  4. SONOS Adapter Abstürze (wegen Move2?)
5 Beiträge 3 Kommentatoren 662 Aufrufe 2 Beobachtet
  • NinjaTurtle85N Offline
    NinjaTurtle85
    Mein Sonos Adapter stürtzt ständig ab:
    2024-04-08 16:10:11.550 - warn: admin.0 (825) sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
    2024-04-08 16:10:11.747 - info: sonos.0 (180242) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.12.1, js-controller: 5.0.19
    2024-04-08 16:10:12.871 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-08 16:10:12.872 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.873 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    at NotificationListener.notificationHandler (/opt/iobroker/node_modules/sonos-discovery/lib/models/Player.js:370:25)
    at NotificationListener.emit (node:events:530:35)
    at /opt/iobroker/node_modules/sonos-discovery/lib/NotificationListener.js:125:17
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2024-04-08 16:10:12.873 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.879 - info: sonos.0 (180242) terminating
    2024-04-08 16:10:12.883 - info: sonos.0 (180242) terminating
    2024-04-08 16:10:12.884 - warn: sonos.0 (180242) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-04-08 16:10:12.889 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-08 16:10:12.889 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.890 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.890 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.894 - error: sonos.0 (180242) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2024-04-08 16:10:12.894 - error: sonos.0 (180242) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.894 - error: sonos.0 (180242) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:12.895 - error: sonos.0 (180242) Cannot read properties of undefined (reading 'recalculateGroupVolume')
    2024-04-08 16:10:13.386 - info: sonos.0 (180242) terminating
    2024-04-08 16:10:13.518 - error: host.IoBroker instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-04-08 16:10:13.519 - info: host.IoBroker Restart adapter system.adapter.sonos.0 because enabled
    Ich würde behaupten das dass Problem erst mit dem Sonos Move 2 anfing.
    Hat jemad eine Idee woran es liegen kann?
    • NinjaTurtle85N NinjaTurtle85
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @ninjaturtle85 sagte in SONOS Adapter Abstürze (wegen Move2?):
      node: v20.12.1
      warum zu aktuell ?
      Geh da mal auf was aktuell Empfohlenes zurück und dann schau mal ;)
      Lehrling seit 1975 !!!
      NinjaTurtle85N 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        node: v20.12.1
        warum zu aktuell ?
        NinjaTurtle85
        @djmarc75 nope, leider keine Besserung:
        2024-04-08 16:36:22.883 - info: host.IoBroker "system.adapter.sonos.0" enabled
        2024-04-08 16:36:23.188 - info: host.IoBroker instance system.adapter.sonos.0 started with pid 2283
        2024-04-08 16:36:24.436 - info: sonos.0 (2283) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.1, js-controller: 5.0.19
        2024-04-08 16:37:18.542 - info: host.IoBroker stopInstance system.adapter.sonos.0 (force=false, process=true)
        2024-04-08 16:37:18.545 - info: sonos.0 (2283) Got terminate signal TERMINATE_YOURSELF
        2024-04-08 16:37:18.546 - info: sonos.0 (2283) terminating
        2024-04-08 16:37:18.548 - info: sonos.0 (2283) terminating
        2024-04-08 16:37:18.550 - info: sonos.0 (2283) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-04-08 16:37:18.775 - info: host.IoBroker stopInstance system.adapter.sonos.0 send kill signal
        2024-04-08 16:37:19.051 - info: sonos.0 (2283) terminating
        2024-04-08 16:37:19.178 - info: host.IoBroker instance system.adapter.sonos.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-04-08 16:37:22.082 - info: host.IoBroker instance system.adapter.sonos.0 started with pid 2315
        2024-04-08 16:37:24.787 - info: sonos.0 (2315) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v18.20.1, js-controller: 5.0.19
        2024-04-08 16:37:26.430 - error: sonos.0 (2315) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-04-08 16:37:26.430 - error: sonos.0 (2315) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
        2024-04-08 16:37:26.431 - error: sonos.0 (2315) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
        at NotificationListener.emit (node:events:529:35)
        2024-04-08 16:37:26.431 - error: sonos.0 (2315) Cannot read properties of undefined (reading 'recalculateGroupVolume')
        2024-04-08 16:37:26.440 - info: sonos.0 (2315) terminating
        2024-04-08 16:37:26.443 - info: sonos.0 (2315) terminating
        2024-04-08 16:37:26.444 - warn: sonos.0 (2315) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-04-08 16:37:26.453 - error: sonos.0 (2315) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-04-08 16:37:26.453 - error: sonos.0 (2315) unhandled promise rejection: Cannot read properties of undefined (reading 'recalculateGroupVolume')
        2024-04-08 16:37:26.453 - error: sonos.0 (2315) TypeError: Cannot read properties of undefined (reading 'recalculateGroupVolume')
        2024-04-08 16:37:26.453 - error: sonos.0 (2315) Cannot read properties of undefined (reading 'recalculateGroupVolume')
        2024-04-08 16:37:26.945 - info: sonos.0 (2315) terminating
        2024-04-08 16:37:27.069 - error: host.IoBroker instance system.adapter.sonos.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-04-08 16:37:27.069 - info: host.IoBroker Restart adapter system.adapter.sonos.0 because enabled
          NinjaTurtle85
          bei neuinstallation des Sonos Adapters warnt der Admin Adapter:
          	2024-04-08 17:04:19.609	warn	sonos has an invalid jsonConfig: [{"instancePath":"/items/devicesTab/items/_sendto","schemaPath":"#/definitions/sendToProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"timeout"},"message":"must NOT have additional properties"},{"instancePath":"/items/devicesTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
          W 1 Antwort Letzte Antwort
            W Online
            W Online
            Wildbill
            @ninjaturtle85 Das warning kommt momentan bei so gut wie jedem Adapter (bei vielen) und hat keine Auswirkungen auf die Funktion. Ist nur kosmetischer Natur und hat mit eventuellen Fehlern nichts zu tun.
            Gruss, Jürgen
