        | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | -/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | -/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
        | -/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | -/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
        | -/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 -/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.5G /var/
        975M /var/log
        969M /var/log/journal/b5953832ba8144d6b0bc329e94b66653
        335M /var/cache
        Archived and active journals take up 968.0M in the file system.
        /opt/iobroker/backups:
        92M /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        816M /opt/iobroker/iobroker-data/
        710M /opt/iobroker/iobroker-data/files
        441M /opt/iobroker/iobroker-data/files/javascript.admin
        409M /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs v20.17.0
        /usr/bin/node v20.17.0
        /usr/bin/npm 10.8.2
        /usr/bin/npx 10.8.2
        /usr/bin/corepack 0.29.3
        nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
        *** 20.17.0-1nodesource1 1001
        500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
        100 /var/lib/dpkg/status
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        12.22.12~dfsg-1~deb11u4 500
        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Core adapters versions
        js-controller: 6.0.11
        admin: 7.0.23
        javascript: 8.7.6
        nodejs modules from github: 0
        Adapter State
        • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        • system.adapter.backitup.0 : backitup : raspberrypi - enabled
        • system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 80
          system.adapter.discovery.0 : discovery : raspberrypi - disabled
          system.adapter.echarts.0 : echarts : raspberrypi - enabled
          system.adapter.email.0 : email : raspberrypi - disabled
          system.adapter.flot.0 : flot : raspberrypi - disabled
          system.adapter.heizoel24-mex.0 : heizoel24-mex : raspberrypi - enabled
        • system.adapter.history.0 : history : raspberrypi - enabled
        • system.adapter.javascript.0 : javascript : raspberrypi - enabled
        • system.adapter.mqtt.1 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
          system.adapter.openweathermap.0 : openweathermap : raspberrypi - enabled
          system.adapter.ping.0 : ping : raspberrypi - disabled
          system.adapter.shelly.0 : shelly : raspberrypi - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.solarmanpv.0 : solarmanpv : raspberrypi - enabled
        • system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0
        • system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled
          system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled
          system.adapter.vis.0 : vis : raspberrypi - enabled
        • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • instance is alive
        ioBroker-Repositories
        │ (index) │ name │ url │ auto upgrade │
        │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
        │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter "admin" : 7.0.23 , installed 7.0.23
        Adapter "backitup" : 3.0.19 , installed 3.0.19
        Adapter "deconz" : 1.4.1 , installed 1.4.1
        Adapter "discovery" : 4.5.0 , installed 4.5.0
        Adapter "echarts" : 1.7.2 , installed 1.7.2
        Adapter "email" : 1.3.1 , installed 1.3.1
        Adapter "flot" : 1.12.0 , installed 1.12.0
        Adapter "heizoel24-mex": 1.3.5 , installed 1.3.5
        Adapter "history" : 3.0.1 , installed 3.0.1
        Adapter "javascript" : 8.7.6 , installed 8.7.6
        Controller "js-controller": 6.0.11 , installed 6.0.11
        Adapter "mqtt" : 5.2.0 , installed 5.2.0
        Adapter "openweathermap": 1.1.2 , installed 1.1.2
        Adapter "ping" : 1.6.2 , installed 1.6.2
        Adapter "shelly" : 7.0.0 , installed 7.0.0
        Adapter "simple-api" : 2.8.0 , installed 2.8.0
        Adapter "socketio" : 6.7.1 , installed 6.7.1
        Adapter "solarmanpv" : 0.5.1 , installed 0.5.1
        Adapter "telegram" : 3.9.0 , installed 3.9.0
        Adapter "tr-064" : 4.3.0 , installed 4.3.0
        Adapter "vis" : 1.5.6 , installed 1.5.6
        Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
        Adapter "web" : 6.2.5 , installed 6.2.5
        Adapter "ws" : 2.6.2 , installed 2.6.2
        Adapter "zigbee" : 1.10.3 , installed 1.10.3
        Objects and States
        Objects: 2500
        States: 2012
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 136564 26546/iobroker.js-c
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 136569 26546/iobroker.js-c
        tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 19616 1562/deCONZ
        tcp 0 0 0.0.0.0:444 0.0.0.0:* LISTEN 0 13280 608/nginx: master p
        tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 139292 26882/io.mqtt.1
        tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15371 578/vncserver-x11-c
        tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 1018 558/cupsd
        tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 0 13279 608/nginx: master p
        tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 17836 1562/deCONZ
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13755 594/sshd: /usr/sbin
        tcp6 0 0 :::8081 :::* LISTEN 1001 137292 26574/io.admin.0
        tcp6 0 0 :::8082 :::* LISTEN 1001 137130 26709/io.web.0
        tcp6 0 0 :::5900 :::* LISTEN 0 15370 578/vncserver-x11-c
        tcp6 0 0 :::22 :::* LISTEN 0 13757 594/sshd: /usr/sbin
        tcp6 0 0 ::1:631 :::* LISTEN 0 1017 558/cupsd
        udp 0 0 0.0.0.0:631 0.0.0.0:* 0 13305 677/cups-browsed
        udp 0 0 0.0.0.0:53889 0.0.0.0:* 108 837 394/avahi-daemon: r
        udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 835 394/avahi-daemon: r
        udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 138664 26844/io.deconz.0
        udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 20612 1562/deCONZ
        udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13764 516/dhcpcd
        udp6 0 0 :::55524 :::* 108 838 394/avahi-daemon: r
        udp6 0 0 :::5353 :::* 108 836 394/avahi-daemon: r
        udp6 0 0 :::1900 :::* 1001 138666 26844/io.deconz.0
        udp6 0 0 :::1900 :::* 1001 138665 26844/io.deconz.0
        udp6 0 0 :::546 :::* 0 13819 516/dhcpcd
        2024-08-28 23:17:10.734 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
        2024-08-28 23:17:10.935 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] publishOnSubscribe
        2024-08-28 23:17:10.940 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.026 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] connected with secret 1724879831024_5801
        2024-08-28 23:17:11.031 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
        2024-08-28 23:17:11.233 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] publishOnSubscribe
        2024-08-28 23:17:11.241 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.330 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] connected with secret 1724879831327_2609
        2024-08-28 23:17:11.337 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
        2024-08-28 23:17:11.539 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] publishOnSubscribe
        2024-08-28 23:17:11.548 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.648 - info: mqtt.1 (26882) Client [mosqpub|20107-Dachrollo] connected with secret 1724879831646_7297
        2024-08-28 23:17:11.668 - info: mqtt.1 (26882) Client [mosqpub|20107-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.767 - info: mqtt.1 (26882) Client [mosqpub|20109-Dachrollo] connected with secret 1724879831760_5992
        2024-08-28 23:17:11.777 - info: mqtt.1 (26882) Client [mosqpub|20109-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.876 - info: mqtt.1 (26882) Client [mosqpub|20111-Dachrollo] connected with secret 1724879831869_594
        2024-08-28 23:17:11.888 - info: mqtt.1 (26882) Client [mosqpub|20111-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:11.983 - info: mqtt.1 (26882) Client [mosqpub|20113-Dachrollo] connected with secret 1724879831982_6023
        2024-08-28 23:17:11.989 - info: mqtt.1 (26882) Client [mosqpub|20113-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:12.087 - info: mqtt.1 (26882) Client [mosqpub|20115-Dachrollo] connected with secret 1724879832085_8693
        2024-08-28 23:17:12.094 - info: mqtt.1 (26882) Client [mosqpub|20115-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:12.379 - info: mqtt.1 (26882) Client [mosqpub|20130-Dachrollo] connected with secret 1724879832377_2746
        2024-08-28 23:17:12.386 - info: mqtt.1 (26882) Client [mosqpub|20130-Dachrollo] connection closed: disconnected
        2024-08-28 23:17:12.552 - info: mqtt.1 (26882) Client [mosqpub|20136-Dachrollo] connected with secret 1724879832551_8318
        2024-08-28 23:17:12.562 - info: mqtt.1 (26882) Client [mosqpub|20136-Dachrollo] connection closed: disconnected
        iob diag has finished.
        Press any key for a summary
        diag.txt
        (Murphys Gesetz)
        spicerS Thomas BraunT 2 Antworten Letzte Antwort
        • spicerS spicer
          Skript v.2024-05-22
          *** BASE SYSTEM ***
          Icon name: computer
          Architecture: arm
          Docker : false
          Kernel : armv7l
          Userland : 32 bit
          CPU threads: 4
          Current issues:
          NTP service: active
          RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal: tty
          *** MEMORY ***
                921 M total memory
                547 M used memory
                404 M active memory
                147 M free memory
                 39 M buffer memory
                187 M swap cache
               2047 M total swap
                374 M used swap
               1673 M free swap
          *** FILESYSTEM ***
          /var:
          3.5G /var/
          975M /var/log
          335M /var/cache
          USB-Devices by-id:
          /usr/bin/npm 10.8.2
          /usr/bin/npx 10.8.2
          nodejs:
          Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States type: jsonl
          admin: 7.0.23
          javascript: 8.7.6
          Adapter State
          • instance is alive
          Objects and States
          Objects: 2500
          States: 2012
          Pending Updates: 0
          diag.txt
          spicerS Offline
          spicerS Offline
          spicer
          Sorry. Hier der richtige Log:
          			v.2024-05-22
                   Icon name: computer
                Architecture: arm
          Installation: 		native
          Kernel: 		armv7l
          Userland: 		32 bit
          Timezone: 		Europe/Zurich (CEST, +0200)
          User-ID: 		1000
          Pending OS-Updates: 	0
          Pending iob updates: 	0
          Nodejs-Installation:
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          Recommended versions are nodejs 20.17.0 and npm 10.8.2
          MEMORY:
          Mem:            921M        557M        149M        0.0K        214M        302M
          Swap:           2.0G        441M        1.6G
          Total:          3.0G        999M        1.8G
          ioBroker Core: 		js-controller 		6.0.11
          			admin 			7.0.23
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          Objects: 		2500
          States: 		2012
          Size of iob-Database:
          14M	/opt/iobroker/iobroker-data/objects.jsonl
          4.6M	/opt/iobroker/iobroker-data/states.jsonl
          (Murphys Gesetz)
          • spicerS spicer
            Skript v.2024-05-22
            *** BASE SYSTEM ***
            Icon name: computer
            Architecture: arm
            Docker : false
            Kernel : armv7l
            Userland : 32 bit
            CPU threads: 4
            Current issues:
            NTP service: active
            RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal: tty
            *** MEMORY ***
                  921 M total memory
                  547 M used memory
                  404 M active memory
                  147 M free memory
                   39 M buffer memory
                  187 M swap cache
                 2047 M total swap
                  374 M used swap
                 1673 M free swap
            *** FILESYSTEM ***
            /var:
            3.5G /var/
            975M /var/log
            335M /var/cache
            USB-Devices by-id:
            /usr/bin/npm 10.8.2
            /usr/bin/npx 10.8.2
            nodejs:
            Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States type: jsonl
            admin: 7.0.23
            javascript: 8.7.6
            Adapter State
            • instance is alive
            Objects and States
            Objects: 2500
            States: 2012
            Pending Updates: 0
            diag.txt
            Installier das bei nächster Gelegenheit komplett neu.
            Dann ohne Desktop und in der 64Bit-Version.
            Und mit einem username ungleich 'pi' und ungleich 'iobroker'.
            iob start echarts.0
            sagt?
            spicerS 2 Antworten Letzte Antwort
              iob start echarts.0
              sagt?
              spicerS Offline
              spicerS Offline
              spicer
              iob start echarts.0 sagt nichts!
              Den Desktop brauche ich, da deCONZ auch da drauf läuft und ich VNC brauche.
              Der RPI 3 kann 64bit?
              (Murphys Gesetz)
              • spicerS spicer
                @spicer
                Zeigen. Komplette Ein- wie Ausgabezeilen.
                • spicerS spicer
                  Nein, braucht man nicht. deCONZ läuft auch headless. Und VNC braucht es auf einem Server nie. Weil da nie eine GUI rennt.
                  Ja.
                    @spicer
                    spicerS Offline
                    spicerS Offline
                    spicer
                    pi@raspberrypi:~ $ iob start echarts.0
                    pi@raspberrypi:~ $
                    (Murphys Gesetz)
                    • spicerS spicer
                      pi@raspberrypi:~ $
                      @spicer
                      iob list instances
                        @spicer
                        iob list instances
                        spicerS Offline
                        spicerS Offline
                        spicer
                        pi@raspberrypi:~ $ iob list instances
                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        + instance is alive
                        (Murphys Gesetz)
                        • spicerS spicer
                          + instance is alive
                          @spicer
                          Dann schau nochmal in das Log:
                          iob logs
                            @spicer
                            iob logs
                            spicerS Offline
                            spicerS Offline
                            spicer
                             MB von 922MB (33%)
                            2024-08-28 23:27:00.129  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1638
                             MB von 2048MB (80%)
                            2024-08-28 23:27:10.247  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connected with secret 1724880430246_4288
                            2024-08-28 23:27:10.252  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:27:10.453  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] publishOnSubscribe
                            2024-08-28 23:27:10.456  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:10.546  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connected with secret 1724880430545_7858
                            2024-08-28 23:27:10.552  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:27:10.752  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] publishOnSubscribe
                            2024-08-28 23:27:10.757  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:10.845  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connected with secret 1724880430844_7856
                            2024-08-28 23:27:10.850  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:27:11.051  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] publishOnSubscribe
                            2024-08-28 23:27:11.054  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:11.139  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connected with secret 1724880431138_4610
                            2024-08-28 23:27:11.143  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:27:11.344  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] publishOnSubscribe
                            2024-08-28 23:27:11.348  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:11.436  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connected with secret 1724880431435_6621
                            2024-08-28 23:27:11.439  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:27:11.640  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] publishOnSubscribe
                            2024-08-28 23:27:11.644  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:11.742  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connected with secret 1724880431741_3090
                            2024-08-28 23:27:11.747  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:11.842  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connected with secret 1724880431840_414
                            2024-08-28 23:27:11.849  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:11.920  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880431917_6742
                            2024-08-28 23:27:11.942  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connected with secret 1724880431941_8754
                            2024-08-28 23:27:11.947  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:12.042  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connected with secret 1724880432041_2336
                            2024-08-28 23:27:12.047  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:12.051  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:27:12.065  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:27:12.066  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                            2024-08-28 23:27:12.142  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connected with secret 1724880432141_7072
                            2024-08-28 23:27:12.147  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:12.251  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:27:12.265  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:27:12.266  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:27:12.268  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:27:12.432  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connected with secret 1724880432431_7101
                            2024-08-28 23:27:12.437  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:12.465  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880432460_7409
                            2024-08-28 23:27:12.584  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:27:12.593  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:27:12.605  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connected with secret 1724880432604_1289
                            2024-08-28 23:27:12.609  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connection closed: disconnected
                            2024-08-28 23:27:12.785  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:27:12.794  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:27:12.795  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:27:12.796  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:27:16.040  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880433108_3203
                            2024-08-28 23:27:16.058  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                            2024-08-28 23:27:16.059  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                            2024-08-28 23:27:16.260  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                            2024-08-28 23:27:17.184  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                            2024-08-28 23:27:19.478  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
                            2024-08-28 23:28:08.339  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                            2024-08-28 23:28:10.235  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connected with secret 1724880490233_3193
                            2024-08-28 23:28:10.238  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:28:10.439  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] publishOnSubscribe
                            2024-08-28 23:28:10.443  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:10.530  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connected with secret 1724880490529_1990
                            2024-08-28 23:28:10.534  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:28:10.734  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] publishOnSubscribe
                            2024-08-28 23:28:10.737  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:10.824  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connected with secret 1724880490822_5106
                            2024-08-28 23:28:10.828  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:28:11.030  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] publishOnSubscribe
                            2024-08-28 23:28:11.034  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:11.122  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connected with secret 1724880491121_2661
                            2024-08-28 23:28:11.128  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:28:11.329  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] publishOnSubscribe
                            2024-08-28 23:28:11.333  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:11.418  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connected with secret 1724880491417_8233
                            2024-08-28 23:28:11.424  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:28:11.626  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] publishOnSubscribe
                            2024-08-28 23:28:11.630  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:11.730  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connected with secret 1724880491729_2398
                            2024-08-28 23:28:11.741  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:11.836  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connected with secret 1724880491834_449
                            2024-08-28 23:28:11.841  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:11.935  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connected with secret 1724880491933_9250
                            2024-08-28 23:28:11.940  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:12.034  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connected with secret 1724880492032_7881
                            2024-08-28 23:28:12.040  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:12.132  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connected with secret 1724880492131_3921
                            2024-08-28 23:28:12.137  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:12.424  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connected with secret 1724880492422_535
                            2024-08-28 23:28:12.429  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:12.595  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connected with secret 1724880492594_2652
                            2024-08-28 23:28:12.600  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connection closed: disconnected
                            2024-08-28 23:28:17.701  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                            2024-08-28 23:29:10.238  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connected with secret 1724880550237_799
                            2024-08-28 23:29:10.242  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:29:10.443  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] publishOnSubscribe
                            2024-08-28 23:29:10.446  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:10.534  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connected with secret 1724880550533_1548
                            2024-08-28 23:29:10.537  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:29:10.740  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] publishOnSubscribe
                            2024-08-28 23:29:10.744  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:10.832  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connected with secret 1724880550831_672
                            2024-08-28 23:29:10.837  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:29:11.038  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] publishOnSubscribe
                            2024-08-28 23:29:11.042  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:11.129  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connected with secret 1724880551128_5523
                            2024-08-28 23:29:11.134  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:29:11.334  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] publishOnSubscribe
                            2024-08-28 23:29:11.338  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:11.424  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connected with secret 1724880551423_9587
                            2024-08-28 23:29:11.427  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:29:11.628  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] publishOnSubscribe
                            2024-08-28 23:29:11.631  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:11.728  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connected with secret 1724880551727_6491
                            2024-08-28 23:29:11.732  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:11.825  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connected with secret 1724880551824_4315
                            2024-08-28 23:29:11.830  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:11.924  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connected with secret 1724880551923_1207
                            2024-08-28 23:29:11.931  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:12.025  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connected with secret 1724880552024_7072
                            2024-08-28 23:29:12.030  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:12.124  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connected with secret 1724880552123_5335
                            2024-08-28 23:29:12.130  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:12.416  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connected with secret 1724880552414_5267
                            2024-08-28 23:29:12.426  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:12.593  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connected with secret 1724880552592_1927
                            2024-08-28 23:29:12.598  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connection closed: disconnected
                            2024-08-28 23:29:17.143  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                            2024-08-28 23:29:19.190  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
                            2024-08-28 23:30:00.147  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 51.5 °C
                            2024-08-28 23:30:00.149  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 51.54 °C
                            2024-08-28 23:30:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 291
                             MB von 922MB (32%)
                            2024-08-28 23:30:00.168  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1641
                             MB von 2048MB (80%)
                            2024-08-28 23:30:06.383  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880606359_1638
                            2024-08-28 23:30:06.508  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:30:06.527  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:30:06.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                            2024-08-28 23:30:06.709  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:30:06.728  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:30:06.729  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:30:06.730  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:30:06.926  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880606923_6224
                            2024-08-28 23:30:07.048  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:30:07.058  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:30:07.059  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:30:07.060  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:30:07.249  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:30:07.259  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:30:07.260  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:30:07.261  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:30:08.311  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880608310_4118
                            2024-08-28 23:30:08.334  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                            2024-08-28 23:30:08.335  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                            2024-08-28 23:30:08.536  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                            2024-08-28 23:30:09.840  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connected with secret 1724880609839_84
                            2024-08-28 23:30:09.845  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:30:10.047  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] publishOnSubscribe
                            2024-08-28 23:30:10.052  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:10.139  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connected with secret 1724880610138_6843
                            2024-08-28 23:30:10.143  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:30:10.344  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] publishOnSubscribe
                            2024-08-28 23:30:10.348  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:10.435  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connected with secret 1724880610434_1514
                            2024-08-28 23:30:10.439  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:30:10.639  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] publishOnSubscribe
                            2024-08-28 23:30:10.642  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:10.729  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connected with secret 1724880610729_4274
                            2024-08-28 23:30:10.734  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:30:10.933  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] publishOnSubscribe
                            2024-08-28 23:30:10.937  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.024  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connected with secret 1724880611022_7241
                            2024-08-28 23:30:11.031  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:30:11.231  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] publishOnSubscribe
                            2024-08-28 23:30:11.235  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.334  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connected with secret 1724880611332_7886
                            2024-08-28 23:30:11.340  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.434  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connected with secret 1724880611432_1732
                            2024-08-28 23:30:11.438  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.532  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connected with secret 1724880611531_1670
                            2024-08-28 23:30:11.536  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.633  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connected with secret 1724880611632_7524
                            2024-08-28 23:30:11.637  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:11.731  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connected with secret 1724880611730_1286
                            2024-08-28 23:30:11.737  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:12.022  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connected with secret 1724880612020_5469
                            2024-08-28 23:30:12.028  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:12.191  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connected with secret 1724880612190_4018
                            2024-08-28 23:30:12.196  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connection closed: disconnected
                            2024-08-28 23:30:16.090  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 3463
                            2024-08-28 23:30:20.386  - info: solarmanpv.0 (3463) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
                            2024-08-28 23:30:26.448  - info: solarmanpv.0 (3463) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                            2024-08-28 23:30:27.010  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 3463 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2024-08-28 23:31:01.576  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                            2024-08-28 23:31:09.600  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connected with secret 1724880669599_266
                            2024-08-28 23:31:09.605  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:31:09.806  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] publishOnSubscribe
                            2024-08-28 23:31:09.810  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:09.897  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connected with secret 1724880669896_5577
                            2024-08-28 23:31:09.901  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:31:10.102  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] publishOnSubscribe
                            2024-08-28 23:31:10.105  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:10.195  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connected with secret 1724880670193_6155
                            2024-08-28 23:31:10.199  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:31:10.400  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] publishOnSubscribe
                            2024-08-28 23:31:10.404  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:10.494  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connected with secret 1724880670492_5423
                            2024-08-28 23:31:10.498  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:31:10.700  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] publishOnSubscribe
                            2024-08-28 23:31:10.704  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:10.793  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connected with secret 1724880670792_2510
                            2024-08-28 23:31:10.798  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:31:10.999  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] publishOnSubscribe
                            2024-08-28 23:31:11.004  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.100  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connected with secret 1724880671099_3141
                            2024-08-28 23:31:11.105  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.201  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connected with secret 1724880671200_5157
                            2024-08-28 23:31:11.205  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.301  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connected with secret 1724880671300_2586
                            2024-08-28 23:31:11.306  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.400  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connected with secret 1724880671398_6147
                            2024-08-28 23:31:11.406  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.498  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connected with secret 1724880671497_5787
                            2024-08-28 23:31:11.502  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.788  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connected with secret 1724880671787_1514
                            2024-08-28 23:31:11.793  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:11.959  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connected with secret 1724880671958_6103
                            2024-08-28 23:31:11.964  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connection closed: disconnected
                            2024-08-28 23:31:12.255  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                            2024-08-28 23:31:53.672  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                            2024-08-28 23:32:09.627  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connected with secret 1724880729626_9840
                            2024-08-28 23:32:09.630  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:32:09.831  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] publishOnSubscribe
                            2024-08-28 23:32:09.836  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:09.920  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connected with secret 1724880729919_130
                            2024-08-28 23:32:09.924  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:32:10.126  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] publishOnSubscribe
                            2024-08-28 23:32:10.131  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:10.215  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connected with secret 1724880730214_885
                            2024-08-28 23:32:10.219  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:32:10.420  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] publishOnSubscribe
                            2024-08-28 23:32:10.424  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:10.512  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connected with secret 1724880730511_5111
                            2024-08-28 23:32:10.515  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:32:10.716  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] publishOnSubscribe
                            2024-08-28 23:32:10.720  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:10.808  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connected with secret 1724880730807_9951
                            2024-08-28 23:32:10.813  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:32:11.014  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] publishOnSubscribe
                            2024-08-28 23:32:11.018  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.116  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connected with secret 1724880731115_4953
                            2024-08-28 23:32:11.122  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.217  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connected with secret 1724880731216_3779
                            2024-08-28 23:32:11.224  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.318  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connected with secret 1724880731317_7677
                            2024-08-28 23:32:11.323  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.414  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connected with secret 1724880731414_1714
                            2024-08-28 23:32:11.421  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.511  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connected with secret 1724880731510_2679
                            2024-08-28 23:32:11.517  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.801  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connected with secret 1724880731800_6944
                            2024-08-28 23:32:11.805  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connection closed: disconnected
                            2024-08-28 23:32:11.974  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connected with secret 1724880731973_9365
                            2024-08-28 23:32:11.979  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1647
                             MB von 2048MB (80%)
                            2024-08-28 23:33:00.169  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 50.5 °C
                            2024-08-28 23:33:00.170  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 50.464 °C
                            2024-08-28 23:33:00.174  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 275
                             MB von 922MB (30%)
                            2024-08-28 23:33:09.618  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880789617_2706
                            2024-08-28 23:33:09.748  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:33:09.763  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:33:09.764  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:33:09.765  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:33:09.766  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                            2024-08-28 23:33:09.949  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:33:09.964  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:33:09.970  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:33:09.971  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                            2024-08-28 23:33:10.158  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880790154_1169
                            2024-08-28 23:33:10.198  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connected with secret 1724880790197_1908
                            2024-08-28 23:33:10.202  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:33:10.278  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                            2024-08-28 23:33:10.288  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                            2024-08-28 23:33:10.289  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                            2024-08-28 23:33:10.290  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                            2024-08-28 23:33:10.403  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] publishOnSubscribe
                            2024-08-28 23:33:10.407  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:10.480  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:33:10.489  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:33:10.491  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:33:10.492  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                            2024-08-28 23:33:10.496  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connected with secret 1724880790495_8889
                            2024-08-28 23:33:10.501  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:33:10.702  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] publishOnSubscribe
                            2024-08-28 23:33:10.707  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:10.782  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880790781_6189
                            2024-08-28 23:33:10.797  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connected with secret 1724880790791_138
                            2024-08-28 23:33:10.802  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                            2024-08-28 23:33:10.803  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                            2024-08-28 23:33:10.806  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:33:10.837  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:10.921  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connected with secret 1724880790921_4967
                            2024-08-28 23:33:10.926  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:33:11.003  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                            2024-08-28 23:33:11.007  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] publishOnSubscribe
                            2024-08-28 23:33:11.126  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] publishOnSubscribe
                            2024-08-28 23:33:11.144  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.231  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connected with secret 1724880791230_2289
                            2024-08-28 23:33:11.235  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:33:11.436  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] publishOnSubscribe
                            2024-08-28 23:33:11.440  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.537  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connected with secret 1724880791536_1720
                            2024-08-28 23:33:11.542  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.635  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connected with secret 1724880791634_1007
                            2024-08-28 23:33:11.640  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.733  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connected with secret 1724880791732_6488
                            2024-08-28 23:33:11.739  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.831  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connected with secret 1724880791830_5171
                            2024-08-28 23:33:11.837  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:11.932  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connected with secret 1724880791931_7
                            2024-08-28 23:33:11.936  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:12.102  - info: host.raspberrypi instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 4431
                            2024-08-28 23:33:12.221  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connected with secret 1724880792220_4268
                            2024-08-28 23:33:12.226  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:12.390  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connected with secret 1724880792389_8236
                            2024-08-28 23:33:12.397  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connection closed: disconnected
                            2024-08-28 23:33:17.921  - info: openweathermap.0 (4431) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.17.0, js-controller: 6.0.11
                            2024-08-28 23:33:33.176  - info: openweathermap.0 (4431) Terminated (NO_ERROR): Without reason
                            2024-08-28 23:33:33.731  - info: host.raspberrypi instance system.adapter.openweathermap.0 having pid 4431 terminated with code 0 (NO_ERROR)
                            2024-08-28 23:33:55.602  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                            2024-08-28 23:34:05.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                            2024-08-28 23:34:10.081  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connected with secret 1724880850080_3567
                            2024-08-28 23:34:10.087  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:34:10.288  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] publishOnSubscribe
                            2024-08-28 23:34:10.292  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:10.382  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connected with secret 1724880850380_616
                            2024-08-28 23:34:10.386  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:34:10.588  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] publishOnSubscribe
                            2024-08-28 23:34:10.592  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:10.680  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connected with secret 1724880850679_9243
                            2024-08-28 23:34:10.684  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:34:10.886  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] publishOnSubscribe
                            2024-08-28 23:34:10.890  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:10.979  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connected with secret 1724880850978_7977
                            2024-08-28 23:34:10.983  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:34:11.184  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] publishOnSubscribe
                            2024-08-28 23:34:11.188  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.273  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connected with secret 1724880851272_675
                            2024-08-28 23:34:11.276  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:34:11.477  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] publishOnSubscribe
                            2024-08-28 23:34:11.480  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.578  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connected with secret 1724880851578_9634
                            2024-08-28 23:34:11.582  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.677  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connected with secret 1724880851676_7585
                            2024-08-28 23:34:11.681  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.783  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connected with secret 1724880851781_2571
                            2024-08-28 23:34:11.787  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.883  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connected with secret 1724880851882_5629
                            2024-08-28 23:34:11.887  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:11.984  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connected with secret 1724880851983_6311
                            2024-08-28 23:34:11.989  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:12.275  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connected with secret 1724880852274_1264
                            2024-08-28 23:34:12.280  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connection closed: disconnected
                            2024-08-28 23:34:12.443  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connected with secret 1724880852442_7748
                            2024-08-28 23:34:12.449  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:10.184  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connected with secret 1724880910179_266
                            2024-08-28 23:35:10.188  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                            2024-08-28 23:35:10.389  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] publishOnSubscribe
                            2024-08-28 23:35:10.392  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:10.481  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connected with secret 1724880910480_4468
                            2024-08-28 23:35:10.485  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                            2024-08-28 23:35:10.686  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] publishOnSubscribe
                            2024-08-28 23:35:10.691  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:10.776  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connected with secret 1724880910775_6079
                            2024-08-28 23:35:10.780  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                            2024-08-28 23:35:10.980  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] publishOnSubscribe
                            2024-08-28 23:35:10.984  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.074  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connected with secret 1724880911073_2895
                            2024-08-28 23:35:11.079  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                            2024-08-28 23:35:11.280  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] publishOnSubscribe
                            2024-08-28 23:35:11.284  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.372  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connected with secret 1724880911370_5712
                            2024-08-28 23:35:11.376  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                            2024-08-28 23:35:11.578  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] publishOnSubscribe
                            2024-08-28 23:35:11.581  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.678  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connected with secret 1724880911677_3316
                            2024-08-28 23:35:11.682  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.777  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connected with secret 1724880911776_1770
                            2024-08-28 23:35:11.781  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.875  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connected with secret 1724880911874_1281
                            2024-08-28 23:35:11.879  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:11.972  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connected with secret 1724880911971_1361
                            2024-08-28 23:35:11.976  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:12.070  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connected with secret 1724880912069_4224
                            2024-08-28 23:35:12.075  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:12.365  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connected with secret 1724880912364_9741
                            2024-08-28 23:35:12.374  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:12.541  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connected with secret 1724880912539_6908
                            2024-08-28 23:35:12.546  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connection closed: disconnected
                            2024-08-28 23:35:16.047  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 5119
                            2024-08-28 23:35:20.529  - info: solarmanpv.0 (5119) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
                            2024-08-28 23:35:24.146  - info: solarmanpv.0 (5119) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                            2024-08-28 23:35:24.701  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 5119 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            pi@raspberrypi:~ $
                            Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
                            (Murphys Gesetz)
                            spicerS 1 Antwort Letzte Antwort
                            • spicerS spicer
                               MB von 922MB (33%)
                               MB von 2048MB (80%)
                               MB von 922MB (32%)
                               MB von 2048MB (80%)
                               MB von 2048MB (80%)
                               MB von 922MB (30%)
                              pi@raspberrypi:~ $
                              spicerS Offline
                              spicerS Offline
                              spicer
                              Das ist wohl interessanter:
                              2024-08-28 23:24:40.199  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                              2024-08-28 23:24:40.201  - error: host.raspberrypi Caught by controller[0]:   throw err;
                              2024-08-28 23:24:40.202  - error: host.raspberrypi Caught by controller[0]:   ^
                              2024-08-28 23:24:40.204  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
                              2024-08-28 23:24:40.205  - error: host.raspberrypi Caught by controller[0]: Require stack:
                              2024-08-28 23:24:40.206  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
                              2024-08-28 23:24:40.207  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                              2024-08-28 23:24:40.208  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                              2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                              2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                              2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
                              2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                              2024-08-28 23:24:40.212  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                              2024-08-28 23:24:40.213  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                              2024-08-28 23:24:40.214  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                              2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                              2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                              2024-08-28 23:24:40.218  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
                              2024-08-28 23:24:40.222  - error: host.raspberrypi Caught by controller[0]: }
                              2024-08-28 23:24:40.223  - error: host.raspberrypi Caught by controller[0]: Node.js v20.17.0
                              2024-08-28 23:24:40.224  - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              2024-08-28 23:24:40.225  - info: host.raspberrypi Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                              (Murphys Gesetz)
                              • spicerS spicer
                                @spicer
                                iobroker rebuild echarts
                                parallel in einer zweiten Session das Log beobachten.
                                iob logs --watch
                                  @spicer
                                  iob logs --watch
                                  spicerS Offline
                                  spicerS Offline
                                  spicer
                                  pi@raspberrypi:~ $ iobroker rebuild echarts
                                  Rebuilding native module "echarts" ...
                                  rebuilt dependencies successfully
                                  Rebuilding native modules done
                                  In der anderen Konsole ist nichts relevantes erschienen.
                                  (Murphys Gesetz)
                                  • spicerS Offline
                                    spicerS Offline
                                    spicer
                                    Sorry, ich muss jetzt erstmal ins Bett. Kann morgen am späteren Nachmittag weiter machen ;)
                                    Vielen Dank schonmal für Deine Hilfe.
                                    (Murphys Gesetz)
                                      @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
                                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                      iob start echarts.0
                                      sagt?
                                      spicerS Offline
                                      spicerS Offline
                                      spicer
                                      schrieb am zuletzt editiert von spicer
                                      @thomas-braun sagte in Nach Update js-controller macht host.raspberrypi Fehler:
                                      Hab ich vor ca 2 Jahren auf Empfehlung von hier bereits gemacht und immer brav die empfohlenen Updates gemacht.
                                      Damals war das System auch in instabilem Zustand wegen Updates.
                                      Dann mache ich doch besser keine Updates mehr... ist eigentlich Irrsinn.
                                      Habe mich ev etwas falsch ausgedrückt.
                                      Am RPI hängt ein RaspBee 2 (ZigBee Adapter). Um diese GUI zu erhalten
                                      habe ich keine Lösung gefunden, bei welcher die GUI per http im Browser angeschaut/editiert werden kann.
                                      Natürlich hat man sonst auf den Servern keine GUI. Das hab ich auf meinen externen Servern auch nirgends drauf ;)
                                      (Murphys Gesetz)
                                      • spicerS Offline
                                        spicerS Offline
                                        spicer
                                        Zum Problem zurück.
                                        Jetzt wird's interessant. eCharts funktioniert und es kommen auch keine Fehler mehr im Log.
                                        Aber bei den Instanzen steht:
                                        (Murphys Gesetz)
                                        • spicerS spicer
                                          Du sollst es ja auch nicht updaten sondern NEUinstallieren.
                                          spicerS M 2 Antworten Letzte Antwort
