  4. io Broker lässt sich nicht updaten (Linux)
71 Beiträge 4 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • hans1990H hans1990
    @homoran said in io Broker lässt sich nicht updaten (Linux):
    Please run iob diag again to verify.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: rasphj
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     16:11:31 up  1:56,  1 user,  load average: 1.13, 0.84, 0.49
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-04-26 16:11:31 CEST
               Universal time: Fri 2024-04-26 14:11:31 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        258M        2.5G        0.0K        995M        3.5G
    Swap:            99M          0B         99M
    Total:          3.9G        258M        2.6G
             3794 M total memory
              258 M used memory
              287 M active memory
              775 M inactive memory
             2540 M free memory
              138 M buffer memory
              856 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  4.1G   52G   8% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  820K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Apr 26 14:15:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:45:7D:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d53cc083-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Apr 26 14:15:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Apr 26 14:15:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Apr 26 14:15:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.7G    /var/
    1.3G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
    1.3G    /var/log
    202M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    24M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    202M    /opt/iobroker/iobroker-data/
    87M     /opt/iobroker/iobroker-data/history
    52M     /opt/iobroker/iobroker-data/files
    45M     /opt/iobroker/iobroker-data/backup-objects
    27M     /opt/iobroker/iobroker-data/files/javascript.admin
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    6.4M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
    6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.2
    /usr/bin/node           v18.20.2
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.2-1nodesource1
      Candidate: 18.20.2-1nodesource1
      Version table:
     *** 18.20.2-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          5.1.25
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : rasphj                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : rasphj                                   - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : rasphj                                   -  enabled
      system.adapter.discovery.0              : discovery             : rasphj                                   -  enabled
      system.adapter.elero-usb-transmitter.0  : elero-usb-transmitter : rasphj                                   - disabled
      system.adapter.flot.0                   : flot                  : rasphj                                   -  enabled
      system.adapter.heytech.0                : heytech               : rasphj                                   - disabled, port: 1002
      system.adapter.history.0                : history               : rasphj                                   -  enabled
      system.adapter.homee.0                  : homee                 : rasphj                                   - disabled
      system.adapter.javascript.0             : javascript            : rasphj                                   -  enabled
      system.adapter.net-tools.0              : net-tools             : rasphj                                   - disabled
      system.adapter.nuki-extended.0          : nuki-extended         : rasphj                                   -  enabled
      system.adapter.nuki.0                   : nuki                  : rasphj                                   -  enabled
      system.adapter.octoprint.0              : octoprint             : rasphj                                   -  enabled
      system.adapter.ping.0                   : ping                  : rasphj                                   - disabled
      system.adapter.rpi2.0                   : rpi2                  : rasphj                                   -  enabled
      system.adapter.shelly.0                 : shelly                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : rasphj                                   - disabled
      system.adapter.sonoff.0                 : sonoff                : rasphj                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.synology.0               : synology              : rasphj                                   - disabled, port: 5000
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : rasphj                                   -  enabled
      system.adapter.vis.0                    : vis                   : rasphj                                   -  enabled
      system.adapter.web.0                    : web                   : rasphj                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.wled.0                   : wled                  : rasphj                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 5.1.25 [Updatable]
    Adapter    "backitup"     : 2.11.0   , installed 2.2.2  [Updatable]
    Adapter    "discovery"    : 4.4.0    , installed 2.7.3  [Updatable]
    Adapter    "homee"        : 1.2.0    , installed 1.2.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Objects and States
    Objects:        3145
    States:         2056
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       92947      12486/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       93230      12486/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11069      520/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90108      12514/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11071      520/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14706      388/avahi-daemon: r
    udp        0      0 0.0.0.0:52988           0.0.0.0:*                           108        14708      388/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13180      729/dhcpcd
    udp6       0      0 :::546                  :::*                                0          11105      729/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14707      388/avahi-daemon: r
    udp6       0      0 :::48970                :::*                                108        14709      388/avahi-daemon: r
    2024-04-26 16:11:36.096  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-04-26 16:11:36.097  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
    2024-04-26 16:11:36.103  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
    2024-04-26 16:11:38.074  - info: host.rasphj instance system.adapter.backitup.0 started with pid 12751
    2024-04-26 16:11:42.464  - info: backitup.0 (12751) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.20.2, js-controller: 5.0.19
    2024-04-26 16:11:42.526  - warn: backitup.0 (12751) Cannot read log file: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.backitup/lib/tools.js
    - /opt/iobroker/node_modules/iobroker.backitup/main.js
    2024-04-26 16:11:52.654  - info: host.rasphj iobroker npm-install: added 28 packages in 16s44 packages are looking for funding  run `npm fund` for details
    2024-04-26 16:11:52.702  - info: host.rasphj iobroker npm-install: host.rasphj install adapter homee@1.2.0
    2024-04-26 16:11:52.836  - info: host.rasphj iobroker npm-install: upload [4] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/custom_m.html custom_m.html text/html
    2024-04-26 16:11:52.851  - info: host.rasphj iobroker npm-install: upload [3] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/homee.png homee.png image/png
    2024-04-26 16:11:52.861  - info: host.rasphj iobroker npm-install: upload [2] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/index_m.html index_m.html text/html
    2024-04-26 16:11:52.871  - info: host.rasphj iobroker npm-install: upload [1] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/jsonCustom.json jsonCustom.json application/json
    2024-04-26 16:11:52.882  - info: host.rasphj iobroker npm-install: upload [0] homee.admin /opt/iobroker/node_modules/iobroker.homee/admin/words.js words.js application/javascript
    2024-04-26 16:11:52.982  - info: host.rasphj iobroker npm-install: host.rasphj object system.adapter.homee created/updated
    2024-04-26 16:11:54.057  - info: host.rasphj iobroker npm-install: exit 0
    2024-04-26 16:11:55.059  - warn: host.rasphj startInstance cannot find adapter "synology". Try to install it... 1 attempt
    2024-04-26 16:11:55.060  - info: host.rasphj iobroker install synology using installedVersion
    2024-04-26 16:12:00.183  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
    2024-04-26 16:12:00.188  - info: host.rasphj iobroker npm-install: Installing iobroker.synology@3.1.0... (System call)
    2024-04-26 16:12:43.860  - info: host.rasphj iobroker npm-install:
    2024-04-26 16:12:43.864  - info: host.rasphj iobroker npm-install: added 32 packages, and changed 1 package in 42s45 packages are looking for funding  run `npm fund` for details
    2024-04-26 16:12:43.916  - info: host.rasphj iobroker npm-install: host.rasphj install adapter synology
    @hans-jürgen-strudler sagte in io Broker lässt sich nicht updaten (Linux):
    hast du sonst noch was gemacht?
    Edit
    möglich dass er jetzt erst mal die Adapter neu baut.
    hans1990H 1 Antwort Letzte Antwort
      Edit
      hans1990H Offline
      hans1990H Offline
      hans1990
      schrieb am zuletzt editiert von hans1990
      iob stop
      iob update
      iob upgrade self
      Ich hab versucht den Fehler zu reproduzieren.
      @hans-jürgen-strudler said in io Broker lässt sich nicht updaten (Linux):
      Leider hab ich nicht gespeichert wie die node Version zu hoch war, aber es sah ca. so aus:
      Copy to Clipboard
      npm ERR! notsup Required: {"node":"8<=  node => 13"}
      npm ERR! notsup Actual:   {"npm":"6.14.16","node":"18.20."}
      auf der Weboberfläche wurde ich informiert, dass das File System geändert wird. das dürfte gerade laufen.
      HomoranH 3 Antworten Letzte Antwort
        iob stop
        iob update
        iob upgrade self
        Copy to Clipboard
        Ich hab versucht
        bitte niemals nicht nix eigenmächtig machen, wenn dir verducht wird zu helfen
        Diesmal Teil 2
        https://forum.iobroker.net/post/884324
        bitte unbedingt lesen und beachten!
          iob stop
          iob update
          iob upgrade self
          Copy to Clipboard
          sah ca. so aus:
          und auch diesmal:
          aus dem Zusammenhang gerissen nutzt das gar nichts
            Ich hab versucht
            Diesmal Teil 2
            hans1990H Offline
            hans1990H Offline
            hans1990
            Stimmt war eine doofe Idee -
              @hans-jürgen-strudler Dann warte jetzt mal bis er mit dem Neubau aller Adapter fertig ist.
                sah ca. so aus:
                und auch diesmal:
                @homoran sagte in io Broker lässt sich nicht updaten (Linux):
                sah ca. so aus:
                und auch diesmal:
                @Hans-Jürgen-Strudler
                auf den controller kann sich das ja nicht bezogen haben, der ist ja jetzt auf v5.x
                  hans1990H Offline
                  hans1990H Offline
                  hans1990
                  ist es normal, dass die Weboberfläche derzeit nicht erreichbar ist?
                    nein!
                    aber du hattest zweimal admin auf dem selben port
                    beobachte dann über Konsole mit iob logs --watch und nicht irgendwo eingreifen
                      nein!
                      hans1990H Offline
                      hans1990H Offline
                      hans1990
                      Das ist das Ergebnis (nur die letzten Zeilen, da sonst zu lange):
                      2024-04-26 16:23:05.616  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:23:05.617  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                      2024-04-26 16:23:05.618  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                      2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:23:05.619  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                      2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:23:05.620  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:23:05.621  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                      2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:23:05.622  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:23:05.623  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:23:05.623  - info: host.rasphj Adapter system.adapter.discovery.0 needs rebuild and will be restarted afterwards.
                      2024-04-26 16:23:05.624  - info: host.rasphj system.adapter.discovery.0 will be rebuilt
                      2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:23:05.838  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:23:05.839  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:23:05.840  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                      2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:23:05.841  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:23:05.841  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:23:05.841  - info: host.rasphj Adapter system.adapter.admin.0 needs rebuild and will be restarted afterwards.
                      2024-04-26 16:23:05.842  - info: host.rasphj system.adapter.admin.0 will be rebuilt
                      2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:23:05.907  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:23:05.908  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:23:05.909  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                      2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:23:05.910  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:23:05.910  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:23:05.911  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild of iobroker.js-controller and will be restarted afterwards.
                      2024-04-26 16:23:05.911  - info: host.rasphj system.adapter.web.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules","module":"iobroker.js-controller","version":"5.0.19"})
                      2024-04-26 16:23:09.675  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                      2024-04-26 16:23:09.678  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                      2024-04-26 16:23:15.923  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_23_10_738Z-debug-0.log
                      2024-04-26 16:23:15.924  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                      2024-04-26 16:23:16.955  - info: host.rasphj iobroker npm-install: exit 25
                      2024-04-26 16:23:17.956  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                      2024-04-26 16:23:17.957  - info: host.rasphj iobroker rebuild
                      2024-04-26 16:23:19.754  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                      2024-04-26 16:23:48.352  - info: vis.0 (18269) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                      2024-04-26 16:23:48.637  - info: vis.0 (18269) vis license is OK.
                      2024-04-26 16:23:49.642  - info: vis.0 (18269) Terminated (NO_ERROR): Without reason
                      2024-04-26 16:24:23.351  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                      2024-04-26 16:24:23.385  - info: host.rasphj iobroker npm-rebuild:
                      2024-04-26 16:24:23.386  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                      2024-04-26 16:24:24.399  - info: host.rasphj iobroker npm-rebuild: exit 0
                      2024-04-26 16:24:24.692  - info: host.rasphj instance system.adapter.discovery.0 started with pid 18660
                      2024-04-26 16:24:24.702  - info: host.rasphj instance system.adapter.admin.0 started with pid 18661
                      2024-04-26 16:24:24.711  - info: host.rasphj instance system.adapter.web.0 started with pid 18662
                      2024-04-26 16:24:25.405  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 4 attempt
                      2024-04-26 16:24:25.406  - info: host.rasphj iobroker install heytech@1.0.5 using installedVersion
                      2024-04-26 16:24:26.853  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:24:26.854  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                      2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:24:26.855  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                      2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:24:26.856  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:24:26.857  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                      2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:24:26.858  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:24:26.859  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                      2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:24:26.860  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:24:26.861  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:24:26.861  - info: host.rasphj Rebuild for adapter system.adapter.discovery.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      2024-04-26 16:24:26.863  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:24:26.864  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                      2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                      2024-04-26 16:24:26.865  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:24:26.866  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                      2024-04-26 16:24:26.867  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:24:26.868  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:24:26.869  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                      2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:24:26.870  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:24:26.870  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:24:26.871  - info: host.rasphj Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      2024-04-26 16:24:27.173  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                      2024-04-26 16:24:27.174  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                      2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:24:27.175  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:24:27.176  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                      2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:24:27.177  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                      2024-04-26 16:24:27.178  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:24:27.179  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:24:27.179  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:24:27.179  - info: host.rasphj Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                      2024-04-26 16:24:27.180  - info: host.rasphj system.adapter.web.0 will be rebuilt
                      2024-04-26 16:24:30.676  - info: host.rasphj iobroker npm-install: NPM version: 10.5.0
                      2024-04-26 16:24:30.679  - info: host.rasphj iobroker npm-install: Installing iobroker.heytech@1.0.5... (System call)
                      2024-04-26 16:24:38.037  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_24_31_757Z-debug-0.log
                      2024-04-26 16:24:38.038  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                      2024-04-26 16:24:39.069  - info: host.rasphj iobroker npm-install: exit 25
                      2024-04-26 16:24:40.070  - warn: host.rasphj adapter "web" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                      2024-04-26 16:24:40.071  - info: host.rasphj iobroker rebuild
                      2024-04-26 16:24:41.868  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules ...
                      2024-04-26 16:25:11.870  - info: vis.0 (19415) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v18.20.2, js-controller: 5.0.19
                      2024-04-26 16:25:12.181  - info: vis.0 (19415) vis license is OK.
                      2024-04-26 16:25:13.263  - info: vis.0 (19415) Terminated (NO_ERROR): Without reason
                      2024-04-26 16:25:38.876  - info: host.rasphj iobroker npm-rebuild: rebuilt dependencies successfully
                      2024-04-26 16:25:38.912  - info: host.rasphj iobroker npm-rebuild:
                      2024-04-26 16:25:38.913  - info: host.rasphj iobroker npm-rebuild: Rebuilding native modules done
                      2024-04-26 16:25:39.928  - info: host.rasphj iobroker npm-rebuild: exit 0
                      2024-04-26 16:25:40.067  - info: host.rasphj instance system.adapter.web.0 started with pid 19767
                      2024-04-26 16:25:40.931  - error: host.rasphj Cannot download and install adapter "heytech@1.0.5". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                      2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                      2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   throw err;
                      2024-04-26 16:25:41.921  - error: host.rasphj Caught by controller[0]:   ^
                      2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js'
                      2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: Require stack:
                      2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.web/main.js
                      2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                      2024-04-26 16:25:41.922  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.web/main.js:10:21)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                      2024-04-26 16:25:41.923  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                      2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                      2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                      2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                      2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.web/main.js' ]
                      2024-04-26 16:25:41.924  - error: host.rasphj Caught by controller[0]: }
                      2024-04-26 16:25:41.925  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                      2024-04-26 16:25:41.925  - error: host.rasphj instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2024-04-26 16:25:41.925  - info: host.rasphj Rebuild for adapter system.adapter.web.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                      HomoranH hans1990H 2 Antworten Letzte Antwort
                        20
                        da isser ja!
                        Der Rest ist natürlich Mist.
                        Jetzt hast du node und Controller upgedatet.
                        Außerdem hattest du ja noch extraneous im npm log gehabt.
                        Vielleicht hat @thomas-braun noch ne Idee.
                          hans1990H Offline
                          hans1990H Offline
                          hans1990
                          hier ein Auszug von den Error Zeilen
                          2024-04-26 16:12:44.343  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                          2024-04-26 16:12:46.377  - warn: host.rasphj startInstance cannot find adapter "net-tools". Try to install it... 1 attempt
                          2024-04-26 16:13:07.751  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=6.13.15"
                          2024-04-26 16:13:09.784  - warn: host.rasphj startInstance cannot find adapter "ping". Try to install it... 1 attempt
                          2024-04-26 16:13:24.644  - warn: host.rasphj startInstance cannot find adapter "shuttercontrol@1.2.1". Try to install it... 1 attempt
                          2024-04-26 16:13:40.311  - warn: host.rasphj startInstance cannot find adapter "heytech@1.0.5". Try to install it... 1 attempt
                          2024-04-26 16:13:50.827  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_13_45_983Z-debug-0.log
                          2024-04-26 16:13:50.828  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                          2024-04-26 16:13:52.864  - warn: host.rasphj startInstance cannot find adapter "flot". Try to install it... 1 attempt
                          2024-04-26 16:13:57.708  - warn: host.rasphj startInstance cannot find adapter "elero-usb-transmitter@0.5.2". Try to install it... 1 attempt
                          2024-04-26 16:16:00.502  - warn: host.rasphj startInstance cannot find adapter "history@1.9.14". Try to install it... 1 attempt
                          2024-04-26 16:16:18.909  - error: host.rasphj iobroker npm-install: host.rasphj Invalid version of "admin". Installed "5.1.25", required ">=5.1.28"
                          2024-04-26 16:16:20.940  - warn: host.rasphj startInstance cannot find adapter "sonoff@2.4.5". Try to install it... 1 attempt
                          2024-04-26 16:16:36.159  - warn: host.rasphj startInstance cannot find adapter "nuki-extended@2.3.1". Try to install it... 1 attempt
                          2024-04-26 16:16:55.100  - warn: host.rasphj startInstance cannot find adapter "rpi2@1.3.1". Try to install it... 1 attempt
                          2024-04-26 16:16:59.371  - warn: nuki-extended.0 (14121) Callback not attached because too many Callbacks attached to the Nuki Bridge already! Please delete a callback!
                          2024-04-26 16:17:36.447  - warn: host.rasphj adapter "discovery" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2024-04-26 16:18:04.280  - warn: host.rasphj Slave controller detected disconnection. Stop all instances.
                          2024-04-26 16:18:05.121  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                          2024-04-26 16:18:05.123  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                          2024-04-26 16:18:05.124  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                          2024-04-26 16:18:05.144  - error: host.rasphj Cannot find view "system" for search "instance" : Connection is closed.
                          2024-04-26 16:18:25.102  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                          2024-04-26 16:18:25.103  - error: host.rasphj Caught by controller[0]:   throw err;
                          2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]:   ^
                          2024-04-26 16:18:25.104  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
                          2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: Require stack:
                          2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
                          2024-04-26 16:18:25.105  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                          2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-04-26 16:18:25.106  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-04-26 16:18:25.107  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                          2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
                          2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-04-26 16:18:25.108  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-04-26 16:18:25.109  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                          2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
                          2024-04-26 16:18:25.110  - error: host.rasphj Caught by controller[0]: }
                          2024-04-26 16:18:25.111  - error: host.rasphj Caught by controller[0]: Node.js v18.20.2
                          2024-04-26 16:18:25.111  - error: host.rasphj instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-04-26 16:18:35.188  - error: host.rasphj iobroker npm-install: npm ERR! code EBADENGINEnpm ERR! engine Unsupported enginenpm ERR! engine Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Not compatible with your version of node/npm: iobroker.heytech@1.0.5npm ERR! notsup Required: {"node":">=8 <13"}npm ERR! notsup Actual:   {"npm":"10.5.0","node":"v18.20.2"}npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-04-26T14_18_29_163Z-debug-0.log
                          2024-04-26 16:18:35.189  - error: host.rasphj iobroker npm-install: host.rasphj Cannot install iobroker.heytech@1.0.5: 1
                          2024-04-26 16:18:37.280  - warn: host.rasphj adapter "admin" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]: node:internal/modules/cjs/loader:1143
                          2024-04-26 16:18:49.984  - error: host.rasphj Caught by controller[0]:   throw err;
                          2024-04-26 16:18:49.985  - error: host.rasphj Caught by controller[0]:   ^
                          2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
                          2024-04-26 16:18:49.986  - error: host.rasphj Caught by controller[0]: Require stack:
                          2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
                          2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                          2024-04-26 16:18:49.987  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-04-26 16:18:49.988  - error: host.rasphj Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                          2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
                          2024-04-26 16:18:49.989  - error: host.rasphj Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-04-26 16:18:49.990  - error: host.rasphj Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-04-26 16:18:49.991  - error: host.rasphj Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-04-26 16:18:49.992  - error: host.rasphj Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
                          2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2024-04-26 16:18:49.993  - error: host.rasphj Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
                          2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[0]: }
                          2024-04-26 16:18:49.994  - error: host.rasphj Caught by controller[1]: Node.js v18.20.2
                          2024-04-26 16:18:49.995  - error: host.rasphj instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            20
                            da isser ja!
                            hans1990H Offline
                            hans1990H Offline
                            hans1990
                            kann das helfen?
                              teilweise vollkommen ok!
                              Die Adapter müssen für das neue node neu gebaut werden. 1st attempt ist also korrekt.
                              Andere Adapter benötigen eine höhere Version vom admin, bei dem es allerdings klemmt
                              heytech ist anscheinend zu alt und nicht mehr unterstützt, oder über github installiert worden???
                              warum das hängt sehe ich jetzt nicht
                                kann das helfen?
                                kann das helfen?
                                lass erst einmal alle Eingriffe sein!
                                gibt es neuere log Zeilen als von 16:25?
                                  kann das helfen?
                                  hans1990H Offline
                                  hans1990H Offline
                                  hans1990
                                  Nein. Das war die letzte Zeile
                                    iob stop
                                    iob update
                                    iob upgrade self
                                    Copy to Clipboard
                                    iob stop
                                    hattest du iobroker gestoppt, während dieser dabei war die Adapter neu zu bauen?
                                      hans1990H Offline
                                      hans1990H Offline
                                      hans1990
                                      Das weiß ich nicht mehr woher ich es installiert habe.
                                        und bei einem neuen iob logs --watch??
                                        ok, dann ist da was schiefgelaufen :-(
                                        bitte wenn nichts neues kommt aktuellen iob diag posten
                                          iob stop
                                          hans1990H Offline
                                          hans1990H Offline
                                          hans1990
                                          ich war auf der Weboberfläche und er hat mich informiert, dass das Filesystem geändert wird.
                                          sonst war nichts
