  4. Beim Update einiger Adapter- "admin" not found
23 Beiträge 4 Kommentatoren 2.7k Aufrufe 3 Beobachtet
  • L line
    $ iob install admin
    adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
    $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.17.14  , installed 6.17.14
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "bshb"         : 0.2.8    , installed 0.2.8
    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
    Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
    Adapter    "denon"        : 1.15.5   , installed 1.15.5
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
    Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
    Adapter    "homekit-controller": 0.5.10, installed 0.5.10
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.3.1    , installed 8.3.1
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "mediola-gateway": 1.1.0  , installed 1.1.0
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
    Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "nuki"         : 2.0.0    , installed 1.6.0  [Updatable]
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openligadb"   : 1.4.9    , installed 1.3.4  [Updatable]
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "scenes"       : 3.0.4    , installed 3.0.4
    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
    Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
    Adapter    "socketio"     : 6.7.0    , installed 6.7.0
    Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
    Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
    Adapter    "solarviewdatareader": 1.0.8, installed 1.0.8
    Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "ws"           : 2.6.1    , installed 2.6.1
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    $ iob upgrade all
    Cannot check dependencies: Required dependency "admin" not found.
    feline@raspberrypi:/home/feline2 $ iob add admin.0
    host.raspberrypi create instance admin
    host.raspberrypi object system.adapter.admin.0.alive created
    host.raspberrypi object system.adapter.admin.0.connected created
    host.raspberrypi object system.adapter.admin.0.compactMode created
    host.raspberrypi object system.adapter.admin.0.cpu created
    host.raspberrypi object system.adapter.admin.0.cputime created
    host.raspberrypi object system.adapter.admin.0.memHeapUsed created
    host.raspberrypi object system.adapter.admin.0.memHeapTotal created
    host.raspberrypi object system.adapter.admin.0.memRss created
    host.raspberrypi object system.adapter.admin.0.uptime created
    host.raspberrypi object system.adapter.admin.0.inputCount created
    host.raspberrypi object system.adapter.admin.0.outputCount created
    host.raspberrypi object system.adapter.admin.0.eventLoopLag created
    host.raspberrypi object system.adapter.admin.0.sigKill created
    host.raspberrypi object system.adapter.admin.0.logLevel created
    host.raspberrypi object admin.0.info created
    host.raspberrypi object admin.0 created
    host.raspberrypi object admin.0.info.connected created
    host.raspberrypi object admin.0.info.connection created
    host.raspberrypi object admin.0.info.newsFeed created
    host.raspberrypi object admin.0.info.newsETag created
    host.raspberrypi object admin.0.info.newsLastId created
    host.raspberrypi object admin.0.info.updatesList created
    host.raspberrypi Set default value of admin.0.info.connected:
    host.raspberrypi Set default value of admin.0.info.connection: false
    host.raspberrypi Set default value of admin.0.info.updatesList:
    host.raspberrypi object system.adapter.admin.0 created
    So jetzt läuft er wieder - danke!
    @line
    Dann zieh jetzt ein aktuelles Backup und dann ziehst du damit auf ein NEUINSTALLIERTES
    Raspberry OS 12 Lite 'Bookworm' (OHNE DESKTOP) in der 64Bit-Version um.
    Auf einem größeren Datenträger dann.
    L 1 Antwort Letzte Antwort
      @line
      line
      @thomas-braun alles klar - Danke! Ich hoffe, es klappt! Danke für eure Hilfe
      • L line
        @homoran said in Beim Update einiger Adapter- "admin" not found:
        da sind in dem Fall die Backups - perfekt.
        nicht perfekt!
        was soll das heißen? Kann ich mit dem backup mein Restore nicht anfangen?
        @line sagte in Beim Update einiger Adapter- "admin" not found:
        das scheinen gefühlt hunderte zu sein!
        nie aufgeräumt??
