  4. Send this to developer
3 Beiträge 2 Kommentatoren 989 Aufrufe
    Na dann will ich das mal machen:
    hm-rpc.2	2017-08-30 20:38:58.961	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERA
    hm-rpc.2	2017-08-30 20:38:58.956	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HMW-IO-12-Sw14-DR.DIGITAL_ANALOG_INPUT.12"
    hm-rpc.2	2017-08-30 20:38:58.688	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"FREQUENCY":{"DEFAULT":0,"FLAGS":1,"ID":"FREQUENCY","MAX":350000,"MIN":0,"OPE
    hm-rpc.2	2017-08-30 20:38:58.679	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HMW-IO-12-Sw14-DR.DIGITAL_INPUT.12"
    hm-rpc.2	2017-08-30 20:38:57.464	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX
    hm-rpc.2	2017-08-30 20:38:57.462	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HMW-IO-12-Sw14-DR.DIGITAL_ANALOG_OUTPUT.12"
    hm-rpc.2	2017-08-30 20:38:56.796	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"STATE":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX
    hm-rpc.2	2017-08-30 20:38:56.788	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HMW-IO-12-Sw14-DR.DIGITAL_OUTPUT.12"
    hm-rpc.2	2017-08-30 20:38:56.480	warn	Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,
    hm-rpc.2	2017-08-30 20:38:56.478	warn	Send this info to developer: _id: "hm-rpc.meta.VALUES.HMW-IO-12-Sw14-DR.MAINTENANCE.12"
    Es handelt sich hierbei um ein 12/14 I/O wired Modul.
    Rainer
    • apollon77A Offline
      Ich denke Github Issues sind zielführender :-)
        Jetzt wo du das sagst :shock: :oops:
