  4. [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
    5.2k
64 Beiträge 6 Kommentatoren 10.2k Aufrufe 5 Beobachtet
  • GaspodeG Gaspode
    @sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    Jetzt das:
    Jep. Jetzt wird es spannend :)
    sigi234S Online
    sigi234S Online
    sigi234
    #61
    @gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
    Jetzt das:
    ***               Welcome to ioBroker.                 ***
    ***     Type 'iob help' for list of instructions.      ***
    ***                For more help see                   ***
    ***     https://github.com/ioBroker/ioBroker.docs      ***
    Your environment has been set up for using Node.js 20.16.0 (x64) and npm.
    C:\SmartHome>npm i diskusage
    npm error code 1
    npm error path C:\SmartHome\node_modules\diskusage
    npm error command failed
    npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
    npm error gyp info it worked if it ends with ok
    npm error gyp info using node-gyp@10.1.0
    npm error gyp info using node@20.16.0 | win32 | x64
    npm error gyp info find Python using Python version 3.12.5 found at "C:\Python\python.exe"
    npm error gyp ERR! find VS
    npm error gyp ERR! find VS msvs_version not set from command line or npm config
    npm error gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
    npm error gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details.
    npm error gyp ERR! find VS Failure details: undefined
    npm error gyp ERR! find VS checking VS2019 (16.11.35130.168) found at:
    npm error gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools"
    npm error gyp ERR! find VS - found "Visual Studio C++ core features"
    npm error gyp ERR! find VS - missing any VC++ toolset
    npm error gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
    npm error gyp ERR! find VS unsupported version "16.11.35130.168" found at "C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools"
    npm error gyp ERR! find VS not looking for VS2015 as it is only supported up to Node.js 18
    npm error gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
    npm error gyp ERR! find VS **************************************************************
    npm error gyp ERR! find VS You need to install the latest version of Visual Studio
    npm error gyp ERR! find VS including the "Desktop development with C++" workload.
    npm error gyp ERR! find VS For more information consult the documentation at:
    npm error gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
    npm error gyp ERR! configure error
    npm error gyp ERR! stack Error: Could not find any Visual Studio installation to use
    npm error gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:116:11)
    npm error gyp ERR! stack at VisualStudioFinder.findVisualStudio (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:72:17)
    npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    npm error gyp ERR! stack at async createBuildDir (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:95:26)
    npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
    npm error gyp ERR! System Windows_NT 10.0.19045
    npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage
    npm error gyp ERR! node -v v20.16.0
    npm error gyp ERR! node-gyp -v v10.1.0
    npm error gyp ERR! not ok
    npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-21T12_54_44_661Z-debug-0.log
    C:\SmartHome>
    Immer Daten sichern!
    • GaspodeG Gaspode
      Achtung: Windows-System. Ich denke aber nicht, dass das Problem Windows spezifisch ist.
      Plötzlich wird bei jedem Adapter Update "node-gyp rebuild" ausgeführt. So genau weiß ich nicht seit wann.
      Das rebuild geht schief, weil ich node-gyp gar nicht eingerichtet habe (hab gar kein Python auf dem Server) und es eigentlich auch nicht brauche.
      $ iobroker upgrade backitup@3.0.16 --debug
      Update backitup from @3.0.15 to @3.0.16
      NPM version: 10.8.1
      Installing iobroker.backitup@3.0.16... (System call)
      > node-gyp rebuild
      gyp info using node-gyp@8.4.1
      gyp ERR! find Python gyp ERR! find Python Python is not set from command line or npm configuration gyp ERR! find Python Python is not set from environment variable PYTHON gyp ERR! find Python checking if "python3" can be used
      gyp ERR! find Python - "python3" is not in PATH or produced an error gyp ERR! find Python checking if "python" can be used gyp ERR! find Python - "python" is not in PATH or produced an error gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
      gyp ERR! find Python - Set the environment variable PYTHON gyp ERR! find Python - Set the npm configuration variable python: gyp ERR! find Python npm config set python "C:\Path\To\python.exe" gyp ERR! find Python For more information consult the documentation at:
      gyp ERR! stack Error: Could not find any Python installation to use gyp ERR! stack at PythonFinder.fail (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:330:47) gyp ERR! stack at PythonFinder.runChecks (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:159:21) gyp ERR! stack at PythonFinder.<anonymous> (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:228:18) gyp ERR! stack at PythonFinder.execFileCallback (C:\ioBroker\XXXXXXX\node_modules\node-gyp\lib\find-python.js:294:16) gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5)
      gyp ERR! System Windows_NT 10.0.19045 gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\ioBroker\\XXXXXXX\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" gyp ERR! cwd C:\ioBroker\XXXXXXX\node_modules\diskusage gyp ERR! node -v v20.16.0 gyp ERR! node-gyp -v v8.4.1 gyp ERR! not ok
      > unix-dgram@2.0.6 install
      > node-gyp rebuild
      gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
      gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
      gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe
      gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
      gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python37\python.exe
      gyp ERR! find Python - "C:\Program Files\Python36\python.exe" could not be run gyp ERR! find Python checking if Python is C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe gyp ERR! find Python - "C:\WINDOWS\system32\config\systemprofile\AppData\Local\Programs\Python\Python36-32\python.exe" could not be run gyp ERR! find Python checking if Python is C:\Program Files\Python36-32\python.exe gyp ERR! find Python - "C:\Program Files\Python36-32\python.exe" could not be run
      gyp ERR! find Python **********************************************************
      gyp ERR! find Python you can try one of the following options:
      gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
      gyp ERR! find Python (accepted by both node-gyp and npm)
      gyp ERR! stack at exithandler (node:child_process:430:5) gyp ERR! stack at ChildProcess.errorhandler (node:child_process:442:5) gyp ERR! stack at ChildProcess.emit (node:events:519:28) gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12) gyp ERR! stack at onErrorNT (node:internal/child_process:484:16) gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      gyp ERR! not ok
      added 1 package, changed 4 packages, and audited 1261 packages in 25s
      147 packages are looking for funding run `npm fund` for details
      66 vulnerabilities (6 low, 37 moderate, 22 high, 1 critical)
      To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details.
      Update "system.adapter.backitup.0"
      upload [95] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [90] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/cifs.jsonConfig.json5 cifs.jsonConfig.json5 application/json5
      upload [80] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
      upload [70] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js custom/static/js/src_AdapterExist_jsx-src_BackupNow_jsx-src_CheckConfigInvisible_jsx-src_DetectConfig_jsx-src_-1b9e72.11bed00e.chunk.js application/javascript
      upload [60] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-6ae257.a0771a5e.chunk.js application/javascript
      upload [50] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.8635b033.chunk.js application/javascript
      upload [40] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/grafana.jsonConfig.json5 grafana.jsonConfig.json5 application/json5
      upload [30] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [20] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
      upload [19] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
      upload [18] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
      upload [17] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
      upload [16] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
      upload [15] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
      upload [14] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
      upload [13] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
      upload [12] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css static/css/main.bd1167d4.css text/css
      upload [11] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/css/main.bd1167d4.css.map static/css/main.bd1167d4.css.map application/json
      upload [10] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js static/js/main.ce422ec2.js application/javascript
      upload [9] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.LICENSE.txt static/js/main.ce422ec2.js.LICENSE.txt text/plain
      upload [8] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/js/main.ce422ec2.js.map static/js/main.ce422ec2.js.map application/json
      upload [7] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/static/media/history.d21dcfa508bd8a624c85.png static/media/history.d21dcfa508bd8a624c85.png image/png
      upload [6] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [5] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      upload [4] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [3] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [2] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
      upload [1] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      upload [0] backitup.admin C:/ioBroker/XXXXXXX/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
      Process exited with code 0$ iobroker upgrade backitup@3.0.16 --debug
      Wie werde ich das wieder los? Hat jemand eine Idee?
      Edit:
      Ach ja, das passiert nur bei Adapter Update über den Admin. Per npm über CLI passiert das nicht.
      Nochmal Edit:
      Soweit ich herausfinden konnte, liegt es an der optionalen dependency diskusage in JS-Controller, dafür wird node-gyp gebraucht. Das Modul ist (zumindest unter Windows) wohl nicht zwingend erforderlich, daher können die nervigen Meldungen ignoriert werden, falls sie auftauchen.
      Eine andere Option ist es, node-gyp zu instrallieren. auf einem frischen Windows 11 System war ich auf diese Weise erfolgreich:
      winget install --id=Python.Python.3.12
      winget install Microsoft.VisualStudio.2019.BuildTools
      Jetzt muss ein neues iob Cmd Fenster geöffnet werden (wegen Path-Änderungen), dann
      npm i node-gyp -g
      npm i diskusage
      Und nochmal Edit:
      Wie sich herausgestellt hat, verhält es sich auf anderen Rechnern anders.
      Dort hat @sigi234 es schließlich hinbekommen, indem er vorgagangen ist, wie weiter hinten in diesem Thread von ihm beschrieben.
      sigi234S Online
      sigi234S Online
      sigi234
      #62
      @gaspode
      Ich installiere mal VS neu
      Ergebnis:
      Habe VS 2022 installiert und bei VS 2019 das Setup verändert.
      Edit:
      Adapter aktuallisiert, Meldung weg! 👍
      $ iobroker upgrade echarts@1.9.0 --debug
      Update echarts from @1.7.2 to @1.9.0
      host.SmartHome Adapter "system.adapter.echarts.0" is stopped.
      NPM version: 10.8.1
      Installing iobroker.echarts@1.9.0... (System call)
      added 12 packages, removed 10 packages, changed 12 packages, and audited 1920 packages in 23s
      405 packages are looking for funding run `npm fund` for details
      77 vulnerabilities (8 low, 36 moderate, 30 high, 3 critical) To address issues that do not require attention, run: npm audit fix To address all issues possible (including breaking changes), run: npm audit fix --force Some issues need review, and may require choosing a different dependency. Run `npm audit` for details.
      Adapter "system.adapter.vis-2.0" restarted.
      upload [17] echarts C:/SmartHome/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
      upload [16] echarts C:/SmartHome/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [10] echarts C:/SmartHome/node_modules/iobroker.echarts/www/preview/manifest.json preview/manifest.json application/json
      upload [9] echarts C:/SmartHome/node_modules/iobroker.echarts/www/preview/static/css/main.e631bfb5.css preview/static/css/main.e631bfb5.css text/css
      upload [7] echarts C:/SmartHome/node_modules/iobroker.echarts/www/preview/static/js/main.bf2caf7b.js preview/static/js/main.bf2caf7b.js application/javascript
      upload [6] echarts C:/SmartHome/node_modules/iobroker.echarts/www/preview/static/js/main.bf2caf7b.js.LICENSE.txt preview/static/js/main.bf2caf7b.js.LICENSE.txt text/plain
      upload [5] echarts C:/SmartHome/node_modules/iobroker.echarts/www/preview/static/js/main.bf2caf7b.js.map preview/static/js/main.bf2caf7b.js.map application/json
      upload [2] echarts C:/SmartHome/node_modules/iobroker.echarts/www/static/js/main.bad2715c.js static/js/main.bad2715c.js application/javascript
      upload [1] echarts C:/SmartHome/node_modules/iobroker.echarts/www/static/js/main.bad2715c.js.LICENSE.txt static/js/main.bad2715c.js.LICENSE.txt text/plain
      upload [0] echarts C:/SmartHome/node_modules/iobroker.echarts/www/static/js/main.bad2715c.js.map static/js/main.bad2715c.js.map application/json
      Update "system.adapter.echarts.0"
      upload [28] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/asset-manifest.json asset-manifest.json application/json
      upload [19] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/chart/static/js/main.bad2715c.js.map chart/static/js/main.bad2715c.js.map application/json
      upload [18] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
      upload [17] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [15] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/asset-manifest.json preview/asset-manifest.json application/json
      upload [14] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/favicon.ico preview/favicon.ico image/vnd.microsoft.icon
      upload [13] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/index.html preview/index.html text/html
      upload [12] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/manifest.json preview/manifest.json application/json
      upload [11] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/static/css/main.e631bfb5.css preview/static/css/main.e631bfb5.css text/css
      upload [10] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/static/css/main.e631bfb5.css.map preview/static/css/main.e631bfb5.css.map application/json
      upload [9] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/static/js/main.bf2caf7b.js preview/static/js/main.bf2caf7b.js application/javascript
      upload [8] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/static/js/main.bf2caf7b.js.LICENSE.txt preview/static/js/main.bf2caf7b.js.LICENSE.txt text/plain
      upload [7] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/preview/static/js/main.bf2caf7b.js.map preview/static/js/main.bf2caf7b.js.map application/json
      upload [6] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css static/css/main.f21b47ed.css text/css
      upload [5] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css.map static/css/main.f21b47ed.css.map application/json
      upload [4] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/static/js/main.6c4f5a4e.js static/js/main.6c4f5a4e.js application/javascript
      upload [3] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/static/js/main.6c4f5a4e.js.LICENSE.txt static/js/main.6c4f5a4e.js.LICENSE.txt text/plain
      upload [2] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/static/js/main.6c4f5a4e.js.map static/js/main.6c4f5a4e.js.map application/json
      upload [1] echarts.admin C:/SmartHome/node_modules/iobroker.echarts/admin/tab.html tab.html text/html
      host.SmartHome Adapter "system.adapter.echarts.0" is started
      • GaspodeG Gaspode
        NPM version: 10.8.1
        > node-gyp rebuild
        > node-gyp rebuild
        gyp ERR! not ok
        Edit:
        Nochmal Edit:
        npm i node-gyp -g
        npm i diskusage
        Und nochmal Edit:
        sigi234S Online
        sigi234S Online
        sigi234
        #63
        @gaspode
        Fazit:
        Alternativ die Installation per Download:
        https://www.python.org/ftp/python/3.12.5/python-3.12.5-amd64.exe
        Das hat dann funktioniert mit Python
        @sigi234 sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
        Jetzt das:
        Copy to Clipboardnpm i diskusage
        Hier kam der Fehler wegen VS
        Habe dann via Installer vom VS die Installation angepasst, habe da Haken gesetzt:
        Ich denke mal das der Standard vom Installer da was nicht installiert.
        GaspodeG 1 Antwort Letzte Antwort
        • sigi234S sigi234
          @gaspode
          Fazit:
          Jetzt das:
          GaspodeG Online
          GaspodeG Online
          Gaspode
          #64
          Hi Sigi,
          schön dass es klappt und vielen Dank für deine Berichte.
          Das nervige ist, dass sich die Sache anscheinend auf jedem Rechner ein wenig anders verhält. Auf meiner Win 11 Test VM klappte es so, wie im ersten Beitrag beschrieben, auf anderen Installationen wieder nicht. Ich bleibe auf jeden Fall dran.
