  4. CUxD mit ioBroker - Send this info to developer
1 Beiträge 1 Kommentatoren 739 Aufrufe
    DeepCore
    Man sollte nicht spät an einem System werkeln, aber ich habe gerade versucht den hm.rpc mit CUxD zu verbinden.
    Erhalte dann im Log ein paar Warn-Meldungen für die Entwickler:
    hm-rpc.1 2017-09-10 22:03:17.625 info Connected
    hm-rpc.1 2017-09-10 22:03:17.622 info new CUxD devices/channels after filter: 0
    hm-rpc.1 2017-09-10 22:03:17.615 info binrpc -> listDevices 21
    hm-rpc.1 2017-09-10 22:03:17.094 info binrpc client is trying to connect to 10.13.4.40:8701 with ['xmlrpc_bin://10.13.4.49:8701','hm-rpc.1']
    hm-rpc.1 2017-09-10 22:03:17.094 info binrpc server is trying to listen on 10.13.4.49:8701
    hm-rpc.1 2017-09-10 22:03:16.994 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.1
    hm-rpc.1 2017-09-10 22:03:13.886 info terminating
    hm-rpc.1 2017-09-10 22:03:13.878 info Disconnected
    hm-rpc.1 2017-09-10 22:03:13.872 info binrpc -> 10.13.4.40:8701 init ['xmlrpc_bin://10.13.4.49:8701','']
    hm-rpc.1 2017-09-10 22:03:13.833 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'STATE':{'ID':'STATE','UNIT':'%','TAB_ORDER':0,'OPERATIONS':5,'FLAGS':1,'TYPE':'FLOAT','MIN':-99999,'MAX':99999,'DEFAULT':0},'SET_STATE':{'ID':'SET_STATE','UNIT':'','TAB_ORDER':1,'OPERATIONS':2,'FLAGS':2,'TYPE':'FLOAT','MIN':-99999,'MAX':99999,'DEFAULT':0},'RESET':{'ID':'RESET','UNIT':'','TAB_ORDER':2,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false}}}
    hm-rpc.1 2017-09-10 22:03:13.832 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.10000.WRAPPER.1'
    hm-rpc.1 2017-09-10 22:03:13.821 info binrpc -> getParamsetDescription ['CUX9000001:1','VALUES']
    hm-rpc.1 2017-09-10 22:03:13.791 info binrpc -> getParamsetDescription ['CUX9000001:0','VALUES']
    hm-rpc.1 2017-09-10 22:03:12.660 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'LEVEL':{'ID':'LEVEL','UNIT':'100%','TAB_ORDER':0,'OPERATIONS':7,'FLAGS':2,'TYPE':'FLOAT','MIN':0,'MAX':1,'DEFAULT':0},'OLD_LEVEL':{'ID':'OLD_LEVEL','UNIT':'','TAB_ORDER':1,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'STOP':{'ID':'STOP','UNIT':'','TAB_ORDER':2,'OPERATIONS':6,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'STATE':{'ID':'STATE','UNIT':'','TAB_ORDER':3,'OPERATIONS':7,'FLAGS':2,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'PRESS_SHORT':{'ID':'PRESS_SHORT','UNIT':'','TAB_ORDER':4,'OPERATIONS':6,'FLAGS':1,'CONTROL':'BUTTON.SHORT','TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'PRESS_LONG':{'ID':'PRESS_LONG','UNIT':'','TAB_ORDER':5,'OPERATIONS':6,'FLAGS':1,'CONTROL':'BUTTON.LONG','TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_RUNS':{'ID':'CMD_RUNS','UNIT':'','TAB_ORDER':6,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_RUNL':{'ID':'CMD_RUNL','UNIT':'','TAB_ORDER':7,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'CMD_KILL':{'ID':'CMD_KILL','UNIT':'','TAB_ORDER':8,'OPERATIONS':2,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_EXEC':{'ID':'CMD_EXEC','UNIT':'','TAB_ORDER':9,'OPERATIONS':2,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'LOGIT':{'ID':'LOGIT','UNIT':'','TAB_ORDER':10,'OPERATIONS':2,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'SYSLOG':{'ID':'SYSLOG','UNIT':'','TAB_ORDER':11,'OPERATIONS':2,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_SETS':{'ID':'CMD_SETS','UNIT':'','TAB_ORDER':12,'OPERATIONS':7,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_SETL':{'ID':'CMD_SETL','UNIT':'','TAB_ORDER':13,'OPERATIONS':7,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_RETS':{'ID':'CMD_RETS','UNIT':'','TAB_ORDER':14,'OPERATIONS':5,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_RETL':{'ID':'CMD_RETL','UNIT':'','TAB_ORDER':15,'OPERATIONS':5,'FLAGS':1,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'CMD_QUERY_RET':{'ID':'CMD_QUERY_RET','UNIT':'','TAB_ORDER':16,'OPERATIONS':2,'FLAGS':2,'TYPE':'ACTION','MIN':false,'MAX':true,'DEFAULT':false},'WORKING':{'ID':'WORKING','UNIT':'','TAB_ORDER':17,'OPERATIONS':5,'FLAGS':1,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'CONTROL':{'ID':'CONTROL','UNIT':'','TAB_ORDER':18,'OPERATIONS':1,'FLAGS':2,'TYPE':'INTEGER','MIN':0,'MAX':1,'DEFAULT':0},'SET_STATE':{'ID':'SET_STATE','UNIT':'','TAB_ORDER':19,'OPERATIONS':2,'FLAGS':2,'TYPE':'FLOAT','MIN':0,'MAX':1,'DEFAULT':0},'RAND':{'ID':'RAND','UNIT':'','TAB_ORDER':20,'OPERATIONS':3,'FLAGS':2,'TYPE':'STRING','MIN':'','MAX':'','DEFAULT':''},'INHIBIT':{'ID':'INHIBIT','UNIT':'','TAB_ORDER':21,'OPERATIONS':3,'FLAGS':1,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false}}}
    hm-rpc.1 2017-09-10 22:03:12.652 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.HM-RC-19.KEY.1'
    hm-rpc.1 2017-09-10 22:03:12.627 info binrpc -> getParamsetDescription ['CUX2801001:1','VALUES']
    hm-rpc.1 2017-09-10 22:03:12.604 warn Send this info to developer: {'type':'meta','meta':{'adapter':'hm-rpc','type':'paramsetDescription'},'common':{},'native':{'LOWBAT':{'ID':'LOWBAT','UNIT':'','TAB_ORDER':0,'OPERATIONS':5,'FLAGS':9,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'UNREACH':{'ID':'UNREACH','UNIT':'','TAB_ORDER':1,'OPERATIONS':5,'FLAGS':9,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false},'STICKY_UNREACH':{'ID':'STICKY_UNREACH','UNIT':'','TAB_ORDER':2,'OPERATIONS':7,'FLAGS':25,'TYPE':'BOOL','MIN':false,'MAX':true,'DEFAULT':false}}}
    hm-rpc.1 2017-09-10 22:03:12.603 warn Send this info to developer: _id: 'hm-rpc.meta.VALUES.HM-RC-19.MAINTENANCE.1'
    hm-rpc.1 2017-09-10 22:03:12.589 info binrpc -> getParamsetDescription ['CUX2801001:0','VALUES']
    hm-rpc.1 2017-09-10 22:03:12.585 info Connected
    hm-rpc.1 2017-09-10 22:03:12.453 warn No image for '10000' found.
    hm-rpc.1 2017-09-10 22:03:12.451 info binrpc -> listDevices 21
    hm-rpc.1 2017-09-10 22:03:11.931 info binrpc client is trying to connect to 10.13.4.40:8701 with ['xmlrpc_bin://10.13.4.49:8701','hm-rpc.1']
    hm-rpc.1 2017-09-10 22:03:11.926 info binrpc server is trying to listen on 10.13.4.49:8701
    hm-rpc.1 2017-09-10 22:03:11.831 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.11.1
