  4. openknx Conversion error DPT11
knx adapteropenknx
3 Beiträge 2 Kommentatoren 431 Aufrufe 2 Beobachtet
  • NWHN Offline
    NWHN Offline
    NWH
    schrieb am zuletzt editiert von NWH
    Hallo
    Ich habe den Adapter openknx laufen. Zu diesem bräuchte ich Hilfe bzw. hätte ich zwei fragen.
    1.)
    Bekomme ich immer diese Fehlermeldungen, und ich weiß nicht genau warum und was ich dagen tun kann.
    openknx.0
    2024-04-25 12:02:14.810	error	[error] "2024-04-25T10:02:14.810Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 12:02:11.219	warn	Ignoring GroupValue_Write of of unknown GA 3/6/29
    openknx.0
    2024-04-25 12:01:12.735	error	[error] "2024-04-25T10:01:12.735Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 12:00:10.694	error	[error] "2024-04-25T10:00:10.694Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:59:08.671	error	[error] "2024-04-25T09:59:08.671Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:58:06.632	error	[error] "2024-04-25T09:58:06.632Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:57:04.462	error	[error] "2024-04-25T09:57:04.462Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:56:02.211	error	[error] "2024-04-25T09:56:02.211Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:55:00.156	error	[error] "2024-04-25T09:55:00.156Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    openknx.0
    2024-04-25 11:53:58.098	error	[error] "2024-04-25T09:53:58.098Z" 'Conversion error DPT11: %j => %d/%d/%d is not valid date according to DPT11' <Buffer 00 00 00> 0 0 2000
    2.) Habe ich Tastenfelder ( Tastsensor Flex)die auch die Zeit&Datum anzeigen.
    Kann diese mit dem Adapter verändert werden oder muss das mit der KNX Software passieren?
    Es gibt unter Datenpunkte einen Ordner der nennt sich "ZENTRAL" und unter diesem einen Ordner mit "Funktionen_Werte"
    Hier gibt es 1x
    Datum --> Thu Nov 30 2023 00:00:00 GMT+0100 (Mitteleuropäische Normalzeit)
    Uhrzeit --> Sun Apr 21 2024 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
    Das wird hier angezeigt! Also eigentlich Quatsch.
    Vielleicht kann mir hier wer helfen? Kannst du @killroy2 hier eventuell helfen?
    K 1 Antwort Letzte Antwort
    • NWHN NWH
      Hallo
      1.)
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      openknx.0
      Hier gibt es 1x
      killroy2
      Hallo @nwh,
      am besten du hängst noch ein Log aus der ETS an, dann kann ich Punkt 1 analysieren.
      Punkt 2 habe ich nicht genau verstanden, du willst etwas mit dem Adapter senden? Um welchen Datentyp handelt es sich?
      NWHN 1 Antwort Letzte Antwort
      • K killroy2
        Hallo @nwh,
        NWHN Offline
        NWHN Offline
        NWH
        @killroy2
        Servus,
        leider habe ich keine ETS Software, dies machte der Elektriker. Oder gibt es noch eine andere Möglichkeit zu einem Log File zu kommen?
        Ich habe ca. 600 DP im openknx Adapter, da wäre es super wenn ich es schaffen täte alles ohne Probleme zu steuern.
        Zu Punkt 2.
        Auf den Tastenfelder wird eine Uhrzeit und ein Datum angezeigt. Diese kommt anscheinend aus der ETS Software oder woher auch immer.
        Jedenfalls stimmt die Uhrzeit nicht, ist es möglich dieses ohne ETS zu ändern?
